Suggested Buttkicker (BKA) crossover settings?... What do you use? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 08-02-2007, 06:41 AM - Thread Starter
DrSurge's Avatar
I am wondering what others are using for their Buttkicker crossover settings and also if anyone can explain the difference between the two switches and one dial.
The documentation suggestes 80hz on the dial and turning high pass filter on... 80hz seems like it is a little high... seem to get a lot of shaking when you don't want it.
Also, if you have any suggested output levels -- obviously this is dependent on your receiver output settings, however if you can give an example of a movie and how hard you feel a particular sound -- like "saving private ryan, scene 10, you should feel machine gun but no door closing" something like that.
-John
DrSurge is offline
post #2 of 12 Old 08-02-2007, 04:41 PM
Ikari Warrior's Avatar
Quoted: 190 Post(s)
Liked: 110
Good question, I was wondering too. I've been moving mine around alot lately, I like it when I can feel gunshots and such in a movie, but then you often get vibration when you don't want it like during background music. I'd be interested to hear what settings others are using.
Xbox Live gamertag: Ikari Warrior
Playstation Network ID: IkariWarrior
Ikari Warrior is offline
post #3 of 12 Old 08-03-2007, 10:18 AM
91BlckGT's Avatar
I have mine crossed over at 50hz, which is as low as the x-over in my amp will go. It's a pretty good setting for movies.
My Theater Build Thread Loganed 11/27/08
91BlckGT is offline
post #4 of 12 Old 08-31-2007, 08:49 AM
John Ballentine's Avatar
Quoted: 96 Post(s)
Liked: 97
I now run my (6) shakers at 40hz. Seems to work pretty good. (I use to run them at 80hz)
John Ballentine is offline
post #5 of 12 Old 08-31-2007, 11:21 AM
jaseman's Avatar
Quoted: 34 Post(s)
I run mine at 40hz. If you only want to feel the really low effects...thus the LFE... then running them any higher will cause them to vibrate whenever anything higher than 40hz is sent to the sub-out. You also need to "probably" set the gain/volume control on the amp running the shakers to relatively low. Otherwise when something comes across at 40hz or lower and it is too "loud" too many watts, it may cause your amp to clip or the circuit breaker on the amp to pop and need resetting.
Vizio M80-C3 - Denon AVR-X4200w - Samsung UBD-K8500 - Roku 4 - Charter Spectrum - Logitech Harmony 700 Remote
Axiom VP150-v2 Center - M60-v2 Front Left & Right - 4>QS8-v2 Quad Polar Surrounds - EP500 Front Sub - DIY 12" Rear Sub
jaseman is offline
post #6 of 12 Old 08-31-2007, 02:39 PM
lanion's Avatar
before I had a decent sub I ran mine at about 55ish hz, but now I have it at 40hz (minimum with the buttkicker amp). Feeling those low frequencies without hearing them just as loud is unpleasent -- and feeling rumble at 60+hz also feels off.
lanion is offline
post #7 of 12 Old 08-31-2007, 04:11 PM
Soundood's Avatar
We run our demos at 40hz.
"Did you make 'em fine-ass-soundin' speakers over there what would sound gooder than hell comin' out of the back of my truck-boat-truck?"
-Early Cuyler. Poet Liquoreate
Soundood is offline
post #8 of 12 Old 08-31-2007, 04:43 PM
craig john's Avatar
Quoted: 1156 Post(s)
Liked: 1419
I run my Crowson transducer at 40 Hz. Any higher than that and the effect becomes overdone and inappropriate, IMO.
Craig
Lombardi said it:
"Perfection is not attainable, but if we chase perfection we can catch excellence."
My System
craig john is offline
post #9 of 12 Old 09-07-2007, 12:22 PM
jongig's Avatar
Quoted: 18 Post(s)
I have my two BKA1000 Buttkicker amps set low and I've recently had a thought. When listening to music that has some lows I can hear the Buttkickers in the 4 chairs and I've been considering adding better isolation to the 4 chairs so that the vibrations stays out of the floor. The Berkline chairs should have been made with better isolation I think.
john
jongig is offline
post #10 of 12 Old 10-21-2007, 09:53 AM
m_tyson's Avatar
recently got the kit and have 1 buttkicker for a rather long (13') and soft couch. after experimenting, i have left the crossover at 45, with the amp at 50%. it's so real, when friends have watched movies and felt the shake they always believed it came from the subwoofer (not a chance) not an attached shaking device. highly recommend the kit!
m_tyson is offline
post #11 of 12 Old 10-21-2007, 11:03 AM
jpmst3's Avatar
Quoted: 196 Post(s)
Liked: 314
I run mine at 60Hz. It really depends on what kind of movie, for action I like 60Hz, for others 40-50.
Joe = LFE Addict
Past Builds: 24" LMS-5400 cube, Anarchy 25Hz Tapped Horn, Danley DTS-10 kit, BFM AutoTuba, BFM THT, BFM THT-LP
Joe's LOWARHORN build, Dual LMS-5400 Ultra Endtables build
jpmst3 is offline
post #12 of 12 Old 10-27-2007, 08:25 PM
Dan Hitchman's Avatar
Quoted: 4457 Post(s)
Liked: 2507
What about leaving the low pass filter off? I understand leaving the high pass filter on, but why would you want the low pass filter on?
What settings do you guys use?
Dan
Listen up, studios! Dolby Atmos Lite™ print-outs must stop!!
Dan Hitchman is online now
