HCFR - Open source projector and display calibration software - Page 43 - AVS Forum | Home Theater Discussions And Reviews
 1405Likes
post #1261 of 11720 Old 01-22-2013, 11:47 AM
PeterLewis's Avatar
Quoted: 173 Post(s)
Liked: 127
Thanks jkoz,
So you set your color by blue filter? do you trust this method over the Calman software?
Sony OLED XBR-65A1E| XBR65X950B|XBR55X900B|2-BR100/Subs|4K X10 Player
Denon - X7200WA|Roku Ultra 4k|PS4
Mirage Omnisat V2 5.1.4 Dolby Atmos set up with SVS PB2000 Sub
PeterLewis is offline
post #1262 of 11720 Old 01-22-2013, 12:51 PM
jkozlow3's Avatar
Quoted: 87 Post(s)
Liked: 65
Originally Posted by PeterLewis View Post
Thanks jkoz,
Personally, I think the filter works fine and have never tried to use HCFR or Calman to set color. I'm not an expert calibrator by any means though - just a novice who loves to tinker.
jkozlow3 is offline
post #1263 of 11720 Old 01-22-2013, 08:33 PM
Make73's Avatar
Quoted: 57 Post(s)
Liked: 60
Originally Posted by sodaboy581 View Post
I can vouch for this as well.
I had been doing my calibrations with my i1Display Pro using ColorHCFR. I set up everything correctly, even the little advanced check boxes and so on, but I'd still detect the calibration was a little more red than I thought it should be.
I went ahead and purchased CalMAN Basic and started doing calibrations with it. I did both my Asus PA246Q monitor and Sony KDL60EX645. The red push I was getting with ColorHCFR was gone.
So, I agree that there is definitely something up with ColorHCFR and the i1Display Pro's calibration.
I noted this in another thread here: https://www.avsforum.com/t/1444311/official-sony-kdl60ex645-thread/60#post_22852255
Sadly JohAd is disappeard so there´s no hope that it will be fixed.
Is CalMAN Basic enough, so it does same thing than HCFR or do I need control version?
Does it work with retail version of i1 Display Pro or do I need to give serial of meter or something to get it working?
Make73 is offline
post #1264 of 11720 Old 01-22-2013, 10:01 PM
sodaboy581's Avatar
Quoted: 27 Post(s)
Liked: 39
I use CalMAN Basic with the retail i1 Display Pro, works just fine. No need to give serial or anything.
It does pretty much the same thing as HCFR, even has a built-in pattern generator too.
If you're looking for more "numerical" values during your calibration, try the Quick Analysis workflow (helps tons because you can see your gamma curve here too, then you can use the HT Basic calibration for your grayscale) once you get it.
Make sure you set the correct display type when using CalMAN and you'll be off!
Sony XBR-65X900E, Denon AVR-X2300W, Polk CS20 Center, Polk Monitor 75T Fronts, Polk TSI300 Rears, Power Sound Audio S1500 Subwoofer.
sodaboy581 is offline
post #1265 of 11720 Old 01-22-2013, 10:09 PM
spongebob's Avatar
Quoted: 421 Post(s)
Liked: 41
Originally Posted by jkozlow3 View Post
Personally, I don't think profiling the i1D3 against another meter should be necessary. It's a very accurate meter by itself, as proven by the links posted above.
The reason that calibrations appear too red without profiling the i1D3 (or without adding an adjustment matrix) is because HCFR and/or the Argyll drivers are doing something incorrectly. I say this with confidence, as I've compared a simple greyscale calibration side-by-side with HCFR and Calman using 2 different color temp presets in the service menu of my Panasonic (picture mode and everything else was equal) and the Calman calibration was visibly better. Skin tones were less red and looked more realistic with the Calman calibration as I flipped back and forth. Not night and day better, but definitely noticeable by eye.
It's not profiling that we need - it's different software.
My $.02
I have a D3 PRO with Chroma Pure and I can say that applying the adjustment matrix that was done for me here gives perfect, if not even better at the low end of the grayscale w/ HCFR. W/O the matrix, I thought it was lacking red but I'd have to check. OTOH, Calman does not come as close and I still haven't been able to profile my CP settings with CM. Gives worse results than just picking Plasma alone.
I was pleantly surprised when I did a back to back CP and HCFR run today and HCFR was perfect.
bob
spongebob is offline
post #1266 of 11720 Old 01-23-2013, 06:15 AM
Rob67's Avatar
Liked: 27
You don´t need to do that because you have matrix correction (correction for plasma display type is included in that matrix...thx zoyd wink.gif ).
Just choose "Display Type : i1D3 Refresh display"
Leave "Spectral sample" empty/none
Load your matrix "Advanced-->XYZ coordinates adjustment matrix-->manually edit XYZ conversion matrix-->Load" and ready to go.
(Sync i1D3 with your TV at IRE30 window by pressing calibrate from sensor configure.)
However if you have not ever used command prompt it´s like this:
cd..
cd..
cd program files (x86)
cd hcfr calibration
cd tools
i1d3ccss
There is two different matrixes for i1D3 created with Panasonic plasma against i1Pro meter.
Gonna try those.
Here are all those six matrix correction .mhc files for i1 Display Pro(3) with plasma TV which I found:
Matrix for i1DPro(3) or CM Display with plasma.zip 2k .zip file
Made calibration with "Panasonic plasma 1 matrix for i1D3 against i1Pro from Argyll database.mhc" matrix and finally I´m happy to results smile.gif
Panasonic TX-P55ST50Y calibration.zip 28k .zip file
Some more calibrations when I´ll get new panel under warranty because of burn-in.
Interesting to see how new panel affects to settings.
However that goes till February because Panasonic couldn´t deliver that quicker to Finland and I´ll do some running in before calibration.
Is there a way to open these mhc files to add the correction tables to CalMAN?
Rob67 is offline
post #1267 of 11720 Old 01-23-2013, 06:44 AM
spongebob's Avatar
Quoted: 421 Post(s)
Liked: 41
Me too! I have tried the new Calman Matrix tool but my results are way off so far. I'm still trying to get my D3 offsets into Calman.
bob
post #1268 of 11720 Old 01-23-2013, 06:47 AM
spongebob's Avatar
Quoted: 421 Post(s)
Liked: 41
Thanks jkoz,
Calman uses the blue filter
bob
post #1269 of 11720 Old 01-23-2013, 07:05 AM
praz's Avatar
Liked: 27
bob
This is only true if the display does not have CMS capability.
praz is offline
post #1270 of 11720 Old 01-23-2013, 08:55 AM - Thread Starter
zoyd's Avatar
Quoted: 1783 Post(s)
Liked: 1348
the matrix correction used in HCFR is different than that used in either CalMAN or CP, HCFR corrects for Y luminance offset between the reference and target meters. So if you use the matrix values generated by HCFR in the other two programs (or vice versa) then will not yield the same measurements.
zoyd is offline
post #1271 of 11720 Old 01-23-2013, 09:11 AM
spongebob's Avatar
Quoted: 421 Post(s)
Liked: 41
Wish I knew that 2 hours ago! Entered them in Calman plasma and crt mode and no go, way off! Oh well
bob
post #1272 of 11720 Old 01-23-2013, 08:14 PM
Make73's Avatar
Quoted: 57 Post(s)
Liked: 60
zoyd,
What is your experience about HCFR 3.x.x, does it measure something wrong, especially red?
Those who paid for matrix delivered with meter, I suppose it´s not created with HCFR smile.gif
(Like I wrote, I copied that matrix from Argyll database and with that it seems to be very nice, no redish white balance. So I think not gonna pay 150$ for CalMan. Things may be different if I had paid for matrix and white balance looks redish because of [email protected] measure faults)
btw, Got my 55ST50 set back with new panel week ago (changed under warranty because of burn-in), I´ll drive 200h break-in slides and recalibrating. If someone is interested to see how different panel affects to settings I can post new measurements day after tomorrow.
Make73 is offline
post #1273 of 11720 Old 01-24-2013, 02:19 AM
realzven's Avatar
Liked: 84
zoyd,
where is your matrix you choose to calibrate your ST50 ?
realzven is offline
post #1274 of 11720 Old 01-24-2013, 07:55 AM
Make73's Avatar
Quoted: 57 Post(s)
Liked: 60
I wrote that earlier and it´s quoted few posts back, it´s named "Panasonic plasma 1 matrix for i1D3 against i1Pro from Argyll database.mhc".
Make73 is offline
post #1275 of 11720 Old 01-24-2013, 08:29 AM
realzven's Avatar
Liked: 84
realzven is offline
post #1276 of 11720 Old 01-24-2013, 09:58 PM
spongebob's Avatar
Quoted: 421 Post(s)
Liked: 41
Where is the excel spreadsheet in this thread?
thx
bob
post #1277 of 11720 Old 01-25-2013, 01:04 AM
realzven's Avatar
Liked: 84
thx
bob
this one ? https://www.avsforum.com/attachments/66073
realzven is offline
post #1278 of 11720 Old 01-25-2013, 01:16 AM
ttnuagmada's Avatar
Quoted: 246 Post(s)
Liked: 272
So, was anyone else besides John working on this project? Does anyone know what happened to John? He was doing awesome things with HCFR, and he also has a really cool program called Upsilon Mixer that he was working on, but the last post I can find from him here or on the Upsilon forum is from september. He obviously hasn't been to the Upsilon website, because the forum has been overrun with spammers for months. I hope that he is ok.
ttnuagmada is offline
post #1279 of 11720 Old 01-25-2013, 03:40 AM
Make73's Avatar
Quoted: 57 Post(s)
Liked: 60
Or this one ?
Make73 is offline
post #1280 of 11720 Old 01-26-2013, 05:08 PM - Thread Starter
zoyd's Avatar
Liked: 1348
I made a change in the D3 meter code that has stabilized it quite a bit. Simply setting the baseline integration time to a larger value (1.5 sec which is the default for CM for low light conditions) did the trick. I don't know anything about git and merging in new code etc. so here is a standalone package with the change.
edit:
Made a proper installation package:
HCFRsetup.exe
Nordo and wl1 like this.
zoyd is offline
post #1281 of 11720 Old 01-26-2013, 06:41 PM
spongebob's Avatar
Quoted: 421 Post(s)
Liked: 41
I made a change in the D3 meter code that has stabilized it quite a bit. Simply setting the baseline integration time to a larger value (1.5 sec which is the default for CM for low light conditions) did the trick. I don't know anything about git and merging in new code etc. so here is a standalone package with the change. I'm new with Visual studio 2010 so let me know if it works, just unzip in an empty directory.
https://dl.dropbox.com/u/2621383/HCFR_stableD3.zip
Forgive me, but what do we do with this?
bob
post #1282 of 11720 Old 01-26-2013, 07:10 PM - Thread Starter
zoyd's Avatar
Liked: 1348
unzip and run ColorHCFR.exe, D3 measurements at 30% on plasma's will be stable. If someone knows how to work with git and wants to submit a change to the archive let me know and I'll send the code changes I made. I think John has to do the final commits though.
zoyd is offline
post #1283 of 11720 Old 01-26-2013, 09:13 PM
Make73's Avatar
Quoted: 57 Post(s)
Liked: 60
edit:
HCFRsetup.exe
Measured ten sequential gray scale (RGB scale 80-120 on images)
Y values 0%=0.013 10%=0.906 20%=3.442 30%=7.884 40%=14.166 50%=22.397 60%=32.775 70%=47.007 80%=65.590 90%=83.218 100%=106.863
Here are new calibrations with new panel:
Panasonic TX-P55ST50Y calibration.zip 52k .zip file
Make73 is offline
post #1284 of 11720 Old 01-27-2013, 07:59 AM
spongebob's Avatar
Quoted: 421 Post(s)
Liked: 41
Oh, sorry. Didn't see that it was a complete new install. What D3 problems did it fix? My D3 using the matrix seems fine, even better 20% readings than CM or CP. I guess I can still run both and compare?
bob
post #1285 of 11720 Old 01-27-2013, 08:17 AM - Thread Starter
zoyd's Avatar
Liked: 1348
bob
The D3 w/HCFR was 2-4 dE unstable (mostly red) due to too low adaptive integration time in the 20-40% stimulus range and that's what was fixed. I have also got it working with the i1pro, at least it does on winxp. Can someone test on win7? The change here is in the driver for the i1pro so after installing the following package you have to update the i1pro driver. Use update driver in device manager and navigate to the new installation file c:\Program Files\HCFR Calibration\libusb1\i1pro.inf
HCFRsetup.exe
zoyd is offline
post #1286 of 11720 Old 01-27-2013, 08:40 AM
PeterLewis's Avatar
Quoted: 173 Post(s)
Liked: 127
@zoyd
Does the colormunki display require this patch since it runs on the i1d3exe? or is fine since it reads slower?
post #1287 of 11720 Old 01-27-2013, 08:50 AM - Thread Starter
zoyd's Avatar
Liked: 1348
@zoyd
Only needed if you are having the same instability problem.
zoyd is offline
post #1288 of 11720 Old 01-27-2013, 10:46 AM
vega509's Avatar
Quoted: 197 Post(s)
Liked: 55
HCFRsetup.exe
Thanks zoyd, but no luck here on Win7 64 bit, the i1pro is not available for selection.
vega509 is offline
post #1289 of 11720 Old 01-27-2013, 11:00 AM - Thread Starter
zoyd's Avatar
Liked: 1348
I'll have to get hold of a win7 machine to debug. After you updated the driver can you check driver properties and list the dlls installed like below?
zoyd is offline
post #1290 of 11720 Old 01-27-2013, 12:06 PM
vega509's Avatar
Quoted: 197 Post(s)
Liked: 55
sure can
vega509 is offline
Reply Display Calibration
