Cheap easy movie storage - AVS Forum | Home Theater Discussions And Reviews
 4Likes
  • 2 Post By unretarded
  • 1 Post By unretarded
  • 1 Post By frankwp
post #1 of 3 Old 12-28-2017, 06:01 PM - Thread Starter
unretarded's Avatar
Quoted: 1687 Post(s)
Liked: 2075
Less than 20 bucks and a hour of work...........
There are lots of variants of this on youtube.
I just built a floor to ceiling one and soo far it is great !!!!!!
Loading 700 plus movies in alphabetic order takes way longer than building the shelf...LOL....
teachsac and Shooter33 like this.
Link to Stereo Integrity SI HT 18 sub build......https://www.avsforum.com/forum/155-di...-pedestal.html
Speakers and subs for sale...https://www.avsforum.com/forum/209-au...kers-subs.html
unretarded is offline
post #2 of 3 Old 11-07-2018, 12:28 AM - Thread Starter
unretarded's Avatar
Liked: 2075
Observations from having this for almost a year now...…..
Still working excellent and with only 2 screws holding at the top super low room impact.
Problems or things I would do different,...all completely my fault,.....its a huge sound reflector, it made a difference in the room for sure as it is a very reflective surface. So be careful with placement.
Same issue with reflectivity due to light...….hundreds of shiney surfaces all in one spot made a difference in my blacked out room, both on screen and out of the corner of my eye...….once again be careful with location.
Would I build another one....YES and I plan on it already......there is no other solution as cheap and easy out there...….just be careful where you put it.
shimonmor likes this.
post #3 of 3 Old 01-12-2019, 11:07 AM
Quoted: 79 Post(s)
Liked: 45
That's a great solution. It's actually better than conventional shelves cause the discs will stay upright even if the shelf is only partially full.
unretarded likes this.
frankwp is offline
Reply HDTV Software Media Discussion
