Epson ELPALK2 Anamorphic Lens and JVC RS50? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 05-16-2011, 09:48 AM - Thread Starter
Jim Parys's Avatar
Quoted: 92 Post(s)
Liked: 53
Can anyone confirm that the subject lens will work with a JVC RS50. My projector is currently on a poll mount about 2 feet off the ceiling. Can I use the lens with this setup and if so what other mounting hw would I need to purchase.
thx,
Jim Parys is Living the dream...
La Sirena III Theater
Jim Parys is offline
post #2 of 4 Old 05-16-2011, 03:52 PM
nightfly85's Avatar
Quoted: 85 Post(s)
Liked: 44
Is the ELPALK2 based on the panamorph uh380? If so, the uh380 has some issues with JVC FPs. Do a search for "UH380 JVC" for more details.
As always, it comes down to throw ratio. If >= 2.0 you should be ok with pretty much any lens.
JVC 4910, Marantz 7010 AVR, HTPC MPC-HC/MPC-BE x64; MadVR/LAV
nightfly85 is offline
post #3 of 4 Old 05-16-2011, 08:00 PM - Thread Starter
Jim Parys's Avatar
Quoted: 92 Post(s)
Liked: 53
I have heard its basically a Panmorph 480
post #4 of 4 Old 05-19-2011, 06:15 AM
CAVX's Avatar
Quoted: 374 Post(s)
Liked: 180
Are you planning on moving the lens or leaving it in place? If leaving it in place, you can pretty much use you pole mount. If moving it, you need to take the weight shift into consideration.
Mark Techer
I love my Constant Image Height system!
CAVX is offline
Reply 2.35:1 Constant Image Height Chat
Jvc Rs50u
