Blu-ray, HD-DVD & HD Broadcasts(H.264 & MPEG-2) Screenshots*BIG FILES* - Page 67 - AVS Forum | Home Theater Discussions And Reviews
post #1981 of 2128 Old 07-28-2008, 12:12 AM
stumlad's Avatar
Quoted: 147 Post(s)
Liked: 60
Here's some shots from Dawn of the Dead. This was put out by Universal during the summer of 2007 and was probably the best catalog release as far as PQ goes (judging by the ones I own). Definitely not DNR'd
stumlad is offline
post #1982 of 2128 Old 07-28-2008, 01:10 AM
stumlad's Avatar
Quoted: 147 Post(s)
Liked: 60
Originally Posted by lgans316 View Post
I agree but I still have no idea as to why the reviewer at avforums gave a very low score.
http://www.avforums.com/movies/index...tlereview=9005
Wow. They gave it a really low score. I do agree with the overblown whites comment. Also some of the darker scenes aren't as good looking, but you can still see pretty good detail. as you can see from their faces, they have texture... even in the dark scenes you can see this texture...
I would give it an 8 or 8.5 /10 for PQ, It would be closer to 9.5 if it werent for some of those issues. But a 5/10.. no way...
stumlad is offline
post #1983 of 2128 Old 07-28-2008, 11:18 PM - Thread Starter
Xylon's Avatar
Sometimes it really helps if these so called "reviewers" have the proper equipment watching these movies.
Xylon is offline
post #1984 of 2128 Old 08-01-2008, 10:35 AM
stumlad's Avatar
Quoted: 147 Post(s)
Liked: 60
Also helps if they watch the whole movie. My guess is that they dont.
stumlad is offline
post #1985 of 2128 Old 08-01-2008, 10:39 AM
stumlad's Avatar
Quoted: 147 Post(s)
Liked: 60
Not sure if anyone has already done captures for this movie. Either way, here are a few
stumlad is offline
post #1986 of 2128 Old 08-01-2008, 10:52 AM
Kram Sacul's Avatar
Looks slightly better than the average Universal catalog title. Slight EE.
Kram Sacul is offline
post #1987 of 2128 Old 08-13-2008, 01:31 AM
gracie20's Avatar
Hello. Thank You for this infomation. Please tell me more about Blu Ray Disc.
Gracie Sh
gracie20 is offline
post #1988 of 2128 Old 08-19-2008, 01:19 AM - Thread Starter
Xylon's Avatar
Escape From New York
DVD
HDNET Mpeg-2
Code:
File Size Processed: 12.78 GB, Play Time: 01h:39m:06s
1920 x 1080, 29.97 fps, 65.00 Mbps (17.56 Mbps Average).
Average Video Quality: 71.51 KB/Frame, 0.28 Bits/Pixel.
AC3 Audio: 3/2 Channels (L, C, R, SL, SR) + LFE, 48.0 kHz, 384 kbps.
Dialog Normalization: -31.0 dB, Center Mix Level: -3.0 dB, Surround Mix Level: -3.0 dB
0 of 178222 video frames found with errors.
0 of 185833 audio frames found with errors.
0 corrupted video bytes in file.
0.000000 seconds of video timestamp gaps.
0.000000 seconds of audio timestamp gaps.
EU Blu-ray
Code:
        Total   Video
Escape From NY                                                  AVC     1:38:56 20,278,026,240  24,024,090,318  27.33   23.00   DTS-HD Master 5.1 1974Kbps (48kHz/16-bit) DD AC3 5.1 640Kbps
DISC INFO:
Disc Size:      24,024,090,318 bytes
Protection:     AACS
BD-Java:        No
PLAYLIST REPORT:
Length:         1:38:56 (h:m:s)
Total Bitrate:  27.33 Mbps
Description:
FILES:
Name            Size            Length          Time In         Time Out
00000.M2TS      20,278,026,240  1:38:56.041     0:00:00.000     1:38:56.041
VIDEO:
Codec               Bitrate         Description
MPEG-4 AVC Video    22997 kbps      1080p / 24fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         1974 kbps       5.1 / 48kHz / 16-bit / 1974kbps (DTS Core: 5.1 / 48kHz / 16-bit / 1536kbps)
Dolby Digital Audio             English         640 kbps        5.1 / 48kHz / 640kbps
Dolby Digital Audio             English         224 kbps        2.0 / 48kHz / 224kbps
CHAPTERS:
Number          Time            Length          Avg Video Rate  Max 1-Sec Rate  Max 1-Sec Time  Max 5-Sec Rate  Max 5-Sec Time  Max 10Sec Rate  Max 10Sec Time  Avg Frame Size  Max Frame Size  Max Frame Time
1               0:00:00.000     0:12:47.375     18,435 kbps     33,759 kbps     00:04:32.042    32,606 kbps     00:04:28.167    31,877 kbps     00:04:24.042    96,016 bytes    378,313 bytes   00:03:53.708
2               0:12:47.375     0:07:58.250     22,481 kbps     32,645 kbps     00:20:13.708    31,904 kbps     00:20:09.667    30,495 kbps     00:20:06.833    117,089 bytes   313,800 bytes   00:13:20.542
3               0:20:45.625     0:11:44.458     20,798 kbps     33,305 kbps     00:21:24.542    31,982 kbps     00:21:20.875    31,150 kbps     00:21:19.125    108,322 bytes   303,635 bytes   00:21:19.167
4               0:32:30.083     0:06:39.667     23,580 kbps     34,071 kbps     00:38:32.125    32,588 kbps     00:38:28.125    32,059 kbps     00:38:23.083    122,812 bytes   382,907 bytes   00:36:33.958
5               0:39:09.750     0:07:38.375     22,343 kbps     36,957 kbps     00:44:36.042    32,529 kbps     00:39:53.667    32,371 kbps     00:39:51.792    116,369 bytes   357,982 bytes   00:43:11.000
6               0:46:48.125     0:08:58.875     25,169 kbps     33,698 kbps     00:54:59.292    32,399 kbps     00:52:08.708    32,191 kbps     00:52:04.208    131,090 bytes   349,847 bytes   00:50:36.250
7               0:55:47.000     0:07:26.667     20,684 kbps     33,625 kbps     00:56:42.500    32,309 kbps     00:56:42.417    31,970 kbps     00:56:39.500    107,730 bytes   394,442 bytes   01:02:53.375
8               1:03:13.667     0:11:19.166     28,963 kbps     35,597 kbps     01:07:33.083    32,932 kbps     01:07:29.083    32,419 kbps     01:12:21.333    150,848 bytes   359,264 bytes   01:05:55.917
9               1:14:32.833     0:04:42.375     30,757 kbps     35,248 kbps     01:15:03.583    32,708 kbps     01:14:49.625    32,447 kbps     01:14:44.458    160,192 bytes   362,353 bytes   01:18:33.208
10              1:19:15.208     0:08:13.125     23,266 kbps     33,840 kbps     01:20:48.417    32,550 kbps     01:20:46.583    32,263 kbps     01:21:54.958    121,177 bytes   383,095 bytes   01:23:48.250
11              1:27:28.333     0:07:05.667     23,426 kbps     34,896 kbps     01:29:29.000    32,015 kbps     01:28:30.250    30,563 kbps     01:29:20.000    122,012 bytes   415,426 bytes   01:29:29.708
12              1:34:34.000     0:04:22.042     17,918 kbps     25,808 kbps     01:35:38.458    23,921 kbps     01:35:36.458    22,539 kbps     01:35:33.333    93,323 bytes    314,998 bytes   01:35:59.167
STREAM DIAGNOSTICS:
File            PID             Type            Seconds         Bytes           Packets         Bitrate
00000.M2TS      4113 (0x1011)   0x1B            5936.04         17,063,963,474  92,821,835      22,997
00000.M2TS      4352 (0x1100)   0x81            5936.04         474,885,120     2,782,530       640
00000.M2TS      4353 (0x1101)   0x86            5936.04         1,464,474,436   8,883,950       1,974
00000.M2TS      4354 (0x1102)   0x81            5936.04         166,209,792     927,510         224
Xylon is offline
post #1989 of 2128 Old 08-19-2008, 01:20 AM - Thread Starter
Xylon's Avatar
Xylon is offline
post #1990 of 2128 Old 08-19-2008, 01:20 AM - Thread Starter
Xylon's Avatar
Xylon is offline
post #1991 of 2128 Old 08-19-2008, 01:58 AM
trailergod's Avatar
WTF !!! is that.... ugh.... another filtered release !!!
trailergod is offline
post #1992 of 2128 Old 08-19-2008, 02:17 AM
Kram Sacul's Avatar
Random comments I've read:
The BluRay is better than the DVD.
It does not look anything like an upscale.
Just because a BD's PQ is not as good as you'd hoped - or as good as it could be - doesn't mean it's an upscale.
From the review at DVDTimes:
Whilst not perfect, Optimum's Blu-ray of this film is a significant improvement on their release of The Fog. Detail is strong but the same issue with the softness of the periphery of the frame is noticeable, contrast is very good for this rather dark movie and colours are handled very well indeed. There are very minor compression artefacts and one instance of aliasing, but watching this along with the Momentum special edition I was confident that this represented an improvement on the visual quality of that former release.
post #1993 of 2128 Old 08-19-2008, 03:47 AM
Dave Mack's Avatar
Quoted: 13 Post(s)
amazing what a little contrast boosting and added color do.
Dave Mack is offline
post #1994 of 2128 Old 08-19-2008, 09:03 AM
Mr. Hanky's Avatar
Quoted: 124 Post(s)
Liked: 99
The hdnet sample DEFINITELY retains a layer of grain detail that is simply not there in the br sample. Who woulda thunk!...mpeg-2 pulls a rabbit out at a mere 18 Mb/s!
Margot Robbie is THE most exquisite human creature on the face of the planet, in this moment in time.
Mr. Hanky is offline
post #1995 of 2128 Old 08-19-2008, 09:59 AM
msgohan's Avatar
Better than DVD in:
Detail (SLIGHTLY more even if you sharpen the DVD to extremes)
Compression
Worse than DVD in:
Shadow detail (heavy black crushing where the DVD actually has pic info)
Colors
So "better than the DVD" isn't even necessarily true here.
The DVD was clearly made from the same HD master as HDNet's. But the Blu-ray has different framing in all directions!
At least the menu is in HD. And it appears there's no DNR on it, so it could've been worse.
John White, the DVDTimes reviewer:
"If this turns out to be accurate then I am sorry I didn't spot the issues when reviewing the disc. I didn't have the benefit of another HD version to compare against and when I review Blu-ray discs I would admit that I am still learning about the format. Some things you just have to accept that you won't see as well as others who know the format better."
Seriously, we need reviewers that are more experienced with digital video and the manipulations applied to it. Anyone who thinks THIS is what a Blu-ray should look like is wholly unqualified.
LG B7 (OLED65B7P, 2017)
UHD: Philips BDP7501 | HD: PS3, WD TV Live
Denon AVR-890 (2009)
msgohan is offline
post #1996 of 2128 Old 08-19-2008, 12:12 PM
Grifter02's Avatar
Originally Posted by msgohan View Post
Better than DVD in:
Compression
Worse than DVD in:
Colors
"If this turns out to be accurate then I am sorry I didn’t spot the issues when reviewing the disc. I didn’t have the benefit of another HD version to compare against and when I review Blu-ray discs I would admit that I am still learning about the format. Some things you just have to accept that you won't see as well as others who know the format better."
The DVDtimes guy gave it 8 out of 10!!! Just give up, man, you are clearly out of your league! LOL!!!
Grifter02 is offline
post #1997 of 2128 Old 08-19-2008, 07:17 PM
cakefoo's Avatar
Quoted: 183 Post(s)
Liked: 76
Oh geez. The guy who's supposed to tell us what's good is asking us what to even LOOK for.
cakefoo is offline
post #1998 of 2128 Old 08-19-2008, 09:35 PM
msgohan's Avatar
For the eternal doubters.
eric.exe did a comparison of the StudioCanal logos, I'm extending what he did with actual matching frames.
Escape From New York - Trailer #1 - 1.85:1 - SD upscaled by me using Lanczos
00005.M2TS MPEG-2 Video 6282 kbps 576i / 25fps / 16:9
Escape From New York - StudioCanal logo (separate encode, plays before disc copyright screen) - 1.78:1 - "HD"
00011.M2TS MPEG-2 Video 29071 kbps 1080p / 24fps / 16:9
Terminator 2 - StudioCanal logo (separate encode, plays when France is selected on country menu) - 1.78:1 - HD
00085.M2TS VC-1 Video 10927 kbps 1080p / 23.976fps / 16:9 / Advanced Profile 3
Escape From New York - Movie encode - 2.35:1 - "HD"
00000.M2TS MPEG-4 AVC Video 22997 kbps 1080p / 24fps / 16:9 / High Profile 4.1
Terminator 2 - StudioCanal logo (separate encode, plays before movie) - 2.35:1 - HD
00128.M2TS VC-1 Video 16862 kbps 1080p / 23.976fps / 16:9 / Advanced Profile 3
Note the similarities between the "HD" logos and the one I upscaled myself from the trailer that's actually encoded on the disc as SD. Then the massive dissimilarity to the logos from the T2 disc. But no, clearly this can't be an upscale. This is just a poor quality telecine of computer-generated graphics.
(On another note, I found it amusing that the DTS-HD instrumental music on the StudioCanal logos is tagged as French. )
msgohan is offline
post #1999 of 2128 Old 08-20-2008, 06:22 AM - Thread Starter
Xylon's Avatar
Xylon is offline
post #2000 of 2128 Old 08-20-2008, 06:48 AM
allargon's Avatar
Quoted: 246 Post(s)
Liked: 198
The HDNet broadcast looks to have the same oversaturated colors as the DVD. Ironically, the patterns on Snake's boots are sharper with the HDNet capture vs. the Blu-Ray.
Xylon have you checked out the MGM HD broadcast of Rebel without a Cause? It's also soft and has questionable DNR as well.
allargon is offline
post #2001 of 2128 Old 08-21-2008, 03:50 AM - Thread Starter
Xylon's Avatar
No but kschmit2's screencap should answer that question.
Can't wait for FIOS to come to my neighborhood.
Xylon is offline
post #2002 of 2128 Old 08-21-2008, 04:04 AM - Thread Starter
Xylon's Avatar
Xylon is offline
post #2003 of 2128 Old 08-21-2008, 07:22 AM
phansson's Avatar
Quoted: 67 Post(s)
Xylon, are you going to do an toshiba XDE SD DVD comparison to Blu Ray.
phansson is offline
post #2004 of 2128 Old 08-21-2008, 08:28 AM
bplewis24's Avatar
Sincere question here...is that possible? Xylon does screen caps from his computer right? Without explaning the process (I know it's probably cumbersome), would he be able to take screen caps from a stand-alone player???
Brandon
bplewis24 is offline
post #2005 of 2128 Old 08-21-2008, 08:34 AM
phansson's Avatar
Quoted: 67 Post(s)
Brandon
Very sincere. I know that Xylon does screencaps via the computer, so I don't know if it is possible. I thought he could use a camera for the screen shots.
I would just like to see a comparison to see if it lives up to its hype.
Sorry, no agenda.
phansson is offline
post #2006 of 2128 Old 08-21-2008, 08:52 AM
bplewis24's Avatar
Sorry, no agenda.
Not being accusatory, I only asked that way because I know that people do screen caps from DVR recordings and I was never clear on if they did so using the DVR with a fireware connection to a PC or some type of PC cable tuner hack. I agree it would be nice to analyze the caps of the XDE's performance, just trying to see if it was possible to have a level playing field.
Brandon
post #2007 of 2128 Old 08-22-2008, 04:42 AM - Thread Starter
Xylon's Avatar
That is going to involve using a camera pointed at my PJ.
So no.
But if someone is going to even attempt doing that, make sure you have the HT video setup of Art and 12+ megapixel DSLR
Xylon is offline
post #2008 of 2128 Old 08-22-2008, 04:52 AM
tteich's Avatar
So no.
An analog HD capture card would also do this particular job, but these babies are expensive and I guess not many of us have access to one. Nevertheless, it would be very interesting to see how the XDE performs in comparison to "real" HD material.
Laserdiscs: ~350
HiVision LDs: 42
HD DVD count: 379 / still 20 on the wishlist
tteich is offline
post #2009 of 2128 Old 08-22-2008, 04:57 AM - Thread Starter
Xylon's Avatar
Ohhhhh I forgot about that. Its probably better. All you need now is the $150 XDE and the Hauppage card $250 and you are set.
Xylon is offline
post #2010 of 2128 Old 08-22-2008, 05:27 AM - Thread Starter
Xylon's Avatar
Xylon is offline
Reply HDTV Software Media Discussion
