Best Conversion Settings for BDMV from a 23.976 File - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 06-04-2017, 07:34 PM - Thread Starter
konfusion's Avatar
Im new to bluray burning and am a bit lost as far as quality is concerned. I want to convert 1080p 23.976 files from the Mp4 and MKV format to BDMV. I am using TmpgEnc Video Mastering Works and the Only Options i have is 1920x1080 29.97 or 24 or 23.976 Out of these three which is going to produce the best quality? Should i keep it at 23.976 or up it to 29.97 also if i have a file that is 29.97 and the quality is better at 23.976 should i change that? i want to have the best quality on a 25-50gb Disc.
konfusion is offline
post #2 of 2 Old 06-04-2017, 08:22 PM
Super Moderator
teachsac's Avatar
Quoted: 1254 Post(s)
Liked: 2061
Your original thread was moved here and has received answers. Please note the forum descriptor. This area is not for discussion of copying software.
https://www.avsforum.com/forum/26-hom...-playback.html
Please use the report post button to alert staff to problematic posts. Never quote or respond to them yourself.
Panasonic DP-UB820 -> Yamaha CX-A5100 -> Sony XBR-75X940C; Mediabridge 6' and 15' HDMI cables.
teachsac is offline
Closed Thread HDTV Software Media Discussion
