Official SVS Owners/Support Thread. - Page 1108 - AVS Forum | Home Theater Discussions And Reviews
 45966Likes
post #33211 of 33258 Old 05-21-2020, 08:53 AM
RafaelSmith's Avatar
Quoted: 1013 Post(s)
Liked: 679
I am getting ready to pull trigger on pair of PB2000 Pros.
Due to limitations, the only decent location for them will be in front under my screen...flanking the center speaker.
I have a question about connections.....I could just run a pair of interconnects from the AVR which is in back of room to the front (~25 foot)....or was thinking about the SVS Wireless adapter? How well does it work? lag issues? interference.. I do have quite a few wifi devices in the house...and a pair of Unifi access points...none of which are in the HT room thou.
My AVR has two separate SUB outputs and controls.
Also, as for power connections....should they be on separate outlets or can both be on a single outlet?
RafaelSmith is offline
post #33212 of 33258 Old 05-21-2020, 10:16 AM
Balbolito's Avatar
Quoted: 478 Post(s)
Liked: 867
@RafaelSmith i would get the cable and not do the wifi adapter, but that is just me.
They will both run on one outlet fine most likely. i have my four SB16's on one. Zero issues for years.
Processors Marantz AV8805 & miniDSP 2x4 HD Amps Crown DCI/N x2 CT8150 x1 Speakers JBL PRO M2 x3 708i x4 328c x6 Subs SVS SB16 x4 Screen SI 160 Slate AT 1.2 Projector Optoma UHZ65 4K Media HTPC w/madVR Cables Wireworld,Hosa & Belden
Balbolito is online now
post #33213 of 33258 Old 05-21-2020, 10:58 AM
tang7969's Avatar
Quoted: 329 Post(s)
Liked: 224
I was just wondering how you increase the volume of your subs when you have the app for your phone. Do you increase the trim in the AVR or do you use the app? I have dual PB2000 pros and a Denon x3500h. Thanks.
SONY XBR-65X900F - Sony UDP X800- PSA 210T L/R -PHANTOM CENTER -ENERGY RC-10 SURROUNDS -PSA S3000i - MARANTZ SR6013 - APPLETV 4K -DIRECTV HR44 -HARMONY ELITE
BASEMENT SETUP- SAMSUNG 7100 60"- ENERGY RC50'S L/R-ENERGY RC LCR- DENON AVR-X3500H- PS3 -APPLETV 4K- SVS PB2000 PRO DUAL
tang7969 is offline
post #33214 of 33258 Old 05-21-2020, 11:01 AM
Balbolito's Avatar
Quoted: 478 Post(s)
Liked: 867
@tang7969 both do the same thing, chose whatever is more convenient to you
What i do since i just like the app, i increase each sub equally, so if i want to add 1db in total i would just add 1db to each sub and level AVR trim untouched.
post #33215 of 33258 Old 05-21-2020, 11:17 AM
ataboada's Avatar
Liked: 0
Originally Posted by nonametofame View Post
Being able to measure your subwoofers, and understand what you're hearing, then being able to EQ and dial in the right adjustments, is just as essential as room correction like audyssey. If not done right, you will have anywhere from mediocre, to passable results.
Probably the most single significant upgrade/investment you can make in a system if you care about getting the best bass possible.
Hi everyone! Just got a second PC-4000 on the Memorial Day sale . Is the MiniDSP 2x4 a requirement, aside from the UMIK-1 and REW, to integrate both subwoofers prior to Dirac Live (or any correction software)? I already have both the UMIK-1 and REW.
Can the options on the SVS app allow for the necessary tuning to integrate both subwoofers using only REW? The idea is to integrate them first, and then use Dirac Live on the whole system.
Small hope that Dirac Bass Management comes to the NAD M17v2 in the future. I’d appreciate not having to buy unnecessary equipment the meantime, or until confirmed unavailability of Dirac Bass Management if the answer to my question is a negative.
ataboada is offline
post #33216 of 33258 Old 05-21-2020, 11:24 AM
nonametofame's Avatar
Quoted: 74 Post(s)
Liked: 44
The SVS app is very useful, and I was able to get a reasonably flat response with dual PB16s, just using the app, and Dirac. You definitely need REW and the mic of course. The SVS PEQ is only limited to three bands, but combined with the Dirac Live adjustments, this can be done.
MiniDSP is really needed if you are running multiple subs, or frequently run room correction if you're often making changes to your setup. My M5 only has one true sub output (there are two, but it's really just one independent output with an internal Y connector).
Audio: Audiocontrol Maestro M5 | Parasound A21 | Parasound A51 | Emotiva XPA 5 Gen 2
Video: LG 65E6P | Panasonic UB9000 | Oppo 203 |
Speakers: Martin Logan 60XT & 50XT| Motion 4| FX2s
| Dual SVS PB16 |
nonametofame is offline
post #33217 of 33258 Old 05-21-2020, 12:07 PM
gvg45's Avatar
Quoted: 13 Post(s)
From my understanding, you should keep your AVR gain in the negative, approximately -5, and adjust the gain in your sub.
Here is a link I found when I had the same question:
https://www.avsforum.com/forum/113-s...-headroom.html
gvg45 is offline
post #33218 of 33258 Old 05-21-2020, 01:42 PM
Jack Gilvey's Avatar
Quoted: 60 Post(s)
Liked: 84
The wireless adapter works quite nicely in these situations and the AVR can time-align around the latency in most cases. Dual PB-2000 Pro are generally fine on a single circuit, audio amps are a transient load and not a steady one.
Jack Gilvey
SVS Customer Service
Jack Gilvey is offline
post #33219 of 33258 Old 05-21-2020, 09:05 PM
ProblemHouston's Avatar
Quoted: 30 Post(s)
Liked: 32
I like SVS and was seriously going to get a sub this weekend, but to advertise "up to 40% off" and there not be a speaker or subwoofer on sale even close to that is a slap in the face.
I never argue with fools cause from a distance you canÂt tell who is who....
ProblemHouston is offline
post #33220 of 33258 Old 05-21-2020, 10:29 PM
cwglideman's Avatar
Quoted: 87 Post(s)
Liked: 82
Just 2 days ago there were a lot more subs (and speakers) showing for sale than what's there now. Looks like items are going fast.
Den: Sony XBR75x950g, Marantz sr8012, ATV4k, Sony X800M2/Oppo bdp105, Emotiva XPR-5/UPA-2, NHT ClassicThree+C3C/iC4x4, SVS SB-16Ultra/Hsu VTF-15,7.2.4
Bedroom: Samsung 64f8500, Denon 4311, ATVHD, Oppo bdp93, NHT Absolute Towers x2, Classic2Center, Classic2 Surround, M&K sub 5.1
Headbanging: MacMini/Roon/Tidal, Oppo HA-1, ProJect PreBox s2, Oppo PM-1, Senheisser 6xx
cwglideman is online now
post #33221 of 33258 Old 05-22-2020, 07:59 AM
Quoted: 138 Post(s)
Liked: 168
I like SVS and was seriously going to get a sub this weekend, but to advertise "up to 40% off" and there not be a speaker or subwoofer on sale even close to that is a slap in the face. [IMG class=inlineimg]/forum/images/smilies/mad.gif[/IMG]
Yes I missed out on getting my 2nd PB16. Maybe next time.
Lsdec2 is offline
post #33222 of 33258 Old 05-22-2020, 08:08 AM
cwglideman's Avatar
Quoted: 87 Post(s)
Liked: 82
I feel ya. I wavered myself on getting another SB-16 but the ones I saw on sale (in the outlet sale) were all mostly too badly blemished, to my liking, but the prices were pretty good, but I ultimately passed. Was hoping they had new units on sale but didn't see any. So, like you, "maybe next time".
post #33223 of 33258 Old 05-23-2020, 05:04 PM
Quoted: 138 Post(s)
Liked: 168
I agree with the excessive blemish. I was going to get the unblemished one for $100 more but as you know our subs are so capable (I’m actually running mine with all 3 ports plugged so it’s essentially a SB16) that there really is no rush.
cwglideman likes this.
Lsdec2 is offline
post #33224 of 33258 Old 05-23-2020, 06:06 PM
rosstg's Avatar
Quoted: 328 Post(s)
Liked: 247
I’ve been experimenting with adding a 3dB boost to each of my PC2k pro’s on top of DEQ. It sounds great since I don’t listen more than -15mv.
OLED65B7P/ OPPO UDP-203/ DENON X4300H/ Emotiva 5175/ Emotiva A-300/ Klipsch RP 440c/ Klipsch RP 250f/ Klipsch RP 240s x4/ Klipsch RP 140sa/ Dual SVS PC-2000 Pro/ Auralex Mopad riser for center channel/
rosstg is offline
post #33225 of 33258 Old 05-23-2020, 06:22 PM
Quoted: 25 Post(s)
Liked: 32
One of my Klipsch R-115SW plate amps finally had it (Still under warranty, Klipsch sent an SPL-150 plate amp. I can still use this sub in my DJ room), failed the night before. The day after I went dual PB-4000's, biggest my space will allow and the wife and I had to carry those to the 2nd floor since my theater is upstairs.
Name:	Dual SVS and K.jpg
tigerhonaker and DarkEnigma like this.
|Epson 5040UB|HDFury Integral 2|Elite Screens 100|Marantz AV7705|Emotiva XPA-7 and XPA-5 Gen 3|Outlaw 5000|Panamax M-5300|2 Klipsch RF7III|Klipsch RC-64III|4 Klipsch RP-502S|mini-DSP 2x2HD|Dual SVS PB-4000|Klipsch R-115SW (retiring)|Panasonic UB820|XboxOneX|PS4|Sanus CFR2136|2 AC Infinity CLOUDPLATE T2|Acoustics by ATS|Logitec Harmony Elite|
DjFreddyD is offline
post #33226 of 33258 Old 05-23-2020, 06:46 PM
Quoted: 16 Post(s)
Liked: 5
Guys, what do you think about mixing ported and sealed subs ?
Since I tested that configuration, I feel something is missing in my main room using 3 ported subs. (Usage is 80% movies/series)
kthz is offline
post #33227 of 33258 Old 05-24-2020, 08:58 AM
D Bone's Avatar
Quoted: 494 Post(s)
Liked: 605
D Bone is online now
post #33228 of 33258 Old 05-24-2020, 09:26 AM
Quoted: 16 Post(s)
Liked: 5
Thanks D-Bone ! 😎
D Bone likes this.
kthz is offline
post #33229 of 33258 Old 05-24-2020, 03:30 PM
Quoted: 18 Post(s)
I got a flawless PB16 this past week for $1900, and a flawless PC4000 for $1400. Not 40% but still a very nice discount. You have to keep checking back as they are replenishing often. Most are damaged but a few flawless ones do show up.
mkellypc is offline
post #33230 of 33258 Old 05-24-2020, 04:07 PM
Quoted: 25 Post(s)
Liked: 32
Because the inventory for the Outlet changes daily.
post #33231 of 33258 Old 05-24-2020, 10:56 PM
steve1616's Avatar
Quoted: 26 Post(s)
How did you get it for 1900? I had a chance to get one for 1999 plus 5percent return discount, but after tax it would still be about 2,079. I probably would have purchased one to try that first day, but I was at work and there was no way to be able to pay.
steve1616 is online now
post #33232 of 33258 Old 05-25-2020, 11:54 AM
rosstg's Avatar
Quoted: 328 Post(s)
Liked: 247
I have a question.
I reran Audyssey XT32 this morning with great results. Only narrow 3dB dip at 90hz.
Using the SVS with the Audyssey app I turned down sub 1 to -25 on the SVS App and -23 on the 2nd sub. After calibration I’m left AVR trims -11 & -10.5 which I believe to be spot on if I want to increase trims on the subs. I leave DEQ ON.
My question is how much power or volume percentage am I using?
I’m used to my pb 1k’s manual knob. Lol love the app now!
rosstg is offline
post #33233 of 33258 Old 05-25-2020, 12:51 PM
Balbolito's Avatar
Quoted: 478 Post(s)
Liked: 867
Originally Posted by rosstg View Post
I have a question.
If i remember correctly i think you have a UMIK and REW. In that case you could run several sweeps (measurements) with DEQ on and your sub level set as above -11 and -10.5 in REW for your subs.
What i would do is to set lets say your AVR vol to -20 then do a measurement, then increase it a bit every time for every new measurement.
Then you could monitor the increase in output in REW, once you run out of gas (in your subs) you will see that you can't turn up the volume on your AVR anymore. Meaning even if you turn the volume higher they will still have the same output.
Here you could either stop at this level on your AVR or just turn your subs down a bit and re-do the same practice to see what is the new higher AVR vol level. that is if you wanted to turn your speakers more than before.
rosstg likes this.
post #33234 of 33258 Old 05-25-2020, 12:54 PM
rosstg's Avatar
Quoted: 328 Post(s)
Liked: 247
Do you happen to know what volume range is the default-10 on the subs are? I imagine 50-60%?
Balbolito likes this.
rosstg is offline
post #33235 of 33258 Old 05-25-2020, 12:57 PM
Balbolito's Avatar
Quoted: 478 Post(s)
Liked: 867
@rosstg as far as i know that is pretty high i would say more than that percentage. I wouldn't personally go above -14 or -15 on each sub but that also because i listen to movies loud mostly around -7 vol on my Marantz.
All depends on what's your listening levels are like.
post #33236 of 33258 Old 05-25-2020, 01:06 PM
rosstg's Avatar
Quoted: 328 Post(s)
Liked: 247
I’m leaving them as Audyssey sets at -25 & -23. Was just curious since I’m used to the typical volume knob.
rosstg is offline
post #33237 of 33258 Old 05-25-2020, 01:08 PM
Balbolito's Avatar
Quoted: 478 Post(s)
Liked: 867
@rosstg in most scenarios you could increase them by a few dbs as most people do, even if you are using DEQ. it's like you are just adding a house curve boost to the already available house curve (by deq)
Just make sure once you have time to measure everything to make sure your subs not being pushed too hard.
rosstg likes this.
post #33238 of 33258 Old 05-25-2020, 01:10 PM
Francis Abraham's Avatar
Liked: 0
Requesting advice,
Currently have Dual SB-3000, placed under the screen cleanly, I was OK with the setup, till I heard single VTF-15H MK2 in my friends house, low frequency extension feel in the chest is completely different.
I have started RMA for SB-3000 as within the 45 day period.
Room dimensions. L x W x H (23 x 15 x 9) with screen is 23.5" from floor.
I am considering Dual PB-3000, will it provide enough low end vibration feel? Does any one have experience laying it on side?
How about Single PC-4000 so that I can keep it cleanly in the side (and add another one in the future if needed)?
Francis Abraham is offline
post #33239 of 33258 Old 05-25-2020, 01:14 PM
Balbolito's Avatar
Quoted: 478 Post(s)
Liked: 867
@Francis Abraham it's hard to compare two different models in two totally different rooms. i am sure your dual SB 3000's once properly calibrated and aligned would sound amazing.
Did you run any sort of room EQ?
post #33240 of 33258 Old 05-25-2020, 01:40 PM
Liked: 0
I did Marantz sr6013 audyssey tuning. After the tuning which I felt subs are under-powered and raised sub levels by 4db. It is possible that my sub are in levels with speaker, but can't feel enough chest vibration.
Francis
Speaker Systems , Svs , svs pb-2000 , Svs Pb1000 10 Inch 300 Watt Powered Subwoofer , Svs Pb12 Nsd Black Vinyl 12 Inch Powered Subwoofer , svs pb12 plus , Svs Pb13 Ultra , svs pc-4000 , Svs Pc12 Nsd 12 Inch 400 Watt Powered Cylinder Subwoofer , Svs Pc12 Ultra , Svs Sb1000 12 Inch 300 Watt Powered Subwoofer , Svs Sb12 Nsd Charcoal Black Vinyl 12 Inch 400 Watt Powered Subwoofer , Svs Sb13 Ultra Piano Gloss 13 Inch 1000 Watt Powered Subwoofer , Svs Sb2000
