Official SVS Owners/Support Thread. - Page 769 - AVS Forum | Home Theater Discussions And Reviews
 44888Likes
post #23041 of 31867 Old 02-06-2016, 11:32 AM
AVS ***** Member
mthomas47's Avatar
Quoted: 5554 Post(s)
Liked: 10772
Originally Posted by Defcon View Post
I have a SVS 25-31PCi, if anyone here remembers their original cylinder subs. I remember reading somewhere here that the sub gain isn't meant to control output and should be left at close to max, and the AVR gain should be then used to dial it in.
Is this good advice? Does it apply to my sub or only the newer ones with the digital amps? Finally do all SVS subs have protection built in to prevent damage to driver (I believe this is a feature) ?
Hi,
That is good advice regardless of whether your sub has a digital control. The following is a quote from Ed Mullen of SVS. Some additional detail is offered in the Audyssey FAQ, linked below. I believe that all SVS subs have a protection circuit built in, but I am not absolutely sure whether that includes the early models.
"A general rule when level matching the subs and the speaker channels is to run the gain hotter at the subs and the AVR sub trim level cooler. That keeps the AVR sub signal clean and allows upward adjustability to run the sub hotter if needed."
GUIDE TO SUBWOOFER CALIBRATION AND BASS PREFERENCES
* The Guide linked above is a comprehensive guide to Audio & HT systems, including:
Speaker placements & Room treatments; HT calibration & Room EQ; Room gain; Bass
Preferences; Subwoofer Buyer's Guide: Sealed/ported; ID subs; Subwoofer placement.
mthomas47 is online now
post #23042 of 31867 Old 02-06-2016, 12:10 PM
WarmongerX's Avatar
Quoted: 114 Post(s)
Liked: 35
Originally Posted by Mongo171 View Post
I called SVS and told them about the pop-pop problem. Big Ed Mullen took care of me. I guess I'm not the 1st with that problem. They shipped me out an amp. Got it today and installed it. No more pop-pop sound and it turns on with my other sub. Have the bad one in the box the new one came in, ready to be shipped back tomorrow.
As I mentioned several pages ago, I had this same problem. I called SVS a couple of times the middle of last year and they'd never heard of it, but had some suggestions to isolate the issue with either the sub or the AVR which included removing the sub cable to see if it made the same sound or not. That got old quick, always forgetting the sub cable was unplugged when sitting down to watch a show or movie and having to rock the 127lbs beast to plug it back in. After finding someone with the same issue in some other forum, I found that switching the sub to On instead of Auto got rid of the problem, however it was a bandaid and I didn't really like it.
After reading about Mongo's issue and knowing he called SVS, I called them as well and they acknowledged that they'd had a few calls about it and said that the people on this forum were knowledgeable enough that they knew what they were talking about and agreed to send me out a new amp. Got it last weekend and installed it...no more pop-pop. I'm glad Mongo171 posted or I would've just let it go for a lot longer thinking I might have had just an AVR issue instead of a Sub amp issue.
Mongo171 and pcfriedrich like this.
Sony 75" XBR75X940D - Panasonic DMP‑UB900 4K UHD Player - Nvidia Shield
Denon AVR‑X6200W Receiver
Definitive Technology StudioMonitor 65 L/R - ProCenter 2000 - ProMonitor 1000 x 4 - DI 5.5R x 2
SVS PB12-Plus & SVS PC12-Plus Subwoofers
WarmongerX is offline
post #23043 of 31867 Old 02-06-2016, 12:14 PM
Mongo171's Avatar
Quoted: 995 Post(s)
Liked: 1428
Glad you got it up and running. It was easier for me to switch and eliminate the cables: I have dual cylinders!
"I am a Meat Popsicle." - Korben Dallas, "The Fifth Element"
Mongo171 is offline
post #23044 of 31867 Old 02-07-2016, 09:00 AM
saprano's Avatar
Quoted: 582 Post(s)
Liked: 602
I guess my SB2000 driver is broken.
When first turning on the sub the sound is overly high and the driver makes a flapping sound like it's rubbing against something. After a few minutes the high sound goes away but the flapping is still there. Playing some test tones it goes in and out of that behavior then goes away. The impact of the sub is not there anymore either even when the flapping is gone.
What could of caused this? I'm disappointed because i only had the sub since December 2014 and it has just 60+ hours of use. I don't even play it loud.
What's the return policy like?
home theater addict
saprano is offline
post #23045 of 31867 Old 02-07-2016, 10:41 AM
WarmongerX's Avatar
Quoted: 114 Post(s)
Liked: 35
It wasn't that hard to switch cables and I did that with several of them, even new. The pain was that they wanted me to leave the cable unplugged and listen for it, eliminating the AVR as a possible source of the signal making the sub do that pop pop sound. Problem was, as you know, it was completely random. You might not hear it for days, because it was in another room. Then I'd go to sit down and watch something and hear no bass and think, 'oh crap, that's right, the sub cable is unplugged'. Rock the thing forward to plug it back in, go sit down and watch. Then forget to unplug the cable...a day later, hear the stupid sound and unplug and wait for it to happen again...rinse, repeat
Mongo171 likes this.
post #23046 of 31867 Old 02-07-2016, 10:59 AM
cyclones22's Avatar
Quoted: 141 Post(s)
Liked: 177
Look here.
Denon X4200W, Emotiva XPA-5
Klipsch RF-7II Front Cherry (x2), RC-64II Center Cherry, RP-280FA Surround/Atmos (x2), RP-140SA Atmos (x2)
SVS SB-2000 Subwoofer (x2)
OPPO BDP-103D, Sony UBP-X800, Synology NAS
LG OLED65C6P
cyclones22 is offline
post #23047 of 31867 Old 02-07-2016, 11:11 AM
Mongo171's Avatar
Quoted: 995 Post(s)
Liked: 1428
Give them a call tomorrow and they will hook you up.
Mongo171 is offline
post #23048 of 31867 Old 02-07-2016, 01:20 PM
saprano's Avatar
Quoted: 582 Post(s)
Liked: 602
Originally Posted by cyclones22 View Post
From reading that it seems they won't send me a new sub, only parts? Since it's been over a year. I've never tried fixing a sub before. I would prefer a replacement in matters of making things worse.
home theater addict
saprano is offline
post #23049 of 31867 Old 02-07-2016, 01:23 PM
saprano's Avatar
Quoted: 582 Post(s)
Liked: 602
Yeah i plan to call early tomorrow and explain the issue. Maybe play it too since it's audibly bad.
home theater addict
saprano is offline
post #23050 of 31867 Old 02-07-2016, 01:34 PM
Mongo171's Avatar
Quoted: 995 Post(s)
Liked: 1428
I just replaced a bad amp in one of my cylinders. Easy. Lefty loosey, righty tighty.
Mongo171 is offline
post #23051 of 31867 Old 02-07-2016, 01:55 PM
saprano's Avatar
Quoted: 582 Post(s)
Liked: 602
Sounds like a bad amp and a driver. Or would the flapping sound be because of the amp? This just happened out of nowhere. Surprised me because i thought these subs were suppose to be well built? 60 hours of non stressful use doesn't look like it to me.
home theater addict
saprano is offline
post #23052 of 31867 Old 02-07-2016, 03:07 PM
cyclones22's Avatar
Quoted: 141 Post(s)
Liked: 177
Well, no piece of hardware or manufacturing process is 100% bulletproof. I have 2 SB-2000s and have put them through their paces for far more time than you have on yours and I've had zero issues. Your experience is definitely not the norm and certainly not worthy of declaring a brand or model as not well built. Sounds like bad luck to me.
LG OLED65C6P
post #23053 of 31867 Old 02-07-2016, 03:13 PM
Mongo171's Avatar
Quoted: 995 Post(s)
Liked: 1428
Stuff happens. They replaced my amp for free, including shipping both ways. Not what a company wants, but it is planned for. Prices for all products have a "safety net" built in. It does chew into the bottom line. It does pay to have excellent engineering and assembly.
Mongo171 is offline
post #23054 of 31867 Old 02-07-2016, 03:57 PM
saprano's Avatar
Quoted: 582 Post(s)
Liked: 602
I guess so but it's still frustrating. The sub is still basically new.
home theater addict
saprano is offline
post #23055 of 31867 Old 02-07-2016, 04:01 PM
saprano's Avatar
Quoted: 582 Post(s)
Liked: 602
What kind of screws are placed on the sub? It doesn't look like anything i have the tools for. Which means taking a trip to the hardware store. Great.
home theater addict
saprano is offline
post #23056 of 31867 Old 02-07-2016, 04:38 PM
bear123's Avatar
Quoted: 2829 Post(s)
Liked: 4313
Most subs I have ever seen use standard, normal, run of the mill phillips head screws. I think that even pre-school children learn how to use toy screwdrivers, I can't imagine that turning a screw can be that daunting of a task for the most intelligent species on the planet. Sorry but you are making a big deal about turning a screwdriver left and right.
k1n3t1k likes this.
bear123 is online now
post #23057 of 31867 Old 02-07-2016, 04:42 PM
saprano's Avatar
Quoted: 582 Post(s)
Liked: 602
It's not Philip head screws. I have a screw driver. Looks like one of those L shaped tools are needed. Which i don't have.
But whatever. I don't even know how SVS is going to handle this so i'll just wait until tomorrow.
"Intelligent species on the planet'
That's debatable.
home theater addict
saprano is offline
post #23058 of 31867 Old 02-07-2016, 04:50 PM
bear123's Avatar
Liked: 4313
That's debatable.
Ok, you got me there. Sounds like you will need an Allen wrench. Probably better off to buy a small cheap set in order to get the right size, unless SVS can tell you exactly what size to use. Sometimes metric and standard are very close but sloppy enough to strip if you use the wrong one. On a positive note, you are much less likely to slip and puncture the driver as is possible with a screwdriver.
post #23059 of 31867 Old 02-07-2016, 05:04 PM
saprano's Avatar
Quoted: 582 Post(s)
Liked: 602
Yes that's what it is, Allen Wrench.
I'm hoping it's just the amp but the scratching sound tells me otherwise.
home theater addict
saprano is offline
post #23060 of 31867 Old 02-07-2016, 05:06 PM
bear123's Avatar
Liked: 4313
I agree, sounds like the driver. I'd bet if you gently push in on the driver(1/2" or so), you will hear the scraping sound.
post #23061 of 31867 Old 02-07-2016, 05:14 PM
saprano's Avatar
Quoted: 582 Post(s)
Liked: 602
I actually did that. Nothing happens. It's there when i play test tones. It randomly happens and stops.
The high volume sound has to be the amp though. 2 separate issues. Wonderful.
home theater addict
saprano is offline
post #23062 of 31867 Old 02-07-2016, 05:17 PM
bear123's Avatar
Liked: 4313
Could be still just the driver. Low frequency test tones can cause extreme excursion but little sound, which would make a scratching or scraping sound more easily discernible. I'm sure SVS will help get you going though.
post #23063 of 31867 Old 02-07-2016, 05:21 PM
saprano's Avatar
Quoted: 582 Post(s)
Liked: 602
ThIs sound is abnormal though. And it never happened before.
We‘ll see.
home theater addict
saprano is offline
post #23064 of 31867 Old 02-07-2016, 05:30 PM
Mongo171's Avatar
Quoted: 995 Post(s)
Liked: 1428
It's a square drive bit. SVS will send you the bit.
Mongo171 is offline
post #23065 of 31867 Old 02-07-2016, 06:04 PM
NODES's Avatar
Quoted: 653 Post(s)
Liked: 276
No pint in stressing out, SVS will take care of you.
Who needs 4K?... just go see your optometrist.
NODES is offline
post #23066 of 31867 Old 02-07-2016, 06:07 PM
NODES's Avatar
Quoted: 653 Post(s)
Liked: 276
That's debatable.
Once you figure out how to take it apart then you just paved your way into the world of DIY
NODES is offline
post #23067 of 31867 Old 02-07-2016, 06:24 PM
TJEli's Avatar
Originally Posted by madhuski View Post
I had the SB13 for a while, and I can echo the comments above that it can be a, in comparison, a bit lacking for movies. That's nothing against the SB13, but its asking a lot for a relatively compact 13 inch sub to go against, for example, bigger 15 inch subs.
here's my little journey to find my current sub:https://www.avsforum.com/forum/113-su...18-review.html
I replaced a perfectly functioning MFW15 with an SB13 Ultra in my 3000 cu ft room. I actually think the SB sounds better in all respects. In my room it is not lacking for movies. (Neither was the MFW). I did add a second one a week later but it had nothing to do with output. So far I am very impressed with them. Fwiw I have owned about 15 subwoofers ranging from DIY to a JL F113.
-Eli
AV Nut
TJEli is offline
post #23068 of 31867 Old 02-07-2016, 06:47 PM
saprano's Avatar
Quoted: 582 Post(s)
Liked: 602
Really? Cool.
I know. I wasn't expecting any problems so soon is all.
Ha. Funny. Maybe it'll peak my interest to build my own sub.
home theater addict
saprano is offline
post #23069 of 31867 Old 02-07-2016, 06:56 PM
AllenA07's Avatar
Quoted: 704 Post(s)
Liked: 580
I was able to find the square bits at Lowes.
My Theater: The Ugly Theater
AllenA07 is offline
post #23070 of 31867 Old 02-07-2016, 07:07 PM
saprano's Avatar
Quoted: 582 Post(s)
Liked: 602
-Eli
I agree with this. I had an SB13 Ultra before and i never thought it wasn't enough for movies. Even now with the SB2000 i still find it sounds amazing.
home theater addict
saprano is offline
Speaker Systems , Svs , svs pb-2000 , Svs Pb1000 10 Inch 300 Watt Powered Subwoofer , Svs Pb12 Nsd Black Vinyl 12 Inch Powered Subwoofer , svs pb12 plus , Svs Pb13 Ultra , svs pc-4000 , Svs Pc12 Nsd 12 Inch 400 Watt Powered Cylinder Subwoofer , Svs Pc12 Ultra , Svs Sb1000 12 Inch 300 Watt Powered Subwoofer , Svs Sb12 Nsd Charcoal Black Vinyl 12 Inch 400 Watt Powered Subwoofer , Svs Sb13 Ultra Piano Gloss 13 Inch 1000 Watt Powered Subwoofer , Svs Sb2000
