Plex vs. EyeTV - is it worth switching? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-12-2019, 07:51 AM - Thread Starter
jdonigan's Avatar
I have EyeTV running on my Mac Mini with 2 HDHomeRun Duals, and things are working properly. I see that Plex has a product that should do the same things. I also see that I would pay $120 for a "lifetime" sub. Does Plex have more going for it than what I'm used to with EyeTV? Thanks in advance!
John
I swear I'll burn those downloaded Replay files to DVD!
(Someday.)
jdonigan is offline
post #2 of 4 Old 01-27-2019, 04:21 PM
beerhunt's Avatar
Quoted: 55 Post(s)
Liked: 30
you may get a quicker response from the folks in this very informative thread:
https://www.avsforum.com/forum/26-ho...on-thread.html
beerhunt is offline
post #3 of 4 Old 02-12-2019, 04:07 PM - Thread Starter
jdonigan's Avatar
I guess I have no choice, now that EyeTV has quit connecting to the TV Guide program guide server.
Thanks, beerhunt.
John
(Someday.)
jdonigan is offline
post #4 of 4 Old 02-13-2019, 10:32 AM
csmith's Avatar
Quoted: 76 Post(s)
Liked: 31
Thanks, beerhunt.
Don't have a Mac, but you could use another program to get the guide, for example, I used to use mc2xml with schedules direct (SD - $25/yr) on my (linux) Kodi with TvHeadEnd dvr/pvr software. In the past, it would also scrub info from Windows Media Center's guide too, for free, I don't recommend doing that long term...but it is an easy way to see if it can be done with your setup. Zap2xml is another one.
http://mc2xml.hosterbox.net/
https://kcore.org/2009/01/07/using-xmltv-with-eyetv/
csmith is offline
Reply HTPC - Mac Chat
eyetv , hdhomerun , mac mini , plex
