HCFR - Open source projector and display calibration software - Page 411 - AVS Forum | Home Theater Discussions And Reviews
 1479Likes
post #12301 of 12314 Old 02-05-2020, 09:13 AM
alfred67's Avatar
Hello
2019 Samsung QN65Q70AFXZC (Backlighting is Direct Full Array 4x) - HCFR display type?
Does anyone know the correct / closest match display type to use when calibrating a Samsung QN65Q70AFXZC using HCFR software and X-Rite i1 Display Pro.
Would one of this correction file work ?
https://colorimetercorrections.displ...%20Pro%29.ccmx
or
https://colorimetercorrections.displ...0Q9%2075_.ccmx
alfred67 is offline
post #12302 of 12314 Old 02-10-2020, 08:20 AM
Quoted: 5520 Post(s)
Liked: 2225
Originally Posted by hannes69 View Post
Many thanks for the link and your explanations, that helped me a lot!
I would never have thought that an average movie delivers only 10% brightness...
When I find the time, I will do 2 calibration runs, one with full fields and one with 10% window.
Then I will see how different the two results will be. In terms of numbers and visually.
Also see this post:
https://www.avsforum.com/forum/139-d...-patterns.html
Dominic Chan is online now
post #12303 of 12314 Old 02-14-2020, 04:37 AM
Liked: 0
Hy!
I calibrated my Benq W2000 projector. After the calibration based on the grayscale measurement, everything is fine and deltaE is below under 3 for all IRE.
But if I check the White clipping video from the AVSHD709 disc, I see a blue tint in the flashing white bars and I see the flashing white bars until the 241 bar.
Before the calibration process I have setting up the contrast where the 235 bar is not visible but the 234 does without any colorization or tint.
Tokodboy is offline
post #12304 of 12314 Old 02-14-2020, 06:12 AM
Liked: 2225
Originally Posted by Tokodboy View Post
Hy!
To help diagnose please post your HCFR Before and After measurement files (chc), as well as the adjustments you made, in particular the Contrast and RGB Gain.
post #12305 of 12314 Old 02-14-2020, 07:35 AM
Liked: 0
Unfortunately, I did not save the file. I only can attach report files which is made with calman and the contrast and gain settings.
Tokodboy is offline
post #12306 of 12314 Old 02-14-2020, 08:42 AM
Liked: 0
I changged
Brightness from 50 to 51
Contrast from 50 to 48
R-Gain: from 100 to 91
G-Gain: from 100 to 94
B-Gain: 100 untouched
R-Offset: from 256 to 253
G-Offset: from 256 to 251
B-Gain: 256 untouched
I can attach file until i have 5 comments
ID:	2684772   Click image for larger version
Tokodboy is offline
post #12307 of 12314 Old 02-14-2020, 09:05 AM
Liked: 2225
I changged
The RGB balance needs to be smooth even when things are not perfect. You have huge bumps at 70% and 90% which can cause problems with near white - unless you didn't re-measure those points after the adjustments.
post #12308 of 12314 Old 02-14-2020, 10:23 AM
Liked: 0
The projector only has 2 point grayscale menu.
I used 30 IRE and 80 IRE patterns, as You can see at 80 IRE the values are good, so I dont know how can I smooth these bumps if i have only 2 point system.
I tried the other method when the green channels left untouched and I adjusted the red and blue channels to match the green but I got worse result.
Tokodboy is offline
post #12309 of 12314 Old 02-14-2020, 10:36 AM
skschatzman's Avatar
Quoted: 2869 Post(s)
Liked: 1668
I wouldn't worry about it with 2pt controls. The errors are within imperceivable values.
skschatzman is online now
post #12310 of 12314 Old 02-14-2020, 02:39 PM
Liked: 2225
The OP is seeing blue tint in the flashing white bars
post #12311 of 12314 Old 02-14-2020, 02:51 PM
Liked: 0
Yes, and I do not understand why I see blueish color in the test pattern while the grayscale measurement gives me a good result. Maybe the test pattern is wrong?
Tokodboy is offline
post #12312 of 12314 Old 02-14-2020, 03:33 PM
Liked: 2225
Are you seeing blue only in the flashing white bars, or in the solid test patterns as well? If the latter then it depends on whether you trust your eyes more than the meter.
post #12313 of 12314 Old Yesterday, 12:50 AM
Liked: 0
Only the flashing bars The solid bakcground is white.
Tokodboy is offline
post #12314 of 12314 Old Yesterday, 09:08 AM
Liked: 2225
The blue tint resulted from you decreasing the R and G gains, which is equivalent to increasing B in a relative sense. This can be verified rerunning the grey-scale sweep and the near white sweep.
To do that you can use the HCFR internal patterns. Save the measurement file.
Reply Display Calibration
