***Official HSU owners/support thread!*** - Page 277 - AVS Forum | Home Theater Discussions And Reviews
 1879Likes
post #8281 of 9432 Old 01-31-2019, 11:58 AM
Invader3's Avatar
Quoted: 109 Post(s)
Liked: 43
Originally Posted by darthray View Post
Sometime, it is worth to just swallow the Blue Pill. And get what you want now
Ray
Thanks. I'm really not in a major hurry, though.
darthray likes this.
Invader3 is offline
post #8282 of 9432 Old 01-31-2019, 04:24 PM
HsuKevin's Avatar
Quoted: 332 Post(s)
Liked: 442
Not sure if I have already made this announcement already, but I have received a few inquiries recently, and we will be attending AXPONA this year. More details to come.
galonzo likes this.
Kevin W.
Hsu Research
Sales and Marketing Representative
HsuKevin is offline
post #8283 of 9432 Old 01-31-2019, 06:10 PM
darthray's Avatar
Quoted: 2619 Post(s)
Liked: 4381
Best way to shop
All the best in your quest.
Ray
darthray is offline
post #8284 of 9432 Old 01-31-2019, 06:57 PM
Calypte's Avatar
Quoted: 27 Post(s)
What about T.H.E. Show in Long Beach, CA, June 7-9, 2019?
HsuKevin likes this.
Calypte is offline
post #8285 of 9432 Old 02-05-2019, 08:43 AM
HsuKevin's Avatar
Quoted: 332 Post(s)
Liked: 442
We are considering it. I don't think we will be able to go this year, though. It's a tricky thing because some hotels isolate bass very well. We found this to be the case at AXPONA. Other places, we've heard the sub from several rooms down, so it makes it a bit difficult to exhibit there. I will likely be at THE Show visiting various rooms, etc.
galonzo likes this.
Kevin W.
Hsu Research
HsuKevin is offline
post #8286 of 9432 Old 02-06-2019, 08:58 AM
mlknez's Avatar
Quoted: 632 Post(s)
Liked: 214
Bringing anything new with you, Kevin?
Media Room: LG oled65c7, Marantz AV8805, Sherbourn 7/2100, Emotiva A-300, Studer A80, Studer Revox b795, Nakamichi RX-202, HTPC, exaSound e38, Sweetvinyl Sugarcube SC-2, (2) Piega P10, Piega Coax Center, (6) Piega AP 1.2, Hsu VTF-15h mk2
Office: Emotiva mini-x A100, Geek Pulse, (2) KEF LS-50, Goldenear FF 4, PC, NAS 130TB
Bedroom: Panasonic TCP55vt35, Marantz NR1200, Dune 3 Prime, (2) Elac Uni-Fi UB5
mlknez is online now
post #8287 of 9432 Old 02-06-2019, 04:53 PM
HsuKevin's Avatar
Quoted: 332 Post(s)
Liked: 442
If we were, I couldn't comment on that bud.
galonzo likes this.
Kevin W.
Hsu Research
HsuKevin is offline
post #8288 of 9432 Old 02-08-2019, 07:20 PM
Quoted: 20 Post(s)
Still toying with the settings on the back of my subs. Not sure what would be best, or if I should plug a port?
2 HSU VTF-15H MK2 in my 800 square foot basement.
Suggestions? Im not as well versed as dialing in dual subs as I thought I was.
DreamCrusher is offline
post #8289 of 9432 Old 02-09-2019, 10:01 AM
Quoted: 67 Post(s)
Liked: 4
Figured I would post this here, too since there's an official Hsu rep that may be able to help :
I just hooked up my VTF-3 MK5 to my Denon 6400 for the first time. I ran audyssey and everything seemed to go fine. The receiver was able to send test signals to the sub with no problem.
However, the sub fails to play anything with the enclosed Hsu test CD including bass heavy tracks.
I went back and manually set all speakers to "small" and expiramented with different crossover settings but nothing seemed to work.
Any ideas why the sub may not be firing?
matpal is offline
post #8290 of 9432 Old 02-09-2019, 12:04 PM
ambesolman's Avatar
Quoted: 1171 Post(s)
Liked: 985
I’d try turning everything off and then on again after 20s or so. It’s likely something in the denon, I’ve had a x4000 for a while and it can act squirrelly sometimes
"Rockbiter" DO SI18 sub build - https://www.avsforum.com/forum/155-d...o-si-18-a.html
Ambesolman's Cleverly Titled Theater build - https://www.avsforum.com/forum/19-de...ter-build.html
ambesolman is offline
post #8291 of 9432 Old 02-09-2019, 12:19 PM
ambesolman's Avatar
Liked: 985
Do it. I’ve always preferred the one port max extension mode for my vtf3 mk3. Digs deeper and is more visceral down low. The versatility of the vtf series is one of the best features.
Calypte likes this.
post #8292 of 9432 Old 02-09-2019, 03:44 PM
Quoted: 47 Post(s)
Liked: 1
Newbie Question
Difference between the HSU mk 2 and later models. Like the VTF3 mk2 vs th3 VTF3 mk 5
I did some searching and will do more
thanks
donindc is offline
post #8293 of 9432 Old 02-11-2019, 04:48 PM
HsuKevin's Avatar
Quoted: 332 Post(s)
Liked: 442
It really has more to do with your room acoustics and personal preference. That is a fairly large room, so I would gather that one port open would probably suit you well. If you do find that you like playing at higher output levels, and you're looking for better dynamic range, you can try 2 ports open/EQ2 mode. Do you have a diagram of your room layout?
Interesting. Check and see if your receiver is in direct mode. If your receiver is in that mode, it will set your speakers to large and disable the sub for CD playback.
thanks
The VTF-3 Mk2 is basically like our VTF-2 Mk5. Similar size enclosure, dual 3" ports, 350w RMS amp, 12" driver. The VTF-3 Mk3, is a larger enclosure (similar volume to the VTF-3 Mk5 HP), and has dual 4" ports and a 12" side firing driver. In terms of performance, it's fairly similar to the VTF-3 Mk2, but more efficiency in the ultra deep bass. So it would be able to play louder and cleaner below 20 Hz. The VTF-3 Mk5 HP has a similar enclosure to the VTF-3 Mk3, but it has a 15" driver and a 600w amp. So it would be able to play significantly louder and cleaner across the board. Almost like having two of the VTF-3 Mk2's put together.
galonzo and donindc like this.
Kevin W.
Hsu Research
HsuKevin is offline
post #8294 of 9432 Old 02-13-2019, 06:25 AM
Quoted: 56 Post(s)
After about 10 days of nagging my wife, I finally ordered my VTF 3 MK5 this morning. I am beyond excited and can't wait to get it. I'm stepping up from Dayton 1200 so this should be a pretty big change. I can't wait for this big boy to show up!
Tom C, galonzo, djdel002 and 1 others like this.
Denon 1400h - Emotiva C2 center - 2x S55's LR - 2x S15's Surround - HSU VTF-3 MK5 Bass
sopel10 is offline
post #8295 of 9432 Old 02-13-2019, 06:29 AM
raistline's Avatar
Quoted: 197 Post(s)
Liked: 175
Wow, that will be a tremendous improvement over the Dayton. You will suddenly want to re-watch every single movie you own that even has a modicum of bass. Congrats on the purchase, and my condolences to your wallet.
Quick top 5 movies you must watch with the new sub.
1: Tron Legacy
2: Mad Max (new version)
3: Cloverfield
4: How to Train Your Dragon
5: Scott Pilgrim Vs. The World
Tom C and galonzo like this.
raistline is online now
post #8296 of 9432 Old 02-13-2019, 07:00 AM
Quoted: 56 Post(s)
1: Tron Legacy
3: Cloverfield
I'm very new to the "sound" world. I just put my setup together in early December so I felt like I needed to re-watch movies even then. I will definitely give a few of those a try, Thank you!
sopel10 is offline
post #8297 of 9432 Old 02-14-2019, 04:51 AM
modenacart's Avatar
Quoted: 282 Post(s)
Liked: 181
When I had that problem it was the AVR not sending a high enough voltage signal to wake the sub up. I switched the power switch on the sub from auto to on and that corrected it.
modenacart is offline
post #8298 of 9432 Old 02-15-2019, 04:53 PM
HsuKevin's Avatar
Quoted: 332 Post(s)
Liked: 442
That's certainly possible. I would check the LED on the back of the sub. If it turns from red to green when a signal is sent to it, then the sub is triggering.
galonzo likes this.
Kevin W.
Hsu Research
HsuKevin is offline
post #8299 of 9432 Old 02-15-2019, 08:27 PM
PG55's Avatar
Quoted: 232 Post(s)
Liked: 38
Soon to be New ULS MK15 owner
Greetings,
I currently have a one Monolith 10 in my 4000^3 room with WAF preventing me from going with 2 and also have size restrictions. After exhaustive research and Kevin from HSU,s magnanimous help I have decided on a ULS MK15. The Monolith is an outstanding sub but just not enough to fill my room with the depth and punch I enjoy with my home theatre. So I am going to go with 1 ULS 15. I will check back in after it arrives next week.
PG55
LG-OLED 65C8PUA
Marantz-SR5012
Sony-UBP X-800, Roku Ultra 4K
Front L&R-Monitor Audio Silver 300's, Center-MA Silver C350, Surrounds-MA Silver FX
Sub Woofers-Paradigm Reference Millenia (2)
PG55 is offline
post #8300 of 9432 Old 02-17-2019, 01:24 PM
BornSlippyZ's Avatar
Quoted: 2113 Post(s)
Liked: 2162
I haven’t posted here in a bit. Life kinda got in the way lol! But I am moving to a new to me home and the living room is an open concept/bigger room than what I am in now. I have 3 HSUs 2 ULSs and one VTF15hmk2 and I am curious what the sound is going to perform? Anyhow I recently watched Bohemian Rhapsody and I will say this disk begs to get played loud! The subs really perform at the last act of the movie and this is my new demo disk!
Oh and my new home is spaced farther so I think my neighbors would appreciate it that lol!
Tom C, galonzo and HsuKevin like this.
BornSlippyZ is offline
post #8301 of 9432 Old 02-20-2019, 06:06 AM
Administrator
Administrator
Mike Lang's Avatar
Quoted: 1737 Post(s)
Liked: 1390
I have a pair of VTF-15H subs set to auto to come on w/ the receiver but they are not really needed when watching "daytime TV" news/talkshow stuff.
I'm toying with the idea of adding a smart plug to each sub so that I can keep them off until needed or even just have one at a time to reduce the mileage on them.
I've been using this one to power on my ButtKicker BKA1000 amp for years.
Are there any drawbacks to using a smart plug on these subs?
Please use the report post button to alert staff to problematic posts. Never quote or respond to them yourself.
Always post about products, never post about other members.
Join the AVS Forum Club and help support the site.
AVS Forum is not sponsored by or in any way affiliated with AV Science Inc.
Mike Lang is offline
post #8302 of 9432 Old 02-20-2019, 07:31 AM
Quoted: 56 Post(s)
My brand new VTF-3 MK5 showed up yesterday. After very quick setup and a little bit of music, my first movie was Bohemian Rhapsody.
Oh, My, God...not only the movie was great, but my chest vibrating when they played "live" music was just amazing. What a huge step up from my little dinky Dayton 1200.
This thing is huge, I knew it was going to be big, but it really surprised me.
I can't wait to play with it more and watch more movies tonight!
Edit: As a side note - I would have never guessed that PS4 doesn't support CD's....so couldn't use the demo that came with the sub.
sopel10 is offline
post #8303 of 9432 Old 02-20-2019, 08:59 AM
Writer & Reviewer
JimWilson's Avatar
Quoted: 2493 Post(s)
Liked: 3991
There shouldn't be an issue as it's mostly a pass-through device. I don't know if the wi-fi antenna will introduce any noise to the A/C line that the HSU amp might pick up, but that would only be interference and not a danger to the amp itself. Kevin will likely reply, but I can't see anything about those devices that could cause a problem.
Mike Lang likes this.
If you take yourself too seriously expect me to do the exact opposite.
BTW, did you really need to quote the entire post?
JimWilson is offline
post #8304 of 9432 Old 02-20-2019, 11:14 AM
Quoted: 47 Post(s)
Liked: 1
thanks
Audioholics has a summary of the improvements of the newer vtf-2 mk-5 over the previous model for what it is worth.
donindc is offline
post #8305 of 9432 Old 02-20-2019, 11:16 AM
Quoted: 47 Post(s)
Liked: 1
UPGRADE OPTIONS - any recommendations?
Room is about 10x20x8’ bricks inside drywall, four bass traps, carpet
I have a HSU stf-1 with blown out circuits (capacitors?), and a working STF-2
Option 1 – get stf-1 fixed (for $125 approx)
Option 2 – buy a used STF-2 ($280 shipped)
Option 3 – get a new VTF-1 mk-3 ($450? or so shipped)
Option 4 – new VTF-2 mk-5 ($600? Shipped)
Stf-1 – will add nothing to the sound – probably would make it sound worse
Stf-2 - will make double stf-2s but both would be 4 years old or older – bound to die at some point and not as good sounding as newer VTFs. But would save $150 or so
VTF-1 – almost matches the STF-2 and will add deeper bass. Could then upgrade to second VTF-1 in future
VTF-2 – full bass coverage, wouldn’t blend well with stf-2 but if doubled eventually would sound the best. Might be too large for the room, although I could put it next to couch and might work well as an end table.
Leaning toward the VTF-1 since budget is important also. Could stretch for a VTF-2 but would probably wait longer to save up money
donindc is offline
post #8306 of 9432 Old 02-20-2019, 01:53 PM
don851's Avatar
Congrats! I actually just received mine last night as well. Time to rewatch some select movies.
galonzo, HsuKevin and sopel10 like this.
don851 is offline
post #8307 of 9432 Old 02-20-2019, 04:50 PM
HsuKevin's Avatar
Quoted: 332 Post(s)
Liked: 442
Originally Posted by PG55 View Post
Greetings,
PG55
Thank you so much! It was my pleasure. If you have any other questions, let me know.
Don't think there should be any problems, but I would forego using the smart plugs. Whether you turn off the power to the unit or leave it in auto, it likely won't change the lifespan of the sub.
I think I recall some consoles not being able to play it. You can try ripping the CD and see if you can play the files via USB.
Good question. How do you feel with the single STF-2 so far? What are your settings on it? 10x20 is not terribly large, so if you get a second VTF-1 or STF-2, that may be OK.
galonzo likes this.
Kevin W.
Hsu Research
HsuKevin is offline
post #8308 of 9432 Old 02-20-2019, 07:58 PM
Quoted: 47 Post(s)
Liked: 1
"Good question. How do you feel with the single STF-2 so far?"
Pretty good. I should try different locations but pretty much need to leave it near the right speaker. I suppose that is the key question - do I like the stf-2 so far. I don't have anything but the stf-1 to compare it to.
"What are your settings on it?"
See pic -just kind of twisted till it sounded good without reading up on it.
"10x20 is not terribly large, so if you get a second VTF-1 or STF-2, that may be OK."
Is it really true that different subs won't sound good together if not pretty close? Would a stf-2 paired with a vtf-2 sound like an stf-2 or worse? - update - many threads about this - if the woofers are two different it makes it hard to set up, maybe not workable to sound good at all. Close to the same or same is better.
donindc is offline
post #8309 of 9432 Old 02-21-2019, 12:35 PM
vlayton's Avatar
Any demand for old Hsu TN1220 tube sub?
I have an old HSU TN1220 cylinder sub that I'd like to get out of the house. Any demand for these anymore? Never liked the sound from the Hsu but that may be because I bought some used amp from them. Bass was not tight and speaker tender to "blart", a made-up term to describe the speaker rumblings. Not seeing recent sales so no idea if there is still a market for these.
vlayton is offline
post #8310 of 9432 Old 02-22-2019, 12:13 PM
Quoted: 47 Post(s)
Liked: 1
loose subwoofer cord jack - is this easy to fix? if cord gets touched it stops working, if I wiggle it a little it starts again. It is the LFE jack on the back of the STF-2
Ascend S1 mains with Hsu STF-2, HSU VTF-1 Mk 3 and old HK receiver
donindc is offline
Hsu Research , Hsu Vtf3 Mk4 , Hsu Vtf2 Mk4 , Hsu Research Hb1 Mk2 , Hsu Research Vtf 2mk3 , Hsu Research Hc 1 Mk2 , Hsu Vtf 15h Subwoofer , Hsu Research Uls 15 Subwoofer , Hsu Research Stf 1 Subwoofer 150 Watt
