Industry Insiders Q&A Thread: only Questions to insiders please - Page 92 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #2731 of 4623 Old 09-27-2006, 09:18 AM
Schlotkins's Avatar
Originally Posted by amirm
Do you mean who makes it?
That is correct - and a model number if you have it. Basically, I'm trying to see if that drive would work in a PC. Probably not but...
I thought HP was going to have PCs with HD-DVD drives by now, but maybe I was mistaken. Is AACS the hold up? If so, any idea on the final agreement?
Since I'm really bugging you already, OCUR/Cablecard stuff still on target for Q1?
Thanks Amir and to all the insiders for the info.
Chris
Schlotkins is offline
post #2732 of 4623 Old 09-27-2006, 09:21 AM
TerryMathews's Avatar
Originally Posted by max-pain
No, it isn't.
Xbox 360's AV out connector pinout:
1 Red Gnd
2 Green Ground
3 Red (Cr in HDTV mode)
4 Green (Y in HDTV mode)
5 Composite Gnd
6 Blue Ground
7 Composite (Sync in RGB mode)
8 Blue (Cb in HDTV mode)
9 H-sync Gnd
10 V-sync Gnd
11 H-sync (VGA Mode)
12 V-sync (VGA Mode)
13 Audio-R Gnd
14 Audio-L Gnd
15 Audio-R
16 Audio-L
17 Switching voltage (for SCART pin-8 )
18 CBL-ID1
19 Blanking Signal (for SCART pin-16)
20 CBL-ID1.1
21 Unknown
22 CBL-ID2
23 Unknown
24 CBL-ID2.1
25 Optical - Audio (SPDIF)
26 CBL-ID3
27 Optical - Gnd (SPDIF)
28 CBL-ID3.1
29 Optical - +5V
30 See J2B1 or J8C1
Setting Cable ID:
ID1-1.1 = VGA mode enabled
ID2-2.1 and ID3-3.1 = RGB (SCART) mode enabled
ID3-3.1 = HDTV (Y/Cb/Cr) mode enabled
ID2-2.1 = Composite (TV) mode enabled
HDMI:
1 TMDS Data 2+
2 TMDS Data 2 Shield
3 TMDS Data 2-
4 TMDS Data 1+
5 TMDS Data 1 Shield
6 TMDS Data 1-
7 TMDS Data 0+
8 TMDS Data 0 Shield
9 TMDS Data 0-
10 TMDS Clock+
11 TMDS Clock Shield
12 TMDS Clock-
13 CEC
14 No Connect
15 DDC Clock
16 DDC Data
17 Ground
18 +5V Power
19 Hot Plug Detect
20 SHELL
No offense intended, but you don't know that. There are not one, but two pins that you don't know what they do. All it takes is one pin to completely change the pinout on a connector using tri-state buffers. Ex: Connect pins 21 and 23 together and pins 1-20 change to HDMI pinout.
Not saying that's how it works, but it's possible.
TerryMathews is offline
post #2733 of 4623 Old 09-27-2006, 11:42 AM
seanb61's Avatar
Quoted: 23 Post(s)
amirm,
Now that the Xbox 360 has been priced, officially by MSFT, can you tell us any further details that you haven't been able to talk about up to this point?
Specifically, in the press briefing Peter Moore said Movies AND games will be output at "Native 1080p" will the only way to get this be via component or VGA meaning that there still isn't and news on an HDMI adaptor of some sort yet?
Oh and for those of you who didn't see it http://biz.yahoo.com/prnews/060927/sfw094.html?.v=63
seanb61 is offline
post #2734 of 4623 Old 09-27-2006, 11:56 AM
amirm's Avatar
Quoted: 1334 Post(s)
Liked: 749
Originally Posted by seanb61
amirm,
Our solution for Xbox customers is to use VGA and component as appropriate. As we have announced, these interfaces support 1080p resolution. And you are correct on no news on HDMI output.
amirm is offline
post #2735 of 4623 Old 09-27-2006, 12:11 PM
AFH
AFH's Avatar
Amir,
In a post above you responded to a poster who asked about 1080p out for movies for the add-on by saying that "But I don't yet have a definitive answer to provide here". Is there an answer coming that will address the HDMI issue and will that answer come before the add-on is released on the 24th of Nov?
"I'm going to call them scallywags" - Ollie
Xbox Live: Stunt1on1
AFH is offline
post #2736 of 4623 Old 09-27-2006, 12:11 PM
lymzy's Avatar
Could any insider comment on the rumor that HD DVD camp plan to boost the bandwidth to 40Mbps?
HDPLEX
lymzy is offline
post #2737 of 4623 Old 09-27-2006, 12:19 PM
amirm's Avatar
Liked: 749
Originally Posted by AFH
Amir,
Those are two seperate questions. I hope to bring a more definitive answer for 1080p frame rates over VGA/component. In an interesting twist, TVs/Monitors provide much wider range of refresh rates/resolutions than they do over HDMI. Right now, I can say that the system supports ATSC defined resolutions/rates. What I am trying to find out is whether we can fully support other combinations which are supported in today's displays.
The answer is complicated because gaming and DVD/HD DVD requirements are impacted differently.
amirm is offline
post #2738 of 4623 Old 09-27-2006, 12:28 PM
amirm's Avatar
Liked: 749
OK, since I have used up my budget of "no comments" :), I guess I have to answer this one. The drive is built by TSST which is the joint Samsung/Toshiba optical manufacturing plant (same place that also makes BD drives :)). For a sense of its performance, you can look at Toshiba laptops. The drive is more performant and has better characteristics than the NEC drive used in Toshiba 1G players.
No, there is no AACS hold up. Niveous (http://www.niveus.com/) announced an HD DVD media center PC at CEDIA (actually two models).
Chris
I don't keep up with their schedules Chris. But I know they are working hard to get it done :).
amirm is offline
post #2739 of 4623 Old 09-27-2006, 12:30 PM
RobertR1's Avatar
Quoted: 199 Post(s)
Liked: 304
Amir,
How will the add on handle DD+ and TrueHD? Internal decode and out via PCM?
Robert.
RobertR1 is offline
post #2740 of 4623 Old 09-27-2006, 12:31 PM
chinch's Avatar
Amir - why can't a DVI adapter be released for 360 (non-hdcp)? is there technical reasons preventing this... even though it's nit-picking, it would be useful for PJs vs VGA (and help those with HDMI/DVI switchboxes in use).
DVD's are about movies & people watch them in living rooms, how many people actually use their computer drives to sit and watch movies- Bluray's Andy Parsons
chinch is offline
post #2741 of 4623 Old 09-27-2006, 12:33 PM
AFH
AFH's Avatar
Right. I understand completely :) . So you're saying that there will be answer as to whether HD DVDs can be played on the 360 add-on using HDMI?
AFH is offline
post #2742 of 4623 Old 09-27-2006, 12:49 PM
BenDover's Avatar
question to insiders:
do you think we need a separate xbox 360/hd dvd addon insiders q&a thread? :D;)
BenDover is offline
post #2743 of 4623 Old 09-27-2006, 12:50 PM
amirm's Avatar
Liked: 749
No :). I meant the answer to whether you can do things like 24p over VGA.
amirm is offline
post #2744 of 4623 Old 09-27-2006, 12:51 PM
BenDover's Avatar
amir, when did microsoft start seriously planning the hd dvd addon?
were strategic purchasing/supply arrangements put in place well in advance to secure drives/blue lasers?
BenDover is offline
post #2745 of 4623 Old 09-27-2006, 12:51 PM
amirm's Avatar
Liked: 749
I hope not as that would surely mean that I have to go and get a gaming handle :D.
amirm is offline
post #2746 of 4623 Old 09-27-2006, 12:54 PM
amirm's Avatar
Liked: 749
Soon after we announced support for HD DVD as a format last year. And yes, securing the drive was the #1 criteria. This is why we announced the option at CES, rather than before....
amirm is offline
post #2747 of 4623 Old 09-27-2006, 12:55 PM
amirm's Avatar
Liked: 749
Going to lunch now. Someone else answer questions until I get back :D.
amirm is offline
post #2748 of 4623 Old 09-27-2006, 01:07 PM
AFH
AFH's Avatar
LOL! I'm going to keep trying to get an answer as to whether there will be an answer so that we all can get an answer :D . So, Amir will there be answer from MS as to whether or not the 360 add-on will be able to play HD-DVDs over HDMI? How does that sound ;) .
AFH is offline
post #2749 of 4623 Old 09-27-2006, 01:10 PM
briankmonkey's Avatar
I'd like to know as well. Esecially for the audio and it not being crippled.
briankmonkey is offline
post #2750 of 4623 Old 09-27-2006, 01:11 PM
RobertR1's Avatar
Quoted: 199 Post(s)
Liked: 304
Amir,
When can we get the specs for the add on? I believe many people want answers to the how the advanced audio codecs will be handled but those questions tend to get skipped over.
Robert.
RobertR1 is offline
post #2751 of 4623 Old 09-27-2006, 01:26 PM
DocX's Avatar
Amir,
I have one question (I signed up especially for that ;) ):
I have an US console but I'm located in Europe at the moment (and I took my box along). Can I just go to a shop here, purchase an european HDDVD AddOn and hook it up to my US X360?
Or do I have to wait until I get back to the states (can take some time) due to some restrictions (HW or SW wise) that prevent operation of an european AddOn with my Xbox?
DocX
DocX is offline
post #2752 of 4623 Old 09-27-2006, 01:45 PM
nilsp's Avatar
No it will not. As you know, the current US standard for digital TV is MPEG-2 so the system simply records that stream unchanged.
When MPEG4 is introduced, will it record that too unchanged?
NilsP
Life is better in HD.
nilsp is offline
post #2753 of 4623 Old 09-27-2006, 02:29 PM
amirm's Avatar
Liked: 749
Answer is simple: NO. There is no HDMI option. Only output options are VGA/Component.
amirm is offline
post #2754 of 4623 Old 09-27-2006, 02:31 PM
Schlotkins's Avatar
Chris
post #2755 of 4623 Old 09-27-2006, 02:32 PM
Will there be 5.1 or 7.1 analog output option available then?
post #2756 of 4623 Old 09-27-2006, 02:35 PM
AFH
AFH's Avatar
AFH is offline
post #2757 of 4623 Old 09-27-2006, 03:05 PM
d2thez's Avatar
Amir,
It is great somebody finally admitted there is no HDMI option. I would, however, like to phrase it a bit different and ask a similar question: Is the 360 hardware capable (out of the box) of supporting HDMI at all, forgetting all manner of potential dongles with built in Analog-to-Digital converters and HDCP chips?
Thanks so much for the great info thus far Amir!!
d2thez is offline
post #2758 of 4623 Old 09-27-2006, 03:09 PM
builty's Avatar
Amirm, you seem to be dancing around the question of whether the XBox addon drive could be connected to a PC. I guess you guys don't want this to happen due to subsidising the cost? Stand alone PC drives seem to be a whole lot more expensive than the addon.
Specifically:
1. can the addon be plugged into a PC via USB and function?
2. can it be removed from the case and inserted into a PC to function (IDE or SATA interface?)
Even if you choose not to answer, no doubt people will attempt such things shortly after release and we'll find out anyway :)
builty is offline
post #2759 of 4623 Old 09-27-2006, 03:24 PM
TheLion's Avatar
Liked: 30
Amir, does the drive inside your 360 HD-DVD addon integrate the necessary AACS keys for itself or are those handled in the control chips outside the drive? (I think looking at my last few questions you get the point behind this one ;) )
What are your comments about this poll:
https://www.avsforum.com/avs-vb/showthread.php?t=727508
There are much more HTPC/MCE users going to/"who would like to :rolleyes: " buy and use the 360 HD-DVD addon than xBox 360 owners... (note: this poll is NOT from the HTPC forum. Therefor I assume at least as many xbox 360 owners reading it or participating in it than HTPC users - just to point out the statistical value of the data...)
GREAT choice/decision about the King Kong bundle btw!
Thank you very much!
TheLion is offline
post #2760 of 4623 Old 09-27-2006, 03:38 PM
Shuley's Avatar
Is HD-DVD getting more studio support? If so, which studio's have signed on or are planning on signing on? Sorry if it's been asked before but I don't care to read 87 pages about video codes.
Shuley is offline
Closed Thread HDTV Software Media Discussion
