HCFR - Open source projector and display calibration software - Page 38 - AVS Forum | Home Theater Discussions And Reviews
 1405Likes
post #1111 of 11723 Old 12-12-2012, 06:38 AM
Losha's Avatar
Originally Posted by smokarz View Post
I am using AVSHD greyscale, saturation patterns, etc. to do the calibration.
But when I go take the greayscale measurement, HCFR didn't even prompts me to display the 0%, 10%, 20% greyscale etc.
In the past, with HCFR it prompt me to display each greyscale. It seems to automatically display its own pattterns and take the measurements extremely quickly.
Unless, I am doing something incorrectly.
goto
MEASURES -> GENERATOR -> SELECT
Is this how HFCR measures grayscale now?
always worked like that, if VIEW IMAGES was selected
It's a guy thing. We don't read. We do. We ask questions later. quote by Curt
Losha is offline
post #1112 of 11723 Old 12-12-2012, 07:08 AM
smokarz's Avatar
Quoted: 30 Post(s)
Liked: 84
Thanks, I'll give that a try tonight.
smokarz is offline
post #1113 of 11723 Old 12-12-2012, 08:59 AM
spongebob's Avatar
Quoted: 429 Post(s)
Liked: 41
Using a D3 meter, I don't see anywhere to choose Plasma, LCD, etc as a display choice?
bob
spongebob is offline
post #1114 of 11723 Old 12-12-2012, 07:50 PM
Make73's Avatar
Quoted: 58 Post(s)
Liked: 63
bob
With plasma use display type "refresh"
Sync it with TV pressing calibrate with IRE30 window
If you use it as contact, wait something like 20-30 minutes until temperature is evened
If use as non-contact, select "projector" and place it 4-8 inch from screen, depends also if there is reflections etc
http://www.avforums.com/forums/16521065-post300.html
From there you can find pretty good DIY so your room don´t have to be dark when measuring smile.gif
Here is also some other basic settings (from there you can find answer to your question):
https://www.avsforum.com/t/1393853/fork-of-hcfr-started-whats-needed/780#post_22266748
(I´m using Win8 and path is c:\Users\"User name"\AppData\Roaming\color\)
If you want use Spectral sample for plasma:
https://www.avsforum.com/t/1433489/favor-request-from-anyone-with-a-i1display-pro-plasma-and-reference-meter-need-a-ccss
http://dispcalgui.hoech.net/colorimetercorrections/?get&type=ccss&manufacturer=Samsung%20Electric%20Company&display=SAMSUNG&instrument=i1%20DisplayPro%2C%20ColorMunki%20Display%2C%20Spyder4&html=1
Save that .ccss file to path where .ccss files are
Run c:\Program Files (x86)\HCFR Calibration\Tools\i1d3ccss.exe from Command Prompt, however if I doubleclick that from windows it don´t add those to HCFR, maby it works for you.
With i1DPro(3) you may wanna try correction matrix by zoyd or kjgarrison:
https://www.avsforum.com/t/1393853/fork-of-hcfr-started-whats-needed/840#post_22311630
You can just type those to:
Advanced-->XYZ coordinates adjustment matrix-->manually edit XYZ conversion matrix
or download those from attachment and
Advanced-->XYZ coordinates adjustment matrix-->manually edit XYZ conversion matrix-->Load
Matrix for i1DPro.zip 1k .zip file
File Type: zip Matrix for i1DPro.zip (597 Bytes, 182 views)
CFC, D-an-W and wl1 like this.
Make73 is offline
post #1115 of 11723 Old 12-12-2012, 09:27 PM
HD-Master's Avatar
Quoted: 444 Post(s)
Liked: 486
When choosing the option to calibrate the meter within HCFR it says to use a white image. (I'm paraphrasing as I cannot remember the exact wording) I simply brought up a 100% white greyscale window from the GCD disc to accomplish this. Is that acceptable or should I be using something else?
LG OLED65C7P - Professionally Calibrated l Apple TV 4K l Microsoft Xbox One S l Sony STR-ZA1100ES l Polk Audio CS2 Series II Center Channel l Polk Audio Monitor 60 Series II Floorstanding L/R l Polk Audio Monitor 45B Rear Surround l Dual BIC V1220 Subwoofers
HD-Master is online now
post #1116 of 11723 Old 12-13-2012, 07:51 AM
smokarz's Avatar
Quoted: 30 Post(s)
Liked: 84
https://www.avsforum.com/t/1393853/fork-of-hcfr-started-whats-needed/840#post_22311630[
/B]
What is the purpose of a matrix correction? Do you need it to calibrate a projector?
smokarz is offline
post #1117 of 11723 Old 12-13-2012, 08:12 AM
Make73's Avatar
Quoted: 58 Post(s)
Liked: 63
/B]
Matrix is made against accurate meter (reference) so it corrects measure faults caused by meter.
Make73 is offline
post #1118 of 11723 Old 12-13-2012, 09:00 AM
smokarz's Avatar
Quoted: 30 Post(s)
Liked: 84
But doesn't everyone's colorimeter (i1D3) different?
I don't think you can simply apply the same adjustments to all i1D3 that are out there. Or am I missing it?
smokarz is offline
post #1119 of 11723 Old 12-13-2012, 09:28 AM
vega509's Avatar
Quoted: 197 Post(s)
Liked: 55
correct, the only way to accurately use a correction matrix is to use your meter and a spectro to create the tables for each type of display.
vega509 is offline
post #1120 of 11723 Old 12-13-2012, 09:33 AM
HD-Master's Avatar
Quoted: 444 Post(s)
Liked: 486
Do you calibrate a meter against a white test surface or a black test surface? I've read conflicting opinions.
post #1121 of 11723 Old 12-13-2012, 02:54 PM
cobhc2010's Avatar
Quoted: 64 Post(s)
Liked: 51
I'm getting major variances when trying to calibrate greyscale from 10-40 IRE, red and blue will move up and down by at least 6 percent without changing anything on the display (GT50), is this a limitation of my meter (i1 Display Pro) or is it something I may be doing wrong? I'm using AVS 709 for my patterns.
Display - LG OLED55C8
Speakers - Dali Zensor 3 (Front), Zensor Vokal, Zensor 1 (Surrounds), Alteco C-1 (Atmos) w/SVS PC-2000
Receiver & Misc - Denon AVR-X2200W, Philips Hue, Harmony Elite, Xbox One X, PS4 Pro, Nintendo Switch, Nvidia Shield, Anti-Mode 8033 Cinema, i1 Display Pro
cobhc2010 is offline
post #1122 of 11723 Old 12-13-2012, 07:22 PM
Make73's Avatar
Quoted: 58 Post(s)
Liked: 63
http://www.drycreekphoto.com/Learn/Calibration/MonitorCalibrationHardware.html
Instrument : i1Display Pro/CM Display
Units Tested : 13
Mean Delta-E 2000 : 0.4
Max DE-2000 : 1.6
Seems that there´s not so much variable between different units (when new).
Many have reported redish white balance without matrix.
Zoyd wrote earlier that using Matrix is more accurate than without it.
Of course you don´t get reference meter with using matrix which is made to other unit , but point is that you can get closer with that.
Zoyd made his one with i1 Pro 2 meter and kjgarrison´s matrix was delivered from Chromapure with meter. Those two matrixes are almost same, at least result is almost same. Only difference what I got was W/B High B +/- 1
rahzel reported same kind of results:
However I used that and get rid of redish white.
Also color temperature difference is almost 500K, without matrix picture is too warm.
Of course it also affects to colors, CMS settings was also pretty different than without matrix.
Try to set one preset without matrix and other with matrix so you can compare those.
Thanks to zoyd and kjgarrison for sharing their matrixes.
Here is picture when matrix was entered and made grayscale remeasurement, as you can see it´s quite redish:
Make73 is offline
post #1123 of 11723 Old 12-14-2012, 01:34 AM
rahzel's Avatar
Liked: 148
Ya, unit to unit variations are fairly small on the i1D3. Obviously referencing your meter to a spectro on your particular display will be the best option, but using a correction matrix from another i1D3 will be considerably better than not using one. I almost ended up with the same settings with zoyd and kj's matrices.
rahzel is offline
post #1124 of 11723 Old 12-14-2012, 05:43 AM
fallengt's Avatar
" Incorrect driver - Starting communication with the meter failed with severe error. Argyll error" I got this error when I used i1 Pro with HCFR on both laptop and desktop, already installed eye one pro argyll driver. Anyone knows why? dispcalGUI works fine though, it uses the same argyll driver as HCFR.
fallengt is offline
post #1125 of 11723 Old 12-14-2012, 08:26 AM
Apierre's Avatar
Have a look here: https://www.avsforum.com/t/1393853/fork-of-hcfr-started-whats-needed/1080#post_22662548
Currently only HCFR Version 3.0.0.0 works with i1 Pro or i1 Pro 2 (note: these devices are different from an an i1 DISPLAY Pro, the i1 Display Pro doesn't have the same issue). You don't need to change your Argyll drivers to use HCFR 3.0.0.0 it is compatible up to Argyll 1.4.0.
Apierre is offline
post #1126 of 11723 Old 12-14-2012, 09:24 AM
vega509's Avatar
Quoted: 197 Post(s)
Liked: 55
are you using small apl windows or fields for the patterns? You may be hitting the limiter on the panel. Have you let the panel warm up with the meter in measuring position? plasmas can take 30+ minutes to warm up, and if using the meter in contact mode, or close to the screen it should have its temperature stabilized as well.
vega509 is offline
post #1127 of 11723 Old 12-14-2012, 09:34 AM
spongebob's Avatar
Quoted: 429 Post(s)
Liked: 41
my kuro needs a full hour.
b
post #1128 of 11723 Old 12-14-2012, 10:53 AM
smokarz's Avatar
Quoted: 30 Post(s)
Liked: 84
Units Tested : 13
Max DE-2000 : 1.6
Thanks, I like to give that a try. So if I've alrteady run my greyscale, can I enter the matrix and see how the numbers changes?
Or do I need to enter the matrix, and re-run grayscale?
smokarz is offline
post #1129 of 11723 Old 12-14-2012, 12:22 PM - Thread Starter
zoyd's Avatar
Quoted: 1783 Post(s)
Liked: 1348
zoyd is offline
post #1130 of 11723 Old 12-14-2012, 04:05 PM
realzven's Avatar
Liked: 84
Zoyd your matrix work with the colormunki display ?
realzven is offline
post #1131 of 11723 Old 12-14-2012, 05:48 PM
spongebob's Avatar
Quoted: 429 Post(s)
Liked: 41
Well, I paid an extra $150 to have this done from Tom and not sure if it was really necessary, at least for the plasma correction. Here is my table:
edit: deleted per Tom.
Not sure how significant the difference is?
bob
post #1132 of 11723 Old 12-14-2012, 07:25 PM - Thread Starter
zoyd's Avatar
Liked: 1348
If it uses the same hardware it will help but i don't know if it does.
zoyd is offline
post #1133 of 11723 Old 12-15-2012, 12:02 AM
realzven's Avatar
Liked: 84
realzven is offline
post #1134 of 11723 Old 12-15-2012, 08:17 AM
Make73's Avatar
Quoted: 58 Post(s)
Liked: 63
Field Reference
White Red Green Blue White Red Green Blue
Plasma
x 0.315 0.638 0.296 0.149 0.325 0.649 0.303 0.150
y 0.336 0.339 0.615 0.062 0.335 0.326 0.608 0.063
bob
Four colour matrix
1,0575508364 -0,0090725012 -0,0145563124
-0,0030463377 1,0004775457 -0,0005755271
0,0031198015 0,0048183942 0,9667572552
Here is how your matrix affects to RGB Levels when added to calibrated RGB Levels without any correction.
Seems little bit different than zoyd´s or kjgarrisons´s
i1D3 spongebob matrix made by Tom Huffman.zip 0k .zip file
File Type: zip i1D3 spongebob matrix made by Tom Huffman.zip (286 Bytes, 121 views)
Make73 is offline
post #1135 of 11723 Old 12-15-2012, 08:29 AM
spongebob's Avatar
Quoted: 429 Post(s)
Liked: 41
Four colour matrix
Please explain in real world terms?
bob
post #1136 of 11723 Old 12-15-2012, 08:31 AM
Make73's Avatar
Quoted: 58 Post(s)
Liked: 63
bob
See attachment and:
I´m totally amateur smile.gif, just used calculator from:
https://www.avsforum.com/t/1393853/fork-of-hcfr-started-whats-needed/630#post_22046028
If I change zoyd´s or kjgarrison´s matrix to your one it looks like this:
Seems that it needs even more red reducing.
Thanks for sharing this one, I´m gonna try with your matrix at next time smile.gif
btw, I can find from Argyll database .ccmx for Panasonic plasma television but is there any way to use that with HCFR? Convert .ccmx to .ccss or something redface.gif
Make73 is offline
post #1137 of 11723 Old 12-15-2012, 08:33 AM
cobhc2010's Avatar
Quoted: 64 Post(s)
Liked: 51
Small APL's, leaving it to warm up for an hour with the meter about 6 inches away from the screen. Still fluxuates a lot.
post #1138 of 11723 Old 12-15-2012, 09:26 AM
vega509's Avatar
Quoted: 197 Post(s)
Liked: 55
you can try to isolate where the fluctuation is sourced by
changing cables
changing inputs
changing blu-ray and dvd players
check the sets user menus and ensure any dynamic contrast, noise, black enhancement etc are off
I'll guess there is some setting on the set that is on and causing the fluctuation you are experiencing.
vega509 is offline
post #1139 of 11723 Old 12-15-2012, 10:40 AM
spongebob's Avatar
Quoted: 429 Post(s)
Liked: 41
See attachment and:
Let me know how it goes.
bob
post #1140 of 11723 Old 12-15-2012, 11:13 AM - Thread Starter
zoyd's Avatar
Liked: 1348
Typical d3 offsets are around 500K, probe variability is probably in the 100K-200K range so I would expect to see that kind of variation when comparing different correction matrices.
zoyd is offline
Reply Display Calibration
