Pioneer ELITE SW-E10 Andrew Jones - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By Audiosaur
post #1 of 7 Old 11-25-2019, 06:16 AM - Thread Starter
tashspop's Avatar
Quoted: 74 Post(s)
Liked: 26
I don't know much about this sub and see its a discontinued model but price seems good to me for someone looking into a small sealed sub at $200.
https://www.newegg.com/p/0S6-0016-00...5xdFi62q8IA%3D
samsung un55hu9000 sek3500 Marantz av7702 Audiocontrol Savoy 7x150 4x MA500U
swope center, tmww fronts, tm surrounds and rears
polk audio OWM3 x4 atmos
4 12" t3 audio subs ep4000 amp 2x15" type r sonotubes
tashspop is offline
post #2 of 7 Old 11-30-2019, 01:00 PM
Liked: 0
I saw this too and am considering purchasing it. Anyone have any thoughts? I mainly want a decently compact sub and I'll be listening to mostly music with the sub, not really any movies.
Charix is offline
post #3 of 7 Old 11-30-2019, 02:08 PM
jpw545's Avatar
Quoted: 14 Post(s)
I like this deal better than the JBL 550P 10" sealed sub for $190. Much more attractive visually and a smaller form factor. I haven't heard either sub though.
Charix - It should make for a good music sub, although I would want two.
jpw545 is offline
post #4 of 7 Old 11-30-2019, 04:11 PM
Audiosaur's Avatar
Liked: 1
True, the Pioneer is smaller, if that's important to you. Having heard both, though, I can tell you the JBL will crush the Pioneer. At $190, the choice would be VERY easy for me.
tashspop likes this.
Audiosaur is offline
post #5 of 7 Old 11-30-2019, 05:08 PM
Liked: 0
I'd probably be able to fit the JBL if you think the sound is THAT much better than the Pioneer. I'm not gonna be cranking it super loud or anything, and I don't have too much to spend, I just want a nice, decent quality sub for music. Just confirming, you think the JBL would be a better choice than the Pioneer? I'm probably going to make a purchase today.
Charix is offline
post #6 of 7 Old 11-30-2019, 06:44 PM
jpw545's Avatar
Quoted: 14 Post(s)
Pretty hard to go against the advice of someone who has heard both subs first hand. It sounds like the JBL has stronger output, which makes sense giving the bigger amp. I would be curious if there is a difference in the sound quality of the bass as well.
Both subs are sealed, so both should be suited for music. The JBL is listed down to 27hz and the Pioneer to 30hz. I've owned a few ported JBL subs, and in my experience, those models had a good amount of punch in the midbass. The kind of punch that hits you in the chest when listening to kick drums. Noticeably more than some other brands I tried although the others went deeper (Velodyne, Klipsch). I found this to be a desirable feature for a music-only sub since I listen to heavy metal. Unfortunately, the ported JBL's weren't tight enough for music-only.
jpw545 is offline
post #7 of 7 Old 12-02-2019, 08:27 AM
Audiosaur's Avatar
Liked: 1
You will not be displeased with the JBL if you can get it for $190.
Reply Great Found Deals
