Oppo 203 and CIH - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 09-06-2019, 07:44 AM - Thread Starter
Adamr1982's Avatar
Liked: 0
Oppo 203 and CIH
Hey Oppo 203 owners. Do any of you use the Oppo built in 21:9 aspect switching for your CIH setups? If so, how well does it work compared to a Lumagen? I recently upgraded projectors and it came with a UB-820. I really like the player, but I am really missing the instant aspect switching that I had with my Lumagen mini-3D. Also, when watching variable aspect movies such as MI: Fallout, are you able to use the player to mask the top and bottom of the image and keep it in 2.35 aspect? Thanks for any info you guys have.
Adamr1982 is offline
post #2 of 5 Old 09-06-2019, 08:36 AM
Josh Z's Avatar
Quoted: 4135 Post(s)
Liked: 3154
Yes, this is possible in the OPPO 203. Assuming that you're doing Zoom Method CIH, set the aspect ratio setting for "21:9 Cropped" in the player's menus. Immediately, this will pillarbox a 16:9 input signal into the center of the 2.35:1 portion of the frame. Then hit the Zoom button on the remote to get to the "21:9" setting, which will fill the width of the screen while blanking off the top and bottom.
Josh Z
Home Theater Writer/Editor, High-Def Digest
My opinions are my own, and do not necessarily reflect those of my employers.
Josh Z is offline
post #3 of 5 Old 09-13-2019, 03:46 PM
Dan Hitchman's Avatar
Quoted: 4595 Post(s)
Liked: 2668
Does this screw up the image resolution if you are playing a 4k disc, especially in 21:9 cropped mode?
Listen up, studios! Dolby Atmos Lite™ print-outs must stop!!
Dan Hitchman is offline
post #4 of 5 Old 09-13-2019, 04:22 PM
Josh Z's Avatar
Liked: 3154
No. When you zoom up to "21:9" size, you should have 1:1 pixel mapping in the 2.35:1 portion of the frame. It just masks off the letterbox bars.
Josh Z
Josh Z is offline
post #5 of 5 Old 09-14-2019, 09:36 AM
ScottAvery's Avatar
Quoted: 674 Post(s)
Liked: 196
Well, watching 16x9 in 21:9 cropped mode does give up something on the order of 44% of the pixels. You are cropping 25% in both directions.
EDIT: nevermind, misunderstood.
ScottAvery is offline
Reply 2.35:1 Constant Image Height Chat
