7' or 8' pool table for home? - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By pkinneb
post #1 of 4 Old 12-14-2019, 05:49 PM - Thread Starter
Liked: 0
First time poster here, found your forum while searching for real life responses to this question rather than reading tables online. I am in the process of finishing my basement and have a portion of the room that's measuring 16'6" x 12'6".
The first page I've found was the Brunswick page and it sounds like I could do an 8' table with shorter cues (48" or 52"). 7' would be a "safer" choice as it would fit more comfortably, but I'd like to try my hand at some snooker and have as much playing surface as possible so I'd like to lean towards to 8'. What do you guys think on this one?
Adam Waters is offline
post #2 of 4 Old 12-14-2019, 06:04 PM - Thread Starter
Liked: 0
And probably worth mentioning, the width of the room is because of a support pole in the basement not necessarily the width of the room if that plays into the recommendation at all.
post #3 of 4 Old 12-20-2019, 12:18 PM
Quoted: 226 Post(s)
Liked: 660
We have an 8' in a 17' x 15' space and it works great. I think you would be fine, some shots on the side could require a shorter cue but only if the ball was on the bumper most likely. That is also assuming there are walls on all four sides if its open most furniture is not going to interfere. The support pole will affect a shot now and then but I would not forgo the table you want over that. Good luck!
Here's a couple picks to give you some perspective. FWIW my measurements are taken from above the half walls here.
ID:	2656452   Click image for larger version
Lynkage likes this.
My Theater Build - Full Circle Cinema
pkinneb is offline
post #4 of 4 Old 12-29-2019, 01:07 PM
Marcus Napier's Avatar
Liked: 0
8 ft for sure if you have the room
Marcus Napier is offline
Reply Game Room Equipment & Accessories
