Used Isco projector lenses? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 03-07-2020, 05:42 PM - Thread Starter
evanft's Avatar
Quoted: 92 Post(s)
Liked: 42
I recently saw on eBay a number of listing for what appear to be used Isco projector lenses intended for cinema use. Does anyone have any info on these?
Here are some examples:
https://www.ebay.com/itm/ISCO-Integr...cAAOxyQ45Q~aIO
https://www.ebay.com/itm/ISCO-Ultra-...AAAOSwQEteXr4V
JVC RS-520, Elite Screens 16x9 100", XY Screen 2.4:1 115"
Klipsch RP-8000F, RP-450C, 2xRP-240S, 2xRP-402S, 2xSVS PB-1000
Denon AVR-X3200W/HDFury Linker/MiniDSP 2x4 HD
Panasonic UB820/PC/PS3/PS4 Pro/Switch/WiiU/Xbox One X/Original Xbox
Logitech Harmony Hub
evanft is offline
post #2 of 5 Old 03-08-2020, 10:00 AM
kemannthey's Avatar
Quoted: 55 Post(s)
Liked: 27
I understand most of these have different ratios the you might want and specific focusing distance. 1.5x and 2.x are pretty commen compression factors but 1.25x (4k Sony JVC) and 1.33x (every one else) are what is turn key for home theater.
kemannthey is online now
post #3 of 5 Old 03-08-2020, 10:18 AM
ruggercb's Avatar
Quoted: 131 Post(s)
Liked: 69
I think they’re too small for most applications too. Like, the light beam from the projector wouldn’t pass through these lenses correctly.
ruggercb is offline
post #4 of 5 Old 03-08-2020, 06:03 PM
Vern Dias's Avatar
The first one is an integrated prime lens / anamorphic lens.
The second first one is not an anamorphic lens.
Both are designed for 35mm Film projectors, not video projectors.
Vern Dias is offline
post #5 of 5 Old 03-10-2020, 07:29 AM - Thread Starter
evanft's Avatar
Quoted: 92 Post(s)
Liked: 42
Got it. Thanks for the info!
evanft is offline
Reply 2.35:1 Constant Image Height Chat
