The Official ChromaPure thread - Page 250 - AVS Forum | Home Theater Discussions And Reviews
 275Likes
post #7471 of 7472 Old 09-08-2019, 04:01 AM
ConnecTEDDD's Avatar
Quoted: 3123 Post(s)
Liked: 3865
Originally Posted by JRodness View Post
The big issue I'm noticing is that Red is too low in all of the color temp modes, and so they're pushing green to get a warm temp or blue to get a neutral/cool temp. And I can't raise red because it's already maxed out. All I can do is cut the blue and green gain to get the appropriate color temp, however, it's killing my light-output and my gamma is no longer running flat :-/. So then my only recourse is to run the projector in normal lamp mode and suffer from the significantly increased noise, raised black levels, and decreased contrast.
So I'm kind of at a crossroads and I have to decide what is worth compromising. At this point, I'm leaning towards running it in one of it's preset color temps and just using the CMS to balance the individual colors at least.
If you have any suggestions, I'm all ears! Thanks again!
Measure all temp modes to see which one will require less adjustments from you later.
Use normal lamp if doing too much RGB balance fix reduce your peak output below 48 nits.
If there is much problem with doing 2-Point calibration, try to use only RGB gains while you will measure whole grayscale and seeing how changes to these control only affects whole GS RGB balance.
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is online now
post #7472 of 7472 Old Yesterday, 04:13 AM
Soulnight's Avatar
Quoted: 1001 Post(s)
Liked: 1509
@TomHuffman
Thank you for the continuous improvement of CP3.
Is there any plan to include:
1) support for high res mode for the i1 pro 2 (driver from argyllcms)
2) support for the pattern generator:
"Raspberry Pi 3 B + with PGenerator by Riccardo Biasiotto"
Thank you,
Florian
Soulnight is offline
Reply Display Calibration
