HCFR - Open source projector and display calibration software - Page 170 - AVS Forum | Home Theater Discussions And Reviews
 1407Likes
post #5071 of 11794 Old 12-28-2014, 11:54 AM
xvfx's Avatar
Quoted: 410 Post(s)
Liked: 244
Who says it gets poor reviews?
xvfx is offline
post #5072 of 11794 Old 12-28-2014, 11:58 AM
thepiecesfit's Avatar
Quoted: 191 Post(s)
Liked: 97
i1 Display 2 all over these boards infamous reports of drift. But seems like I am lucky and get pretty consistent results even at 10%. Although I was getting wildly different results from HCFR 2 vs 3. Now my tv calibration matches my pc monitor in terms of color fidelity. I am quite happy with the VideoEq MX took this display to a whole other level.
thepiecesfit is offline
post #5073 of 11794 Old 12-28-2014, 12:45 PM
LastButNotLeast's Avatar
Quoted: 2385 Post(s)
Liked: 2023
The "drift" is over TIME - old meters are not as accurate as new meters.
Glad you're happy with your results.
Did you really need to quote that entire post in your reply?
Welcome to AVS - Get out while you still can!
Don't guess, measure: https://www.avsforum.com/forum/91-au...l#post22789786
LastButNotLeast is offline
post #5074 of 11794 Old 12-29-2014, 06:17 AM
visata's Avatar
I was going to buy spyder4 colormeter for TV calibration to use with HCFR today but after reading this post (sorry, I can't add links but the link is /forum/139-display-calibration/1528143-x-rite-spyder-questions.html, just add avsforum [dot] com in front) I'm no longer sure. It's stated that:
Our findings showed the probes to be very inaccurate, and not at all suitable for accurate calibration.
We did report our findings to Datacolor...
Does it mean the product is useless? What would you recommended for TV, monitor, laptop LCD calibration?
visata is offline
post #5075 of 11794 Old 12-29-2014, 07:38 AM
Liked: 2023
The problem is that only SOME of them are useless.
This one:
http://www.bhphotovideo.com/c/produc...splay_Pro.html
post #5076 of 11794 Old 12-29-2014, 07:53 AM
shpitz's Avatar
Quoted: 74 Post(s)
Liked: 58
This one:
And the i1Display Pro goes on sale once in a while, there was a $25 rebate (BHPhoto had it for $150), so if you're patient, and keep looking, you might find a great deal for the meter.
Newegg, Adorama, BHPhoto, Amazon have it on sale ever so often...
Keep an eye @ Slickdeals
shpitz is offline
post #5077 of 11794 Old 12-29-2014, 08:00 AM
visata's Avatar
This one:
Do you mean that buying spyder4 is like lottery? Some of them works correctly and some not? What if I keep exchanging till get the correct working one? Or there is no way to find out whether I received the correct working unit?
visata is offline
post #5078 of 11794 Old 12-29-2014, 08:09 AM
visata's Avatar
I checked slickdeals and there was a sale on BH, the price after rebate only $129. Wish we had similar deals in Europe...
visata is offline
post #5079 of 11794 Old 12-29-2014, 08:13 AM
Liked: 2023
Right.
It is a lottery, some work and some don't, and the only way to know if the meter you have works is to compare it to a known working unit.
post #5080 of 11794 Old 12-29-2014, 09:13 AM
HeffeMusic's Avatar
Quoted: 460 Post(s)
Liked: 194
Hello all,
Does the i1 pro come with software to calibrate your panel, or do I have to buy additional software?
HeffeMusic is offline
post #5081 of 11794 Old 12-29-2014, 09:48 AM
Basstrix's Avatar
Quoted: 53 Post(s)
Originally Posted by HeffeMusic View Post
Hello all,
It will have s/w to calibrate a computer monitor. There may be a way to use it with a TV, but most use HCFR (freeware) or one of the other programs like Calman or Chromapure.
I believe there are package deals available which include the meter and the software, but they are not sold by X-Rite.
Vizio M652i-B2....................HCFR 3.3.1
Vizio E600i-B3.....................i1 Display Pro
Sharp LC-70C8470U............ControlCAL Elite X5 Edition v2
Onkyo TX-SR606.................AVSHD-709
PS-3
Homegrown HTPC
Basstrix is offline
post #5082 of 11794 Old 12-29-2014, 09:56 AM
HeffeMusic's Avatar
Quoted: 460 Post(s)
Liked: 194
Thanks for the reply! I am looking to purchase the least expensive and most accurate way of getting into self calibration.
post #5083 of 11794 Old 12-29-2014, 09:58 AM
22point8's Avatar
Quoted: 141 Post(s)
Liked: 71
You can just plug it in and use HCFR straight away.
22point8 is offline
post #5084 of 11794 Old 12-29-2014, 10:10 AM
Basstrix's Avatar
Quoted: 53 Post(s)
Assuming you have a computer (with a DVD burner) and a BD player, you should be able to get everything except the meter for free.
PS-3
Homegrown HTPC
Basstrix is offline
post #5085 of 11794 Old 12-29-2014, 10:25 AM
fotto's Avatar
Quoted: 21 Post(s)
As info, Xrite has a $25 rebate available for either the i1 pro or colormunki running through 12/31 xrite I just ordered the colormunki display and should get it by Wed. Let the fun begin
fotto is offline
post #5086 of 11794 Old 12-29-2014, 10:38 AM
HeffeMusic's Avatar
Quoted: 460 Post(s)
Liked: 194
Understood, so what it sound like the i1 is the better meter than the Spyder4? Also if I burn this software is there a tutorial or do I go in blind?
post #5087 of 11794 Old 12-29-2014, 11:26 AM
Basstrix's Avatar
Quoted: 53 Post(s)
I've read that the Spyder meter is a "lottery" as to whether or not you get a good one. I have no personal experience with other than the i1 Display Pro (aka i1D3) and I don't even know if mine is accurate! lol.
Go to the first page of this thread and look at the links in the first post. There is one from CurtPalme that goes through the process using an older version of HCFR....that's the Calibaration for Dummies. There's a newer version of this guide that uses one of the other S/W, so I recommend using the original guide. There are other guides out there that will help but the one I listed is the most specific to HCFR. HCFR also has a decent help menu....it's helpful, but lacks detail in areas. I would not rely solely on the help menu.
There are also links to pattern material. The GCD is very good and includes "Color Checker" patterns. The AVSHD709 is what I started out with...it's good, but lacks the color check material and some say it's difficult to navigate...I use it with a PS3 and find it to be very convenient using the PS3 remote's "red square" button to skip ahead to the predefined bookmarks.
Plan on doing A LOT of reading and searching. It's fun hobby, but man...it's a time vampire for sure!
PS-3
Homegrown HTPC
Basstrix is offline
post #5088 of 11794 Old 12-29-2014, 10:10 PM
pdawg17's Avatar
Quoted: 13 Post(s)
Liked: 26
Is anyone using this on Windows 10? Or Windows 8?
I installed HCFR on my Windows 10 Preview laptop and once I click next on the "generator selection" screen it crashes saying "HCFR has stopped working". My i1display pro works fine with the xrite software for my laptop screen.
Before reformatting the drive it'd be nice to know if Windows 8 works or if I have to go all the way back to Windows 7...thanks...
pdawg17 is offline
post #5089 of 11794 Old 12-30-2014, 08:09 AM
xvfx's Avatar
Quoted: 410 Post(s)
Liked: 244
HCFR works fine on Windows 8.1.
xvfx is offline
post #5090 of 11794 Old 12-30-2014, 08:51 AM
pdawg17's Avatar
Quoted: 13 Post(s)
Liked: 26
Good to know...I ended up reformatting and putting 7 x64 back on the laptop as it is pretty old so figured 7 would work best with it. There is something about 10 HCFR doesn't like (makes sense since it's a preview)...
pdawg17 is offline
post #5091 of 11794 Old 12-30-2014, 10:17 AM - Thread Starter
zoyd's Avatar
Quoted: 1783 Post(s)
Liked: 1348
Originally Posted by CharlieS. View Post
Where can is see what luminance i need for the color calibration with REC 709 75%/75%?
I just see what luminance i have but not what i need.
Target Y is not displayed for primaries/secondaries, only delta luminance. The most accurate indicator for target luminance when using 75%/75% pseudo-colorspace will be the the 100% RGB bars (RGB mode) or the 100% V bar (HSV mode).
Originally Posted by AMartin56 View Post
Is it possible to directly compare two meter profiles in HCFR?
Yes, just load the two corrections in separate sheets and measure an RGBW sequence.
Can anyone tell me how to display 100% Stimulus/75% Saturation patterns using HCFR that doesn't involve manually entering values into the "Test Colors" palette? I can't get the GCD patterns to match up exactly with HCFR's patterns.
BT
That combination is not a supported sequence.
Originally Posted by thepiecesfit View Post
I'm getting some discrepancies between V2 and V3 of HCFR. Can anyone shine some light on this? I was getting Green and Cyan shifts in V2 that I was wondering about. Seems like V3 the primary and secondary colors align much better. I'm a bit puzzled by which one I can trust? Using an i1Display 2 without much drift it seems as my results are consistent. Both were set to rec 709 .
Any ideas? Using a TC-P50ST50 Panasonic. The only difference is the lack of a Plasma setting and I left the Color difference formula to recommended. The calibration settings are exactly the same. Added RGB Levels and CIE diagrams below.
My guess is that since the old version is using an xrite driver that you are probably comparing the measurements with and without a plasma table correction but it's hard to say without more info.
The instrument drivers (ArgyllCMS) are not compatible with 10.
zoyd is offline
post #5092 of 11794 Old 12-30-2014, 10:20 AM
pdawg17's Avatar
Quoted: 13 Post(s)
Liked: 26
One other "tangent" question. If my i1display pro cannot sit flat against the screen is there a trick? Painters tape maybe? How to set that up?
pdawg17 is offline
post #5093 of 11794 Old 12-30-2014, 10:41 AM
Liked: 2023
I use the handle of a tripod to push the sensor gently against the screen.
I would strongly recommend against using any type of tape.
If the room is dark enough, you actually don't need to have the sensor touch the screen.
post #5094 of 11794 Old 12-30-2014, 11:28 AM
bmcn's Avatar
Quoted: 2202 Post(s)
Liked: 3102
Yes to the painters tape.
Sorry I can't get to a camera: First I use 5 or 6 pieces of 2, 3" tape to secure the cable to the top ledge and top of bezel of my wall mounted 64". Then apply a few 1-2" pieces to the top of the bezel, aligning the sensor in the general area of the target, then press the sensor against the target, removing the load of the cable weight, while applying a few more short pieces to the bezel to lock the cable in place. If done correctly, when you release the sensor it will securely rest against both target and screen.
I've calibrated during different ambient light conditions, so I don't like any gap between the sensor and screen. I also taped the cable weight to prevent scratching the screen when the sensor pulls away from the tape, which it has on occasion.
There's a photo floating around somewhere on AVS that shows this technique. I just mimicked that and am impressed it works.
bmcn is offline
post #5095 of 11794 Old 12-30-2014, 11:48 AM
Basstrix's Avatar
Quoted: 53 Post(s)
zoyd, thanks for the response.
PS-3
Homegrown HTPC
Basstrix is offline
post #5096 of 11794 Old 12-30-2014, 12:00 PM
bmcn's Avatar
Liked: 3102
Curious why the strong objection to painters tape?
bmcn is offline
post #5097 of 11794 Old 12-30-2014, 12:03 PM
AMartin56's Avatar
Quoted: 2166 Post(s)
Liked: 1150
Another vote for painters tape if needed. You can tape the meter down without touching the screen / only the bezel.
AMartin56 is offline
post #5098 of 11794 Old 12-30-2014, 12:07 PM
Quoted: 191 Post(s)
Liked: 97
I did use a Plasma setting in v2 with the xrite driver. Could not find a plasma table correction for V3 is it a setting? I just used LCD.
post #5099 of 11794 Old 12-30-2014, 12:12 PM
Liked: 2023
My RPCRT background, mostly. Much as I love GooGone, I'd rather not use it on my plasma screen.
But if it works, go for it.
post #5100 of 11794 Old 12-30-2014, 12:35 PM
bmcn's Avatar
Liked: 3102
No tape is applied to the screen, only the housing ledge and bezel. I admit it is barrio, but works for me.
AMartin56 likes this.
bmcn is offline
Reply Display Calibration
