The Official ChromaPure thread - Page 215 - AVS Forum | Home Theater Discussions And Reviews
 275Likes
post #6421 of 7472 Old 04-07-2015, 07:05 AM
Pres2play's Avatar
Quoted: 877 Post(s)
Liked: 393
Tom, I've seen measurements here showing low delta errors and almost perfect grayscale charts, but not so great gamma, and sometimes the opposite. While each is vital, which do you think is more important to get right?
Pres2play is offline
post #6422 of 7472 Old 04-07-2015, 11:35 AM
TomHuffman's Avatar
Quoted: 1000 Post(s)
Liked: 839
White balance errors are more serious than gamma. Even relatively small white balance errors can be easily visible. Small deviations in gamma are not nearly as important.
anta1974 likes this.
Tom Huffman
ChromaPure Software/AccuPel Video Signal Generators
ISF/THX Calibrations
Springfield, MO
TomHuffman is offline
post #6423 of 7472 Old 04-07-2015, 12:38 PM
Pres2play's Avatar
Quoted: 877 Post(s)
Liked: 393
Really didn't know that. Wish I had asked sooner, I've been focusing on perfect gamma all this time.
post #6424 of 7472 Old 04-07-2015, 02:46 PM
buzzard767's Avatar
Quoted: 1668 Post(s)
Liked: 2459
EBU Tech 3320v3 - recommends gamma +/- .1 for CRT monitors. Better said, 2.3 - 2.5, and, they now endorse BT.1886. Bottom line, relax and concentrate on getting color out of gray.
Pres2play likes this.
Buzz
THX Certified Level II Video Calibrator
buzzard767 is offline
post #6425 of 7472 Old 04-07-2015, 04:08 PM
Pres2play's Avatar
Quoted: 877 Post(s)
Liked: 393
Funny you mention color. The more I strive to get the gamma to flatline at 2.22, the more de-saturated my colors become.
However, I only notice this on the gamut chart, and not with real content.
post #6426 of 7472 Old 04-07-2015, 06:27 PM
rmongiovi's Avatar
Quoted: 27 Post(s)
I've always wanted a test pattern that is a continuous gray ramp with tick marks at the 5% and 10% intervals. I've seen ramps with 16 and 235 marked, but never one with any values between. Using the continuous ramp I can see color variations that are between the control points I calibrate, but it's hard to tell exactly where they are to determine where a tweak might help. Has anyone seen anything like that?
rmongiovi is offline
post #6427 of 7472 Old 04-08-2015, 12:27 AM
TomHuffman's Avatar
Liked: 839
Something like this?
http://www.chromapure.com/increments.png
Tom Huffman
Springfield, MO
post #6428 of 7472 Old 04-08-2015, 06:45 AM
msamblanet's Avatar
Originally Posted by TomHuffman View Post
What would be really cool would be a ramp at the top/bottom with a marker where you are and a test square in the middle for your meter to measure so you can get feedback from the meter while also seeing the impact on the ramp...
msamblanet is offline
post #6429 of 7472 Old 04-08-2015, 07:16 AM
rmongiovi's Avatar
Quoted: 27 Post(s)
That's pretty much exactly what I'm looking for Tom. Is that on your disk?
post #6430 of 7472 Old 04-08-2015, 09:14 AM
Pres2play's Avatar
Quoted: 877 Post(s)
Liked: 393
I take that back, adjusting WB I see no affect on gamut points.
post #6431 of 7472 Old 04-08-2015, 12:03 PM
TomHuffman's Avatar
Liked: 839
No, it is just something I made up on the spur of the moment. I can include it in the built-in test patterns for v 3.
Tom Huffman
Springfield, MO
post #6432 of 7472 Old 04-08-2015, 01:55 PM
rmongiovi's Avatar
Quoted: 27 Post(s)
Thanks, but don't do it just for me. I would want it on a disk or as a pattern on my Lumagen.
post #6433 of 7472 Old 04-08-2015, 02:12 PM
davehancock's Avatar
Quoted: 113 Post(s)
Liked: 60
I'd certainly like to see that in V3.0. Perhaps there should be 2 sets: Full digital range (with markings showing bits) and the video range one.
Dave Hancock
davehancock is offline
post #6434 of 7472 Old 04-09-2015, 07:32 AM
Geof's Avatar
Quoted: 44 Post(s)
Liked: 50
Gamma affects saturation, hue, and brightness -- for example, saturation increases as gamma is raised and it's one of the reasons some folks prefer a higher gamma.
Greg Rogers explains it very well in this post: https://www.avsforum.com/forum/24-dig...l#post20927047
Geof
Geof is offline
post #6435 of 7472 Old 04-09-2015, 04:03 PM
Pres2play's Avatar
Quoted: 877 Post(s)
Liked: 393
Geof, thanks for posting that link. Is that a typo in example 2 ?
...2) Color (a yellow complementary color with 100% gamut saturation)
R' G' B'
0.75 0.75 0
R G B (2.2 gamma display)
0.53 0.53 0
R G B (2.4 gamma display)
0.50 0.50 0
Again there is a brightness change but nothing else because the proportions of red and green don't change...
post #6436 of 7472 Old 04-09-2015, 04:23 PM
Pres2play's Avatar
Quoted: 877 Post(s)
Liked: 393
Here's what I mean. To fix luminance for red I lowered red component; to adjust blue, I lowered blue component. Red and blue color points are now farther from target in post-cal.
pre-cal gamut
post-cal gamut
post #6437 of 7472 Old 04-09-2015, 05:03 PM
Pres2play's Avatar
Quoted: 877 Post(s)
Liked: 393
^^^Wrong images. The above involved changes to luminance, not gamma. I'll use higher gamma to get neutral grays if I must, and report back.
post #6438 of 7472 Old 04-10-2015, 08:10 AM
Geof's Avatar
Quoted: 44 Post(s)
Liked: 50
R' G' B'
0.75 0.75 0
0.53 0.53 0
0.50 0.50 0
I don't see any typo's....
Geof
Geof is offline
post #6439 of 7472 Old 04-10-2015, 08:46 AM
Pres2play's Avatar
Quoted: 877 Post(s)
Liked: 393
Apologies, I misread the figures.
Is 2.4 gamma recommended for the entire grayscale, or just at various intensity levels?
post #6440 of 7472 Old 04-10-2015, 09:08 AM
Geof's Avatar
Quoted: 44 Post(s)
Liked: 50
Tom and others are more qualified to answer this but I think generally one uses the same gamma targets for all stimulus levels except when calibrating to BT1886. That said, at times I've calibrated my projector to 2.3 where I gradually lower gamma at 20% and below to help mitigate black crush. I don't think there is any right or wrong depending on your tastes.
Geof
Geof is offline
post #6441 of 7472 Old 04-10-2015, 09:12 AM
CalWldLif's Avatar
Quoted: 281 Post(s)
Liked: 81
Originally Posted by geof View Post
tom and others are more qualified to answer this but i think generally one uses the same gamma targets for all stimulus levels except when calibrating to bt1886. That said, at times i've calibrated my projector to 2.3 where i gradually lower gamma at 20% and below to help mitigate black crush. i don't think there is any right or wrong depending on your tastes.
bt1886
Loving D65
CalWldLif is offline
post #6442 of 7472 Old 04-10-2015, 07:33 PM
Pres2play's Avatar
Quoted: 877 Post(s)
Liked: 393
Thanks, Geof. I'll experiment more this weekend using the information you linked. I'm very satisfied with the calibration I have now, btw. Just want to increase my knowledge base and have some fun messing with this stuff.
post #6443 of 7472 Old 04-11-2015, 07:15 AM
dreameruk's Avatar
I would like to see this test pattern included also.
dreameruk is offline
post #6444 of 7472 Old 04-14-2015, 08:30 PM
pharbrian's Avatar
Quoted: 13 Post(s)
I want to run the color checker with chromapure, but I do not want to use the built in chart generator with chromapure.
Does anyone know where I can obtain that chart to burn to a disc to play on a bluray or DVD player?
pharbrian is offline
post #6445 of 7472 Old 04-14-2015, 11:59 PM
Pres2play's Avatar
Quoted: 877 Post(s)
Liked: 393
Using 2.3 gamma was enough to get the color points back on target. Wish I had lowered gamma starting around 40 IRE, though, instead of 20 IRE, for better shadows. I'll do that next time.
post #6446 of 7472 Old 04-15-2015, 12:24 AM
Gordon Fraser's Avatar
Quoted: 238 Post(s)
Liked: 295
ConecTed's disc has colourchecker patterns i believe
http://www.displaycalibrations.com/r...ad_no_ads.html
Convergent-AV
ISF, Home Theater Consultants and Distribution, U.K.
Gordon Fraser is offline
post #6447 of 7472 Old 04-15-2015, 12:25 AM
TomHuffman's Avatar
Liked: 839
Our calibration Blu-ray has this. So does Masicor's disc and I believe Ted's disc. Other discs have ColorChecker patterns, though the precise RGB values may be slightly different.
pharbrian likes this.
Tom Huffman
Springfield, MO
post #6448 of 7472 Old 04-15-2015, 12:40 AM
ConnecTEDDD's Avatar
Quoted: 3257 Post(s)
Liked: 4050
Yes, there Color Checker + Color Checker Skin Tones Chapters.
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is offline
post #6449 of 7472 Old 04-15-2015, 08:13 AM
starbuck69's Avatar
Liked: 29
Of Course, ChromaPure Blu-Ray Disc is just perfect for the ColorChecker but you'll be very happy with Ted's Disk as you'll find the Skin Tones section also (and a lot of very nice patterns to check your calibration too).
buzzard767 and ConnecTEDDD like this.
starbuck69 is offline
post #6450 of 7472 Old 04-17-2015, 01:29 AM
anta1974's Avatar
Quoted: 61 Post(s)
Liked: 30
Dear TOM!
1) What %background APL and ARL in yuor wonderfull calibration disk?
2) Why in the gamma is not possible to separate output by color -red, green, blue?
anta1974 is offline
Reply Display Calibration
