Official SVS Owners/Support Thread. - Page 989 - AVS Forum | Home Theater Discussions And Reviews
 45160Likes
post #29641 of 32261 Old 11-18-2018, 12:39 PM
drh3b's Avatar
Quoted: 2135 Post(s)
Liked: 4405
Originally Posted by Chokurei View Post
I switched the connections at the Marantz, both subs are working now! Could the amp work intermittently? Could shutting it down completely and restarting it, "re-set" the amp? I guess I''ll turn everything off, and let the subs go into standby and see what happens when I turn it all back on.
Probably the RCA cable wasn't seated correctly. If you don't have any further problems, that's probably it. If the problems pop up again, I'd try another cable before calling SVS.
darthray likes this.
drh3b is offline
post #29642 of 32261 Old 11-18-2018, 07:10 PM
mattg3's Avatar
Quoted: 972 Post(s)
Liked: 326
Wonder if SVS will put a sub on sale for Black Friday like they did last year.
Matt
mattg3 is online now
post #29643 of 32261 Old 11-18-2018, 07:20 PM
bigzee3's Avatar
Quoted: 177 Post(s)
Liked: 123
Hi guys,
Just finished testing with DEQ off. Boosted the sub 6db to compensate and to tell you the truth I think both had their advantages. Anyway then I was thinking if I watch a movie at -15mv all I have to do is set the offset to -15 in AVR and then I’d get no DEQ boost besides what I did in the AVR. Anyone else uses this method.
bigzee3 is online now
post #29644 of 32261 Old 11-18-2018, 07:22 PM
e30cabrio's Avatar
Quoted: 434 Post(s)
Liked: 183
I'm hoping for a deal on Ultra towers.
mattg3 likes this.
Denon AVR-X7200WA, SVS Prime Tower & Ultra Center, Klipsch R-2650 HSU VTF-15H MK2, Sony XBR 75X940D & 75X910C, OPPO BDP-93, Panasonic DP-UB820, Sony UBP-X800, Samsung UBD K8500, Roku Ultra, Hopper 3, HTPC, Technics SL-BD22D
e30cabrio is offline
post #29645 of 32261 Old 11-18-2018, 07:35 PM
AVS ***** Member
mthomas47's Avatar
Quoted: 5653 Post(s)
Liked: 11215
Originally Posted by bigzee3 View Post
Hi guys,
Hi,
I would give myself some time with this to see what I like, if I were you. Nothing says that you have to decide right away, or that you can't go back-and-forth with different program material. I think that DEQ may add a little excitement, but at the cost of some clarity, so as you say, it's really just a matter of which you prefer. And, that may change, based on the listening material, or on your own mood.
Setting an RLO of -15, with a master volume of -15, is exactly the same as turning DEQ off, except that you won't have access to the tone controls unless DEQ actually is off. What I might try, though, is an RLO of -10, or -5, to see if having just a little bit of DEQ works better. Those are all YMMV scenarios.
Mike
bigzee3 likes this.
GUIDE TO SUBWOOFER CALIBRATION AND BASS PREFERENCES
* The Guide linked above is a comprehensive guide to Audio & HT systems, including:
Speaker placements & Room treatments; HT calibration & Room EQ; Room gain; Bass
Preferences; Subwoofer Buyer's Guide: Sealed/ported; ID subs; Subwoofer placement.
mthomas47 is online now
post #29646 of 32261 Old 11-18-2018, 07:37 PM
bigzee3's Avatar
Quoted: 177 Post(s)
Liked: 123
Thanks mike,
Experimenting is half the fun.😁
mthomas47 likes this.
post #29647 of 32261 Old 11-18-2018, 11:29 PM
MIX_MASTER_ICE's Avatar
Quoted: 2676 Post(s)
Liked: 2485
PB12-NSD and SB12-NSD are back yet again this Turkey Day Holiday for $500 and $400, respectively.
Kevin Desai likes this.
Subs>RBH I-12e, I-12. HSU VTF-15H mk2. Monolith THX 12(x2), THX 10(x2). XTZ 1X12. SVS PB-1000(x2). Speakers>JBL Studio 270/235c/230/225c. Sony CS3/CS8/CS5. QA 3020i/3090Ci, 2020i/2000c. Monolith Cinema 5bs. Polk RTiA1/CSiA4. Other Audio>Sony MDR-Z7m2,V6, XB900n,700,XB32,XB31. Sennheiser HD58X,HD4.50,PC37X. HiFiMAN HE4XX. Philips SHP9500. SIVGA SV004. SA HDTwo. HyperX CloudPS4. TB Elite AtlasAero. LG FH6,RK8,RK7,PK5. HK Onyx Studio4(x2).
MIX_MASTER_ICE is offline
post #29648 of 32261 Old 11-19-2018, 06:02 AM
flenn's Avatar
Historically, has SVS offered additional discounts on new or outlet items for Black Friday? I can find that they offered the same deals on PB12-NSD/SB12-NSD last year but wonder if they do anything else on that day?
flenn is offline
post #29649 of 32261 Old 11-19-2018, 08:16 AM
Malodium's Avatar
Quoted: 49 Post(s)
I had been considering getting one Monoprice Monolith 15". Would I be better off with two PB12s? At $500 this would be cheaper than one Monolith. Room is around 4500 cubit feet and perhaps 80% movies 20% music.
Malodium is online now
post #29650 of 32261 Old 11-19-2018, 08:50 AM
spacecowboy's Avatar
Quoted: 188 Post(s)
Liked: 142
I have the same sized room with 2 Klipsch 15" (one of which went kaput last week) and one SVS PB12-NSD. I just purchased another PB12 this morning which will give me dual PB12s as well. Won't be able to let you know until later this week.
gene4ht, darthray and Louis Bartay like this.
"Excuse me...What does God need with a Starship?" (Captain Kirk - Star Trek V: The Final Frontier)
spacecowboy is offline
post #29651 of 32261 Old 11-19-2018, 12:08 PM
Cla55clown's Avatar
Quoted: 389 Post(s)
Liked: 120
Currently have a Polk PSW505 (-3 dB frequency response is 28-125Hz per documentation) in a living room that is open to kitchen and rest of the house via 20 ft ceiling. Would the PB12-NSD be more of a lateral move for movies or a major upgrade?
I only have the space or WAF to run 1 sub.
Cla55clown is offline
post #29652 of 32261 Old 11-19-2018, 12:13 PM
gajCA's Avatar
Quoted: 9539 Post(s)
Liked: 6585
That would be a large upgrade going to the PB12.
Free returns makes it an easy decision to at least give it a go if you are in the US.
PORTED SUBWOOFERS $600 AND BELOW, DELIVERED
NOTE:
*IF LOOKING AT LARGER/MORE EXPENSIVE SUBWOOFERS ADD PSA TO THE LIST OF BRANDS
*IF YOU ARE NOT AN ACTION MOVIE FAN A SUBWOOFER WITH 22-30HZ EXTENSION WOULD BE FINE
*FOR MUSIC A 30HZ SUB IS A FINE CHOICE
*BEFORE BUYING MAKE A CARDBOARD CUTOUT OF THE SIZE OF THE SUB TO MAKE SURE IT IS NOT TOO LARGE FOR YOU
Specs are from the manufacturer unless noted otherwise.
150watts =11w18h13d= 18 lbs 8" [28hz] $199 EMOTIVA BASX S8
200watts =14w16h16d= 34 lbs 10" [27hz] $299 EMOTIVA BASX S10
350watts =15w16h17d= 40 lbs 10" [30hz] $399 RSL SPEEDWOOFER 10S, (extension from Sound & Vision review)
200watts =14w15h15d= 32 lbs 10" [25hz] $450 ELAC DEBUT 2.0 SUB3010, (extension from Sound & Vision review)
NOTE: THIS SUB HAS PHONE APP EQ FOR THE SUB
250watts =15w19h17d= 42 lbs 10" [25hz] $455 HSU VTF 1 MK3 (extension from Audioholics review)
300watts =15w19h20d= 46 lbs 10" [18hz] $499 SVS PB1000, (extension from Sound & Vision Review)
400watts =17w21hx22d= 66 lbs 12" [19hz] $500 SVS PB12 NSD, (extension from Sound & Vision Review)
500watts =15w19h20d= 72 lbs 10" [20hz] $500 MONOPRICE MONOLITH THX 10"
300watts =16w22h21d= 69 lbs* 12" [19hz] $549 RHYTHMIK LV12R
350watts =15w21h22d= 62 lbs 12" [18hz] $607 HSU VTF2 MK5, (extension from Audioholics review)
* = shipping weight
SEALED SUBWOOFERS $650 AND BELOW, DELIVERED
400watts =15w14h14d= 35 lbs 12" [21hz] $400 SVS SB12 NSD, (extension from Audioholics Review)
300watts =13w14h16d= 27 lbs 12" [23hz] $499 SVS SB1000, (extension from Sound & Vision)
300watts =14w14h16d= 58 lbs* 12" [18hz] $539 RHYTHMIK L12
500watts =14w15h17d= 35 lbs 12" [19hz] $649 SVS SB2000 outlet, (extension from Sound & Vision)
* = shipping weight
Geoff A. J., California
gajCA is offline
post #29653 of 32261 Old 11-19-2018, 12:14 PM
gene4ht's Avatar
Quoted: 2014 Post(s)
Liked: 2763
Congrats! BTW...what did you finally upgrade your AVR to?
Epson: 5040UB | Elite: 115" Fixed Frame CinemaScope (2.35:1) | Onkyo: TX-RZ920 + M-5010 (7.2.4) | Klipsch: RF-7 II's, RC-64 II, RS-62 II, RB-61 II MICCA: M-8C (Atmos) x 6 | SVS: PB16-Ultra x 2 | Philips: BDP7501, Panasonic: DMP UB900, Oppo: UDP-203
gene4ht is online now
post #29654 of 32261 Old 11-19-2018, 12:16 PM
gene4ht's Avatar
Liked: 2763
No question or doubt...the PB12 NSD will be a "MAJOR" upgrade from the PSW505!
JeffChap likes this.
post #29655 of 32261 Old 11-19-2018, 12:20 PM
Cla55clown's Avatar
Quoted: 389 Post(s)
Liked: 120
Yes, it would fit but it would be getting major boundary reinforcement (corner of room, side of couch, side of cradenza) basically dropped into a open top hole. Is that bad?
Yeah, my Polk would probably do well in my dedicated 2-channel room with its extension specs.
post #29656 of 32261 Old 11-19-2018, 12:28 PM
gajCA's Avatar
Liked: 6585
Your current sub is also ported, in the rear, the PB12 is ported in the front so with free returns no harm in trying the SVS sub.
So you only have one placement option and it's in a corner inside a cabinet?
What EQ does your AVR have?
gajCA is offline
post #29657 of 32261 Old 11-19-2018, 01:16 PM
flenn's Avatar
Good question and my guess is one Mono 15. I'm sure others can chime in with a technical comparison. Problem is that until you get them in your room you won't truly know which solution is more cost effective...
I'm sort of in the same boat. Been convinced that I needed duals in my 3000+ room but as I've been sitting back waiting for Black Friday, I keep wondering if I shouldn't just go with one big sub. VTF-15, Mono 15, PB-4000, etc. Well, I pulled the trigger on two PB12's today and will finally start to answer my questions. They'll arrive Weds and I'll start testing. I may purchase a PB-4000 while I'm within the 45 day period and do an A/B test.
flenn is offline
post #29658 of 32261 Old 11-19-2018, 02:48 PM
Cla55clown's Avatar
Quoted: 389 Post(s)
Liked: 120
Yes, one placement option. It's not in a cabinet, just boundaried by 4 things (2 walls, side of sofa, and side of cradenza).
post #29659 of 32261 Old 11-19-2018, 03:09 PM
gajCA's Avatar
Liked: 6585
Does your AVR EQ the sub?
gajCA is offline
post #29660 of 32261 Old 11-19-2018, 03:27 PM
Cla55clown's Avatar
Quoted: 389 Post(s)
Liked: 120
Well, no, I don't think so. My Yamaha AVR has simple YPAO and just sets a low pass filter at 100hZ. That doesn't quality as EQ does it? I can pick up a simple MiniDSP 2x4 for under $100 bucks to play around with.
post #29661 of 32261 Old 11-19-2018, 03:32 PM
gajCA's Avatar
Liked: 6585
If you didn't need it with your old sub may not need it with the new one.
But I use a Minidsp in my secondary room, (with Umik and REW), for my two little subs because their frequency response isn't exactly "good" out of the box considering I paid $200.........................................for two!
I needed the MiniDSP to act as a crossover as my old analog NAD stereo receiver has no bass management but, luckily, has pre outs/main ins for the minidsp to act as a crossover.
It was an added bonus to use it to flatten the EQ of the subs for me.
gajCA is offline
post #29662 of 32261 Old 11-19-2018, 04:07 PM
Quoted: 188 Post(s)
Liked: 142
Yamaha 3070
gene4ht likes this.
post #29663 of 32261 Old 11-19-2018, 04:56 PM
alwaller's Avatar
Quoted: 109 Post(s)
Liked: 72
major upgrade
1) Polk Audio LSI 9 and matching center
2) RSL CG4 (side speakers)
3) SVS PB13 Ultra subwoofer
4)Onyko TX-SR705 receiver,Outlaw 7125 amplifier
5) Sony UBP X800 Ultra Blu-ray Player & Panasonic 55" Plasma
alwaller is offline
post #29664 of 32261 Old 11-19-2018, 05:21 PM
gene4ht's Avatar
Liked: 2763
Originally Posted by Islandborn View Post
Sup fellas. Finally after swapping out the bad amp on one of my new PB4000's and running Audyssey x32 the other night (it literally took me 3 hours to dial in the subs to my preference and what audyssey wants to set-Did this all at 1AM when kids were asleep and all external power/noise turned off btw )
Anyways, finally got to enjoy my sytem last night and watched Jurassic Park. What a difference these dual PB 4000's do for my system! Gobs of power even in my 4500 CF living room. I have one sub on back left wall and right sub positioned in the middle of my right wall. My living room is large open floor plan to the kitchen so this is the best I got to work with.
I had to set both subs to -14 to get Audyssey/Denon avr to set their trims at -11 and -11.5. I boosted them about 6 db in my AVR. Sound is large and base hits hard! Little boomy if I crank it to reference but I usually watch at about -10. Before bed, I of course had to play the infamous EOT opening scene and holy hell!!, I didn't know my house had that many rattles? My wife ran downstairs and was like WTF??? Anyways, pretty happy with the PB4000's. I think these are great woofers and for most people pretty much all anyone would ever need.... Happy thanksgiving fellas!
That should remove any doubts in your mind relative to both SVS's customer satisfaction and product performance. Congrats and welcome to the club...finally!
darthray and Islandborn like this.
post #29665 of 32261 Old 11-19-2018, 07:12 PM
darthray's Avatar
Quoted: 2390 Post(s)
Liked: 3664
Originally Posted by mthomas47 View Post
Hi,
Mike
Very much agree
Hi guys,
As Mike post quoted above, do not make your decision right away.
Since I mostly listen to movies, I normally give my-self a few movies before making my final decision.
Ray
darthray is offline
post #29666 of 32261 Old 11-19-2018, 07:31 PM
Chokurei's Avatar
Quoted: 27 Post(s)
Liked: 34
I've used the system a couple of times since my last post. Each time both subs have come on right away and stayed on. Not sure why it hasn't happened again, but I'll be keeping a close eye on them going forward. They sound great!! Very pleased with my purchase so far. I love the app. I wouldn't be able to tweak them any where near as much if I had to access controls on the back panels.
Louis Bartay and drh3b like this.
Chokurei is online now
post #29667 of 32261 Old 11-19-2018, 08:32 PM
Nuggles's Avatar
Quoted: 51 Post(s)
Liked: 29
Pulled the trigger today and am excited to be adding a 2nd PB16 Ultra to my home theater this Christmas. I’ve been waiting for this moment for two years when they first introduced the PB16s as I got my first one for Christmas 2016. Life is good, much to be thankful for including the good folks on this forum that continue to educate and support us on our quest for home theater greatness.
And special shout out to the amazing folks at SVS (Scott Miller is the shiznit) who truly understand that a company’s customer service is as important as the products they sell.
Happy Thanksgiving to all my fellow AVS Forum Addicts,
Nathan
Nuggles is offline
post #29668 of 32261 Old 11-20-2018, 04:15 AM
Pfeffernuss's Avatar
Quoted: 12 Post(s)
I'm expecting the 3000-series will be rather (for me that is) expensive here in The Netherlands. But, natural born optimistic as I am, maybe the price of the 2000-series will drop a bit by then. Probably wishful thinking though.
Would really love a PC-3000 (for the Bluetooth functionality mainly) but that one will be out of reach as well I guess.
So, for the time being I will just keep on watching all those double PB16-Ultra crates be delivered and installed and wiping some drool from the keyboard.
mthomas47 and Louis Bartay like this.
Pfeffernuss is offline
post #29669 of 32261 Old 11-20-2018, 07:09 AM
audiocologne's Avatar
Quoted: 67 Post(s)
Liked: 60
SB12-NSD Subwoofer -- What does NSD stand for?
Hopefully, Never Say Die.
Louis Bartay likes this.
audiocologne is offline
post #29670 of 32261 Old 11-20-2018, 07:59 AM
vpn75's Avatar
Quoted: 32 Post(s)
Liked: 32
I'm tempted by the PB12-NSD deal. I currently have an Outlaw LFM-Plus sub that has served me well but I've been thinking of moving to dual-subs now that I've moved into a single-family home with a basement HT setup. Would the PB12 pair well with the Outlaw or should I hold off until I can get two of the same type subs?
AV equipment: Sony XBR65X930E, Denon X4400H, Sony UBP-X800 UHD, ATV 4K, PS4 Pro
5.1.4 Atmos setup: Klipsch RP-250C | RP-250F | RP-150M surrounds |SVS Prime Elevations (x4)
Subwoofers: SVS PB12-NSD |Outlaw LFM1-Plus
Gaming PC: i7 3770K OC 4.2Ghz, 16GB RAM, MSI GTX 1080 Ti Gaming X
vpn75 is offline
Speaker Systems , Svs , svs pb-2000 , Svs Pb1000 10 Inch 300 Watt Powered Subwoofer , Svs Pb12 Nsd Black Vinyl 12 Inch Powered Subwoofer , svs pb12 plus , Svs Pb13 Ultra , svs pc-4000 , Svs Pc12 Nsd 12 Inch 400 Watt Powered Cylinder Subwoofer , Svs Pc12 Ultra , Svs Sb1000 12 Inch 300 Watt Powered Subwoofer , Svs Sb12 Nsd Charcoal Black Vinyl 12 Inch 400 Watt Powered Subwoofer , Svs Sb13 Ultra Piano Gloss 13 Inch 1000 Watt Powered Subwoofer , Svs Sb2000
