HCFR - Open source projector and display calibration software - Page 29 - AVS Forum | Home Theater Discussions And Reviews
 1405Likes
post #841 of 11719 Old 08-14-2012, 11:26 AM
jkozlow3's Avatar
Quoted: 87 Post(s)
Liked: 65
I finally picked up an i1D3 and used it with HCFR 3.0.4.0 on my Panasonic VT30 plasma.
HCFR was reading red noticeably low on my plasma by around 8-10%. If I boosted red to the level HCFR wanted me to, the resulting color temp would have been somewhere in the 6000k-6250k range and the picture was distinctly too red when viewing several pieces of reference material which I use for checking skin-tones when calibrating.
I manually applied Zoyd's correction matrix posted back around page 21 and this helped things considerably. Calibrating to 6500k using Zoyd's matrix results in much more natural looking skin tones vs. without the matrix. I calibrated 1 color temp (i.e. "normal") without the matrix and 1 color temp (i.e. "warm") with the matrix applied so that I could easily do A-B comparisons on the same material and Zoyd's matrix was more accurate on 100% of the content I tested vs. using no matrix at all.
So in summary, thank-you very much Zoyd for posting your matrix, and I really hope that this plasma error gets corrected in a future release!
jkozlow3 is offline
post #842 of 11719 Old 08-14-2012, 12:54 PM - Thread Starter
zoyd's Avatar
Quoted: 1783 Post(s)
Liked: 1348
no problem. Just to clarify, there is no plasma error with HCFR, this is just the way the D3 probe reads plasmas. It has to be adjusted using the correction matrix due to the particular nature of the phosphor spectral distribution.
zoyd is offline
post #843 of 11719 Old 08-14-2012, 01:16 PM
jkozlow3's Avatar
Quoted: 87 Post(s)
Liked: 65
Interesting. Well, it would probably make sense at some point for HCFR to provide a "Plasma" display type selection and load a standard/built-in correction matrix by default (which can be overridden if needed/desired) vs. simply letting users calibrate their displays and wind up with too much red in the grayscale unbeknownst to them.
I believe this is what Calman does for users automatically, no? I fully realize Calman is a paid product with a lot more resources to devote to development, but building similar functionality into HCFR should be a goal, even if it cannot be accomplished immediately. I just think a lot of plasma owners will make the mistake of not manually adjusting the matrix and will therefore end up with incorrect calibration results.
jkozlow3 is offline
post #844 of 11719 Old 08-14-2012, 01:48 PM
ndaa75's Avatar
Just purchased an i1pro, thought it may work with HCFR 3.0.4.0, alas it cannot find any driver?????? Does the I1pro work with HCFR?
Benq W1080ST Projector, Panasonic TXP55VT30 plasma, Yamaha RXA3020 AVR, Denon DVD-2500BT, Q Acoustics 1010i in 7.1, i1 Pro spectro, i1 Display Pro, Calman 5 Enthusiast, PS3, Xbox 360, Wii
Calibration Management Disc
ndaa75 is offline
post #845 of 11719 Old 08-14-2012, 03:44 PM
rahzel's Avatar
Liked: 148
+1. And the i1D3 is probably the most popular colorimeter.
So what about LCDs? Do you have to use a correction matrix, or are the spectral samples included with the i1profiler software good enough? I calibrated my LG LCDs back when my i1display lt was still somewhat accurate and I re-checked my settings after about a year with my i1display pro without a spectral sample and the measurements were almost identical to my measurements with my i1d-lt a year ago.
rahzel is offline
post #846 of 11719 Old 08-14-2012, 04:18 PM
DaGamePimp's Avatar
Quoted: 550 Post(s)
Liked: 583
You can use HCFR 2.1 with the i1Pro spectro.
Jason
HT = Sony HW45ES @133" / Lumagen Radiance / Denon x5200 7.3.4 Atmos / B&K 5000 II amp / Boston VR2/VR12/CR67 speakers / Rythmik 12" subs x2 / CV 15" sub / Sony x800 / Toshiba HD-A3
Media Room = Sony 65x930e / Denon x3300 /Klipsch speakers /Velodyne subs /Sony x700 /PS4 Pro + PSVR/WiiU/PS3/360/Wii/ 2080 TI game PC / Multi-Arcade / Virtual Pinball TRE45ON
DaGamePimp is offline
post #847 of 11719 Old 08-14-2012, 10:59 PM
ndaa75's Avatar
Jason
Tried that - get a driver error every time even though im puttting eyeone.dll in the colorhcfr folder??
ndaa75 is offline
post #848 of 11719 Old 08-14-2012, 11:13 PM
stevekale's Avatar
Quoted: 382 Post(s)
Liked: 46
I understand a correction matrix is only needed for certain cheaper probes, correct?
Demand greater honesty and transparency in high-end audio
With Theta, Egglestonworks and Krell since 1998!
stevekale is offline
post #849 of 11719 Old 08-14-2012, 11:17 PM
djams's Avatar
That should be all you need to do. Try this: If you've got any x-rite software running in your system tray, shut it down before launching HCFR. ( a guess, but it's all I've got)
djams is offline
post #850 of 11719 Old 08-14-2012, 11:21 PM
ndaa75's Avatar
got it working now - now i want to proifile my id3 from my i1pro.
When I do a run with hcfr 2.1 with the i1pro, do i do a full run of RGB colors and a full grayscale measurement?
Cheers
ndaa75 is offline
post #851 of 11719 Old 08-14-2012, 11:39 PM
djams's Avatar
Cheers
Here are clear instructions by LarryInRI: https://www.avsforum.com/t/1420779/noob-question-profiling-i1-display-pro-against-and-i1-pro#post_22230797
Now here's the twist though. Since your i1d3 isn't supported in HCFR 2.1, you'll have to use the i1Pro to take the measurements in 2.1, save the file, launch HCFR 3, open the file you just saved, and pick up the process from there with the i1d3. An extra step, but no problem.
djams is offline
post #852 of 11719 Old 08-14-2012, 11:53 PM
stevekale's Avatar
Quoted: 382 Post(s)
Liked: 46
JohnAD, how far away are you from getting the i1Pro working with the latest version? I can push off going back to my calibration for a few weeks or so if this is near-term. I've used older versions of HCFR with my i1Pro. In terms of functionality, what's the difference between 3.0.0 (I believe from reading Zoyd's posts that the i1Pro works with this version) and later versions? How far away are we from the next significant release?
post #853 of 11719 Old 08-15-2012, 12:02 AM
djams's Avatar
Originally Posted by stevekale View Post
In terms of functionality, what's the difference between 3.0.0 and later versions?
http://sourceforge.net/p/hcfr/wiki/Changelog/
djams is offline
post #854 of 11719 Old 08-15-2012, 12:18 AM
stevekale's Avatar
Quoted: 382 Post(s)
Liked: 46
Yes saw that. A plain English summary would be good. I understand the fundamental change is the use of Argyll instead of individual probe manufacturer drivers for probe management? (In OS-X we don't need to mess with things like dlls and that sort of guff.) If the i1Pro worked with 3.0.0 why did functionality drop in later versions?
post #855 of 11719 Old 08-15-2012, 04:21 AM
ndaa75's Avatar
Actually its not that clear - as per my question, presumably i use red green blue and 1 x white window, all at 75% for example?
Or do i use red green blue and the entire grayscale from 0 to 100 ire - apologies for the questions but i am still learning.
ndaa75 is offline
post #856 of 11719 Old 08-15-2012, 07:06 AM
dominickwok's Avatar
red green blue and 1 x white window, all at 75% (or all at 100%)
dominickwok is offline
post #857 of 11719 Old 08-15-2012, 08:07 AM
ndaa75's Avatar
Great! thanks
ndaa75 is offline
post #858 of 11719 Old 08-15-2012, 11:57 AM - Thread Starter
zoyd's Avatar
Liked: 1348
For profiling I measure RGBW (75%) with the i1pro using version 3.0.0.0 and then copy those measurements into a simulated probe sheet in 3.0.4.0 Check it as reference and then run the D3 in another sheet and compute the correction matrix.
zoyd is offline
post #859 of 11719 Old 08-15-2012, 12:05 PM
vega509's Avatar
Quoted: 197 Post(s)
Liked: 55
where can I find ver 3.0.0.0? sourceforge only has the latest version.
I found it, google hcfr 3.0.0.0 and a link to sourceforge will be the 1st hit/
thanks
vega509 is offline
post #860 of 11719 Old 08-15-2012, 01:28 PM
stevekale's Avatar
Quoted: 382 Post(s)
Liked: 46
or....I run an xp vbox on my Mac that works with HCFR
But then I would have to buy a copy of XP. It would be great if HCFR could run on Crossover. Then a Mac user could run it without Parallels etc and without having to purchase Windows.
EDIT: Hmmm..... http://www.codeweavers.com/compatibility/search/?name=hcfr&search=app Anyone had a play with this on later versions?
post #861 of 11719 Old 08-15-2012, 02:06 PM
ndaa75's Avatar
Hi Zoyd
Any specific reaspon why you have decided to take this route? Presumably using 2.1 for the pro profile then using 3.0.3.4 for the iD3 should be ok?
ndaa75 is offline
post #862 of 11719 Old 08-15-2012, 03:16 PM
DaGamePimp's Avatar
Quoted: 550 Post(s)
Liked: 583
Yes that works just fine, I have done it several times already (2.1 -> 3.0.4.0).
I had thought there was a bug in 3.0.0.0 with the i1Pro and the later version 3 releases simply did not work..(maybe not)?
Jason
post #863 of 11719 Old 08-16-2012, 12:09 AM
Killerbeenl's Avatar
Jason
+1
i1pro does not work in 3.0.0.0
Successful manually installed Argyll driver and win7 64bit reports i1pro is working.
After i start HCFR 3.xx program can not communicate with i1pro.
Am i forgeting something?
Sometimes you are 1 click away from pulling your hair out and bang your head against the wall
Killerbeenl is offline
post #864 of 11719 Old 08-16-2012, 02:26 AM
rahzel's Avatar
Liked: 148
Code:
1.055150     0.008338        -0.013504
0.009191        1.028573        -0.008165
-0.013243       0.020807        0.977213
Originally Posted by kjgarrison View Post
Code:
1.038606808  -0.002502512    -0.011492028
0.010401065     0.994002567     -0.003384238
-0.006758658    0.008717773     0.977999919
Just want to thank zoyd and kjgarrison for posting their correction matrices. I've tried both of them on my 60ST50 / i1Display Pro and they are very similar indeed and both work very well. Most notably Red in the highend measured low without correction making me set W/B High R to +1 vs -6 / -7 with the correction matrices. They each measure blue and red slightly different but the resulted settings for both were within +/-1.
zoyd's matrix / jjgarrison's matrix / no correction:
W/B High R: -7 / -6 / +1
W/B High G: 0 / 0 / 0
W/B High B: +5 / +4 / +4
W/B Low R: +11 / +11 / +11
W/B Low G: 0 / 0 / 0
W/B Low B: +3 / +2 / +2
Looking at other calibration reports by pros, the color points for the ST50 are very close, but mine (without correction) green and cyan were a little off. Using these matrices made the points much closer after a GS calibration.
Very happy with how things look now.
rahzel is offline
post #865 of 11719 Old 08-16-2012, 04:59 AM
ndaa75's Avatar
Just out of curiosity, what is the difference between the 3 color matrix and a 4 color matrix, as per kjgarrisons earlier post in respect of correction matrix.
ndaa75 is offline
post #866 of 11719 Old 08-16-2012, 06:41 AM
rahzel's Avatar
Liked: 148
I'm interested to know as well. I think I read somewhere in this thread that the 4 color matrix should be used. The one I quoted (4 color matrix) was the one I used.
rahzel is offline
post #867 of 11719 Old 08-16-2012, 10:49 AM
vega509's Avatar
Quoted: 197 Post(s)
Liked: 55
I used v 2.1 to create a reference document to profile my i1d3 to my i1pro. I measure the primaries and secondaries with the i1pro, including the white measure, and save the file. I open the chc file in v 3.0.4.0, create a new file, run the primary and secondary measures with the i1d3, select the i1pro file as the reference, and create the profile, then save the profile. All goes well to this point. When I load the profile into a new file to use with the i1d3, everything measures ok until the last measure in the primaries sand secondaries, then an error pops up "Invalid measure matrix".
I have repeated this 3 times with the same result. Am I missing something or doing something wrong?
thanks
vega509 is offline
post #868 of 11719 Old 08-16-2012, 01:15 PM
stevekale's Avatar
Quoted: 382 Post(s)
Liked: 46
If one has an i1Pro why would you want to use an i1D3 for calibration?
post #869 of 11719 Old 08-16-2012, 01:21 PM
I1D3 does a better low ire (brightness) measure than the i1pro.
post #870 of 11719 Old 08-16-2012, 01:21 PM
grunnsat's Avatar
I bought a new ColorMunki Display, installed the software, updated the software from V1.01 to V1.02, and I was able to calibrate the screen of my PC. So the ColorMunki drivers are working.
I also installed HCFR 3.04, and this version is supposed to support the ColorMunki.
However when I try to use HCFR, it doesn't find the ColorMunki. My only choices are Simulated Sensor, DTP-94, and HCFR sensor.
I tried to figure out what can be wrong, and I noticed that the ColorMunki.inf file in the drivers section has different Vendor and and Product IDs compared to the real ID's that I found with DXdiag.
The ColorMunki.inf file has VID_ 0971 and PID_2007, the real values are VID_0765 and PID_5020.
I noticed that the DTP-94.inf file in HCFR also has VID_0765, but a different PID value.
I edited the ColorMunki.inf file to reflect the actual VID and PID values, but still HCFR only gave me the same three choices.
Then I removed all DTP-94 files from the driver section, and still I get the same three choices.
HCFR is aware that the ColoMunki is connected, because it reports Incorrect driver - Starting communication with the meter failed with severe error. Argyll error. Without the ColoMunki connected I don't get this notification.
I reported this on the HCFR forum, but so far no reaction. Is there anyone on this forum who can tell me what is wrong?
grunnsat is offline
Reply Display Calibration
