Where to Mount CIH Projector? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 07-08-2019, 03:09 PM - Thread Starter
Liked: 0
Hi,
I have an Epson 5040ub projector with lens memory I'd like to set up with CIH. I can do an 39" vertical and want to switch between 16:9 and 2.35:1 and just accept black bars on the sides when viewing in 16:9. How do I determine the range of possible mounting positions (distance from screen)? I'm trying to figure out projector calculators with my zoom, etc but need advice.
According to Projector Central, I have a 2.10:1 zoom and 1.35-2.84 throw ratio...
Thank you,
Alex
EDIT: I changed 80" vertical to 39" because I got confused. An 80" 16:9 screen has a 39" vertical. I need help figuring out the range of distances where I can mount my projector to project 39" high picture in 16:9 and 2.35:1
dragonist2 is offline
post #2 of 4 Old 07-10-2019, 10:28 AM
jeahrens's Avatar
Quoted: 2019 Post(s)
Liked: 1296
Originally Posted by dragonist2 View Post
Hi,
Thank you,
Alex
The easiest way to do this when using lens memory is to get the distances for two 16:9 screens. The first 16:9 screen is using the height of the screen (so 69"W x 39"H). The second 16:9 screen is using the width of the 2.35:1 screen (so 92"W x 52" H). Where these 2 16:9 screens overlap in throw distance is where you can mount your projector. I would mount towards the close end of the overlap with at least a 6" cushion.
jeahrens is offline
post #3 of 4 Old 07-10-2019, 11:59 AM - Thread Starter
Liked: 0
Thank you for the clear and helpful reply!
So according to the Projector Central calculator for this model:
At 39" image height, I can do 7'9" to 16'3". At 92" image width, I can do 10'4" to 21'9". So 10'4" to 16'3" seems to be the range.
I know you suggested to err on the lower end of possible mounting distances, but that 16 foot upper limit would actually let me slot the projector into this nice weird cubby that the room has so I will try that first just by placing it on a tall shelf, etc to see if that's possible.
Thanks again for your help. I've been scouring the forum and internet for how to calculate possible mounting positions without success (probably because I'm bad at searching), but I now feel like I have a solid starting point to go out and start testing.
post #4 of 4 Old 07-10-2019, 01:13 PM
jeahrens's Avatar
Liked: 1296
The near end just increases light output some for a bit more pop. Far end will increase contrast and sharpness a bit at the expense of a little brightness. Looks like you've got the range right. Now enjoy that very nice Epson projector
jeahrens is offline
Reply 2.35:1 Constant Image Height Chat
