AVS Forum | Home Theater Discussions And Reviews (https://www.avsforum.com/forum/)
-   2.35:1 Constant Image Height Chat (https://www.avsforum.com/forum/117-2-35-1-constant-image-height-chat/)
-   -   Upgrade to replace my Panasonic AE8000U? (https://www.avsforum.com/forum/117-2-35-1-constant-image-height-chat/3083466-upgrade-replace-my-panasonic-ae8000u.html)
maxweb 08-08-2019 11:11 PM
Hello-
I've owned a succession of Panny AE series projectors and currently have the last AE8000U model. I run a constant-height 2:35:1 home-made screen and use programmed lens presets to automatically select between 2:35:1 and 16:9 sources. What should I be thinking about next? The AE8000U works ok but it would be nice to have HDR or even just brighter SDR someday. I like the auto-zoom feature of my projector that automatically switches lens presets when it detects letterboxing. Are there other projectors or processors that work this way?
Cheers
jeahrens 08-13-2019 02:22 PM
Originally Posted by maxweb (Post 58400588)
Hello-
Cheers
There aren't other projectors that auto switch to my knowledge. What budget are you working with?
maxweb 08-13-2019 05:11 PM
My budget is flexible depending on how long I wait and save up for a purchase. :)
In a one-year time frame I'm probably in the $5k-or-less range for a new projector setup, and unfortunately I think this keeps me out of the external anamorphic lens club.
jeahrens 08-14-2019 07:29 AM
That's fine. You'd need a lot more than $5K to get a lens and projector and today's units work well without a lens.
For that budget range my recommendation would be a JVC NX5 or Epson 5050UB. The Epson will get you slightly more calibrated lumens to work with if you have a larger screen. The JVC will have better contrast, better optics, better motion handling and a native 4K panel (the Epson uses pixel shifting of a 1080 panel for 4K). The JVC also has a 17:9 panel which means for ARs wider than 1.85:1 you can get a bit of extra pixel fill and light (though the Epson will still be brighter). Both will handle 4K very well.
If your screen is less than 150" with that budget the NX5 would be my pick here.
Powered by vBulletin® Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
