Please, need help.. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 10-08-2011, 11:05 AM - Thread Starter
snoop832's Avatar
I am currently trying to adjust the 10 point on the samsung and every time I adjust one point the others change and I am sick and tired of going through the 10 point test every time an adjustment is made... Is there any other easier way to do this or am I doing something wrong. I am using the HCFR program and my eyeone display 2 unit.
Ready to give up!!
Thanks -A
snoop832 is offline
post #2 of 11 Old 10-08-2011, 11:15 AM - Thread Starter
snoop832's Avatar
Can you take a continuous measurement on 1 Ire while make an adjustment in 10 point?
snoop832 is offline
post #3 of 11 Old 10-08-2011, 12:50 PM
buzzard767's Avatar
Quoted: 1665 Post(s)
Liked: 2456
Sure, except it's %, not IRE. For instance, measure 70%, adjust with 60% control, measure 60%, adjust with 50% control, etc. Simple, and in the case of Samsungs, sometimes required to finally get it right.
Buzz
THX Certified Level II Video Calibrator
buzzard767 is offline
post #4 of 11 Old 10-08-2011, 12:51 PM
Chad B's Avatar
Quoted: 690 Post(s)
Liked: 1566
You need to keep contrast set high... In the mid 90's is best. Lower causes the 10 pt to mistrack and have excessive interaction.
touring ISF/THX calibrator with Jeti 1211 and Klein K-10
Latest reviews:JVC RS540, JVC RS3000, Sony VPL-VW695ES
Copied settings measured, Review archive
Chad B is offline
post #5 of 11 Old 10-08-2011, 01:08 PM - Thread Starter
snoop832's Avatar
I've tried that in continuous measure... example Measure 20% adjust with 10 but I see no change in RGB adjustments ....
snoop832 is offline
post #6 of 11 Old 10-08-2011, 01:09 PM - Thread Starter
snoop832's Avatar
I have it set to 95... That should be good enough I assume..
snoop832 is offline
post #7 of 11 Old 10-08-2011, 02:18 PM
Chad B's Avatar
Quoted: 690 Post(s)
Liked: 1566
Yes, that's good. So for instance, you're taking continuous measurements at a given level, say 20%, and you're adjusting the R, G, B at interval 2 in the 10 pt adjustment and see no change?
That is strange.
Chad B is offline
post #8 of 11 Old 10-08-2011, 02:19 PM
buzzard767's Avatar
Liked: 2456
Does adjusting 20% affect 10 & 30? If so, compromise. You'll never get a display perfect.
Buzz
post #9 of 11 Old 10-08-2011, 03:28 PM
LarryInRI's Avatar
Liked: 192
For the new Samsungs at relatively low peak output (below about 30 ftL,) the 10 point tracking is off. Adjusting one range usually will effect the next higher range. This is easy to see by displaying a 21 point grayscale step pattern while moving a color setting in a 10 point adjustment range all the way to maximum and observing where the change occurs on the grayscale. Knowing where the change will happen significantly reduces the number of iterations to complete the task.
Larry
LarryInRI is offline
post #10 of 11 Old 10-08-2011, 04:33 PM
jdoostil's Avatar
Quoted: 17 Post(s)
Liked: 26
this...and check FW
ISF certified in 2008, Level II in 2010, Level III in 2017
ISF instructor certified since 2012
ISF International Trainer since 2014
[email protected]
Serving Florida
jdoostil is offline
post #11 of 11 Old 10-09-2011, 07:35 AM - Thread Starter
snoop832's Avatar
Here are some pics... I think this is the best I will get it for now, unless you think I need more tweaking, just say so...
Thank u guy's for all your help...
snoop832 is offline
Reply Display Calibration
