Jvc rs540 with a isco iiiL question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 10-06-2018, 10:26 AM - Thread Starter
ohioratrodder's Avatar
Quoted: 23 Post(s)
Liked: 0
I have a 150" 2.40:1 (120" 16x9) screen and my projector lens is 16ft from the screen would a isco iiiL work without moving the projector. Also how much pincushion would I have, my screen is flat but has 3" boarders
ohioratrodder is offline
post #2 of 6 Old 10-06-2018, 03:01 PM
ScottAvery's Avatar
Quoted: 698 Post(s)
Liked: 204
Yes, it will fit with room to spare. I think you can search for a calculator/spreadsheet made by Aussiebob or similar to get info on pincushion and potential screen curve radius to eliminate it.
Mine is at 15 feet now, 135 inch 2.4:1 and there is maybe an inch of overscan in each corner
ScottAvery is offline
post #3 of 6 Old 10-06-2018, 03:34 PM - Thread Starter
Quoted: 23 Post(s)
Liked: 0
Thanks, how much pincushion do you have
post #4 of 6 Old 10-06-2018, 03:52 PM
ScottAvery's Avatar
Quoted: 698 Post(s)
Liked: 204
I am guessing about an inch off in each corner, maybe an inch and a half. It will be far less than your black border at any rate.
Are you currently zooming to fill that?
post #5 of 6 Old 10-06-2018, 04:05 PM - Thread Starter
Quoted: 23 Post(s)
Liked: 0
Yes, I am happy with zooming but recently upgraded to a rs540(had a rs400) plus finally bought 3d glasses. I have seen a few deals on isco iii recently and been thinking of buying one for extra lumens for 3d and hdr
post #6 of 6 Old 10-12-2018, 01:07 PM
jjcook's Avatar
Quoted: 468 Post(s)
Liked: 189
You are at a comfortable 1.87 throw ratio for the lens with minimal pincushion (~0.74 inches) so curved screen is not really needed.
Name:	Screen Shot 2018-10-12 at 10.58.07 AM.png
jjcook is offline
Reply 2.35:1 Constant Image Height Chat
