Runco Whitney Vertical Compression & JVC RS45. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 01-06-2020, 02:50 PM - Thread Starter
Dennis Moore's Avatar
Quoted: 62 Post(s)
Hello there.
Looking at picking up a Runco Whitney lens for pretty cheap... but not sure it will work well with my setup, or benefit me in any real way.
Currently I have a 14' throw onto a 4' x 8' DIY screen. I can increase the throw distance by about a foot and a half, if I absolutely had to.
Ideally, I'd make a new screen that was 114" wide and 48" tall for a 2.39:1 screen... but I don't think I can even fill that in my room?
If I am doing my math right on the lens... I would need a throw distance of at least 17.2 feet for this (48 x 4.3). Is this correct?
So I would ask you all (if there is anyone that still frequents this forum regularly)... what is the largest image I can project (assuming a 16' max throw distance) without any adverse effects on the image through the lens?
My second question is an HTPC question... but I am assuming there are ways to leave the lens fixed and then scale 16:9 content, right? From what I gather, sliding the lens in and out of place would require two different zoom setups for different aspect ratios.
Thanks! I will probably pick this lens up, as it is rather cheap. If it doesn't work with my setup, maybe somebody here could appreciate it.
Dennis Moore is online now
Reply 2.35:1 Constant Image Height Chat
