everything but the screen and projector.. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 03-15-2019, 04:13 PM - Thread Starter
Liked: 1
CIH group,
Need suggestions... I need help figuring out the best way to get a true 4k and CIH set up around 150"wide....easily confused with reading thru the threads... Will diy my screen for now. maybe a SI screen next year. I've focused on the Sony 695 and the JVC nx5 or the nx7.
695es without a-lens? does it need it? thought I could run this w/o a-lens...if needed, then JVC...
nx5 or nx7 with or without a-lens?
room specs:
-dedicated movie room, total light control
-95%movies...occasional soccer/football/basketball
-matte dark blue walls and ceiling with dark grey carpet
-18ft wide by 23ft long; 1st row is about 12ft back
-projector can be mounted as close as necessary or as far back as needed - no overhead obstructions
-have a 7.1.4 set up right now. will likely move to 7.2.4 in the future
-denon x6400, oppo 203, apple tv 4k, svs sub, rest def tech
any advice/help is greatly appreciated.
thanks!!
JH
65" Sony A1E
tjh7 is offline
post #2 of 3 Old 03-16-2019, 08:45 AM
microwiz's Avatar
Quoted: 282 Post(s)
Liked: 194
Its going to be a challenge to light that screen up with any of the combos you mentioned. Your going to need a high gain screen, all those projectors are going to struggle and remember the bulb will dim over time.
Pick a high gain screen and projector first then finish up with a lens if that doesn't quite get you there.
Pioneer SC-95, Axiom M80, VP180 Dual EP500 all V4. ISCO III, RS540 + Stewart Cima Neve 133
microwiz is offline
post #3 of 3 Old 03-16-2019, 07:22 PM - Thread Starter
Liked: 1
Thanks for taking the time to help me out!!
I'll do exactly that. nx7 or the 695es and buy a screen...then grab a lens next year or so.
again, thanks for your help!!
JH
65" Sony A1E
tjh7 is offline
Reply 2.35:1 Constant Image Height Chat
