Banana Plugs???? - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By prof55
  • 1 Post By kokishin
post #1 of 22 Old 08-21-2017, 10:03 AM - Thread Starter
Quoted: 28 Post(s)
Liked: 7
Banana Plugs????
Best place to buy some decent but cheapish banana plugs? I need about 60 or so. Monoprice is out of stock on their 20 packs for about a month, anyplace else decent to grab them without spending a ton?
bikerboy337 is offline
post #2 of 22 Old 08-21-2017, 10:10 AM
Quoted: 246 Post(s)
Liked: 68
Amazon has tons of affordable options for the quantities your looking for
Dbruce13 is offline
post #3 of 22 Old 08-21-2017, 10:20 AM
Quoted: 562 Post(s)
Liked: 189
tinhvo is offline
post #4 of 22 Old 08-21-2017, 10:25 AM
Quoted: 1039 Post(s)
Liked: 572
i am pretty sure you can get the exact same monoprice banana plugs form amazon matter of fact here is the link they have 6 sets of 20 still in stock https://www.amazon.com/Monoprice-Pla...e+banana+plugs
liffie420 is offline
post #5 of 22 Old 08-21-2017, 11:07 AM
Falconsfan71's Avatar
Quoted: 1544 Post(s)
Liked: 524
I definitely recommend the Sewell Silverback banana plugs. They secure nice and tightly with good connection.
Denon X4300H * Def Tech BP8080st front L/R * Def Tech CLR2002 center * Def Tech ProMonitor 800 surrounds (x4) * Hsu VTF-3 MK5 HP sub * Outlaw OAW4 wireless sub kit * Vizio 60" 4K HDRtv * Sony UBP-X800 Bluray * PS4 * AC Infinity S9 AVR fan
Falconsfan71 is offline
post #6 of 22 Old 08-21-2017, 07:20 PM
mecmec's Avatar
Quoted: 535 Post(s)
Liked: 220
http://www.ebay.com/itm/50-x-High-qu...item3aee118ad7
save yourself some money. compare these to the sewell ones... :-)
mecmec is offline
post #7 of 22 Old 08-21-2017, 09:41 PM
Quoted: 76 Post(s)
Liked: 64
^ I have those cheap secure no issues in the past year
chicago1 is offline
post #8 of 22 Old 08-21-2017, 09:52 PM
Moderator
Moderator
prof55's Avatar
Quoted: 23 Post(s)
I've been very happy with these at Amazon: Mediabridge Banana Plugs
Azekecse likes this.
prof55 is offline
post #9 of 22 Old 08-22-2017, 04:07 AM
Liked: 524
Those Media Bridge are similar in size and style to the Sewell Deadbolt and even the Rocketfish I had before. They are a little "fatter" and take up more space. The Silverbacks are "thinner" and are not as long as some others. It made it easy to use them on the back of AVR and it still fit in my tv console.
post #10 of 22 Old 08-22-2017, 05:33 AM
Azekecse's Avatar
Quoted: 135 Post(s)
Liked: 89
+1, these worked very well for me, secure fit, great customer ratings...
Peace and blessings,
Azeke
Azekecse is offline
post #11 of 22 Old 08-22-2017, 06:06 AM
mecmec's Avatar
Quoted: 535 Post(s)
Liked: 220
at about 50 cents each shipped, it is hard pressed to find a better plug. the nice thing about these is that you can also leave the outer cover off if you want a thinner profile. The double screw holds wire very firmly as well. I use these without the outer cover but heat shrinked them black and red. Super secure and thin profile. I do NOT like the ones that do not use screws as I had issues before where a wire would pull out.,,,
mecmec is offline
post #12 of 22 Old 08-22-2017, 09:07 AM
Liked: 524
Yea, the Silverbacks also have two set screws and you can leave the outer shell or cover off if you need them thinner. But I'm just saying they are thinner than most with the cover on.
post #13 of 22 Old 08-22-2017, 11:46 AM
mecmec's Avatar
Quoted: 535 Post(s)
Liked: 220
Agreed! Compare a Sewell Silverback to the posted Nakamichi...With the exception of the fact that the Naks are about half the price, pretty sure you won't find anything else different...other than the logo...
My only "gripe" is one time I got some with teeny tiny philips heads set screws vs the nice flat ones...
mecmec is offline
post #14 of 22 Old 08-22-2017, 11:51 AM
animeking's Avatar
Quoted: 301 Post(s)
Liked: 91
Sewell Strike is the smallest plug offering.
animeking is offline
post #15 of 22 Old 08-22-2017, 12:35 PM
wpbpete's Avatar
Quoted: 199 Post(s)
Liked: 193
+1 For 7 years I've been using these and never a problem
wpbpete is offline
post #16 of 22 Old 08-22-2017, 01:26 PM
Liked: 524
Yea I like the Naki's too!
post #17 of 22 Old 08-22-2017, 02:02 PM
rfb6435's Avatar
Quoted: 206 Post(s)
Liked: 93
I find the sewell deadbolts to be superior to the normal style banana plugs.
I used cheap monoprice bananas for a while and also had some from GLS audio. These cheaper banana plugs eventually start to get loose as the spring metal gets bent inward after a bit of use. I then have to then bend them back out to restore the "bow" shape so that they are tight again. The sewell deadbolts cost more but don't have that issue. I also didn't like like how the monoprice plugs have a screw in banana connector that can get loose...
The only case where i had a problem with the sewell plugs was on one particular speaker that had a short binding post where the deadbolt plug was just barely deep enough to work and didn't seem as stable as it should.
No matter what I recommend getting banana plugs where the two halves screw together to clamp down on the wire. This is far superior to plugs that have a set screw that tightens down on the wire. It is faster to assemble the ones that clamp down and the connection is stronger.
-Rich
Quad Marantz AVR 9.2.(4+2) Atmos/DTS:X using Dual sr7010's + Dual scAtmos nr1403's
Marantz MM8003 150W/ch Amplifier Driving (L/C/R/SL/SR/SBL/SBR)
HTD Speakers L3 Tower L/R, L3 Center, Dual 12" L3 Subs, L2 Tower SL/SR, L2 Bkshlf SBL/SBR, Flat Panel WL/WR, Angled 6.5" In Ceiling FH/RH, 8" In Ceiling TM
Epson 5040UB Faux-K/3D with 106" Multi-Format Screen.
rfb6435 is offline
post #18 of 22 Old 08-22-2017, 02:43 PM
kokishin's Avatar
Quoted: 1301 Post(s)
Liked: 1319
I use these plugs because they're:
- good quality
- easy to attach
- BFA which means they won't collapse (get loose) like regular banana plugs
- made with plastic sheathes which avoids shorts should a hot plug come loose
- cheap
https://www.amazon.com/Eastone%C2%AE...%AE+EB534AE%2C
BruZZi likes this.
Denon AVR-X6200W, Outlaw Audio 7125 Amp, Oppo UDP-203, Oppo BDP-103, Amazon FTV Stick 4K, Tivo Roamio Pro, Pioneer Elite Andrew Jones Dolby Atmos Enabled EFS-73 Fronts/EBS-73 Surrounds, Chane A2.4 Center, SVS SB-2000 Sub, Panasonic Plasma TH-58PX600
avsforum Members Atmos & Auro Configuration Spreadsheet
I'm just a caveman. Your modern world frightens and confuses me. RIP Phil Hartman
kokishin is online now
post #19 of 22 Old 08-22-2017, 11:08 PM
noah katz's Avatar
Quoted: 1999 Post(s)
Liked: 729
+1, I have those too
Noah
noah katz is online now
post #20 of 22 Old 08-23-2017, 12:04 AM
Peterc613's Avatar
Quoted: 667 Post(s)
Liked: 1111
GLS Audio banana plug speaker connectors
https://www.glsaudio.com/GLS-Audio-B...ack_p_368.html
When I make us custom runs of speaker wire, I use Belden Belden 1312A wrapped in TechFlex Flexi Pet Carbon and terminated with Tributaries boots and GLS Audio banana plug speaker connectors. Belden 1312A has four 12 AWG stranded (168x34) high-conductivity bare copper OFC conductors which makes up as two 9 AWG conductors. The GLS connectors are the only banana plugs I have found that will easily accommodate 9 AWG wire. They run about $2.50 a plug, come in packs of 20, are made out of solid brass and are gold plated. There are two internal set screws to secure the wire and the sleeve rotates so they expand and lock for a solid connection. They may not be as cheep as something on amazon or ebay, but short of spending $30 or more on WBT connectors, I think it's the best quality out there for the money.
Peterc613 is offline
post #21 of 22 Old 08-23-2017, 07:47 AM
BruZZi's Avatar
Quoted: 211 Post(s)
Liked: 771
- good quality
- easy to attach
- cheap
Another vote for BFA Banana Plugs.
BruZZi is offline
post #22 of 22 Old 08-23-2017, 08:23 AM
tarzan1234's Avatar
+1
I've had these for years and they work well. They fit 12 gauge wire without any problem. I recently tried out something else that I got from Amazon but ended up returning them and picking up more Nakamichis.
tarzan1234 is offline
Reply Great Found Deals
