speaker placement behind CIH screen for 16:9 content - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By bud16415
post #1 of 5 Unread 08-18-2019, 07:32 AM - Thread Starter
gnarlycow's Avatar
I was wondering if this was a dumb thing to do. I am leaning more towards getting a cinemascope screen instead of a 16:9 one. However, since there will be regular tv being watched on this screen as well some times, I am wondering if I should place my speakers behind where the 16:9 portion of my cinemascope screen would be, so that when 16:9 content is being displayed, I could have curtains or something come in and cover the black bar areas of the screen, and the sound not being affected. Since I don't want to have the curtains in front of where the speakers would be if my speakers were wide apart, I thought perhaps putting the speakers outside the curtain area would be good, and then I could have the option of 16:9 or cinemascope watching.
However, if that would ruin the cinemascope movie watching, then I won't do that, and I will put the speakers wide behind the cinenascope screen, and then perhaps get the accoustically transparent cloth to make curtains out of. I just want to hide the black bar area.
What do you guys recommend?
gnarlycow is offline
post #2 of 5 Unread 08-18-2019, 07:53 AM
bud16415's Avatar
Quoted: 2102 Post(s)
Liked: 1054
I believe most people put them just inside the 16:9 area.
CAVX likes this.
Bud
bud16415 is offline
post #3 of 5 Unread 08-18-2019, 06:18 PM
dschulz's Avatar
Quoted: 835 Post(s)
Liked: 591
This really depends on your screen size and viewing distance, as by far the most important thing here is that the speakers be separated by the appropriate distance and angles from the main listening position. The L/R speakers should each be 30 degrees off the centerline (give or take a few degrees) from the main listening position. If that puts them outside the 16:9 framelines then look into acoustically transparent masking. My favorite budget solution is the approach from Seymour AV - they use a steel frame for their screen, and you can get acoustically transparent masking panels that mount to the screen using magnets, making them easy to add or remove as needed.
dschulz is offline
post #4 of 5 Unread 08-20-2019, 05:05 AM
CAVX's Avatar
Quoted: 374 Post(s)
Liked: 180
For once, bud and I are in total agreement.
When I was moving to CIH around 2005, I made a set up that allowed me to shift the L and R speakers. At the time, all LCRs were below the screen.
My screen is not even that big, yet there is perfectly clear stereo separation with the speakers just inside the 16:9 portion of the Scope screen.
The proof of the testing I did came from simply listening to film sound track that have are older and we've all heard hundreds of times.
The idea of using an AT screen is so that sound and picture match better than if the sound comes from outside the screen area.
My listening tests confirmed that placement just inside the 16:9 area worked better than when the speakers were inline with the edges of the Scope screen for both movies in Scope and flat. In fact, movies in flat became annoying with the speakers inline with edges of the Scope screen.
And then there was 4x3 content.
What I have attempted to achieve is a seamless blend of sound and picture and to hopefully reproduce the effect heard in a good cinema. I believe I have done that.
Sent from my CPH1701 using Tapatalk
Mark Techer
I love my Constant Image Height system!
CAVX is offline
post #5 of 5 Unread 08-20-2019, 05:12 AM
bud16415's Avatar
Liked: 1054
It was bound to happen sooner or later.
CAVX likes this.
Bud
bud16415 is offline
Reply 2.35:1 Constant Image Height Chat
cih , cinemascope , speaker placement
