Official SVS Owners/Support Thread. - Page 804 - AVS Forum | Home Theater Discussions And Reviews
 44516Likes
post #24091 of 31449 Old 06-05-2016, 01:01 PM
AVS ***** Member
mthomas47's Avatar
Quoted: 5424 Post(s)
Liked: 10209
Originally Posted by beardedcrow81 View Post
Well I couldn't find a percent tune for the sb2000, as it depends on what's playing.
It'll sound great with music, then when I watch a movie it'll be too much.
Luckily the dials are under my bed so I can tune it easily.
the SB2000 is great though, shakes my room with ease.
If you have an Audyssey AVR, try turning DEQ off for movies (or using one of the RLO settings) and see if that helps.
GUIDE TO SUBWOOFER CALIBRATION AND BASS PREFERENCES
* The Guide linked above is a comprehensive guide to Audio & HT systems, including:
Speaker placements & Room treatments; HT calibration & Room EQ; Room gain; Bass
Preferences; Subwoofer Buyer's Guide: Sealed/ported; ID subs; Subwoofer placement.
mthomas47 is offline
post #24092 of 31449 Old 06-05-2016, 01:07 PM
LukeSky's Avatar
Quoted: 47 Post(s)
Liked: 82
The PB13 is just silly...
https://youtu.be/daZE2jaFh7k
cchunter likes this.
LukeSky is offline
post #24093 of 31449 Old 06-05-2016, 01:53 PM
baron2's Avatar
Quoted: 124 Post(s)
Liked: 147
Just wondering what volumes are you listening at and what movie were you watching?
Ive got some stuff
baron2 is offline
post #24094 of 31449 Old 06-05-2016, 04:55 PM
januza's Avatar
Quoted: 323 Post(s)
Liked: 229
Looks like interstellar
januza is offline
post #24095 of 31449 Old 06-05-2016, 07:10 PM
LukeSky's Avatar
Quoted: 47 Post(s)
Liked: 82
Yes, interstellar.... Silly is an awesome way.
LukeSky is offline
post #24096 of 31449 Old 06-05-2016, 11:59 PM
Ben Tan's Avatar
Quoted: 527 Post(s)
Liked: 509
So over the weekend, watched some movies and Daredevil with the dual SB2000s. Thoroughly impressed by what it can do, but when the source asks for 20hz or below, the SB2000's cabinets would actually vibrate pretty damn hard, was literally shaking left and right.
In fact, using the stock feets, the subs were actually bouncing on the floor! I needed to switch to the soundpath feets (yes I know it does almost nothing) for the wider rubber surfaces to stop them from bouncing actually.
No distortion, cone flapping or bottoming out to speak of though (where my SB1000 had), so at least that's a plus. Anyone experienced the same thing?
cyclones22 likes this.
Ben Tan is online now
post #24097 of 31449 Old 06-06-2016, 08:59 AM
jwtallguy's Avatar
Quoted: 119 Post(s)
Liked: 56
My ultras move when pushed hard also, on tile.
januza likes this.
jwtallguy is offline
post #24098 of 31449 Old 06-06-2016, 05:05 PM
garnuts's Avatar
Quoted: 86 Post(s)
Liked: 60
Originally Posted by Jaurhead View Post
Is anyone using their sub with a bass shaker? Just set up my PB1000 and I'm having a hard time finding the right balance between the two.
Can you give a little more info on what you mean by the right balance between the two?
Do you have your shakers powered by a separate amp?
I have 4 shakers connected to a plate amp that has a volume (gain) control and a frequency control, so its easy for me to reach behind the couch where the plate amp is and adjust the shakers. Usually it's set it and forget it, but some movies I'll turn up the shakers.
Much of the time I can't discern what is coming from the shakers vs. what is coming from my PC12+ sub.
My connection is from the AVR sub out to a y-splitter. One split to the sub and one to the plate amp.
When I run Audyssey, I disconnect the plate amp and reconnect when finished.
Living Room: Denon X4000, XPA-5, Polk RTiA9, CSiA6, RTiA3-wides, FXiA4, OWM3, SVS PC12+, 4 Shakers, Epson 5030, VApex 92”, Sony XBR9 52”, PS3, Xbox 360, Darbee, Harmony 1.
Bedroom: Denon X2000, Polk: RTiA3, CSiA4, RTiA1, OWM3, SVS SB12-NSD, Sony XBR-55X850B, Sony BPD-S590, Xbox 360, RPi2-RasPlex, Darbee, Harmony 510.
Home Office: Onkyo 707, Polk: LSiM 703, LSiM 704, Monitor 70, Yamaha SW315 x 2, Turntable, Triple Monitors, Harmony 610.
garnuts is online now
post #24099 of 31449 Old 06-06-2016, 07:29 PM
Quoted: 244 Post(s)
Liked: 162
They on hard floor or carpet? I'm getting my SB2000's tomorrow and wondering if this will happen to me too - I'm on carpet.
Magellan55 is offline
post #24100 of 31449 Old 06-06-2016, 09:10 PM
januza's Avatar
Quoted: 323 Post(s)
Liked: 229
What kind shakers do u have ?
januza is offline
post #24101 of 31449 Old 06-06-2016, 09:45 PM
Jaurhead's Avatar
Quoted: 240 Post(s)
Liked: 230
I had played around with the levels of each since that post. When I first posted, I was noticing significantly more bass shaker than actual bass from the woofer no matter what I adjusted. I think I've leveled it out nicely, though. Mostly just took some getting used to.
I've got one Aura Pro in our loveseat powered by an APA150. My AVR has two subwoofer preouts so I use one for the PB1000 and one for the APA. I never once considered unplugging the amp when running MCACC - I was going back and turning the AVR dB WAYYY down on the second "sub" since that mic can't hear it.
I was never really concerned about shaking the place with my old Monoprice subs, but now.... I'm always turning things down to make sure my neighbors aren't ringing the bell or pounding on the door Can't even imagine what will happen once the Prime speakers arrive!
Mr. Pibb > Dr. Pepper > Everything Else
7.1.4 - Marantz SR6011 - LG 77" C8 - JBL 530/580/590 - PSA S3000i + S3600i
Oppo 203 - PS4 - Xbox One S - Roku Ultra - Apple TV 4K
335 UHD and counting...
Jaurhead is offline
post #24102 of 31449 Old 06-07-2016, 01:57 AM
Ben Tan's Avatar
Quoted: 527 Post(s)
Liked: 509
My subs are on tiles as well. Seems like a common thing, reading around.
Hard floor, tile.
I'm not saying the sub shaking around is a bad thing, I'm just even more impressed that with the SB2000 being pushed so hard it didn't lose its composure (which my previous SB1000 did). I was pushing around 101db at my MLP (6ft away) when my subs were shaking and bouncing, so unless you play that loud, you shouldn't have an issue.
post #24103 of 31449 Old 06-07-2016, 04:45 AM
cchunter's Avatar
Quoted: 583 Post(s)
Liked: 865
No they will not move on carpet.
Sony 75X900E 4K
Marantz SR7011 Parasound Halo A52+
Klipsch RF7II's, RC-64II, RS-62II's, RP500SAs Atmos
SVS Dual SB13 Ultra's
Oppo UDP-203 4K Sony PS4 Pro Panamax 5300PM
cchunter is offline
post #24104 of 31449 Old 06-07-2016, 06:19 AM
garnuts's Avatar
Quoted: 86 Post(s)
Liked: 60
Aura Pro Bass Shakers:
http://www.parts-express.com/aurasou...ducer--299-028
januza likes this.
post #24105 of 31449 Old 06-07-2016, 06:27 AM
AllenA07's Avatar
Quoted: 704 Post(s)
Liked: 579
Sub will not move on carpet so you're fine. For those of you with the sub on tile I might even consider something like an Auralex Great Gramma or Subdue to fix the problem of the sub moving around. It won't do a thing for the quality, but at least your sub won't walk away from you during a movie.
My Theater: The Ugly Theater
AllenA07 is offline
post #24106 of 31449 Old 06-07-2016, 07:41 AM
anaththeanswer89's Avatar
Quoted: 51 Post(s)
Liked: 34
Just got a special delivery yesterday, two PB-2000s. Can't wait to get these things hooked up. They are HUGE! Speakers will be delivered today so I am going to try and get everything set up in the living room until our basement gets finished. I'm ready to start getting noise complaints
Krogan's Home Theater/Basement Project
R55Ti Tower Speakers x2 | R5Bi Bookshelf Speakers x2 | R56Ci Center Channel Speaker | SVS PB-2000 x2 | RBH A607 x4 for atmos | Yamaha RX-A2050 | Sony VPL-45ES | Carada 126" BW Screen
anaththeanswer89 is offline
post #24107 of 31449 Old 06-07-2016, 08:09 AM
gene4ht's Avatar
Quoted: 1981 Post(s)
Liked: 2673
Congratulations and welcome to the SVS family! You won't be disappointed!
retro124 likes this.
Epson: 5040UB | Elite: 115" Fixed Frame CinemaScope (2.35:1) | Onkyo: TX-RZ920 + M-5010 (7.2.4) | Klipsch: RF-7 II's, RC-64 II, RS-62 II, RB-61 II MICCA: M-8C (Atmos) x 6 | SVS: PB16-Ultra x 2 | Philips: BDP7501, Panasonic: DMP UB900, Oppo: UDP-203
gene4ht is online now
post #24108 of 31449 Old 06-07-2016, 10:25 AM
AVS ***** Member
mthomas47's Avatar
Liked: 10209
New speakers and new subs at the same time--that is definitely exciting!
post #24109 of 31449 Old 06-07-2016, 10:43 AM
AllenA07's Avatar
Quoted: 704 Post(s)
Liked: 579
You sir, appear to be having a good day!
AllenA07 is offline
post #24110 of 31449 Old 06-07-2016, 12:08 PM
Quoted: 51 Post(s)
Liked: 34
haha if only I didnt have to work. Waiting all day to put together everything is making this day take forever
Matt2026 likes this.
post #24111 of 31449 Old 06-07-2016, 12:14 PM
Mongo171's Avatar
Quoted: 995 Post(s)
Liked: 1428
*cough* sick day *cough*
Tell the boss you "have a booming headache and need to go home to turn it down a notch."
"I am a Meat Popsicle." - Korben Dallas, "The Fifth Element"
Mongo171 is offline
post #24112 of 31449 Old 06-07-2016, 12:20 PM
Quoted: 51 Post(s)
Liked: 34
If I havn't had to work from home so much due to the basement project I probably would have. I've burned a lot of good employee points having to meet with contractors etc.
post #24113 of 31449 Old 06-08-2016, 12:55 AM
Ben Tan's Avatar
Quoted: 527 Post(s)
Liked: 509
I'm using the soundpath feets, the SB2000 hasn't moved an inch even when pushed to its very limits. It doesn't however stop the awkward cabinet vibration from side to side, not a flaw of course because I've seen way heavier and bigger subs do the same thing.
post #24114 of 31449 Old 06-08-2016, 05:10 AM
tezster's Avatar
Quoted: 644 Post(s)
Liked: 542
For those who may be looking for a cheaper alternative, I bought a pack of these, and double-stacked them on each of my SB2000's... it doesn't look as pretty as the soundpath feet, but they work the same way.
tezster is offline
post #24115 of 31449 Old 06-08-2016, 05:26 PM
tang7969's Avatar
Quoted: 299 Post(s)
Liked: 210
Hello. I just wanted to get some opinions with a potential upgrade.
I currently have 2 sb12 nsd's in a secondary system in my basement. I have been considering upgrading to 2 sb2000's. It would cost me $622 to upgrade. Has anyone gone from the nsd's to the 2000's? Is it a worthy upgrade?
SONY XBR-65X900F - Sony UDP X800- PSA 210T L/R -PHANTOM CENTER -ENERGY RC-10 SURROUNDS -PSA S3000i - MARANTZ SR6013 - APPLE TV -DIRECTV HR44 -HARMONY ELITE
BASEMENT SETUP- SAMSUNG UN466500- ENERGY RC50'S L/R-ENERGY RC LCR- DENON-AVR-3311CI- PS3 -APPLETV- MINI GENIE
tang7969 is offline
post #24116 of 31449 Old 06-08-2016, 05:36 PM
Mongo171's Avatar
Quoted: 995 Post(s)
Liked: 1428
I would call it more of a subtle upgrade.
Mongo171 is offline
post #24117 of 31449 Old 06-08-2016, 07:16 PM
Bond 007's Avatar
Quoted: 3225 Post(s)
Liked: 2534
No
Bond 007 is offline
post #24118 of 31449 Old 06-08-2016, 07:28 PM
tang7969's Avatar
Quoted: 299 Post(s)
Liked: 210
Originally Posted by Bond 007 View Post
No
Thanks ,really helpful and enlightening
tang7969 is offline
post #24119 of 31449 Old 06-08-2016, 07:30 PM
tang7969's Avatar
Quoted: 299 Post(s)
Liked: 210
Thanks Mongo, that's what I was thinking also but always looking for an upgrade and really don't want or need the sb13 Ultra
tang7969 is offline
post #24120 of 31449 Old 06-08-2016, 07:34 PM
Bond 007's Avatar
Liked: 2534
Im busy.
januza likes this.
Bond 007 is offline
Speaker Systems , Svs , svs pb-2000 , Svs Pb1000 10 Inch 300 Watt Powered Subwoofer , Svs Pb12 Nsd Black Vinyl 12 Inch Powered Subwoofer , svs pb12 plus , Svs Pb13 Ultra , svs pc-4000 , Svs Pc12 Nsd 12 Inch 400 Watt Powered Cylinder Subwoofer , Svs Pc12 Ultra , Svs Sb1000 12 Inch 300 Watt Powered Subwoofer , Svs Sb12 Nsd Charcoal Black Vinyl 12 Inch 400 Watt Powered Subwoofer , Svs Sb13 Ultra Piano Gloss 13 Inch 1000 Watt Powered Subwoofer , Svs Sb2000
