HCFR - Open source projector and display calibration software - Page 15 - AVS Forum | Home Theater Discussions And Reviews
 1405Likes
post #421 of 11718 Old 04-04-2012, 12:28 PM - Thread Starter
zoyd's Avatar
Quoted: 1783 Post(s)
Liked: 1348
Originally Posted by JohnAd View Post
@zoyd
Some very interesting results, it does indeed look like speed is being traded for accuracy, I'm wary of plain averaging maybe best 2 of 3 might best.
By the way I'm still looking at improving the crash handling so that we can hopefully get the missing bit of that file next time, looks like the error is being buffered to me and we're missing the useful bit ...
John
It looks to me to be purely statistical so either increase the integration by 4 for that range of luminances (I don't know if it's settable by signal level) or average 4 samples. I also don't know how that interacts with the probe's internal auto-integration level code. It would probably be better to work with the argyll team to change it at the driver level instead of averaging in HCFR since it will improve their readings as well.
zoyd is offline
post #422 of 11718 Old 04-04-2012, 01:21 PM
JohnAd's Avatar
Your tests do look like normal random noise, in my own tests with the i1d2 I occasionally (but still more often that I'd expect) get a rogue result which would skew an average but would get picked up with a rejection type filter. The rogue result issue is why I'd prefer to use a rejection filter and an averge rather than just an average. It would also help with situation where the image changes mid read which is more likely the longer the read time.
Agree that ideally we'd be increasing the integration time in the driver layer but there are other issues at play there too not least the lack of a sensible timeout mechanism which I think means we have to stay quite conservative at the low light levels to avoid hangs. But I'll review the code and speak with Graeme to see what if anything can be done.
John
My Company - Upsilon Software
Free Projects - DScaler & hcfr fork
JohnAd is offline
post #423 of 11718 Old 04-04-2012, 01:52 PM
dml1333's Avatar
Now that I have an i1D3 along with my old DTP-94, I can also reproduce the crash with i1D3 whenever I run a grayscale using a setting on my Samsung plasma that allows it to turn completely off during the 0% measurement.
There is also a different problem that is related to too quick timing with the i1D3. When starting any of the automated measures such as grayscale or primaries, the confirming dialog box in HCFR comes up in the middle of the screen (it always has). When running with "View Images", rather than "DVD manual", using my laptop with HDMI out or my HTPC, I usually have HCFR running in full screen mode. The confirming dialog box will then usually be directly under the meter and it seems that the i1D3 is starting to take measurements before the dialog box goes away and the 0% screen comes up. This causes a totally bad reading for 0% which also messes up the gamma calculation. A temporary workaround has been for me to move the dialog box out from under the meter (every time I start a measurement), and then the readings are fine. I wonder if other meters might also experience this when used with View Images? A very short delay after getting the OK click and before starting an actual measurement might solve the problem for all (just a suggestion).
dml1333 is offline
post #424 of 11718 Old 04-04-2012, 02:01 PM
dml1333's Avatar
I know there was brief mention of using the EDR calibrations that come with the i1D3 and using i1d3ccss to convert them to Argyll format. I couldn't tell if version 3.0.1.0 or 3.0.2.0 is supposed to use them (and present those choices in the Argyll meter dialog), or is that a feature that is planned for a future version? I also wonder if the 500 degree kelvin error that was mentioned in an earlier post might be partially corrected if the appropriate correction file was used?
BTW, I have successfully run simultaneous measures with my DTP-94 and the i1D3, and do see a consistent offset between the two. However, I don't have a spectro to be able to tell which is more accurate.
dml1333 is offline
post #425 of 11718 Old 04-04-2012, 02:21 PM
JohnAd's Avatar
The tool is in 3.0.2, the generated ccmx files will be used in a later version (in the next weeks rather than months)
John
JohnAd is offline
post #426 of 11718 Old 04-04-2012, 02:31 PM
JohnAd's Avatar
Thanks, the crash is still proving difficult to track down. If you could help test the next verfsion that would be great.
Hmmm, I think the pause might be in the wrong place, should be addresssed in the next version.
John
JohnAd is offline
post #427 of 11718 Old 04-05-2012, 06:45 AM - Thread Starter
zoyd's Avatar
Liked: 1348
So the following files can be generated from my i1d3 disk, can someone describe how they could be used? I would like to compare them to my i1pro based correction to see which to recommend for plasmas.
CCFLFamily_07Feb11.ccss
WGCCFLFamily_07Feb11.ccss
ProjectorFamily_07Feb11.ccss
WLEDFamily_07Feb11.ccss
RGBLEDFamily_07Feb11.ccss
zoyd is offline
post #428 of 11718 Old 04-05-2012, 07:44 AM
JohnAd's Avatar
They are just text files, you should be able to look at the matrices in notepad and compare them to your one.
By the way, which display type did you use in your tests above, Graeme mentioned that plasmas might be better with a refresh based display type.
John
JohnAd is offline
post #429 of 11718 Old 04-05-2012, 08:02 AM - Thread Starter
zoyd's Avatar
Liked: 1348
thanks John, I believed I did use the refresh based option but I'll check it. The .ccss files contain full spectral data and can be used to form probe corrections within dispcalGUI but I don't think an equivalent exists for HCFR use, maybe I can convert them to matrix based from dispcalGUI.
zoyd is offline
post #430 of 11718 Old 04-05-2012, 09:12 AM
JohnAd's Avatar
I thought you said you did, did you calibrate the meter before the run to lock onto a white patch, a stderr.log from that might be handy to confirm thta it found the right refresh rate.
Sorry I was thinking of the ccmx files which are matrices Can you send me the files I don't think I've seen them.
I'll be adding the ui to load those up in the next week or so, there may be a interim version to gather more diagnostics on the various crashes and possible fixes for the i1pro issues but that's the next feature.
John
JohnAd is offline
post #431 of 11718 Old 04-05-2012, 09:29 AM - Thread Starter
zoyd's Avatar
Liked: 1348
zoyd is offline
post #432 of 11718 Old 04-05-2012, 03:41 PM - Thread Starter
zoyd's Avatar
Liked: 1348
Checked my measurements and I did have the probe synched in refresh mode. Here is another set comparing the D2 and D3 in various modes. I ran my display at both 60Hz and 96Hz and the worst performance was the D3 in refresh mode on a 60Hz screen. Both red and correlated color temperature had a bit more than twice the error of the other measurements. The probe synched at 30Hz on the 60Hz screen and 24Hz on the 96Hz screen, the patterns are 24 fps.
60Hz 100% White tile
Code:
i1d3: instrument inited OK
i1d3: Sending cmd 'SetLED' args '21 01 05 01 02 00 00 00'icoms: About to return hid write 64 bytes, ICOM err 0x0
 ICOM err 0x0
i1d3: Reading response icoms: About to return hid read 64 bytes, ICOM err 0x0
 '00 21 00 00 00 00 00 00 00 00 00 00 00 00' ICOM err 0x0
i1d3: Refresh period = 33.513524 msec
i1d3: integration time quantize to 0.201081 secs
i1d3: Refresh period = 33.127407 msec
i1d3: integration time quantize to 0.231892 secs
96Hz 100% White tile
Code:
 ICOM err 0x0
i1d3: Refresh period = 41.650735 msec
i1d3: integration time quantize to 0.208254 secs
i1d3: Refresh period = 41.775024 msec
edit: Added D3 synched at 30Hz to a 30 FPS pattern, this one generates the largest instability with the 1-sigma CCT = 2% (130K).
Also took a look at the skewness parameter and John was right, the D3 had some larger spikes (non-normal distribution) but it wasn't correlated with whether the probe was being used in sync or non-sync mode.
zoyd is offline
post #433 of 11718 Old 04-06-2012, 02:51 AM
anta1974's Avatar
Quoted: 61 Post(s)
Liked: 30
You write:
Enter the location of the new drivers, which are in the Drivers directory under the location of the ColorHCFR executable. The drivers will normally be found in C:\\Program Files\\HCFR Calibration\\Drivers.
But I using a driver argyll and all the excellent (good)!
I have Colormunki Photo.
You can do so?
Why there are differences in the performance measurement CALMAN 4.4 and your program?
What the correct?
anta1974 is offline
post #434 of 11718 Old 04-06-2012, 10:37 AM
65Cobra427SC's Avatar
Something I noticed during a previous calibration which I'm not familia6r with... forgot about it till now...
When measuring grey scale I noticed it takes longer to measure 0 IRE than it does to measure 100 IRE. There is a definite pause when measuring 0 IRE but the time is shorter for each subsequent test pattern and by the time I get to ~ 70 IRE it's requesting the next screen instantly. Just curious if this is normal?
65Cobra427SC is offline
post #435 of 11718 Old 04-06-2012, 12:33 PM
DaGamePimp's Avatar
Quoted: 550 Post(s)
Liked: 583
Perfectly normal, more time is spent at the lower IRE to give a more accurate read.
Jason
HT = Sony HW45ES @133" / Lumagen Radiance / Denon x5200 7.3.4 Atmos / B&K 5000 II amp / Boston VR2/VR12/CR67 speakers / Rythmik 12" subs x2 / CV 15" sub / Sony x800 / Toshiba HD-A3
Media Room = Sony 65x930e / Denon x3300 /Klipsch speakers /Velodyne subs /Sony x700 /PS4 Pro + PSVR/WiiU/PS3/360/Wii/ 2080 TI game PC / Multi-Arcade / Virtual Pinball TRE45ON
DaGamePimp is offline
post #436 of 11718 Old 04-07-2012, 04:53 AM
anta1974's Avatar
Quoted: 61 Post(s)
Liked: 30
When you edit fields in the grayscale value of 0% program closes with an error.
Windows 7 x64
HCFR 3.0.1 and 3.0.2
original no error.
anta1974 is offline
post #437 of 11718 Old 04-07-2012, 07:21 AM
Jason
post #438 of 11718 Old 04-07-2012, 12:45 PM
dml1333's Avatar
With both HCFR 3.0.2 or 3.0.1, if you double click on a .chc file, the program appears to hang during startup with the transparent graphic displayed. However after closing (using right-click on the task bar icon), an error dialog is revealed (it was underneath the graphic), and it says "Unexpected File Format". Version 2.1 would open the .chc file to view prior calibrations. This one is pretty minor IMHO, so I would suggest putting it low on the list.
I'm really glad that the work to utilize the .ccss is high on the list. And thanks for the great work!
dml1333 is offline
post #439 of 11718 Old 04-08-2012, 11:02 AM
gingerman's Avatar
Hey guys, quick note. Using HCFR 3.0.1.0 I started to cal a my JVC X30 (46 hours on the lamp) with a Spyder4 we had around the office about a week ago. No issues, but probably not the best tool for the job. Switched to a i1d3 later in the week. Following the guide at curtpalme.com I have made a night and day difference in the picture quality. Sometimes I get an error when starting a new hcfr file about driver loading for the i1d3, a reboot clears it everytime and it is off to calibrating. I am sure it has to do with the xrite sw, which I just disabled in the msconfig startup. I've done greyscale with the DVE BluRay, and I just did the primary colors with the AVS709 disc. Supprisingly I had to push the color control to +4 on to get the red primary to 21% of the 100% Y. Going by eye I would have expected to need to dial the color down, which is testement to the need for a app and meter.
gingerman is offline
post #440 of 11718 Old 04-08-2012, 02:43 PM
JohnAd's Avatar
Windows 7 x64
original no error.
I can't reproduce this, can you send any minidump files produces in 3.0.2.0 or later versions.
John
JohnAd is offline
post #441 of 11718 Old 04-08-2012, 02:52 PM
JohnAd's Avatar
I can't reproduce this so if there is a file you have an issue with can you send it to me.
John
JohnAd is offline
post #442 of 11718 Old 04-08-2012, 03:15 PM
JohnAd's Avatar
Time for another version
http://sourceforge.net/projects/hcfr/files/Windows/3.0.3.0/
This is mainly another attempt at gathering information about the issue people are seeing so improved crash logging and error handling.
I've also integreated the latest argyll code which promises better refresh locking for the colorimeters and which may assist with the low light accuracy issues seem with the i1d3.
There should be fixes for a couple of the crashes reported, it would be very helpful if you could please test any outstanding issues against this version.
John
JohnAd is offline
post #443 of 11718 Old 04-08-2012, 07:21 PM
dml1333's Avatar
Using the i1D3, 3.0.3.0 takes several seconds longer before the first reading in a sequence (gray scale or primaries, etc.), but gets the first reading wrong. On both gray scale and primary/secondary readings the first reading is barely above zero (.001ftL instead of ~.02-.04 for my Samsung Plasma). This makes for a crazy gamma and non-existent color triangle. I'll go try with my DTP-94 to see if it's only due to changes in the i1D3 Argyll driver.
dml1333 is offline
post #444 of 11718 Old 04-08-2012, 07:24 PM
dml1333's Avatar
John
John, regarding the Unexpected File Format when double-clicking on a .chc file, I found that on my laptop, it still had ColorHCFR2.1 associated with .chc files, and at first I couldn't get it to change to HCFR3.x. But after uninstalling and rebooting I finally could get .chc files associated with HCFR 3.0.3 and then it worked fine. So other that the suggestion to automatically register that file association (worth thinking about), there is NO bug.
dml1333 is offline
post #445 of 11718 Old 04-08-2012, 08:15 PM
dml1333's Avatar
I tested 3.0.3 with my DTP-94 with both X-Rite and Argyll drivers and no particular issues. Then retested the i1D3 and the results were slightly different. The 0% stimulus on the gray scale measured normally, but the Red (1st measure) in the Primary/Secondary measures was still WAY off. I'm attaching the .chc files as well as the stderr.log files from some of those runs.
HCFR3030tests.zip 13.412109375k . file
dml1333 is offline
post #446 of 11718 Old 04-09-2012, 01:37 AM
JohnAd's Avatar
Great, thanks, I'll look at adding the association to the installer.
Cheers
John
JohnAd is offline
post #447 of 11718 Old 04-09-2012, 07:42 AM
anta1974's Avatar
Quoted: 61 Post(s)
Liked: 30
Problem signature:
Problem Event Name: BEX
Application Name: ColorHCFR.exe
Application Version: 3.0.1.0
Application Timestamp: 4f68ea40
Fault Module Name: ColorHCFR.exe
Fault Module Version: 3.0.1.0
Fault Module Timestamp: 4f68ea40
Exception Offset: 000a9692
Exception Code: c0000409
Exception Data: 00000000
OS Version: 6.1.7601.2.1.0.256.4
Locale ID: 1049
Additional Information 1: e325
Additional Information 2: e32556d617456f9ef83281b79349e66e
Additional Information 3: a20b
Additional Information 4: a20b3ce7c0a04d619d05042e6d8f3d9e
Read our privacy statement online:
http://go.microsoft.com/fwlink/?link...8&clcid=0x0409
If the online privacy statement is not available, please read our privacy statement offline:
C:\\Windows\\system32\\en-US\\erofflps.txt
anta1974 is offline
post #448 of 11718 Old 04-09-2012, 08:49 AM
JohnAd's Avatar
Problem signature:
the latest version should give a crash dump minidump.dmp file which will help solve this.
John
JohnAd is offline
post #449 of 11718 Old 04-09-2012, 09:25 AM
anta1974's Avatar
Quoted: 61 Post(s)
Liked: 30
3.0.3 all ok, no crash!
Very Very Thanx!!!
When approximately сalculations corrected?
anta1974 is offline
post #450 of 11718 Old 04-09-2012, 07:12 PM
jdbimmer's Avatar
Quoted: 65 Post(s)
Liked: 46
Should the i1Pro work in 3.0.3 with the Argyll driver? I am still getting an error:
Code:
icoms: About to open USB port 'usb:/bus1/dev3/ (GretagMacbeth i1 Pro)'
libusb:debug [libusb_open] open 1.3
libusb:error [libusb0_open] libusb0_open: invalid device name '\\\\.\\USB#VID_0971&PID_2000#6&6581723&0&2#{A5DCBF10-6530-11D2-901F-00C04FB951ED}'
Opening USB port 'usb:/bus1/dev3/ (GretagMacbeth i1 Pro)' config 1 failed (Other error) (Permissions ?)icoms: delete called
libusb:debug [libusb_unref_device] destroy device 1.3
libusb:debug [libusb_exit]
libusb:debug [usbi_remove_pollfd] remove fd 4
libusb:debug [windows_clock_gettime_threaded] timer thread quitting
libusb:debug [libusb_exit] freeing default context
____________________________________________
C8/E8 Questions? Try JCC's_FAQ Or LiQiCE's_Wiki
jdbimmer is online now
Reply Display Calibration
