Official SVS Owners/Support Thread. - Page 944 - AVS Forum | Home Theater Discussions And Reviews
 44459Likes
post #28291 of 31356 Old 05-26-2018, 01:44 PM
Rengozu's Avatar
Quoted: 199 Post(s)
Liked: 266
Originally Posted by mthomas47 View Post
That's sort of like being all dressed up with nowhere to go!
I think that you are really going to like your new PB16, but as for what mode you will prefer to use it in, that's something that you will need to experiment with to determine. If you don't use any of the port plugs, and you keep it in Standard mode, you will get a little more SPL above 20Hz. Whether you would actually notice the difference is a YMMV sort of thing.
If you plug one port (any port) and set the DSP to Extended mode, you will get more SPL below 20Hz. With the right content, most people are likely to notice that. <20Hz frequencies are where you will hear/feel the deepest bass effects. Most professional recommendations I have seen for the various Ultras have recommended using the Extended mode, and that is certainly what I prefer. But, that's just something for you to decide for yourself.
If you plug all of the ports and set the DSP to Sealed mode, you will have converted your great big ported sub into an SB16. So, that is not a mode that most people use, although again it's a YMMV issue. I hope that this brief discussion of modes helps!
Mike
Yep, been all dressed up for it a couple days now, but least everything's ready and in place for its arrival.
And awesome, thanks for that. Sounds like plugging one port is exactly what I'm looking to do. Doubt I'll ever want to plug them all unless I'm just playing around with music, but this will mainly be used for movies and I'm ready for Blade Runner to kick me in the chest.
mthomas47 likes this.
JMAX Home Theatre
Spoiler!
Rengozu is offline
post #28292 of 31356 Old 05-26-2018, 01:52 PM
nodoubt's Avatar
Quoted: 417 Post(s)
Liked: 253
Originally Posted by GOOCHY View Post
I just wanted to follow up in this thread to let folks know that the amp in my SB-4000 did fail and SVS had a new amp to me within two days. I put the new amp in last night and everything is back up and rolling. They provided me a return ship label so the failed amp will go back to SVS. Brad in customer service was awesome. One phone call, a couple follow-up emails post-troubleshooting, and they had an amp out the door early the next morning. That's customer service. Thanks SVS!
so you had to tear into a 1500 dollar sub yourself, and replace the amp?
nodoubt is offline
post #28293 of 31356 Old 05-26-2018, 01:57 PM
GOOCHY's Avatar
I did, but it wasn't any big deal. There are ten or so screws holding the amp on, and two easily removed cables - one going to the display, and one going to the woofer - to remove. I can see how plenty of people would not be on board to do that.
Rengozu likes this.
GOOCHY is offline
post #28294 of 31356 Old 05-27-2018, 01:36 AM
Quoted: 163 Post(s)
Liked: 469
I'm running dual PB-16's in Extended mode, and Blade Runner 2049 is one of my favorite movies Not running my subs anywhere close to their limit, as I wish them to last for a good number of years.
Please do let us know your thoughts once you're up and running!
gene4ht, Louis Bartay and Rengozu like this.
TCL 55P607, OPPO UDP-203, 4K Fire TV, Marantz 6011, Rotel 1075 (Atmos)
DefTech SM 65 (X7), SVS PB16 Ultra (X2), SVS Prime Elevation (X4)
Headphone rig: PC-> Schiit Wyrd ->Schiit Modi Multibit ->Stax SRM-353X ->THX AAA 789
Headphones: Stax SR-207, Stax SR-L700, M1060, TH-X00 Purpleheart, HD600, HD6XX, etc
Keith Zuehlke is offline
post #28295 of 31356 Old 05-27-2018, 03:01 PM
Louis Bartay's Avatar
Quoted: 403 Post(s)
Liked: 850
Hi,
You are very welcome! Yes, you can absolutely just trade AVR trim for subwoofer gain without rerunning Audyssey. It may be a little difficult to determine exactly where you are in subwoofer volume, but honestly, that is not something I would worry about. If I were you, I would just set my AVR trim at about -5 or -6, and then turn up the gain controls on my subwoofers symmetrically to the volume that sounds appropriate to you. You could be playing some bass-heavy content at your normal -15 MV while you make the adjustment, and just adjust the sub gains symmetrically until you are satisfied with the balanced bass.
I would probably make a note of what your original sub gains were, just for future reference, but in my opinion, it's not really critical information anyway. Wherever your gain settings are, after calibration, you are just going to add bass until you have what you want. If you start with an AVR trim setting of about -6, that will give you a little room to adjust upward and downward in a listening session, with the remote and without ever leaving your chair. For more substantial increases than a decibel or two, I would continue to make any further increases after this with the gain controls.
Mike
Thanks Mike I printed this to show how much gain/trim in the AVR to a sub my friend is setting up his first AVR and 5.1 system. After he read what you posted here he understood.
I ran across this bech test on a PB 13 Ultra, wow there is a lot of info here plus your articles. This is a lot to take in but I am going to do the test to see when you need to back off the gain when the dB does NOT go up. I purchased the CM-130 SPL meter Ed at SVS likes to use to help read the signal. My old Rat Shack is really close on C FAST, surprised after 28 years. REW and the mic and read more. Ed set mine up for me so I can swap sub cables from my AVR and plug in my NAD analog system and not have to touch the DSP.
https://www.audioholics.com/subwoofe...3-measurements
Thanks again Mike for all the time you spent on this.
Louis
gene4ht and mthomas47 like this.
Klipsch Cornwall I,C7,RS3-II, R-14M
Klipsch Heresy II, NAD C272/C162,PL-518X ATOC9ML/III
Klipsch KLF-20,ReVox A77 MK IV D, Nakamichi BX-300
Klipsch Synergy Sub 12" X 3, SVS PB 13 Ultra Sub
Yamaha RX-V1900 HD 7.1, CDC 697, PS4
Louis Bartay is offline
post #28296 of 31356 Old 05-27-2018, 04:10 PM
AVS ***** Member
mthomas47's Avatar
Quoted: 5371 Post(s)
Liked: 10023
Louis
You are very welcome, Louis! I'm glad if the Guide has helped. Those Data-Bass and Audioholics tests and articles are terrific aren't they?
Believe it or not, I think I have benefited from the Guide more than anyone. The research, writing, editing, and updating have taught me a lot. And, every time I learn something new, or develop a little better understanding of something, I put it in the Guide so that everyone (including myself) can refer to it whenever we need to.
Mike
GUIDE TO SUBWOOFER CALIBRATION AND BASS PREFERENCES
* The Guide linked above is a comprehensive guide to Audio & HT systems, including:
Speaker placements & Room treatments; HT calibration & Room EQ; Room gain; Bass
Preferences; Subwoofer Buyer's Guide: Sealed/ported; ID subs; Subwoofer placement.
mthomas47 is offline
post #28297 of 31356 Old 05-28-2018, 05:36 AM
mrcarnut's Avatar
Quoted: 94 Post(s)
Liked: 41
Thanks Mike. I get so much help from everyone on this forum. It's cost me a lot in the process but at least when I buy new gear I know it will work out great in the end. Have a great holiday.
Mike
mrcarnut is online now
post #28298 of 31356 Old 05-28-2018, 06:42 AM
Quoted: 31 Post(s)
Liked: 1
Anybody know of a good AV guy in the DC area who can install and optimize a subwoofer for me? Will probably need a new center channel speaker as well, but will hold off after seeing how the system sounds after a new sub. Also could use some calibration/setting optimization for another room as well. Would be an extra perk if s/he can also calibrate a new jvc rs540 projector. PM is fine. Thanks.
zeak is offline
post #28299 of 31356 Old 05-30-2018, 02:50 AM
Cal68's Avatar
Quoted: 346 Post(s)
Liked: 340
I too live in the DC area and know of a few AV guys who can do installations for less than what the big store guys charge. But they are not calibrators and all they will do for you is run Audyssey (or its equivalent) which you can do for yourself for free. If you do need a name of someone who can do wiring and install the sub for you, let me know and I'll PM you his details. If you find the name of someone who does calibrations (especially REW which I would very much like to learn to use), please let me know since I need some help too. Thanks.
Cal68
Cal68
Cal68 is offline
post #28300 of 31356 Old 05-30-2018, 06:50 AM
Jim Kiler's Avatar
Quoted: 202 Post(s)
Liked: 107
Who would not be onboard to do it themselves? I got my amp swapped out and it was was better an experience than shipping it or bringing it somewhere and waiting 2 weeks for something that took me less than 30 minutes to do and SVS gives you the only tool you need for the job.
TV - Sony 65XBR-930e | Receiver - Yamaha RX-V577 | 4K player - Sony UBP-X700 | PS3 | Router - Asus RT-AC86U | SVS SB-2000 sub | Paradigm Monitor SE 6000F L/R | Paradigm Monitor SE 2000C center | Paradigm ADP-170 v.3 rears
Jim Kiler is online now
post #28301 of 31356 Old 05-30-2018, 07:03 AM
GOOCHY's Avatar
You can't understand how a potentially non-technical person would not want to tear into their brand new $1500 subwoofer after just a month of ownership?
GOOCHY is offline
post #28302 of 31356 Old 05-30-2018, 09:53 AM
Kevog's Avatar
Quoted: 29 Post(s)
Hi folks! I'm new to SVS ownership, having purchased a used PC12-Plus a few weeks ago. So far, I'm blown away by this sub (layers of extremely accurate and tight bass...IMO) and the famous SVS customer service. I made a small riser using SVS Soundpath feet and some MLV (mass loaded vinyl) I had laying around - seems to work well. Overall - I'm super pleased, but feel foolish for waiting so long to get a real sub!
ID:	2409566   Click image for larger version
Kevog is offline
post #28303 of 31356 Old 05-30-2018, 09:55 AM
gene4ht's Avatar
Quoted: 1968 Post(s)
Liked: 2656
You both make valid points. I would guess the majority of people (myself included) who frequent these threads have no problem or issue replacing a sub amp. However, there are some who admittedly don’t care to or are not adept at performing such tasks.
Epson: 5040UB | Elite: 115" Fixed Frame CinemaScope (2.35:1) | Onkyo: TX-RZ920 + M-5010 (7.2.4) | Klipsch: RF-7 II's, RC-64 II, RS-62 II, RB-61 II MICCA: M-8C (Atmos) x 6 | SVS: PB16-Ultra x 2 | Philips: BDP7501, Panasonic: DMP UB900, Oppo: UDP-203
gene4ht is online now
post #28304 of 31356 Old 05-30-2018, 12:11 PM
Delija's Avatar
Quoted: 395 Post(s)
Liked: 268
It's a matter of choice. You can send whole subwoofer, but then you will have to wait longer.
Jim Kiler likes this.
Anthem MRX 720 | Parasound Halo A21
Dynaudio Contour 60 | Dynaudio Excite X28 | Dynaudio Emit M20 | 2x SVS SB16-Ultra
LG OLED65C7V
Delija is online now
post #28305 of 31356 Old 05-30-2018, 05:23 PM
Kini62's Avatar
Quoted: 2675 Post(s)
Liked: 2463
Congrats on the sub. But you could've just removed the base plate and put the soundpath isolation feet right on the sub. Might have been easier.
Def Tech SC8000
Onkyo RZ820
Roku Ultra, Apple TV, Sharp 70" Quattron
Kini62 is offline
post #28306 of 31356 Old 05-30-2018, 05:51 PM
confinoj's Avatar
Quoted: 1201 Post(s)
Liked: 1009
Nice. I wonder if that was mine. I recently traded up dual pc12+ for dual pc-4000. I put the soundpath feet right on the base plate. Enjoy- it’s an excellent sub.
LG OLED65C7P (Chad B Calibrated) | Denon X4300H | Tivo Roamio OTA | Nvidia Shield | ATV 4K | Oppo UDP-203 | Plex server
5.2.4 | Front Klipsch RP-160M x2 | Center Klipsch RP-450C | Surrounds Klipsch RP-150M x2 | Atmos Klipsch RP-140SA x 4 | Subs SVS PC-4000 x 2
confinoj is offline
post #28307 of 31356 Old 05-30-2018, 06:02 PM
Rengozu's Avatar
Quoted: 199 Post(s)
Liked: 266
Oh man, barely out of the box with almost factory settings and this thing is so much fun! Exactly what I was missing in this room, and don't even get me started on Blade Runner 2049. . . might even need to check for foundation damage on the house after all that boom!
Old sub comparison
Spoiler!
JMAX Home Theatre
Spoiler!
Rengozu is offline
post #28308 of 31356 Old 05-30-2018, 06:36 PM
Matt2026's Avatar
Quoted: 833 Post(s)
Liked: 24233
My Ultra BS was on the FedEx truck for delivery at 3:59 this morning... so, no further away than 10 miles and showing delivery by the end of the day...
At the end of the day the website shows "No scheduled delivery date available at this time."
All day waiting... (Not the first issue I've had with them.)
Of course that means another all day wait whenever they figure out what they're doing.
Regards, Ken (Retired)
9.1.) Denon 4520CI; Samsung 55H8000; OPPO 203; 6x SVS Ultra BS,
Ultra Center; FH 2xPolk; Rythmik F12; CyberPower CP1500PFCLCD (x2)
2.1 Ch.) Nak RE-1, CR7A, BD F7500, Aircom T-8, Denon 300F/Ortofon 2M Bronze;
Matt2026 is offline
post #28309 of 31356 Old 05-30-2018, 06:39 PM
drh3b's Avatar
Quoted: 1860 Post(s)
Liked: 3377
That is Ultra BS!
Matt2026 and Rengozu like this.
Spoiler!
drh3b is offline
post #28310 of 31356 Old 05-30-2018, 06:39 PM
Jim Kiler's Avatar
Quoted: 202 Post(s)
Liked: 107
That is frustrating, specially if you cannot work from home.
post #28311 of 31356 Old 05-30-2018, 06:41 PM
Matt2026's Avatar
Quoted: 833 Post(s)
Liked: 24233
Originally Posted by drh3b View Post
That is Ultra BS!
You must have read my mind because I was thinking the same thing as I wrote up my post
drh3b likes this.
Matt2026 is offline
post #28312 of 31356 Old 05-30-2018, 07:04 PM
Matt2026's Avatar
Quoted: 833 Post(s)
Liked: 24233
Thanks for commiserating with me Jim, but fear not, I'll survive it
Actually, I turned in my resignation letter in March of 1997. Ended up doing some part time contract work for ~7 years, averaging 4 to 5 hours a week the last 3 years and then pulled the plug. So, no work since ~2004 It was a great way to leave the job behind as I went from 60 hours a week, winding down to 4-5 hours some weeks at the end with some 1 to 2 month periods of no work tossed into the mix.
There was zero shock at the end compared to some folks who are going full speed one day and then zero the next Also I realized along my life's journey, that amongst other things, I was not my job. It was something I had
Matt2026 is offline
post #28313 of 31356 Old 05-30-2018, 07:29 PM
Rengozu's Avatar
Quoted: 199 Post(s)
Liked: 266
Now that sucks. For whatever reason they used a Semi-truck specialty service to deliver mine and not the typical UPS/Fed-Ex types. Well hopefully someone can be there to sign for it tomorrow.
JMAX Home Theatre
Spoiler!
Rengozu is offline
post #28314 of 31356 Old 05-30-2018, 07:35 PM
Matt2026's Avatar
Quoted: 833 Post(s)
Liked: 24233
FedEx just dropped off my speaker Driver said that because of the holiday he had more packages to deliver until he's caught up
Time to open it up and see what condition its in...
[Edit] Looks brand new
Connected in place of my front right to check it out.
The Guess Who (Quadrophonic recording) Road Food sounds great
Matt2026 is offline
post #28315 of 31356 Old 05-31-2018, 05:58 AM
Kevog's Avatar
Quoted: 29 Post(s)
I thought about that - but I wanted to raise the sub and get a few layers of that MLV going....
Kevog is offline
post #28316 of 31356 Old 05-31-2018, 03:41 PM
rx7gslse's Avatar
Quoted: 22 Post(s)
Its here! Its here!
Got the new PB-16 Ultra sub in today, drug it upstairs, re-ran Audyssey etc and got all set in to listen to music and watch stuff blow up...
And my first impression? meh...
It definately does lower than my 10yr old 15" Velodyne that it just replaced, but the volume just isn't there. Super 8 train crash had more depth but signifiantly less force. So much so that I drug the old one back in and plugged it in just to be sure Audyssey didn't mess with something. Even at 60% volume on my Velodyone DLR-5000R (15" 1000W RMS, 23Hz from ~2007) it has significantly more thump (>3dB based on my iphone free SPL meter app) than the PB-16 Ultra does set at 0dB. That's without changing any of the AVR settings, just moving the cord from one sub to the other and replaying the same track...
Do these things take awhile to loosen up perhaps?? What am I missing?? I set the EQ to extended and plugged the center port, but haven't messed with any other setting it arrived with.
rx7gslse is offline
post #28317 of 31356 Old 05-31-2018, 04:02 PM
nodoubt's Avatar
Quoted: 417 Post(s)
Liked: 253
Originally Posted by rx7gslse View Post
Its here! Its here!
my pb4000 took a few weeks to loosen up, as well as all other svs subs ive had.
that pb16 you have should still mop the floor with that vd , even out of the box.
i would def run the standard setting to break it in, all ports open
it has more overall output
are you getting good excursion with the woofer ?
Louis Bartay likes this.
nodoubt is offline
post #28318 of 31356 Old 05-31-2018, 04:56 PM
AVS ***** Member
mthomas47's Avatar
Liked: 10023
Its here! Its here!
Hi,
I have never been quite sure about subwoofer break-in. It did seem to me that a new PB4000 got louder after a few spirited listening sessions, but who knows? I am sure, though, that running Audyssey, and then just switching back-and-forth between the two subs doesn't prove anything. The room EQ would be entirely different for those two subwoofers. Audyssey might have deliberately done something based on the PB16's interaction with the room, that allowed the Velodyne to exhibit a louder peak at a particular frequency.
Did I understand you to say that you turned the PB16 up to the max setting on the subwoofer, and you still weren't getting enough volume? If so, it is also possible that you are accustomed to hearing more mid-bass than the PB16 produces, and that you may like mid-bass more than low-bass. (Note: your phone app won't even be able to measure the low-bass SPL. It doesn't go low enough to do that.)
If it does turn out that you really prefer mid-bass to low-bass as some people certainly do, then break-in period or not, the PB16 may not be the best subwoofer for you. I would definitely give myself some time to see if the low-bass capabilities of the PB16 grow on you. But, if they don't grow on you, and you believe that you just want more mid-bass than it can produce, then I would investigate a PSA V3601. That subwoofer deliberately emphasizes mid-bass frequencies relative to low-bass frequencies, where the PB16 does the exact opposite. It's entirely a YMMV issue!
Mike
drh3b likes this.
post #28319 of 31356 Old 05-31-2018, 05:42 PM
rx7gslse's Avatar
Quoted: 22 Post(s)
Hi,
Mike
I dunno about mid-bass vs low base, but even at 0db this doesn’t have very much room rattle, movies or music... I’ve done the crawl and it’s in the 1/4 wall front position where it seemed. I keep flipping back and forth and it just seems like something on this isn’t working right. I can see the woofer move, and I get a fair amount of sound, it’s just not very impactful?
I remember just being able to feel the one I demoed at the store... this one I don’t get that. Wondering if this one is messed up or something?
My brother in law got his sb-16 delivered today as well, so may have to do some comparisons this weekend... but for the size/power/weight of this it doesn’t seem to hold up to my old one... not what I expected at all.
rx7gslse is offline
post #28320 of 31356 Old 05-31-2018, 05:49 PM
darthray's Avatar
Quoted: 2092 Post(s)
Liked: 2974
Sound like you have a placement problem, or maybe the setting on your sub or AVR.
Not sure if you read this thread, while long to read, a lot of good information can be found;
https://www.avsforum.com/forum/113-su...eferences.html
The answer to your problem, is more likely in there.
Ray
darthray is offline
Speaker Systems , Svs , svs pb-2000 , Svs Pb1000 10 Inch 300 Watt Powered Subwoofer , Svs Pb12 Nsd Black Vinyl 12 Inch Powered Subwoofer , svs pb12 plus , Svs Pb13 Ultra , svs pc-4000 , Svs Pc12 Nsd 12 Inch 400 Watt Powered Cylinder Subwoofer , Svs Pc12 Ultra , Svs Sb1000 12 Inch 300 Watt Powered Subwoofer , Svs Sb12 Nsd Charcoal Black Vinyl 12 Inch 400 Watt Powered Subwoofer , Svs Sb13 Ultra Piano Gloss 13 Inch 1000 Watt Powered Subwoofer , Svs Sb2000
