Seaton Sound SubMersive1 - Page 358 - AVS Forum | Home Theater Discussions And Reviews
 878Likes
post #10711 of 10805 Old 04-19-2018, 03:33 PM
forin's Avatar
Quoted: 86 Post(s)
Liked: 72
Looking forward to my 562 lb delivery on Monday, thanks Mark!
forin is offline
post #10712 of 10805 Old 04-19-2018, 04:25 PM
Quoted: 1012 Post(s)
Liked: 1263
What did you order? F18+ and three slaves?
Pradeep2 is offline
post #10713 of 10805 Old 04-19-2018, 04:53 PM
forin's Avatar
Quoted: 86 Post(s)
Liked: 72
4 F18 Masters 😁
sandbagger and DRC3 like this.
forin is offline
post #10714 of 10805 Old 04-19-2018, 04:55 PM
Liked: 1263
Whoa. Think you'll eventually go to four quad stacks?
Pradeep2 is offline
post #10715 of 10805 Old 04-19-2018, 04:58 PM
forin's Avatar
Quoted: 86 Post(s)
Liked: 72
Eventually yes 😀, but I mainly wanted independent control over each sub for easier room optimization.
Marc Alexander and Pradeep2 like this.
forin is offline
post #10716 of 10805 Old 04-21-2018, 02:08 PM
jjackkrash's Avatar
Quoted: 2223 Post(s)
Liked: 2332
4 F18 Masters 😁
Wow. 4 stacks of three in each corner ought to do it.
jjackkrash is offline
post #10717 of 10805 Old 04-24-2018, 08:49 AM
madhuski's Avatar
Quoted: 1449 Post(s)
Liked: 904
if anyone is interested, i’m selling my F2 slave unit
https://www.avsforum.com/forum/209-au...l#post55860930
Selling in AVS Classifieds
Seaton Catalyst 12c (4) and 8c (3) Speakers
madhuski is offline
post #10718 of 10805 Old 04-24-2018, 04:28 PM
forin's Avatar
Quoted: 86 Post(s)
Liked: 72
All 4 F18 masters arrived yesterday without a scratch, thanks Mark!. I was able to place them but have not yet had a chance to fire them up!
ID:	2395086   Click image for larger version
ID:	2395088   Click image for larger version
forin is offline
post #10719 of 10805 Old 04-24-2018, 05:58 PM
BRAC's Avatar
Quoted: 706 Post(s)
Liked: 619
Congrats. 4 F18’s must punish that space!
Samsung 82” Q90R * LG 55” C8 * Denon X4500H * 5.2.4 Atmos * Xbox One X * PS4 Pro
BRAC is offline
post #10720 of 10805 Old 04-24-2018, 09:05 PM
Liked: 1263
In AVS sub forums it's merely a good start but a tremendous foundation to build upon.
BRAC and jsc79 like this.
Pradeep2 is offline
post #10721 of 10805 Old 04-24-2018, 09:16 PM
BRAC's Avatar
Quoted: 706 Post(s)
Liked: 619
Isn’t that the truth!
BRAC is offline
post #10722 of 10805 Old 04-24-2018, 10:02 PM
forin's Avatar
Quoted: 86 Post(s)
Liked: 72
Full bore I think all 4 subs would tear my home apart! I grabbed 4 to use with Andyc56's multisub optimization for the smoothest frequency response possible. Honestly I am not really a bass head!! ( gonna pay for that comment, lol) Just shooting for the most accurate natural sound possible! I do enjoy sub 20hz extension, old pier and beam construction works wonderful, it adds such amazing floor flexion! Just waiting for the minidsp to get here and I will be all set!
forin is offline
post #10723 of 10805 Old 04-25-2018, 04:42 AM
femi's Avatar
Quoted: 307 Post(s)
Liked: 361
Awesome room forin. Which JBL speakers do you have there?
Femi
(2)JTR Cap 4000's---(6) Enclosures Seal SI HT-18's---Behringer iNUKE 6000DSP--- Behringer iNUKE 3000DSP---Denon AVR-4250CI---(3)JBL 4722n---(5)Behringer Eurolive B215XL---(2)Klipsch SS-1 Surround---JVC RS500---Sony HW50es---VApex Fixed frame 135" 16:9---Sony UBP-X800---Oppo BDP-93---Toshiba HD DVD-XA2---Xbox 360---PS4---HDFURY Linker---Darbee Darblet DVP-5000---miniDSP Balanced 2x4---Harmony 1100 remote
femi is offline
post #10724 of 10805 Old 04-25-2018, 10:21 AM
forin's Avatar
Quoted: 86 Post(s)
Liked: 72
Femi
Hi femi,
I have 7 JBL LSR 308s for LCR and surrounds
And 4 JBL LSR 305s for atm is heights.
Hopefully later this year I’ll swap them out for JBL 708p and 705p. That all depends on how fast the wifey forgets about the sub purchase!
iceatola and mik2h like this.
forin is offline
post #10725 of 10805 Old 04-27-2018, 11:37 AM
Slickman's Avatar
Quoted: 531 Post(s)
Liked: 503
Originally Posted by Marc Alexander View Post
I did that and I never thought it looked stupid. It actually looked better.
Does this degrade sound quality at all? Also one thing I like about the Submersive is that the cabinet is inert, does the F18 shake like a leaf when producing alot of bass? My wife likes to set things on top of subwoofers that's why I ask.
Slickman is offline
post #10726 of 10805 Old 04-27-2018, 01:34 PM
Liked: 1263
I dont have an F18 but my um18-22 drivers in 4 cuft sealed enclosues will try and go for walkies on my concrete slab in the basement (Penn Elcom rubber feet attached). Also my surround rear speakers that I had sitting on top of them would rotate and try and commit suicide off the edges at higher volume levels. If you are on carpet the walkabout problem shouldn't be an issue.
DRC3 and mik2h like this.
Pradeep2 is offline
post #10727 of 10805 Old 04-27-2018, 01:43 PM
Mark Seaton's Avatar
Quoted: 930 Post(s)
Liked: 2593
Rotating a woofer has almost zero effect on the sound, especially below 100Hz. What rotating a woofer does do is move the acoustic location of the woofer/subwoofer. The acoustic center is the center of the woofer or woofers, not the box. With a woofer on the front of a box, rotating it 180 deg moves the source closer to the front wall by the depth of the subwoofer. At a 24" movement there can definitely be differences, with differences shifting to higher and higher frequencies with shorter distance changes. In the case of the F18, it's probably only a movement of ~6" closer to the front wall and a few more inches laterally. In short, differences will most likely be measured at upper frequencies as subtle differences and not readily heard.
Any front firing woofer will have some reaction force on the enclosure. When at their maximum excursion down low, you will feel a little shake fore-aft. If you want it to be more stable, swap the included rubber feet for spikes, and you'll have a lot less motion once the spikes set in the flooring. Of course any force cancelling design will have the edge in being perfectly inert where weight of the enclosure has no impact on shaking of the sub.
Mark Seaton
Seaton Sound, Inc.
"Make no little plans; they have no magic to stir men's blood..." Daniel H. Burnham
Mark Seaton is offline
post #10728 of 10805 Old 04-27-2018, 04:52 PM
Marc Alexander's Avatar
Quoted: 5866 Post(s)
Liked: 5427
^^ What he said @Slickman
Marc Alexander is online now
post #10729 of 10805 Old 05-30-2018, 08:52 PM
Groto's Avatar
I disappeared from this forum for the past month, but believe I’m ready to take the plunge on some F18s. @Mark Seaton I sent you an email to get the process going.
Thanks all. I’ll probably be back later with calibration questions
jjackkrash, DRC3 and Pradeep2 like this.
Groto is offline
post #10730 of 10805 Old 08-10-2018, 07:25 AM
MIkeDuke's Avatar
Quoted: 634 Post(s)
Liked: 315
I just wanted to add something extra again.
So here is a something interesting. Normally I watch loud movies on my own. And I have the Crowson so I get extra shake from that. Well, a day or two ago I thought something was wrong with my sub. When I ran the test tone through my preamp I barely heard the sub so I started to panic. I watched King Aurthur: Legend of the sword which I like, and there some bass in there but nothing outrageous. Then last night I was still worried so I put on the test I always use to test my sub. The intro to Edge of Tomorrow. But I had another person in the room with me as well. I only had it at -18. (just so you know, my sub is on a sub platform and directly on the floor.)Boy howdy is this thing working. The sweep was incredible. The other person was standing up and they said that they felt the bass through the floor. Not only that, but they swore they saw the floor moving. I have my theater on the second floor. Now I can not confirm or deny that part but this person said it multiple times. So the SubMersive HP is still rocking my room after having it for 11 years. Just wanted to share that little tid bit.
It ain't easy being green.
My System
MIkeDuke is offline
post #10731 of 10805 Old 08-10-2018, 07:54 AM
iceatola's Avatar
Quoted: 263 Post(s)
Liked: 235
Time for an upgrade ?
MIkeDuke likes this.
Video: BenQ HT3550 4K Projector - Elite Screens Manual Grande Series - 128inch
Pre Amp: Marantz 7705/ Power Amplifiers: Emotiva XPA-3, UPA-700
JBL - Stage A190 Towers L/R , Stage A135 Center , Stage A190 surrounds , Atmos Klipsch rp-500sa
Subwoofer PSA 2xV1801 / Xbox One X, Nvidia Shield, Darbee Darblet 5000
iceatola is offline
post #10732 of 10805 Old 08-10-2018, 08:10 AM
MIkeDuke's Avatar
Quoted: 634 Post(s)
Liked: 315
UMMM.... NO. One suits me just fine. In my small room (1000 cf) I have usable output down to 10Hz. And again, that was just on -18. I know I can go louder on the MV if I want so again I say, No. Not saying that I wouldn't mind... Hey now, stop putting that idea in my head. I have the perfect spot of an F2. STOP IT... . All kidding aside, I have been with the SubMersive when it had a 1000 watt amp. It is a great sub. Rocks for movies and sounds awesome for music. I have never heard the F18 but that will change in a few weeks.
kbarnes701 likes this.
My System
MIkeDuke is offline
post #10733 of 10805 Old 08-10-2018, 08:28 AM
iceatola's Avatar
Quoted: 263 Post(s)
Liked: 235
OK so after you hear the F18 then I will check back in on you to see if we still would not upgrade
iceatola is offline
post #10734 of 10805 Old 08-10-2018, 08:33 AM
MIkeDuke's Avatar
Quoted: 634 Post(s)
Liked: 315
You know, your quite feisty and tenacious . TBH, I would be interested in hearing Mark's comparison of the two. I am sure it's
compared somewhere, but I am too lazy to look. I am going to hear 8 of them so it won't be a fair fight.
My System
MIkeDuke is offline
post #10735 of 10805 Old 08-13-2018, 03:58 AM
kbarnes701's Avatar
Quoted: 7743 Post(s)
Liked: 7059
Hey Mike - very long time no type! Good to see you're still rocking that great setup of yours! Like you, I've had my Submersives for a long time (Master/slave F2 pair with the bigass UK spec amp) and they are still the only subs I have ever wanted. A year or so ago I had a problem with my amp and Mark could not have been more responsive or more helpful in swapping it out under warranty for me. Initially the F2s were in my small (10ft6in x 10ft6in x 8ft6in) 'Hobbit Theater' but now they take pride of place (albeit hidden behind an AT wall) in my new, purpose-designed HT (see my sig link if you want to know more but I'll attach a couple of pics to this post.
Also like you, my go-to demo for bass is the beginning of Edge of Tomorrow (which is also a favourite movie of mine). It is just amazing - the room shakes, the bass terrifies, jaws drop...
Great to read your comments buddy and to see that your enthusiasm is still undiminished after all these years.
The Submersives are at the back of the room, on concrete plinths about 1 ft high (to avoid problems with the vertical room mode). One is next to the rack and the nother on the corresponding location on the other side of the entrance door (below the PJ).
kbarnes701 is offline
post #10736 of 10805 Old 08-13-2018, 04:06 AM
kbarnes701's Avatar
Liked: 7059
^^^ Just an additional point - let's not forget that the single most important component in any system is also the most overlooked: the room itself. To get the best out of whichever speakers and subs anyone uses, it is so important to acoustically treat the room. Fortunately, it is also a cheap upgrade, and even cheaper still if you DIY the panels (real easy).
Mike_WI and Modicen like this.
post #10737 of 10805 Old 08-13-2018, 07:24 AM
MIkeDuke's Avatar
Quoted: 634 Post(s)
Liked: 315
Wow, Kbarnes, is that your room? It looks amazing. I am going to have to check that out. I am still in a Hobbit room and will be for sometime. But like I posted, The SunMersive is still making me grin.
My System
MIkeDuke is offline
post #10738 of 10805 Old 12-18-2018, 12:17 AM
matthewa's Avatar
Originally Posted by jamiebosco View Post
I just had a look and it looks like AXPONA is in April (unless there's 2 of them?) http://www.axpona.com/
@buddhamus I've been waiting for a reply to a few emails as well (though nowhere near as long as you). I know Mark had something VERY big come up a week or so ago so he may be hard to get a hold of at the moment
I sent you a pm but the fact that your posting here basically answered my question anyway lol.......us Aussies seem to have a tough time with Mark
Another Aussie here having a hard time getting a hold of Mark, anyone on the forum had any contact lately with @Mark Seaton , I have an issue (red port light on) I'd like to resolve with my SubM's and have tried calling and email with little luck, I know it's close to Xmas, but have been trying for a few weeks now, and basically going to miss out using these bad boys over the break.
Any ideas form the forum to troubleshoot would also be welcome.
matthewa is offline
post #10739 of 10805 Old 12-18-2018, 01:34 AM
jamiebosco's Avatar
Quoted: 841 Post(s)
Liked: 2114
Originally Posted by matthewa View Post
Another Aussie here having a hard time getting a hold of Mark, anyone on the forum had any contact lately with @Mark Seaton, I have an issue (red port light on) I'd like to resolve with my SubM's and have tried calling and email with little luck, I know it's close to Xmas, but have been trying for a few weeks now, and basically going to miss out using these bad boys over the break.
Sorry I haven't heard back from Mark since October . Just be persistent and email him every day till you get a reply. Which amp do you have? (I assume you meant the PROT light?)
TV: Panasonic P65ST60 AVR: Denon X4000 Speakers: PSA MTM-210C (Centre), PSA MTM-210 (Left & Right), PSA MT-110 (Surrounds) Subwoofers: Dual Seaton SubMersives
jamiebosco is online now
post #10740 of 10805 Old 12-18-2018, 01:51 AM
matthewa's Avatar
Yes the PROT light, auto correct must have got me, I have the upgraded Amp 6000W and the additional slave to run from the master when I upgraded.
matthewa is offline
Seaton Sound , Velodyne Dd 15 Digital Drive Subwoofer 15 Inch Gloss Black , Velodyne , Speaker Systems , New Pac Sni 1 Ground Loop Signal Isolator
