Official SVS Owners/Support Thread. - Page 941 - AVS Forum | Home Theater Discussions And Reviews
 44474Likes
post #28201 of 31360 Old 05-10-2018, 06:51 AM
Canuck31's Avatar
Quoted: 305 Post(s)
Liked: 53
Originally Posted by mthomas47 View Post
Hi,
I wouldn't do it if I were you. You can contact SVS directly for more information on why it wouldn't be a good idea, but I will try to hit a couple of the highlights. To answer your first question, I believe that the port sizes are different (3" for the smaller sub, and 3.5" for the PB4000). But, the real issue is not the incompatibility of the port sizes, it is the incompatibility of the DSP (digital signal processing) which controls the subwoofer's operation.
The PB1000 was only designed to be a ported subwoofer, and its DSP controls the SPL that it tries to achieve at specific frequencies. It is designed to be more powerful at low-frequencies than a comparable sealed subwoofer would be. If you plug the port, without also being able to change the DSP which controls its operation, the subwoofer will probably not sound very good, and you may damage it, especially if you try to boost the volume much.
Subwoofers such as the PB4000, are designed to operate in more than one port mode. And, there is built-in DSP that you can change when you go from one port mode to another. That DSP is already programmed into the sub to make it possible to switch modes when port plugs are added or removed. But, it isn't just a matter of plugging the port with something, whether it is an SVS foam plug of the correct size, or something else.
Mike
Hmm okay. I was just curious more than anything. I know the port size is the same when I compared the two subs on the SVS website. I'm still considering buying the SB-1000 to A/B sound test it with my PB-1000. I have a feeling I might like the sealed version more. Then I'd buy a second one to have dual. My room is only a 12'x13' size bedroom in an apartment. I do like the PB-1000 but only having one does offset the bass to one side a bit.
mthomas47 likes this.
Canuck31 is offline
post #28202 of 31360 Old 05-11-2018, 03:15 PM
sid369's Avatar
Quoted: 451 Post(s)
Liked: 24
I got my pb1000, how do I set it up. Right now I have just placed it in the front in the corner. I will rerun audyssey should I leave the gain at 12 0clock or something else. Should the master volume be at 0?
Once done do I turn deq and dyn vol on? Should I put the crossover of th bass at 120 default or 80?
sid369 is offline
post #28203 of 31360 Old 05-11-2018, 03:29 PM
markmanner's Avatar
Quoted: 345 Post(s)
Liked: 294
Originally Posted by Duckbacker View Post
Replacing a Definitive Technology BP-8080 System, I finally pulled the trigger on the remainder of my all SVS loudspeaker home theater setup. In addition to four of the ceiling mounted Prime Elevation Atmos speakers and dual SB16-Ultra subs I currently have, I will now add to them a pair of the Ultra Towers, Ultra Center Channel and four Ultra Surrounds all in Piano Gloss finish. They should be here and in operation by this time next week. With slightly under 1700 cubic feet of enclosed space to work with, the room should have no excuse to be fully pressurized.
Your setup will look great when you finish adding the other speakers. I really like the finish of the SVS piano black speakers. I have 2 SVS subs in my main HT, and in my basement room have some prime towers and another SVS sub and they look really nice. They don't sound too bad either
Magellan55 and Duckbacker like this.
System
Spoiler!
markmanner is offline
post #28204 of 31360 Old 05-11-2018, 04:03 PM
gene4ht's Avatar
Quoted: 1969 Post(s)
Liked: 2657
Have you had the opportunity to review the thread linked below? @mthomas47 post will answer all your questions and beyond. It's a must read for all enthusiasts...novices and experts alike.
https://www.avsforum.com/forum/113-su...eferences.html
mthomas47 and Louis Bartay like this.
Epson: 5040UB | Elite: 115" Fixed Frame CinemaScope (2.35:1) | Onkyo: TX-RZ920 + M-5010 (7.2.4) | Klipsch: RF-7 II's, RC-64 II, RS-62 II, RB-61 II MICCA: M-8C (Atmos) x 6 | SVS: PB16-Ultra x 2 | Philips: BDP7501, Panasonic: DMP UB900, Oppo: UDP-203
gene4ht is offline
post #28205 of 31360 Old 05-11-2018, 04:25 PM
AVS ***** Member
mthomas47's Avatar
Quoted: 5373 Post(s)
Liked: 10036
Hi Gene,
Thank you for the compliment about my Guide! I don't know if it's a must read, but it's certainly a long read. It seems to grow a little more almost every week.
Mike
GUIDE TO SUBWOOFER CALIBRATION AND BASS PREFERENCES
* The Guide linked above is a comprehensive guide to Audio & HT systems, including:
Speaker placements & Room treatments; HT calibration & Room EQ; Room gain; Bass
Preferences; Subwoofer Buyer's Guide: Sealed/ported; ID subs; Subwoofer placement.
mthomas47 is offline
post #28206 of 31360 Old 05-12-2018, 06:41 AM
sid369's Avatar
Quoted: 451 Post(s)
Liked: 24
Thanks for the link and it packed with information. I did not read the whole thing too lazy. Wish there was a Reddit style summary TLDR;
sid369 is offline
post #28207 of 31360 Old 05-12-2018, 07:19 AM
Duckbacker's Avatar
Quoted: 83 Post(s)
Liked: 93
I agree. Just spoke yesterday with R+L Carriers, SVS's transport company, to schedule delivery on Thursday. Sending one pallet weighing in at 300 lbs some 2500 miles can't be cheap yet it's once again all part of SVS's great customer service. I am sure I will be more than pleased with the final result.
gene4ht and markmanner like this.
Sony XBR-85X900F 85-Inch 4K Ultra HD Smart LED TV; Denon AVR-X8500H (Dolby Atmos 7.2.6/DTS:X 7.2.4/Auro-3D 13.2); Emotiva XPA-7 Gen 3 Amplifier; SVS Ultra Towers; SVS Ultra Center Channel; (4) SVS Ultra Surround Speakers; (12) SVS Prime Elevations for Dolby Atmos/DTS:X/Auro-3D; Dual SVS SB16-Ultra Subwoofers w/SVS Soundpath Isolation System; Auralex Subdude II Isolation Pads; Panasonic DP-UB820 UHD Blu-ray Player; Panamax M5400 Power Conditioner
Duckbacker is offline
post #28208 of 31360 Old 05-12-2018, 07:38 AM
Quoted: 71 Post(s)
Hello,
I will be purchasing an open box special pb-2000 from IQ entertainment. Anyone had experience with them? Also, any suggestions on how to calibrate dual pb-2000's? My AVR doesn't have any sort of room eq, so it's all up to me. Thank you, and I look forward to your responses.
Sincerely,
TCL/Roku 65" R615 4K TV, Onkyo HT-S990 THX 7.1 Surround System, Dual SVS PB-2000 Subwoofers, Sony UBP X700 4K Ultra Blu-ray Player
Dan30thz28 is offline
post #28209 of 31360 Old 05-12-2018, 11:10 AM
AVS ***** Member
mthomas47's Avatar
Liked: 10036
Hi,
I have added some Cliff Notes tips to the first post of that thread. Perhaps those abbreviated tips will help.
Mike
Louis Bartay and Matt2026 like this.
post #28210 of 31360 Old 05-12-2018, 03:00 PM
gordojones88's Avatar
Quoted: 35 Post(s)
Liked: 30
IQ hosted a launch party for the SVS PB-4000. I bought an open-box Denon 4300 from them and it was factory sealed never opened. I suspect they sell new items as open-box kind of like a sale. However, you will not be able to do the 1 year upgrade, you have to purchase direct from SVS.
Skip ahead to 4 minutes.
B&W 683S2 / B&W HTM61S2 / B&W 686S2x4
LG OLED65C7 / Denon 4300 / Monolith 3x200
SVS PB16 / Xbox One X / Oppo 203
gordojones88 is offline
post #28211 of 31360 Old 05-12-2018, 10:06 PM
youthman's Avatar
Quoted: 159 Post(s)
Liked: 545
Today I invited two audio friends over today to help me inbox and to have some fun comparing Dual SB-16’s to Dual PB-16’s. Frank has a really good ear for audio and can express what he hears better than I can. Here are his thoughts on the PB-16’s.
“Bass was always clean, never bottomed out, generally pretty tight (though not snappy). Well-built, awesome for HT. No port noise complaints (at least that we're discernable over the mains) PB-16 were absolutely no comparison to the SB-16s. The SBs were OK, but that's it. The PB-- I've heard higher SPL, but it was like a well-composed earthquake”.
Needless to say, the Dual PB-16’s were simply “Controlled Violence”.
We did manage to remove my 4 Klipsch RSW-15’s from behind my 150” screen and replace them with the PB-16’s. The did move my screen quite a bit but was only noticeable when the lights were on.
So far...color me impressed!
youthman is offline
post #28212 of 31360 Old 05-13-2018, 03:41 AM
Quoted: 163 Post(s)
Liked: 469
Wow, didn't realize the SB-16's would look quite so diminutive next to the PB's! I have dual PB-16's myself, and holy crap, getting them behind your screen and up on your (I think) hip-height shelf took QUITE a bit of doing, I'm sure.
You need to search out sub-20hz content now, that's where they shine Blade Runner 2049, "9", The Incredible Hulk (2008), War of the Worlds, Tron Legacy, Mad Max Fury Road, Hellboy II, etc.
Those PB's are rated to 13hz, make them work for it
youthman likes this.
TCL 55P607, OPPO UDP-203, 4K Fire TV, Marantz 6011, Rotel 1075 (Atmos)
DefTech SM 65 (X7), SVS PB16 Ultra (X2), SVS Prime Elevation (X4)
Headphone rig: PC-> Schiit Wyrd ->Schiit Modi Multibit ->Stax SRM-353X ->THX AAA 789
Headphones: Stax SR-207, Stax SR-L700, M1060, TH-X00 Purpleheart, HD600, HD6XX, etc
Keith Zuehlke is offline
post #28213 of 31360 Old 05-13-2018, 09:12 AM
BRAC's Avatar
Quoted: 587 Post(s)
Liked: 497
That is INCREDIBLE! The SB’s look tiny next to those PB’s.
I don’t know about anyone else, but I’m starting to appreciate the presence of large subs in my room. It just looks like they mean business. Even better when they can back it up with bone crushing bass!
Samsung 82” Q90R * Denon X4500H * 5.2.4 Atmos * Xbox One X * PS4 Pro
BRAC is online now
post #28214 of 31360 Old 05-13-2018, 09:43 PM
nodoubt's Avatar
Quoted: 417 Post(s)
Liked: 253
holy crap, you could cut the pb in half, and hide 2 sb boxes inside i think !
ut ooo, i might be in trouble.
i just sent back a sb-4000 and have a pb -4000 on the way.
i told my better half, it was only a tad bigger, with a few little holes in it !
oops, just realized those are the 16s.
but still.......
Louis Bartay likes this.
nodoubt is offline
post #28215 of 31360 Old 05-14-2018, 06:21 AM
confinoj's Avatar
Quoted: 1206 Post(s)
Liked: 1010
but still.......
You are gonna have some splainin' to do. The PB-4000 is only about 1" smaller in each dimension than the PB16. The PB-4000 has about twice the volume of the SB-4000.
LG OLED65C7P (Chad B Calibrated) | Denon X4300H | Tivo Roamio OTA | Nvidia Shield | ATV 4K | Oppo UDP-203 | Plex server
5.2.4 | Front Klipsch RP-160M x2 | Center Klipsch RP-450C | Surrounds Klipsch RP-150M x2 | Atmos Klipsch RP-140SA x 4 | Subs SVS PC-4000 x 2
confinoj is online now
post #28216 of 31360 Old 05-14-2018, 07:01 AM
B T C's Avatar
Location: Lansing, MI via Kentucky, Georgia & Tennessee
Quoted: 660 Post(s)
Liked: 299
If my calculations are correct, the PB16 is about 114% larger than the SB16, so over double. Both models look really nice in that photo.
B T C is offline
post #28217 of 31360 Old 05-14-2018, 12:13 PM
eightninesuited's Avatar
Quoted: 309 Post(s)
Liked: 313
I have to say I am very impressed by the size of the SB. It looks like it can easily disappear into the background.
If you have small room like 10x12 or something, those SBs would make killer subs.
I've got a PC 13 Ultra and a PC 12 NSD.
But my room is 16x 22 with another 10x 20 opening. Ideally, I would love to have 4x SB ultras.
Proud Member of "Bass-a-holic Anonymous" - Dual Bottle of Choice: SVS PC-13 Ultra + SVS PC-12 NSD. Drink of Choice: Ready Player One Delorean Race
DaLite 0.9 Grey 110" screen. Epson 3000 1080P Projection. 7.2 SVS and Energy Reference + Parasound THX Ultra Amplification system.
eightninesuited is offline
post #28218 of 31360 Old 05-14-2018, 07:11 PM
youthman's Avatar
Quoted: 159 Post(s)
Liked: 545
After only a few days with the PB16's, man, I'm blown away (pun intended). I have always enjoyed my 4 Klipsch RSW-15's. They pressurize my room but they lose authority below 30Hz and drop like a rock at 20Hz. That is not the case with the Dual PB16's.
I shared a lot of my thoughts about them in this video.
gene4ht, mthomas47 and d-rail34 like this.
youthman is offline
post #28219 of 31360 Old 05-14-2018, 07:23 PM
nodoubt's Avatar
Quoted: 417 Post(s)
Liked: 253
yeah, im working on a good story now
you say twice the volume in size, or sound ?
nodoubt is offline
post #28220 of 31360 Old 05-14-2018, 07:57 PM
gene4ht's Avatar
Liked: 2657
Another great review and video Mike! But then again, I’m biased!
gene4ht is offline
post #28221 of 31360 Old 05-14-2018, 08:11 PM
youthman's Avatar
Quoted: 159 Post(s)
Liked: 545
youthman is offline
post #28222 of 31360 Old 05-14-2018, 09:50 PM
confinoj's Avatar
Liked: 1010
Size
post #28223 of 31360 Old 05-15-2018, 04:38 PM
AVS ***** Member
mthomas47's Avatar
Liked: 10036
https://youtu.be/MrFeBEXZTss
Good review, although like Gene, I'm biased, too!
One tip I might give you with respect to the SB16's, you compared in your video, is to keep the AVR trim levels well in the negative range. That is especially important at master volume levels of -10 and above. Instead of having the sub gain at -10 and the AVR trim level at 0.0, I believe that the SB16's would have struggled less if those numbers had been reversed. Or, perhaps even split down the middle at -5 each.
As master volumes climb toward Reference, it becomes more important to make sure that as much of the voltage as possible is coming from the subwoofer amp and not from the AVR. That would also be the case with the PB16's, even though they are inherently much more powerful than the SB16's. As a general rule, trying to keep the AVR trims at -5 or less (lower might be better) would help to prevent clipping and other potential audio issues.
Mike
gene4ht, youthman and Magellan55 like this.
post #28224 of 31360 Old 05-15-2018, 04:51 PM
Kini62's Avatar
Quoted: 2680 Post(s)
Liked: 2470
Mike
I believe Ed said that same thing is a post a while back. I think he recommended running the gain on the sub as high as possible.
Def Tech SC8000
Onkyo RZ820
Roku Ultra, Apple TV, Sharp 70" Quattron
Kini62 is offline
post #28225 of 31360 Old 05-15-2018, 08:07 PM
youthman's Avatar
Quoted: 159 Post(s)
Liked: 545
Thanks for the suggestion. I'll back the gain on the subs to -5db and increase the gain on the sub to +5db. I just assumed that would not leave much headroom on the sub amp.
youthman is offline
post #28226 of 31360 Old 05-16-2018, 02:53 AM
Quoted: 163 Post(s)
Liked: 469
Just for reference, I run my pair at -5.5db in my Marantz, and the volume on my sub amps at -9 and -13db. Those numbers are a combined 6db hotter than the Audyssey calibration. My room is far from optimal (bordering on terrible, actually), your subs will likely be much more symmetrical.
I typically watch movies at -6MV, and TV at -12MV. So I have headroom to spare on both the receiver MV and the sub amps, but on the rare occasion I turn it up louder I do so grudgingly......my eye is toward the longevity of my components.
*edit* Oh yeah, and I arrived at my current settings after reading Mike's guide and taking his suggestions
post #28227 of 31360 Old 05-16-2018, 05:27 AM
Quoted: 309 Post(s)
Liked: 313
Ed recommended running the gain on the high - only when you feel you don't have enough to pressurise the room. In that case keeping AVR trim to below -5 and cranking up the sub as high as it goes is ideal. If you don't need the output, keeping both the AVR trim below -5 and Sub in the minus is the way to go.
gene4ht likes this.
post #28228 of 31360 Old 05-18-2018, 09:12 PM
Duckbacker's Avatar
Quoted: 83 Post(s)
Liked: 93
The delivery truck has arrived, the boxes opened and the speakers are all in place and dialed in. I now have an all SVS Ultra Tower setup for my Atmos 7.2.4 installation. Not to let any grass grow under my feet as I have my eyes fixed on adding Auro 3D 13.1 via the newly released Denon X8500H and eight more SVS Prime Elevations.
The first movie to test out was the new 4K Blu ray, the 20th Anniversary of Saving Private Ryan. The first 27 minutes did not disappoint. My already set up dual SVS SB16-Ultras blended in effortlessly, even more so than when my Def Tech towers were there. It even meets the Hound's Helm's approval (see last pic).
I am now wavering on replacing the sealed subs with their ported counterparts but in a less than 1700 cubic foot enclosed room, that may be overkill. At any rate, somebody please talk me out of that. I have only had the SB16s for seven months and I have no complaints. it's just that you never know what you may be leaving on the table.
Many thanks to Ed Mullen and staff at SVS for their constant vigilance in providing unparalleled performance, value and customer service. I am and will continue to be a life long customer.
ID:	2404540   Click image for larger version
ID:	2404544   Click image for larger version
ID:	2404546   Click image for larger version
ID:	2404548   Click image for larger version
post #28229 of 31360 Old 05-18-2018, 10:18 PM
gene4ht's Avatar
Liked: 2657
If there are no budget constraints, not many will talk you out of the PB-16's...especially for LFE blockbuster action movies...even for your space! If you missed it, you have only to listen to the SB16/PB16 review/impressions by @youthman several posts back.
https://www.avsforum.com/forum/113-su...l#post56188164
Duckbacker likes this.
gene4ht is offline
post #28230 of 31360 Old 05-19-2018, 05:16 AM
Ed Mullen's Avatar
Quoted: 295 Post(s)
Liked: 735
Originally Posted by iStorm View Post
Hi guys,
I recently did a lot of tweaking with my SVS setup with the PC 13 ULTRA cylinder sub.
I am noticing that the grill on the top of the PC 13 Ultra has been rattling a bit when the sub hits pretty hard. (AVR at -5 and sub at -8).
Has anyone found a remedy to the grill on the cylinder sub rattling?
Also, on a sub like this, I know i will get the best bass extension with one port plugged and setting the sub at 16hz, but is it better than having all ports open for movies and setting it at 20hz?
How many movies will dip below the 20hz all ports open?
This room is just used for movies only and not any music by the way.
Thanks a lot guys!
If your grille is rattling, we can replace it - just contact SVS CS at [email protected].
If you decide to plug a port - leave enough of the port plug sticking out such that it contacts the grille and creates some additional damping.
Ed Mullen
Director - Technology and Customer Service
SVS
"What We Do In Life, Echoes In Eternity"
Ed Mullen is offline
Speaker Systems , Svs , svs pb-2000 , Svs Pb1000 10 Inch 300 Watt Powered Subwoofer , Svs Pb12 Nsd Black Vinyl 12 Inch Powered Subwoofer , svs pb12 plus , Svs Pb13 Ultra , svs pc-4000 , Svs Pc12 Nsd 12 Inch 400 Watt Powered Cylinder Subwoofer , Svs Pc12 Ultra , Svs Sb1000 12 Inch 300 Watt Powered Subwoofer , Svs Sb12 Nsd Charcoal Black Vinyl 12 Inch 400 Watt Powered Subwoofer , Svs Sb13 Ultra Piano Gloss 13 Inch 1000 Watt Powered Subwoofer , Svs Sb2000
