Bravia x3500 calibration--> PS3--> best settings - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 07-13-2009, 01:27 PM - Thread Starter
Gonalo Dias's Avatar
I'm not sure if i'm posting this on the right section but...here it goes
I have a 40Kdl Bravia x3500 and a Ps3, and i've been messing around with the picture settings for a long time in order to achieve the best quality...so it seems, I couldn't yet found one that I can say it's great no matter the game I play...
thing that I change more often is the white balance, but I would really apreciate if you guys, who have a x3500 and a ps3, could tell me your settings for me to achieve the best picture possible.
thanks in advance
Gonalo Dias is offline
post #2 of 3 Old 07-13-2009, 02:18 PM
Bear5k's Avatar
https://www.avsforum.com/avs-vb/showthread.php?t=1055906
Color accuracy evangelist and CalMAN insider
Bear5k is offline
post #3 of 3 Old 07-13-2009, 02:25 PM
Michael TLV's Avatar
Location: THX/ISF Calibrationist/Instructor, Calgary, AB, Canada
Quoted: 41 Post(s)
Liked: 144
Greetings
If you are even half serious about getting a better image, you will get yourself a test disc and follow the instructions.
Even something free like the THX optimode found on any THX mastered DVD will help you to a better image in less than 5 minutes.
Copying numbers is not calibration. It's like copying combination lock numbers. Maybe they work for you ... maybe not.
If you are intent on copying ... there are other forum areas that cover that stuff. Not the Calibration forum.
We are here to help you should you choose the calibration route and run into problems.
regards
Michael Chen @ The Laser Video Experience
ISF/THX/TLV Video Instructor
The Video Calibration Education Hub - www.TLVEXP.com
Michael TLV is offline
Reply Display Calibration
