Software to Print to HDV 1080 24p Tape - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 02-09-2017, 12:21 AM - Thread Starter
latreche34's Avatar
Quoted: 148 Post(s)
Liked: 66
Hi everybody I want to do some HDV tape printing in 24p using my Sony HVR-M15AU deck which is capable of recording progressive, What software is capable of printing progressive ? I have Sony Vegas and I only have the option to print 1080 60i or 50i. My files are rendered as HDV 1080x1440 24p and I want to print them as they are without interlacing them.
latreche34 is offline
post #2 of 2 Old 04-25-2017, 11:38 AM
panavised's Avatar
Liked: 9
You've probably resolved this problem by now, but Adobe Premiere Pro should be able to print HDV 24p to tape.
You can record your edited sequence onto videotape directly from your computer, for example, to create a master tape. When you start a new sequence, you specify the format and quality for the videotape in the Editing Mode area of the New Sequence dialog box. (Adobe Help)
HDV 24p is an option in the Editing Mode section, so I see no reason why you couldn't print 24p to tape.
panavised is offline
Reply HDTV Software Media Discussion
