I THINK i get CIH... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 04-12-2019, 02:21 PM - Thread Starter
MinHeadroom's Avatar
Quoted: 56 Post(s)
Liked: 63
Hi and thanks,
I’ve never used a projector and am planning my first purchase. I’m also framing my basement and near to running conduit and electrical.
So if l
a) I use the pj’s zoom to fill 2.39:1 (at 120” diag), and
b) i use no zoom for 16:9 (94.4” diag), both using a 46.3” height screen,
THEN
c) For a projected image to fill a 2.39:1 screen with an image, I am projecting a big 16:9 image (127” diag), where the “black bars” are just above and below the screen.
I got this right?
If so, assuming i have a light controlled room covered in black velvet, how important is it for me to put the pj as close to the screen as possible?
(Assume I’m using a 1 gain screen and an Epson 5050 for now please).
If I can manage 16’ to the screen, I can put the PJ in a hush box going into a crawl space.
Last question: If I am getting this right, how critical is it for the lens of the PJ to be at the top of the screen in order to do CIH? I think it depends on lens shift and lens memory, but I-may be missing something. I understand, at least superficially, the lens must be below the top of the screen.
MinHeadroom is offline
post #2 of 5 Old 04-13-2019, 12:41 AM
ScottAvery's Avatar
Quoted: 672 Post(s)
Liked: 192
Your screen size math looks correct. Use an online projector calculator to get the throw range for your screen size. The one I checked says 78 to 163 inch diagonal 16:9 range for a 16 foot throw, so well in range. You could get a brighter image if you got closer, but that is a tradeoff on noise. I'd go with the longer throw, personally, if there was an option for a hushbox.
As long as you are keeping the projector on the centerline there is plenty of room for vertical offset, up to and above screen. Range is reduced if you have to horizontal shift, also. There is a calculator built by one of the forum users that does precise lens shift calculations, but the link is not in my favorites. Perhaps someone else can provide it if you need it.
ScottAvery is offline
post #3 of 5 Old 04-13-2019, 12:45 AM
ScottAvery's Avatar
Quoted: 672 Post(s)
Liked: 192
Screen seems a little small for a room with 16 foot depth. Are you width limited? I see the ceiling is low but that is not as much an issue for CIH.
post #4 of 5 Old 04-13-2019, 05:02 AM - Thread Starter
Quoted: 56 Post(s)
Liked: 63
Thank you- this jives with what I imagined, your confirmation appreciated!
post #5 of 5 Old 04-13-2019, 05:04 AM - Thread Starter
Quoted: 56 Post(s)
Liked: 63
That’s good to hear given my fear i was going too big. I’m going for two rows (the second sub-optimal), but the main seat will be ~ 9.5’ from the screen. Room width is 13’:
Reply 2.35:1 Constant Image Height Chat
