Scott on The Tech Buzz Podcast - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 2 Post By Scott Wilkinson
post #1 of 6 Old 02-16-2016, 09:36 AM - Thread Starter
Scott Wilkinson's Avatar
Quoted: 1881 Post(s)
Liked: 4905
Yesterday, I was a guest on The Tech Buzz podcast, hosted by Stephen Heywood. We talked about all sorts of home-theater coolness, including the near-ubiquity of 4K/UHD TVs at low prices, seating distances and screen sizes at different resolutions, the importance (or not) of 8K and beyond, streaming 4K, Ultra HD Blu-ray, high dynamic range, VR, and more.
skoolpsyk and freeman4 like this.
Scott Wilkinson is offline
post #2 of 6 Old 02-16-2016, 11:46 AM
Joe Bloggs's Avatar
Quoted: 446 Post(s)
Liked: 126
Good podcast.
Though around 25:38 the host asks about whether 1080p is becoming the norm for internet broadcasting - I thought it was. If it's a youtube program don't you want to shoot at 1080p (or higher) and have youtube automatically convert to all the lower formats (unless the reason is that they can't do that high a frame rate at the higher resolution or something)? Over the air broadcasts doing 1080i not 1080p - the BBC in the UK does 1080p (but only at 1080p25 not p50). But still, 1080i in the US is more pixels per sec than 1080p24 of Blu-ray and equal to the number of pixels per sec of 1080p30.
The host says "a lot of people say that 1080i is the equivalent of 720p29.97. I'm sure a lot of people don't say that - aren't they usually comparing 1080i and 720p59.94 - where they are very similar in pixels per second - and the argument for 720p59.94 would be that it compresses better. Though really the 1080i vs 720p is surely outdated (at least in terms of new formats). Also, the podcast is 29.97 fps when it could also be 59.94 fps. So 720p29.7 isn't equivalent to 1080i59.94 - in terms of resolution or temporal resolution - unless the 1080i show is shot/made in a progressive-style (progressive segmented frame) format (30 different pictures per sec), whereas 1080i59.94 can easily be approx 60 different images per sec (twice as much temporal resolution as 720p29.97 the host asked about). So you wouldn't end up with 30 frames per sec from 1080i - if it was a live show (eg. sports) - because you'd de-interlace to 60 frames per sec (even though it's stored 30 full frames per sec, you'd de-interlace to 60 because they're frame different points in time, and you don't want feathering+lowering of the output temporal resolution). So 720p59.94 doesn't have better temporal resolution (especially when it is converted from a 1080i59.94 signal in the first place) - except for the fact that it may be better able to handle more compression.
Also, surely an object in motion - eg. sports in 1080i60 (ignoring compression issues) isn't going to be any more blury than the same object captured in 720p60 - when output (when properly de-interlaced to 1080p60). If it's able to properly de-interlace it (to 1080p60), both formats will have the object blurred for 1/60th of a second (shutter open time). Though I suppose it depends on how good the de-interlacer is. If it's just line doubling the moving parts of the image, the object could be slightly lower res in height (fields) but higher res in width (1920 vs 720).
So I think the reason the sports channels went for 720p was to use a lower bandwidth without visible artefacting on fast motion - plus allow further re-compression further downstream without it introducing affecting pq too much. Other countries (such as the UK) use 1080i (when they're not transmitting "1080p25"), including for sport.
Joe Bloggs is offline
post #3 of 6 Old 02-17-2016, 01:25 PM
Blacklightning's Avatar
Quoted: 998 Post(s)
Liked: 853
Wow, Scott you pretty much owned that show. It seemed like a HTG Q&A show for one person in the chatroom with one guest that just sits down and looks pretty.
Blacklightning is offline
post #4 of 6 Old 02-17-2016, 07:16 PM
cuzed2's Avatar
Quoted: 219 Post(s)
Liked: 270
Sorry, but couldn't endure the MANY sponsor plugs .............................................
Cuzed2
CuznEddy Cinema
cuzed2 is offline
post #5 of 6 Old 02-18-2016, 05:00 AM
freeman4's Avatar
Quoted: 70 Post(s)
Liked: 1057
Scott, I really enjoyed the show and look forward to future Tech Buzz podcasts with you as a guest!
freeman4 is offline
post #6 of 6 Old 02-19-2016, 10:11 AM
IanR's Avatar
Quoted: 144 Post(s)
Liked: 101
This show just reaffirmed to me what an excellent job Scott does with these kinds of educational broadcasts. Unlike the second guest who could hardly string together an intelligent question .. or the talking head 'techie' host who wasn't even sure if the TV he just bought was 1080p or UHD ... Scott has a great ability to communicate complex concepts in easy to understand terms along with explanations of geeky terms and acronyms .. plus his command of the english language is excellent and he always seems to use the right words in a smooth flowing style without stammering. To synthesize an answer to a technical question on the fly and include appropriate nuances and 'it depends' topics .. in a smooth delivery .. is a rare ability. There are plenty of geeks in the world that we wouldn't want to listen to for an hour .. but Scott isn't one of them. Well done!!
Ian
My finished "Media Room"
IanR is offline
Reply AVS Forum® Podcasts
hdr , uhdtv , ultra hd blu-ray
