Blu-ray, HD-DVD & HD Broadcasts(H.264 & MPEG-2) Screenshots*BIG FILES* - Page 70 - AVS Forum | Home Theater Discussions And Reviews
post #2071 of 2128 Old 09-15-2008, 01:47 AM
Kram Sacul's Avatar
As Whiggles has mentioned on his site here there is DNR baked into the master in certain scenes. Not terrible but it's there.
Kram Sacul is offline
post #2072 of 2128 Old 09-15-2008, 09:24 AM
stumlad's Avatar
Quoted: 147 Post(s)
Liked: 60
Originally Posted by Whiggles review View Post
What's particularly interesting is that, on certain occasions, particularly the extended Pai Mei section, the NR is either turned off completely or at least lowered to an acceptable level..
I just watched both movies -- the entire Pai Mai sequence looks like it was shot with completely different film stock. From the moment it starts, to the moment it ends, its clear the entire look of the film changes... it does not look as if DNR were turned off...it looks like it has completely different grain structure. IMO if you were to DNR the Pai Mai scenes, you would probably find it hard to see 720p detail. I guess the reviewer noted this was shot differently, but why keep DNR off for this, but on for the rest of the film?
As for DNR in other areas... there were some scenes where I said to myself "why am i not seeing any grain here"... one scene that comes to mind is when Beatrix is underneath Bud's trailer. It's dark, but I dont see any grain...
stumlad is offline
post #2073 of 2128 Old 09-15-2008, 10:50 AM
Mr. Hanky's Avatar
Quoted: 124 Post(s)
Liked: 99
For the overweight pixel luva's in da house...I give you- NoiseView shots:
br sample
sky sample
Margot Robbie is THE most exquisite human creature on the face of the planet, in this moment in time.
Mr. Hanky is offline
post #2074 of 2128 Old 09-27-2008, 07:57 PM
Patsfan123's Avatar
Quoted: 470 Post(s)
Liked: 309
Yeah, they are dull. The HDTV cap must have been contrast boosted. The Blu-ray image is more detailed and not DNR'd but I wish the colors had a bit more oomph. Can you do a comparison with Interview with the Vampire, or at least just post shots of the BD?
LG 65C6P FW: 05.30.30 | Onkyo TX-RZ730 5.1.4 | Oppo UDP-203 | Sony UBP-X700 | Xbox One X | Chromecast Ultra | Apple TV 4K
LG 55EG9100 | LG 60PK550 | Samsung LN-S4095D | Samsung UBD‑K8500 | Philips BDP7501 | Panasonic DMP-BDT110
Patsfan123 is offline
post #2075 of 2128 Old 09-28-2008, 06:04 AM - Thread Starter
Xylon's Avatar
Wait a minute HDNET adds DNR?
Xylon is offline
post #2076 of 2128 Old 09-28-2008, 06:40 AM
bplewis24's Avatar
For a Few Dollars More is an import, right? There's no U.S. release as of yet?
Brandon
bplewis24 is offline
post #2077 of 2128 Old 09-28-2008, 07:05 AM
lgans316's Avatar
Quoted: 92 Post(s)
Liked: 62
Brandon
Think it's the Italian import.
Code:
(IT) For a Few Dollars More (no English subs)   VC-1    2:12:15 19,418,609,664  21,286,711,724  19.58   17.99   DTS-HD Master Audio 1.0
Blu-ray : 340
lgans316 is offline
post #2078 of 2128 Old 09-29-2008, 05:58 AM
Oliver Klohs's Avatar
Quoted: 45 Post(s)
Liked: 26
Blu-ray (18 Mbps VC1) vs HDNet Movies HDTV (17.55 Mbps MPEG-2)
Well I doubt anyone will ever understand why HDNet DNRs the way they do. It doesn't even remove any grain, it just screws up the contrast and makes everything smudgier.
I just compared caps Nr. 1,3,4 and 6 and only number one is really showing a big difference, the other caps look very close. I will revisit the caps tonight on the projector but right now it seems to me that except for the very grainy first scene the full bitrate HDnet version is looking pretty good, it would probably be more interesting to show how much the HDlite version with low bitrate and 1440 x 1080 differs in picture quality.
Oliver Klohs is offline
post #2079 of 2128 Old 10-07-2008, 05:15 PM
eric.exe's Avatar
Quoted: 106 Post(s)
Liked: 44
The Shawshank Redemption
itv UK Blu-ray (26 Mbps AVC) vs HDTV (10 Mbps MPEG-2)
[pic host dead]
Unless Warner pulls a new transfer out of their ass, the US BD is probably going to look identical to the UK one.
eric.exe is offline
post #2080 of 2128 Old 10-07-2008, 05:55 PM
paku's Avatar
Quoted: 57 Post(s)
Liked: 40
Is there a reason (stylistic choice) why the first two caps look so terribly un-detailed compared to the rest?
paku is offline
post #2081 of 2128 Old 10-07-2008, 06:50 PM
Kram Sacul's Avatar
I'll give you three letters...
Other than that I think it looks okay but I suspect it has been filtered. Glad to see the transfer keeps the low contrast overcast look.
post #2082 of 2128 Old 10-09-2008, 07:42 PM
stumlad's Avatar
Quoted: 147 Post(s)
Liked: 60
Now I see why it was delayed for 2 yrs! Oh wait... no, I don't.
stumlad is offline
post #2083 of 2128 Old 10-11-2008, 12:20 AM
Kram Sacul's Avatar
DVDBeaver has screenshots of Beetlejuice here:
http://www.dvdbeaver.com/film2/DVDRe...ce_blu-ray.htm
Looks much better than the washed out HDNet capture I have. No Warner jaggies either.
post #2084 of 2128 Old 04-11-2009, 06:10 AM - Thread Starter
Xylon's Avatar
D-Theater File size: 21.54 GB
Bitrate: 21.50 mbps
Code:
Sequence Frame 183732(10-B) / Time 2:07:14 :
Info: End of MPEG2 sequence
Sequence Summary:
File Size Processed: 21.54 GB, Play Time: 02h:07m:14s
1920 x 1080, 29.97 fps (24.07 fps Telecine), 45.00 Mbps (21.50 Mbps Average).
Average Video Quality: 109.08 KB/Frame, 0.43 Bits/Pixel.
AC3 Audio: 3/2 Channels (L, C, R, SL, SR) + LFE, 48.0 kHz, 576 kbps.
Dialog Normalization: -27.0 dB, Center Mix Level: -3.0 dB, Surround Mix Level: -3.0 dB
0 of 183732 video frames found with errors.
0 of 238569 audio frames found with errors.
0 corrupted video bytes in file.
0.000000 seconds of video timestamp gaps.
0.000000 seconds of audio timestamp gaps.
End of Log
Blu-ray File size: 28.00 GB
Bitrate: 22.39 mbps
Code:
        Total   Video
Title                                                           Codec   Length  Movie Size      Disc Size       Bitrate Bitrate Main Audio Track
                 Secondary Audio Track
00013.MPLS                                                      AVC     2:06:32 28,268,316,672  41,566,110,546  29.79   22.39   DTS-HD Master 5.1
3959Kbps (48kHz/24-bit)
DISC INFO:
Disc Title:     PASSION_OF_CHRIST
Disc Size:      41,566,110,546 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.1
PLAYLIST REPORT:
Length:                 2:06:32 (h:m:s)
Total Bitrate:          29.79 Mbps
Description:
VIDEO:
MPEG-4 AVC Video        22390 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             Aramaic         3959 kbps       5.1 / 48 kHz / 3959 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
Dolby Digital Audio             English         224 kbps        2.0 / 48 kHz / 224 kbps
SUBTITLES:
Presentation Graphics           English         8.859 kbps
Presentation Graphics           English         13.187 kbps
Presentation Graphics           Chinese         7.778 kbps
Presentation Graphics           Chinese         7.261 kbps
Presentation Graphics           Korean          6.314 kbps
Presentation Graphics           Korean          36.820 kbps
Presentation Graphics           Korean          43.761 kbps
Presentation Graphics           Korean          53.320 kbps
Presentation Graphics           Korean          23.296 kbps
Presentation Graphics           Portuguese      8.617 kbps
Presentation Graphics           Portuguese      50.732 kbps
Presentation Graphics           Portuguese      52.137 kbps
Presentation Graphics           Portuguese      70.772 kbps
Presentation Graphics           Portuguese      33.590 kbps
Presentation Graphics           Spanish         8.965 kbps
Presentation Graphics           Spanish         50.512 kbps
Presentation Graphics           Spanish         53.082 kbps
Presentation Graphics           Spanish         69.086 kbps
Presentation Graphics           Spanish         33.751 kbps
Presentation Graphics           Tagalog         11.337 kbps
Presentation Graphics           Thai            9.084 kbps
FILES:
00078.M2TS      0:00:00.000     0:15:02.526     3,389,337,600   30,043
00080.M2TS      0:15:02.526     0:01:11.738     288,909,312     32,218
00082.M2TS      0:16:14.264     0:20:40.781     4,660,168,704   30,047
00085.M2TS      0:36:55.046     0:01:25.877     319,426,560     29,756
00087.M2TS      0:38:20.923     0:15:04.320     3,341,611,008   29,561
00115.M2TS      0:53:25.243     0:15:56.413     3,544,688,640   29,650
00117.M2TS      1:09:21.657     0:04:39.904     1,037,150,208   29,643
00119.M2TS      1:14:01.562     0:01:07.859     254,920,704     30,053
00118.M2TS      1:15:09.421     0:02:19.722     525,834,240     30,107
00121.M2TS      1:17:29.144     0:29:04.325     6,475,204,608   29,697
00095.M2TS      1:46:33.470     0:07:02.422     1,564,311,552   29,626
00093.M2TS      1:53:35.892     0:12:56.192     2,866,753,536   29,547
CHAPTERS:
Number          Time In         Length          Avg Video Rate  Max 1-Sec Rate  Max 1-Sec Time  Max 5-Sec Rate  Max 5-Sec Time  Max 10Sec Rate  Max
10Sec Time  Avg Frame Size  Max Frame Size  Max Frame Time
1               0:00:00.000     1:08:12.463     22,530 kbps     40,088 kbps     00:15:13.954    35,250 kbps     00:15:09.950    34,706 kbps
00:15:04.945    117,459 bytes   759,484 bytes   00:10:32.965
2               1:08:12.463     0:04:21.052     21,526 kbps     36,629 kbps     01:12:09.700    32,332 kbps     01:09:02.388    28,961 kbps
01:08:59.176    112,226 bytes   461,093 bytes   01:09:17.611
3               1:12:33.515     0:02:50.378     22,759 kbps     35,928 kbps     01:14:15.993    30,910 kbps     01:14:10.529    29,601 kbps
01:14:07.943    118,655 bytes   431,293 bytes   01:13:37.454
4               1:15:23.894     0:01:14.032     22,810 kbps     32,164 kbps     01:16:29.918    30,923 kbps     01:16:29.918    27,904 kbps
01:16:24.997    118,921 bytes   408,573 bytes   01:15:57.386
5               1:16:37.926     0:04:09.624     22,047 kbps     31,941 kbps     01:19:32.726    29,707 kbps     01:17:01.533    27,225 kbps
01:17:45.869    114,945 bytes   886,333 bytes   01:18:16.942
6               1:20:47.550     0:02:30.525     22,054 kbps     28,075 kbps     01:21:02.607    25,685 kbps     01:21:02.440    24,331 kbps
01:22:36.201    114,981 bytes   408,355 bytes   01:22:20.268
7               1:23:18.076     0:04:09.791     22,681 kbps     31,839 kbps     01:25:22.992    29,809 kbps     01:25:31.167    27,902 kbps
01:25:28.164    118,248 bytes   432,882 bytes   01:25:08.061
8               1:27:27.867     0:00:45.086     22,522 kbps     31,060 kbps     01:28:08.741    27,887 kbps     01:28:05.196    25,803 kbps
01:28:02.443    117,422 bytes   448,238 bytes   01:28:08.866
9               1:28:12.954     0:06:20.505     21,962 kbps     36,446 kbps     01:30:38.224    34,097 kbps     01:30:34.220    33,139 kbps
01:30:30.049    114,500 bytes   495,865 bytes   01:33:33.733
10              1:34:33.459     0:00:18.852     22,283 kbps     28,844 kbps     01:34:38.631    24,863 kbps     01:34:37.171    23,592 kbps
01:34:33.459    116,174 bytes   361,352 bytes   01:34:39.465
11              1:34:52.311     0:08:19.290     22,103 kbps     38,029 kbps     01:39:38.889    32,689 kbps     01:35:29.348    31,539 kbps
01:35:29.348    115,236 bytes   666,781 bytes   01:39:38.931
12              1:43:11.602     0:12:33.085     24,552 kbps     37,262 kbps     01:54:18.768    35,221 kbps     01:55:17.160    35,047 kbps
01:55:17.201    128,003 bytes   621,600 bytes   01:55:25.168
13              1:55:44.687     0:01:37.680     32,064 kbps     37,362 kbps     01:57:13.276    35,517 kbps     01:57:09.272    35,198 kbps
01:57:04.267    167,165 bytes   604,694 bytes   01:56:34.654
14              1:57:22.368     0:01:27.587     31,773 kbps     39,545 kbps     01:58:42.740    35,875 kbps     01:58:38.819    35,256 kbps
01:58:33.773    165,652 bytes   599,281 bytes   01:58:43.449
15              1:58:49.956     0:07:42.128     14,889 kbps     26,887 kbps     02:04:36.552    25,920 kbps     02:04:36.510    25,395 kbps
02:04:35.134    77,631 bytes    415,470 bytes   02:04:41.307
STREAM DIAGNOSTICS:
File            PID             Type            Codec           Language                Seconds                 Bitrate                 Bytes
Packets
00078.M2TS      4113 (0x1011)   0x1B            AVC                                     902.402                 22,664                  2,556,542,904
13,907,045
00078.M2TS      4352 (0x1100)   0x86            DTS-HD MA       arc (Aramaic)           902.402                 3,893                   439,120,068
2,527,286
00078.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           902.402                 224                     25,270,784
141,020
00078.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           902.402                 224                     25,270,784
141,020
00078.M2TS      4355 (0x1103)   0x81            AC3             eng (English)           902.402                 224                     25,270,784
141,020
00078.M2TS      4356 (0x1104)   0x81            AC3             eng (English)           902.402                 224                     25,270,784
141,020
00078.M2TS      4357 (0x1105)   0x81            AC3             eng (English)           902.402                 224                     25,270,784
141,020
00078.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           902.402                 7                       788,399
4,660
00078.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           902.402                 10                      1,088,910
6,498
00078.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           902.402                 8                       855,173
5,042
00078.M2TS      4611 (0x1203)   0x90            PGS             por (Portuguese)        902.402                 8                       846,561
4,994
00078.M2TS      4612 (0x1204)   0x90            PGS             zho (Chinese)           902.402                 7                       824,827
4,878
00078.M2TS      4613 (0x1205)   0x90            PGS             kor (Korean)            902.402                 6                       661,043
3,988
00078.M2TS      4614 (0x1206)   0x90            PGS             zho (Chinese)           902.402                 7                       794,978
4,718
00078.M2TS      4615 (0x1207)   0x90            PGS             tgl (Tagalog)           902.402                 10                      1,177,845
6,797
00078.M2TS      4616 (0x1208)   0x90            PGS             tha (Thai)              902.402                 9                       982,656
5,729
00078.M2TS      4617 (0x1209)   0x90            PGS             spa (Spanish)           902.402                 53                      5,978,543
34,135
00078.M2TS      4618 (0x120A)   0x90            PGS             por (Portuguese)        902.402                 53                      5,962,312
34,043
00078.M2TS      4619 (0x120B)   0x90            PGS             kor (Korean)            902.402                 38                      4,304,588
25,033
00078.M2TS      4620 (0x120C)   0x90            PGS             spa (Spanish)           902.402                 61                      6,826,251
38,914
00078.M2TS      4621 (0x120D)   0x90            PGS             por (Portuguese)        902.402                 61                      6,913,256
39,400
00078.M2TS      4622 (0x120E)   0x90            PGS             kor (Korean)            902.402                 50                      5,584,264
32,170
00078.M2TS      4623 (0x120F)   0x90            PGS             spa (Spanish)           902.402                 73                      8,272,375
46,818
00078.M2TS      4624 (0x1210)   0x90            PGS             por (Portuguese)        902.402                 75                      8,491,838
48,023
00078.M2TS      4625 (0x1211)   0x90            PGS             kor (Korean)            902.402                 51                      5,706,387
32,868
00078.M2TS      4626 (0x1212)   0x90            PGS             spa (Spanish)           902.402                 40                      4,480,319
25,609
00078.M2TS      4627 (0x1213)   0x90            PGS             por (Portuguese)        902.402                 40                      4,487,822
25,654
00078.M2TS      4628 (0x1214)   0x90            PGS             kor (Korean)            902.402                 27                      3,006,952
17,608
00080.M2TS      4113 (0x1011)   0x1B            AVC                                     71.613                  24,759                  221,636,247
1,205,543
00080.M2TS      4352 (0x1100)   0x86            DTS-HD MA       arc (Aramaic)           71.613                  3,946                   35,324,600
203,130
00080.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           71.613                  224                     2,008,832
11,210
00080.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           71.613                  224                     2,008,832
11,210
00080.M2TS      4355 (0x1103)   0x81            AC3             eng (English)           71.613                  224                     2,008,832
11,210
00080.M2TS      4356 (0x1104)   0x81            AC3             eng (English)           71.613                  224                     2,008,832
11,210
00080.M2TS      4357 (0x1105)   0x81            AC3             eng (English)           71.613                  224                     2,008,832
11,210
00080.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           71.613                  0                       70
7
00080.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           71.613                  11                      98,500
585
00080.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           71.613                  0                       70
7
00080.M2TS      4611 (0x1203)   0x90            PGS             por (Portuguese)        71.613                  0                       70
7
00080.M2TS      4612 (0x1204)   0x90            PGS             zho (Chinese)           71.613                  0                       70
7
00080.M2TS      4613 (0x1205)   0x90            PGS             kor (Korean)            71.613                  0                       70
7
00080.M2TS      4614 (0x1206)   0x90            PGS             zho (Chinese)           71.613                  0                       70
7
00080.M2TS      4615 (0x1207)   0x90            PGS             tgl (Tagalog)           71.613                  0                       70
7
00080.M2TS      4616 (0x1208)   0x90            PGS             tha (Thai)              71.613                  0                       70
7
00080.M2TS      4617 (0x1209)   0x90            PGS             spa (Spanish)           71.613                  87                      779,435
4,431
00080.M2TS      4618 (0x120A)   0x90            PGS             por (Portuguese)        71.613                  88                      785,870
4,467
00080.M2TS      4619 (0x120B)   0x90            PGS             kor (Korean)            71.613                  57                      513,600
2,986
00080.M2TS      4620 (0x120C)   0x90            PGS             spa (Spanish)           71.613                  63                      559,514
3,218
00080.M2TS      4621 (0x120D)   0x90            PGS             por (Portuguese)        71.613                  62                      554,865
3,193
00080.M2TS      4622 (0x120E)   0x90            PGS             kor (Korean)            71.613                  53                      477,037
2,769
00080.M2TS      4623 (0x120F)   0x90            PGS             spa (Spanish)           71.613                  91                      816,437
4,634
00080.M2TS      4624 (0x1210)   0x90            PGS             por (Portuguese)        71.613                  93                      832,177
4,717
00080.M2TS      4625 (0x1211)   0x90            PGS             kor (Korean)            71.613                  61                      544,596
3,154
00080.M2TS      4626 (0x1212)   0x90            PGS             spa (Spanish)           71.613                  4                       38,705
217
00080.M2TS      4627 (0x1213)   0x90            PGS             por (Portuguese)        71.613                  4                       35,680
201
00080.M2TS      4628 (0x1214)   0x90            PGS             kor (Korean)            71.613                  3                       27,346
156
00082.M2TS      4113 (0x1011)   0x1B            AVC                                     1240.656                22,651                  3,512,783,593
19,108,677
00082.M2TS      4352 (0x1100)   0x86            DTS-HD MA       arc (Aramaic)           1240.656                3,828                   593,606,032
3,419,813
00082.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           1240.656                224                     34,742,400
193,875
00082.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           1240.656                224                     34,742,400
193,875
00082.M2TS      4355 (0x1103)   0x81            AC3             eng (English)           1240.656                224                     34,742,400
193,875
00082.M2TS      4356 (0x1104)   0x81            AC3             eng (English)           1240.656                224                     34,742,400
193,875
00082.M2TS      4357 (0x1105)   0x81            AC3             eng (English)           1240.656                224                     34,742,400
193,875
00082.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           1240.656                16                      2,547,279
14,935
00082.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           1240.656                22                      3,431,893
20,191
00082.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           1240.656                17                      2,598,225
15,203
00082.M2TS      4611 (0x1203)   0x90            PGS             por (Portuguese)        1240.656                16                      2,503,147
14,695
00082.M2TS      4612 (0x1204)   0x90            PGS             zho (Chinese)           1240.656                15                      2,250,186
13,312
00082.M2TS      4613 (0x1205)   0x90            PGS             kor (Korean)            1240.656                11                      1,736,256
10,503
00082.M2TS      4614 (0x1206)   0x90            PGS             zho (Chinese)           1240.656                13                      2,086,313
12,414
00082.M2TS      4615 (0x1207)   0x90            PGS             tgl (Tagalog)           1240.656                21                      3,223,042
18,610
00082.M2TS      4616 (0x1208)   0x90            PGS             tha (Thai)              1240.656                16                      2,492,836
14,599
00082.M2TS      4617 (0x1209)   0x90            PGS             spa (Spanish)           1240.656                60                      9,348,917
53,486
00082.M2TS      4618 (0x120A)   0x90            PGS             por (Portuguese)        1240.656                60                      9,285,331
53,117
00082.M2TS      4619 (0x120B)   0x90            PGS             kor (Korean)            1240.656                44                      6,849,294
39,871
00082.M2TS      4620 (0x120C)   0x90            PGS             spa (Spanish)           1240.656                57                      8,763,396
49,998
00082.M2TS      4621 (0x120D)   0x90            PGS             por (Portuguese)        1240.656                58                      9,026,595
51,432
00082.M2TS      4622 (0x120E)   0x90            PGS             kor (Korean)            1240.656                48                      7,517,360
43,209
00082.M2TS      4623 (0x120F)   0x90            PGS             spa (Spanish)           1240.656                70                      10,916,870
61,908
00082.M2TS      4624 (0x1210)   0x90            PGS             por (Portuguese)        1240.656                71                      11,054,615
62,656
00082.M2TS      4625 (0x1211)   0x90            PGS             kor (Korean)            1240.656                48                      7,447,790
43,052
00082.M2TS      4626 (0x1212)   0x90            PGS             spa (Spanish)           1240.656                38                      5,870,108
33,716
00082.M2TS      4627 (0x1213)   0x90            PGS             por (Portuguese)        1240.656                38                      5,848,866
33,601
00082.M2TS      4628 (0x1214)   0x90            PGS             kor (Korean)            1240.656                25                      3,902,008
23,006
00085.M2TS      4113 (0x1011)   0x1B            AVC                                     85.752                  22,158                  237,517,717
1,292,069
00085.M2TS      4352 (0x1100)   0x86            DTS-HD MA       arc (Aramaic)           85.752                  4,012                   43,009,996
247,128
00085.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           85.752                  224                     2,404,864
13,420
00085.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           85.752                  224                     2,404,864
13,420
00085.M2TS      4355 (0x1103)   0x81            AC3             eng (English)           85.752                  224                     2,404,864
13,420
00085.M2TS      4356 (0x1104)   0x81            AC3             eng (English)           85.752                  224                     2,404,864
13,420
00085.M2TS      4357 (0x1105)   0x81            AC3             eng (English)           85.752                  224                     2,404,864
13,420
00085.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           85.752                  10                      108,384
625
00085.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           85.752                  13                      135,769
787
00085.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           85.752                  10                      102,290
591
00085.M2TS      4611 (0x1203)   0x90            PGS             por (Portuguese)        85.752                  9                       97,799
566
00085.M2TS      4612 (0x1204)   0x90            PGS             zho (Chinese)           85.752                  8                       82,361
482
00085.M2TS      4613 (0x1205)   0x90            PGS             kor (Korean)            85.752                  6                       62,534
376
00085.M2TS      4614 (0x1206)   0x90            PGS             zho (Chinese)           85.752                  9                       93,839
545
00085.M2TS      4615 (0x1207)   0x90            PGS             tgl (Tagalog)           85.752                  13                      138,877
789
00085.M2TS      4616 (0x1208)   0x90            PGS             tha (Thai)              85.752                  11                      113,427
650
00085.M2TS      4617 (0x1209)   0x90            PGS             spa (Spanish)           85.752                  72                      774,549
4,425
00085.M2TS      4618 (0x120A)   0x90            PGS             por (Portuguese)        85.752                  71                      765,544
4,377
00085.M2TS      4619 (0x120B)   0x90            PGS             kor (Korean)            85.752                  56                      604,805
3,497
00085.M2TS      4620 (0x120C)   0x90            PGS             spa (Spanish)           85.752                  61                      656,013
3,741
00085.M2TS      4621 (0x120D)   0x90            PGS             por (Portuguese)        85.752                  63                      674,562
3,842
00085.M2TS      4622 (0x120E)   0x90            PGS             kor (Korean)            85.752                  51                      547,469
3,151
00085.M2TS      4623 (0x120F)   0x90            PGS             spa (Spanish)           85.752                  79                      845,024
4,772
00085.M2TS      4624 (0x1210)   0x90            PGS             por (Portuguese)        85.752                  76                      816,692
4,621
00085.M2TS      4625 (0x1211)   0x90            PGS             kor (Korean)            85.752                  57                      615,425
3,523
00085.M2TS      4626 (0x1212)   0x90            PGS             spa (Spanish)           85.752                  60                      638,685
3,657
00085.M2TS      4627 (0x1213)   0x90            PGS             por (Portuguese)        85.752                  59                      634,982
3,640
00085.M2TS      4628 (0x1214)   0x90            PGS             kor (Korean)            85.752                  39                      419,705
2,468
00087.M2TS      4113 (0x1011)   0x1B            AVC                                     904.195                 22,274                  2,517,531,375
13,694,936
00087.M2TS      4352 (0x1100)   0x86            DTS-HD MA       arc (Aramaic)           904.195                 3,784                   427,694,432
2,465,653
00087.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           904.195                 224                     25,321,856
141,305
00087.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           904.195                 224                     25,321,856
141,305
00087.M2TS      4355 (0x1103)   0x81            AC3             eng (English)           904.195                 224                     25,321,856
141,305
00087.M2TS      4356 (0x1104)   0x81            AC3             eng (English)           904.195                 224                     25,321,856
141,305
00087.M2TS      4357 (0x1105)   0x81            AC3             eng (English)           904.195                 224                     25,321,856
141,305
00087.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           904.195                 19                      2,143,428
12,404
00087.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           904.195                 25                      2,798,568
16,293
00087.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           904.195                 19                      2,170,766
12,563
00087.M2TS      4611 (0x1203)   0x90            PGS             por (Portuguese)        904.195                 18                      2,054,492
11,918
00087.M2TS      4612 (0x1204)   0x90            PGS             zho (Chinese)           904.195                 16                      1,782,007
10,438
00087.M2TS      4613 (0x1205)   0x90            PGS             kor (Korean)            904.195                 12                      1,405,515
8,407
00087.M2TS      4614 (0x1206)   0x90            PGS             zho (Chinese)           904.195                 14                      1,633,539
9,631
00087.M2TS      4615 (0x1207)   0x90            PGS             tgl (Tagalog)           904.195                 23                      2,636,451
15,090
00087.M2TS      4616 (0x1208)   0x90            PGS             tha (Thai)              904.195                 19                      2,092,823
12,119
00087.M2TS      4617 (0x1209)   0x90            PGS             spa (Spanish)           904.195                 56                      6,354,712
36,373
00087.M2TS      4618 (0x120A)   0x90            PGS             por (Portuguese)        904.195                 55                      6,226,224
35,678
00087.M2TS      4619 (0x120B)   0x90            PGS             kor (Korean)            904.195                 41                      4,590,886
26,773
00087.M2TS      4620 (0x120C)   0x90            PGS             spa (Spanish)           904.195                 53                      5,981,987
34,015
00087.M2TS      4621 (0x120D)   0x90            PGS             por (Portuguese)        904.195                 53                      5,952,360
33,861
00087.M2TS      4622 (0x120E)   0x90            PGS             kor (Korean)            904.195                 44                      4,969,220
28,497
00087.M2TS      4623 (0x120F)   0x90            PGS             spa (Spanish)           904.195                 68                      7,656,708
43,508
00087.M2TS      4624 (0x1210)   0x90            PGS             por (Portuguese)        904.195                 71                      8,040,315
45,592
00087.M2TS      4625 (0x1211)   0x90            PGS             kor (Korean)            904.195                 55                      6,175,478
35,458
00087.M2TS      4626 (0x1212)   0x90            PGS             spa (Spanish)           904.195                 25                      2,828,343
16,276
00087.M2TS      4627 (0x1213)   0x90            PGS             por (Portuguese)        904.195                 24                      2,718,118
15,673
00087.M2TS      4628 (0x1214)   0x90            PGS             kor (Korean)            904.195                 16                      1,802,452
10,698
00115.M2TS      4113 (0x1011)   0x1B            AVC                                     956.289                 22,289                  2,664,313,194
14,493,459
00115.M2TS      4352 (0x1100)   0x86            DTS-HD MA       arc (Aramaic)           956.289                 3,970                   474,567,640
2,728,593
00115.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           956.289                 224                     26,779,648
149,440
00115.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           956.289                 224                     26,779,648
149,440
00115.M2TS      4355 (0x1103)   0x81            AC3             eng (English)           956.289                 224                     26,779,648
149,440
00115.M2TS      4356 (0x1104)   0x81            AC3             eng (English)           956.289                 224                     26,779,648
149,440
00115.M2TS      4357 (0x1105)   0x81            AC3             eng (English)           956.289                 224                     26,779,648
149,440
00115.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           956.289                 4                       440,705
2,600
00115.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           956.289                 9                       1,124,173
6,635
00115.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           956.289                 4                       445,507
2,620
00115.M2TS      4611 (0x1203)   0x90            PGS             por (Portuguese)        956.289                 3                       408,942
2,425
00115.M2TS      4612 (0x1204)   0x90            PGS             zho (Chinese)           956.289                 3                       355,627
2,131
00115.M2TS      4613 (0x1205)   0x90            PGS             kor (Korean)            956.289                 3                       335,044
2,018
00115.M2TS      4614 (0x1206)   0x90            PGS             zho (Chinese)           956.289                 3                       346,385
2,085
00115.M2TS      4615 (0x1207)   0x90            PGS             tgl (Tagalog)           956.289                 5                       576,121
3,336
00115.M2TS      4616 (0x1208)   0x90            PGS             tha (Thai)              956.289                 4                       445,085
2,613
00115.M2TS      4617 (0x1209)   0x90            PGS             spa (Spanish)           956.289                 44                      5,288,709
30,182
00115.M2TS      4618 (0x120A)   0x90            PGS             por (Portuguese)        956.289                 45                      5,391,636
30,746
00115.M2TS      4619 (0x120B)   0x90            PGS             kor (Korean)            956.289                 32                      3,788,427
22,017
00115.M2TS      4620 (0x120C)   0x90            PGS             spa (Spanish)           956.289                 58                      6,963,960
39,574
00115.M2TS      4621 (0x120D)   0x90            PGS             por (Portuguese)        956.289                 55                      6,591,715
37,550
00115.M2TS      4622 (0x120E)   0x90            PGS             kor (Korean)            956.289                 47                      5,616,883
32,248
00115.M2TS      4623 (0x120F)   0x90            PGS             spa (Spanish)           956.289                 71                      8,467,067
48,171
00115.M2TS      4624 (0x1210)   0x90            PGS             por (Portuguese)        956.289                 74                      8,842,149
50,197
00115.M2TS      4625 (0x1211)   0x90            PGS             kor (Korean)            956.289                 59                      7,042,275
40,411
00115.M2TS      4626 (0x1212)   0x90            PGS             spa (Spanish)           956.289                 36                      4,270,933
24,376
00115.M2TS      4627 (0x1213)   0x90            PGS             por (Portuguese)        956.289                 35                      4,134,199
23,626
00115.M2TS      4628 (0x1214)   0x90            PGS             kor (Korean)            956.289                 25                      2,998,310
17,447
00117.M2TS      4113 (0x1011)   0x1B            AVC                                     279.780                 22,088                  772,469,165
4,202,163
00117.M2TS      4352 (0x1100)   0x86            DTS-HD MA       arc (Aramaic)           279.780                 4,050                   141,644,020
813,398
00117.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           279.780                 224                     7,838,208
43,740
00117.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           279.780                 224                     7,838,208
43,740
00117.M2TS      4355 (0x1103)   0x81            AC3             eng (English)           279.780                 224                     7,838,208
43,740
00117.M2TS      4356 (0x1104)   0x81            AC3             eng (English)           279.780                 224                     7,838,208
43,740
00117.M2TS      4357 (0x1105)   0x81            AC3             eng (English)           279.780                 224                     7,838,208
43,740
00117.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           279.780                 10                      343,770
1,973
00117.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           279.780                 14                      482,588
2,801
00117.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           279.780                 9                       322,154
1,856
00117.M2TS      4611 (0x1203)   0x90            PGS             por (Portuguese)        279.780                 9                       316,936
1,827
00117.M2TS      4612 (0x1204)   0x90            PGS             zho (Chinese)           279.780                 9                       330,279
1,898
00117.M2TS      4613 (0x1205)   0x90            PGS             kor (Korean)            279.780                 7                       254,524
1,488
00117.M2TS      4614 (0x1206)   0x90            PGS             zho (Chinese)           279.780                 8                       278,270
1,614
00117.M2TS      4615 (0x1207)   0x90            PGS             tgl (Tagalog)           279.780                 12                      434,615
2,467
00117.M2TS      4616 (0x1208)   0x90            PGS             tha (Thai)              279.780                 11                      391,758
2,235
00117.M2TS      4617 (0x1209)   0x90            PGS             spa (Spanish)           279.780                 48                      1,670,120
9,551
00117.M2TS      4618 (0x120A)   0x90            PGS             por (Portuguese)        279.780                 48                      1,664,460
9,525
00117.M2TS      4619 (0x120B)   0x90            PGS             kor (Korean)            279.780                 34                      1,199,165
6,987
00117.M2TS      4620 (0x120C)   0x90            PGS             spa (Spanish)           279.780                 56                      1,954,436
11,092
00117.M2TS      4621 (0x120D)   0x90            PGS             por (Portuguese)        279.780                 51                      1,778,113
10,139
00117.M2TS      4622 (0x120E)   0x90            PGS             kor (Korean)            279.780                 43                      1,491,250
8,574
00117.M2TS      4623 (0x120F)   0x90            PGS             spa (Spanish)           279.780                 77                      2,677,584
15,233
00117.M2TS      4624 (0x1210)   0x90            PGS             por (Portuguese)        279.780                 83                      2,899,956
16,430
00117.M2TS      4625 (0x1211)   0x90            PGS             kor (Korean)            279.780                 62                      2,177,430
12,502
00117.M2TS      4626 (0x1212)   0x90            PGS             spa (Spanish)           279.780                 54                      1,888,128
10,706
00117.M2TS      4627 (0x1213)   0x90            PGS             por (Portuguese)        279.780                 54                      1,880,998
10,665
00117.M2TS      4628 (0x1214)   0x90            PGS             kor (Korean)            279.780                 38                      1,316,333
7,598
00119.M2TS      4113 (0x1011)   0x1B            AVC                                     67.734                  22,336                  189,116,175
1,028,764
00119.M2TS      4352 (0x1100)   0x86            DTS-HD MA       arc (Aramaic)           67.734                  4,366                   36,961,952
211,454
00119.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           67.734                  224                     1,900,416
10,605
00119.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           67.734                  224                     1,900,416
10,605
00119.M2TS      4355 (0x1103)   0x81            AC3             eng (English)           67.734                  224                     1,900,416
10,605
00119.M2TS      4356 (0x1104)   0x81            AC3             eng (English)           67.734                  224                     1,900,416
10,605
00119.M2TS      4357 (0x1105)   0x81            AC3             eng (English)           67.734                  224                     1,900,416
10,605
00119.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           67.734                  2                       19,517
119
00119.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           67.734                  3                       28,534
175
00119.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           67.734                  3                       21,436
131
00119.M2TS      4611 (0x1203)   0x90            PGS             por (Portuguese)        67.734                  3                       24,018
144
00119.M2TS      4612 (0x1204)   0x90            PGS             zho (Chinese)           67.734                  2                       14,613
93
00119.M2TS      4613 (0x1205)   0x90            PGS             kor (Korean)            67.734                  2                       20,959
127
00119.M2TS      4614 (0x1206)   0x90            PGS             zho (Chinese)           67.734                  3                       22,384
135
00119.M2TS      4615 (0x1207)   0x90            PGS             tgl (Tagalog)           67.734                  4                       33,731
198
00119.M2TS      4616 (0x1208)   0x90            PGS             tha (Thai)              67.734                  3                       21,671
132
00119.M2TS      4617 (0x1209)   0x90            PGS             spa (Spanish)           67.734                  62                      524,590
2,987
00119.M2TS      4618 (0x120A)   0x90            PGS             por (Portuguese)        67.734                  62                      526,727
3,000
00119.M2TS      4619 (0x120B)   0x90            PGS             kor (Korean)            67.734                  48                      402,686
2,324
00119.M2TS      4620 (0x120C)   0x90            PGS             spa (Spanish)           67.734                  72                      605,763
3,439
00119.M2TS      4621 (0x120D)   0x90            PGS             por (Portuguese)        67.734                  65                      547,286
3,121
00119.M2TS      4622 (0x120E)   0x90            PGS             kor (Korean)            67.734                  59                      499,940
2,863
00119.M2TS      4623 (0x120F)   0x90            PGS             spa (Spanish)           67.734                  62                      524,384
2,996
00119.M2TS      4624 (0x1210)   0x90            PGS             por (Portuguese)        67.734                  64                      541,907
3,091
00119.M2TS      4625 (0x1211)   0x90            PGS             kor (Korean)            67.734                  52                      436,586
2,517
00119.M2TS      4626 (0x1212)   0x90            PGS             spa (Spanish)           67.734                  14                      117,463
673
00119.M2TS      4627 (0x1213)   0x90            PGS             por (Portuguese)        67.734                  15                      124,651
711
00119.M2TS      4628 (0x1214)   0x90            PGS             kor (Korean)            67.734                  11                      95,206
552
00118.M2TS      4113 (0x1011)   0x1B            AVC                                     139.598                 22,318                  389,446,163
2,118,544
00118.M2TS      4352 (0x1100)   0x86            DTS-HD MA       arc (Aramaic)           139.598                 4,382                   76,467,760
437,455
00118.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           139.598                 224                     3,912,832
21,835
00118.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           139.598                 224                     3,912,832
21,835
00118.M2TS      4355 (0x1103)   0x81            AC3             eng (English)           139.598                 224                     3,912,832
21,835
00118.M2TS      4356 (0x1104)   0x81            AC3             eng (English)           139.598                 224                     3,912,832
21,835
00118.M2TS      4357 (0x1105)   0x81            AC3             eng (English)           139.598                 224                     3,912,832
21,835
00118.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           139.598                 1                       17,625
110
00118.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           139.598                 4                       61,606
378
00118.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           139.598                 1                       15,947
100
00118.M2TS      4611 (0x1203)   0x90            PGS             por (Portuguese)        139.598                 1                       13,143
85
00118.M2TS      4612 (0x1204)   0x90            PGS             zho (Chinese)           139.598                 1                       13,403
87
00118.M2TS      4613 (0x1205)   0x90            PGS             kor (Korean)            139.598                 1                       16,326
102
00118.M2TS      4614 (0x1206)   0x90            PGS             zho (Chinese)           139.598                 1                       14,506
93
00118.M2TS      4615 (0x1207)   0x90            PGS             tgl (Tagalog)           139.598                 1                       14,618
93
00118.M2TS      4616 (0x1208)   0x90            PGS             tha (Thai)              139.598                 1                       16,110
101
00118.M2TS      4617 (0x1209)   0x90            PGS             spa (Spanish)           139.598                 35                      614,150
3,531
00118.M2TS      4618 (0x120A)   0x90            PGS             por (Portuguese)        139.598                 35                      616,386
3,543
00118.M2TS      4619 (0x120B)   0x90            PGS             kor (Korean)            139.598                 27                      478,780
2,791
00118.M2TS      4620 (0x120C)   0x90            PGS             spa (Spanish)           139.598                 64                      1,112,936
6,322
00118.M2TS      4621 (0x120D)   0x90            PGS             por (Portuguese)        139.598                 58                      1,018,936
5,811
00118.M2TS      4622 (0x120E)   0x90            PGS             kor (Korean)            139.598                 58                      1,005,913
5,740
00118.M2TS      4623 (0x120F)   0x90            PGS             spa (Spanish)           139.598                 81                      1,411,563
8,029
00118.M2TS      4624 (0x1210)   0x90            PGS             por (Portuguese)        139.598                 86                      1,497,068
8,488
00118.M2TS      4625 (0x1211)   0x90            PGS             kor (Korean)            139.598                 65                      1,126,987
6,483
00118.M2TS      4626 (0x1212)   0x90            PGS             spa (Spanish)           139.598                 42                      731,595
4,144
00118.M2TS      4627 (0x1213)   0x90            PGS             por (Portuguese)        139.598                 43                      753,537
4,265
00118.M2TS      4628 (0x1214)   0x90            PGS             kor (Korean)            139.598                 30                      531,952
3,055
00121.M2TS      4113 (0x1011)   0x1B            AVC                                     1744.243                22,291                  4,860,169,806
26,438,594
00121.M2TS      4352 (0x1100)   0x86            DTS-HD MA       arc (Aramaic)           1744.243                4,019                   876,257,728
5,033,609
00121.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           1744.243                224                     48,841,856
272,555
00121.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           1744.243                224                     48,841,856
272,555
00121.M2TS      4355 (0x1103)   0x81            AC3             eng (English)           1744.243                224                     48,841,856
272,555
00121.M2TS      4356 (0x1104)   0x81            AC3             eng (English)           1744.243                224                     48,841,856
272,555
00121.M2TS      4357 (0x1105)   0x81            AC3             eng (English)           1744.243                224                     48,841,856
272,555
00121.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           1744.243                8                       1,811,492
10,517
00121.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           1744.243                13                      2,740,328
16,143
00121.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           1744.243                8                       1,760,535
10,246
00121.M2TS      4611 (0x1203)   0x90            PGS             por (Portuguese)        1744.243                8                       1,697,350
9,894
00121.M2TS      4612 (0x1204)   0x90            PGS             zho (Chinese)           1744.243                7                       1,546,667
9,080
00121.M2TS      4613 (0x1205)   0x90            PGS             kor (Korean)            1744.243                6                       1,291,505
7,707
00121.M2TS      4614 (0x1206)   0x90            PGS             zho (Chinese)           1744.243                7                       1,439,196
8,493
00121.M2TS      4615 (0x1207)   0x90            PGS             tgl (Tagalog)           1744.243                11                      2,292,693
13,132
00121.M2TS      4616 (0x1208)   0x90            PGS             tha (Thai)              1744.243                8                       1,835,618
10,639
00121.M2TS      4617 (0x1209)   0x90            PGS             spa (Spanish)           1744.243                45                      9,894,448
56,762
00121.M2TS      4618 (0x120A)   0x90            PGS             por (Portuguese)        1744.243                47                      10,176,007
58,296
00121.M2TS      4619 (0x120B)   0x90            PGS             kor (Korean)            1744.243                34                      7,347,610
42,893
00121.M2TS      4620 (0x120C)   0x90            PGS             spa (Spanish)           1744.243                51                      11,213,091
63,727
00121.M2TS      4621 (0x120D)   0x90            PGS             por (Portuguese)        1744.243                50                      10,806,186
61,507
00121.M2TS      4622 (0x120E)   0x90            PGS             kor (Korean)            1744.243                42                      9,093,716
52,204
00121.M2TS      4623 (0x120F)   0x90            PGS             spa (Spanish)           1744.243                69                      14,964,640
85,066
00121.M2TS      4624 (0x1210)   0x90            PGS             por (Portuguese)        1744.243                70                      15,219,774
86,442
00121.M2TS      4625 (0x1211)   0x90            PGS             kor (Korean)            1744.243                54                      11,815,329
67,926
00121.M2TS      4626 (0x1212)   0x90            PGS             spa (Spanish)           1744.243                27                      5,970,550
34,086
00121.M2TS      4627 (0x1213)   0x90            PGS             por (Portuguese)        1744.243                27                      5,898,833
33,692
00121.M2TS      4628 (0x1214)   0x90            PGS             kor (Korean)            1744.243                19                      4,223,643
24,587
00095.M2TS      4113 (0x1011)   0x1B            AVC                                     422.297                 22,303                  1,177,319,701
6,404,440
00095.M2TS      4352 (0x1100)   0x86            DTS-HD MA       arc (Aramaic)           422.297                 4,041                   213,295,660
1,225,592
00095.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           422.297                 224                     11,828,096
66,005
00095.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           422.297                 224                     11,828,096
66,005
00095.M2TS      4355 (0x1103)   0x81            AC3             eng (English)           422.297                 224                     11,828,096
66,005
00095.M2TS      4356 (0x1104)   0x81            AC3             eng (English)           422.297                 224                     11,828,096
66,005
00095.M2TS      4357 (0x1105)   0x81            AC3             eng (English)           422.297                 224                     11,828,096
66,005
00095.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           422.297                 3                       162,601
982
00095.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           422.297                 8                       411,938
2,476
00095.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           422.297                 3                       172,142
1,035
00095.M2TS      4611 (0x1203)   0x90            PGS             por (Portuguese)        422.297                 3                       171,676
1,032
00095.M2TS      4612 (0x1204)   0x90            PGS             zho (Chinese)           422.297                 3                       147,312
899
00095.M2TS      4613 (0x1205)   0x90            PGS             kor (Korean)            422.297                 3                       170,302
1,025
00095.M2TS      4614 (0x1206)   0x90            PGS             zho (Chinese)           422.297                 3                       146,691
896
00095.M2TS      4615 (0x1207)   0x90            PGS             tgl (Tagalog)           422.297                 4                       201,304
1,192
00095.M2TS      4616 (0x1208)   0x90            PGS             tha (Thai)              422.297                 3                       184,531
1,093
00095.M2TS      4617 (0x1209)   0x90            PGS             spa (Spanish)           422.297                 45                      2,355,542
13,508
00095.M2TS      4618 (0x120A)   0x90            PGS             por (Portuguese)        422.297                 45                      2,366,859
13,573
00095.M2TS      4619 (0x120B)   0x90            PGS             kor (Korean)            422.297                 32                      1,682,988
9,853
00095.M2TS      4620 (0x120C)   0x90            PGS             spa (Spanish)           422.297                 55                      2,919,057
16,602
00095.M2TS      4621 (0x120D)   0x90            PGS             por (Portuguese)        422.297                 54                      2,831,029
16,124
00095.M2TS      4622 (0x120E)   0x90            PGS             kor (Korean)            422.297                 45                      2,385,567
13,702
00095.M2TS      4623 (0x120F)   0x90            PGS             spa (Spanish)           422.297                 66                      3,463,910
19,618
00095.M2TS      4624 (0x1210)   0x90            PGS             por (Portuguese)        422.297                 64                      3,378,952
19,150
00095.M2TS      4625 (0x1211)   0x90            PGS             kor (Korean)            422.297                 54                      2,849,538
16,276
00095.M2TS      4626 (0x1212)   0x90            PGS             spa (Spanish)           422.297                 9                       468,749
2,709
00095.M2TS      4627 (0x1213)   0x90            PGS             por (Portuguese)        422.297                 9                       478,322
2,761
00095.M2TS      4628 (0x1214)   0x90            PGS             kor (Korean)            422.297                 7                       360,072
2,119
00093.M2TS      4113 (0x1011)   0x1B            AVC                                     776.067                 22,162                  2,149,939,082
11,695,392
00093.M2TS      4352 (0x1100)   0x86            DTS-HD MA       arc (Aramaic)           776.067                 4,119                   399,549,212
2,292,815
00093.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           776.067                 224                     21,734,272
121,285
00093.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           776.067                 224                     21,734,272
121,285
00093.M2TS      4355 (0x1103)   0x81            AC3             eng (English)           776.067                 224                     21,734,272
121,285
00093.M2TS      4356 (0x1104)   0x81            AC3             eng (English)           776.067                 224                     21,734,272
121,285
00093.M2TS      4357 (0x1105)   0x81            AC3             eng (English)           776.067                 224                     21,734,272
121,285
00093.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           776.067                 0                       24,154
151
00093.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           776.067                 1                       112,065
683
00093.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           776.067                 0                       43,473
264
00093.M2TS      4611 (0x1203)   0x90            PGS             por (Portuguese)        776.067                 0                       43,660
266
00093.M2TS      4612 (0x1204)   0x90            PGS             zho (Chinese)           776.067                 0                       33,643
212
00093.M2TS      4613 (0x1205)   0x90            PGS             kor (Korean)            776.067                 0                       37,900
234
00093.M2TS      4614 (0x1206)   0x90            PGS             zho (Chinese)           776.067                 0                       34,935
219
00093.M2TS      4615 (0x1207)   0x90            PGS             tgl (Tagalog)           776.067                 0                       29,591
183
00093.M2TS      4616 (0x1208)   0x90            PGS             tha (Thai)              776.067                 0                       44,651
269
00093.M2TS      4617 (0x1209)   0x90            PGS             spa (Spanish)           776.067                 45                      4,352,549
24,897
00093.M2TS      4618 (0x120A)   0x90            PGS             por (Portuguese)        776.067                 45                      4,377,737
25,031
00093.M2TS      4619 (0x120B)   0x90            PGS             kor (Korean)            776.067                 33                      3,179,947
18,519
00093.M2TS      4620 (0x120C)   0x90            PGS             spa (Spanish)           776.067                 29                      2,818,801
16,027
00093.M2TS      4621 (0x120D)   0x90            PGS             por (Portuguese)        776.067                 29                      2,784,090
15,836
00093.M2TS      4622 (0x120E)   0x90            PGS             kor (Korean)            776.067                 24                      2,341,167
13,419
00093.M2TS      4623 (0x120F)   0x90            PGS             spa (Spanish)           776.067                 57                      5,546,540
31,482
00093.M2TS      4624 (0x1210)   0x90            PGS             por (Portuguese)        776.067                 57                      5,547,894
31,492
00093.M2TS      4625 (0x1211)   0x90            PGS             kor (Korean)            776.067                 48                      4,663,181
26,663
00093.M2TS      4626 (0x1212)   0x90            PGS             spa (Spanish)           776.067                 49                      4,726,662
26,753
00093.M2TS      4627 (0x1213)   0x90            PGS             por (Portuguese)        776.067                 50                      4,881,251
27,592
00093.M2TS      4628 (0x1214)   0x90            PGS             kor (Korean)            776.067                 35                      3,423,771
19,664
Xylon is offline
post #2085 of 2128 Old 04-11-2009, 06:12 AM - Thread Starter
Xylon's Avatar
Xylon is offline
post #2086 of 2128 Old 04-11-2009, 06:53 AM
Patsfan123's Avatar
Quoted: 470 Post(s)
Liked: 309
Nice Xylon.. I miss this thread. The BD keeps the grain structure intact although there isn't much to complain about on the DTheater tape.
post #2087 of 2128 Old 04-12-2009, 04:37 AM - Thread Starter
Xylon's Avatar
Xylon is offline
post #2088 of 2128 Old 05-19-2009, 07:25 AM
eric.exe's Avatar
Quoted: 106 Post(s)
Liked: 44
[pic host dead]
eric.exe is offline
post #2089 of 2128 Old 07-30-2009, 06:35 PM
msgohan's Avatar
HD DVD
Code:
        Total   Video
Title                                   Codec   Length  Movie Size      Disc Size       Bitrate Bitrate Main Audio Track        IME     Secondary Audio Track
(UK) Pan's Labyrinth                    VC-1    1:58:43 20,986,124,288* 28,030,399,774  23.56   21.48   DDPlus 5.1 1536Kbps     No
Blu-ray
Code:
        Total  Video
Title                                    Codec   Length  Movie Size      Disc Size       Bitrate Bitrate Main Audio Track                          Secondary Audio Track
(UK) Pan's Labyrinth                     VC-1    1:58:56 28,573,224,960  36,599,330,132  32.03   29.45   DD AC3 5.1 640Kbps                        DD AC3 2.0 224Kbps
Case comparison pix
21.48Mbps VC-1 vs 29.45Mbps VC-1 screencap comparison - Mouseovers here
On the commentary, Guillermo Del Toro said the final image was his "favorite shot".
LG B7 (OLED65B7P, 2017)
UHD: Philips BDP7501 | HD: PS3, WD TV Live
Denon AVR-890 (2009)
msgohan is offline
post #2090 of 2128 Old 07-30-2009, 09:32 PM
bplewis24's Avatar
Is #6 solely a result of DNR or is there some loss of HFD with the encoding?
Brandon
post #2091 of 2128 Old 07-30-2009, 10:42 PM
msgohan's Avatar
I bet I could take the Blu-ray and re-encode it at 21Mbps and keep all the rain unlike the HD DVD. If that's what you mean.
msgohan is offline
post #2092 of 2128 Old 07-30-2009, 11:17 PM - Thread Starter
Xylon's Avatar
UK Blu-ray wins this one. HD DVD UK scrubbed. Thank you DNR amateur artists
Xylon is offline
post #2093 of 2128 Old 08-02-2009, 06:44 PM
msgohan's Avatar
Code:
        Video                                           Total
 Region  Year   Title                                                           Codec   Display Aspect  Bitrate Length  Movie Size      Disc Size       Bitrate Primary Language Audio
ABC [DK] 1994   Pulp Fiction                                                    AVC     1080p24 2.35:1  24.81   2:34:20 36,598,665,216  36,723,700,812  31.62   DTS-MA  5.1    48/24  4382  / AC3     5.1    48     640
 B  [FR] 1994   Pulp Fiction                                                    AVC     1080p24 2.35:1  26.95   2:34:24 38,332,047,360  48,749,470,384  33.10   DTS-MA  5.1    48/16  1985
24.81Mbps AVC vs 26.95Mbps AVC screencap comparison - Mouseovers here
Not only does the Danish SF Film release have significantly more blocking despite only being 2.14Mbps less, they did automated digital scratch removal on it leaving all those "painted" artifacts you see. Thankfully for the most part these aren't visible in motion (though some are, like the sections of the blinds disappearing throughout the first minute of the film).
And despite displaying no signs of automated scratch removal, the French TF1 release actually has FEWER print anomalies as you can see in screenshot #1, #3, and #6. I wonder if they went through a manual process to paint them out.
Sadly the superior French Blu-ray is Region B locked with forced French subs and has PAL higher-pitch audio.
msgohan is offline
post #2094 of 2128 Old 08-03-2009, 04:35 PM - Thread Starter
Xylon's Avatar
Where did the fine film grain go? I will check if I still have the broadcast version.
Xylon is offline
post #2095 of 2128 Old 08-03-2009, 04:50 PM
eric.exe's Avatar
Quoted: 106 Post(s)
Liked: 44
Why would the pitch be higher if they are both 23.976?
Heres are some more comparisons I made, French on left, Nordic on right
eric.exe is offline
post #2096 of 2128 Old 08-03-2009, 05:28 PM
msgohan's Avatar
No idea. Was there ever a reason found for why the same thing happened with those StudioCanal HD DVDs?
Are you saying you don't hear it? I wasn't sure at first but I switched back and forth comparing dialogue and particularly music. It's definitely not just in my imagination, though I suppose it could theoretically be some strange decode issue on my end.
EDIT: Oh my god, your last pair of caps! Was the camera doing a whip during that shot or what? Surely that one's noticeable in motion.
msgohan is offline
post #2097 of 2128 Old 08-05-2009, 03:11 PM
eric.exe's Avatar
Quoted: 106 Post(s)
Liked: 44
I did hear a difference, but neither had that annoying chipmunk sound. When listening to parts with music, the Nordic version sounded "faster".
eric.exe is offline
post #2098 of 2128 Old 08-12-2009, 02:20 AM
msgohan's Avatar
All of the added Unrated Director's Cut footage is really easy to spot because it's upscaled SD (on both discs). There's even enlarged interlace lines at times. Strange since the other Saw films don't have this issue.
Full specs here
23.15Mbps MPEG-2 vs 24.90Mbps VC-1 screencap comparison - Mouseovers here
msgohan is offline
post #2099 of 2128 Old 08-12-2009, 03:32 PM
stumlad's Avatar
Quoted: 147 Post(s)
Liked: 60
Pic 2 seems to look worse on the US disc. Pic 7 - if you look at the girls's face, the US has weird blocking there. The rest seem close enough that i wouldnt be too disappointed with either (not counting the interlacing). Grain retention seems a bit better on the US, but it may be little macro blocks disguised as grain
I own the first two but havent watched them yet. My wife said we can rewatch them all once the last one comes out, but doesnt like them too much so these wont be repeated viewings My US version will suit me.
I'm glad that the US and DE discs are close enough in color... when watching Saw IV and V , i was wondering if they pulled off another Descent because those two were really washed out looking.
stumlad is offline
post #2100 of 2128 Old 08-12-2009, 04:04 PM
bplewis24's Avatar
Pic 2 I believe is the one that has all of the blocking on the US encode, right? Now I wish I paid more attention to all of those posts about the "deblocking" filter or loop thingie in the VC1 codec.
On a side note, I do appreciate that the coding frame size is included with each capture.
Brandon
Reply HDTV Software Media Discussion
