Marantz 8802a not stretching - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 03-10-2019, 08:31 AM - Thread Starter
Quoted: 144 Post(s)
Liked: 211
OK, so I think I have a mystery on my hands.
For the longest time I have been running my Nvidia Shield through the Oppo 205 to do the vertical stretch. My projector (Benq TK800) doesnt do it, nor the Nvidia has that option. So the Oppo it is. Yet for the longest time I have tried to get my "Vertical Stretch" option to work on my 8802a so I can bypass the 205 and plug the Shield directly into the 8802a... but to no avail. Turning "vertical stretch" on/off makes zero difference to the output on my projector.
The manual says that "vertical stretch" can be set when "ip scaler" is set to anything but "off". I find this to be wrong as "vertical stretch" is always available as an option regardless of "ip scaler" setting. I have tried ofcourse to stretch with "ip scaler" "on" and "off".... no difference.
Honestly I dont think there is issue with running the Shield through the 205, but... it bugs me. For the principle...
Any ideas?
Thank you
partcrash is offline
post #2 of 2 Old 03-10-2019, 09:50 AM - Thread Starter
Quoted: 144 Post(s)
Liked: 211
Nevermind. Found the answer... 4k at 60fps is a no-no for stretching with the Marantz.
Hope this helps to somebody with a similar issue.
Reply 2.35:1 Constant Image Height Chat
