Replacement for Pan AE4000...CIH without lens - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 04-28-2019, 10:31 AM - Thread Starter
agnathra's Avatar
Quoted: 29 Post(s)
Hi folks, my ae4000 is getting old so i've been looking at these threads to see what the obvious replacement is. If there is one, i can't find it.
So if i don't want to get an anamorphic lens, is there a model people generally get that will allow the same kind of lens position/focus memory, so i can change between 16x9 and 2.35:1?
the AR autosensing and changing isn't really important to me (it tends to get fooled by video games), but switching between AR's with a handful of remote clicks is crucial. 4K would be ideal, but not a deal breaker. And the cheaper the better, but $3000 would be the rough ceiling.
Any ideas? the panny was just great, and current epson features seem to do this, but i'm afraid i maybe misunderstanding features since i see so much talk about extra lenses, which just sounds like a lot of work if an epson will do it .
Thanks everyone in advance, and for the last 15 years of your amazing help!
- Chris
agnathra is offline
post #2 of 4 Old 04-28-2019, 03:10 PM
dschulz's Avatar
Quoted: 836 Post(s)
Liked: 591
If you have just a bit of wiggle room on the budget, take a look at the JVC projectors. Their D-ILA (as opposed to the more-common DLP) gives lovely black levels and very pleasing film-like images, and the 4K e-Shift is a very capable faux 4K image technology. And they have lens memory to do widescreen without an A-lens.
dschulz is offline
post #3 of 4 Old 05-01-2019, 05:12 AM
abhilash220's Avatar
Quoted: 21 Post(s)
Liked: 1
If you are lucky you may be able to find a JVC x590r. Or if you can stretch a little bit, X790R which won't be easy to get a hold of.
abhilash220 is offline
post #4 of 4 Old 05-01-2019, 12:26 PM - Thread Starter
agnathra's Avatar
Quoted: 29 Post(s)
thanks for the responses!
- Chris
agnathra is offline
Reply 2.35:1 Constant Image Height Chat
