GCD - Gamut Calibration Disk - Page 17 - AVS Forum | Home Theater Discussions And Reviews
View Poll Results: What format would you prefer for the HTPC?
.mp4 36 31.30%
.mkv 78 67.83%
others (please detail in thread) 1 0.87%
Voters: 115. You may not vote on this poll
 3Likes
post #481 of 633 Old 10-18-2012, 10:06 AM - Thread Starter
visca blaugrana's Avatar
It has all required patterns, but the sequence is not optimised for calman yet
Sent from my HTC One X using Tapatalk 2
visca blaugrana is offline
post #482 of 633 Old 10-18-2012, 10:21 AM
zoyd's Avatar
Quoted: 1783 Post(s)
Liked: 1349
zoyd is offline
post #483 of 633 Old 10-18-2012, 12:15 PM
hrc4u's Avatar
hi!
whould it be difficult to include saturation sweeps in jpg format? (calmans own dpg pattern generators uses jpg on their patterns and sweep patterns is missing on older units).(otherwise i have to change colorspace when using video based patterns( RGB Low)...and switch back to still mode/picture colorspace RGB High)...otherwise it will be wrong..)
cheers/Harry
hrc4u is offline
post #484 of 633 Old 10-18-2012, 11:58 PM - Thread Starter
I am considering uploading them, but the last thing I want is them spread all over the internet while developing the disk.
hrc4u likes this.
post #485 of 633 Old 10-22-2012, 05:45 PM
hungro's Avatar
Quoted: 177 Post(s)
Liked: 116
In it's current beta version , can GCD be used with Chromapure pattern sequence wise?
hungro is offline
post #486 of 633 Old 10-22-2012, 11:54 PM - Thread Starter
More or less you will have to skip a few patterns, but it's only a few. It's more with calman you will have to navigate a bit more
post #487 of 633 Old 10-23-2012, 06:23 PM
gadgtfreek's Avatar
Quoted: 634 Post(s)
Liked: 6055
Id like to use the 10% grayscale patterns from this disc to calibrate my newer panasonic plasma. In my reading it seems 10% is a pretty reliable size for that application, and Im glad you guys have spent the time on these patterns.
Im going to use my new Oppo 103 blu-ray player as the generator, so can I just burn the AVCHD pattern on a DVD-R and go to town, or does it need to be the blu-ray version on a BD-R?
XBR65A9G / XBR65A8F / 55R615
DP-UB420 / ATV4K (3) / PS Vue
AVRX6500H / RP-8000F / RP-504C / RP-502S / FV15HP
gadgtfreek is offline
post #488 of 633 Old 10-25-2012, 04:48 PM - Thread Starter
Hi
Just burn to a DVD.
gadgtfreek likes this.
post #489 of 633 Old 10-26-2012, 12:23 AM
fredman2005's Avatar
Originally Posted by fredman2005 View Post
First I want to thank you for your great job.
Unfortunately the Blu Ray version b4.3.13. doesn´t work. I burnt it, but on two different players playback failed.
Any news about my problem? Has anyone else burned and used successfully the Blu-Ray version?
fredman2005 is offline
post #490 of 633 Old 10-26-2012, 01:25 PM
l-dan's Avatar
I also had problem with the Blu-Ray version.
When I investigated the directory structure on the disc I found that the STREAM directory was empty, but all files were actually on the disc. If I remember correctly the BDMV and CERTIFICATE folders are repeated in the BDMV folder. Solution is to use only these two sub folders and recreate the disc.
(Maybe it is easier to understand what is wrong if you compare folder structure with previous version of the GCD disc)
How to build a new disc or ISO file with ImgBurn
Use “Ez-Mode Picker” and select “Write files/folders to disc” or “Create image file from files/folders” if you want an ISO file.
Drag the correct BDMV and CERTIFICATE folders into the larger window below Source.
Select Mode1/2048, UDF 2.50 under “Options” and label UDF: GCDb4_3_13 under “Labels”
Start the Build process
l-dan is offline
post #491 of 633 Old 10-26-2012, 01:39 PM
Thanks, I will try it tomorrow. I think Imgburn is a windows program, so I will look wether it is install on my Win PC.
post #492 of 633 Old 10-26-2012, 05:15 PM
vincentfam's Avatar
Visca Blaugrana,
Unless I have done so already, just wanted to make sure to thank you for all of your hard work.
Vincentfam
vincentfam is offline
post #493 of 633 Old 10-27-2012, 02:42 AM - Thread Starter
as you have noticed there was an issue with the folder structure on the bluray version, this is now fixed.
post #494 of 633 Old 10-27-2012, 09:23 AM
hungro's Avatar
Quoted: 177 Post(s)
Liked: 116
How is the progress coming with the Chromapure version?
hungro is offline
post #495 of 633 Old 10-27-2012, 10:16 AM - Thread Starter
The disk as it is works very well with chromapure, you are only required to skip a few patterns however to answer your question smile.gif I would say around a month, but no guarantees, I should have an alpha release ready tomorrow but this is only for calman, focus was put on calman due to the very different pattern sequence.
The actual patterns is the same, so the result will be accurate with the current disk.
post #496 of 633 Old 10-27-2012, 12:14 PM
Thanks vista blaugrana. The BR works now very fine. Thanks again for your good work.
post #497 of 633 Old 10-28-2012, 05:53 AM - Thread Starter
I have complied a list of what I belive will be the filal pattern list.
GCDb5_0_0.xlsx 16k .xlsx file
a filnal release with all patterns are not likly to be within the next month or so
any thing I have missed?
post #498 of 633 Old 10-28-2012, 07:50 AM - Thread Starter
in the first post is there an alpha release of the new disk, this only contain basic patterns and patterns equence for CALMAN, for hcfr and chromapure useb4.3.13
post #499 of 633 Old 10-28-2012, 08:27 AM
PeterLewis's Avatar
Quoted: 173 Post(s)
Liked: 127
To calibrate color using this disc and HCFR with a iD2 colorimeter on a 2011 Panny GT30,do I use 75% amp.100% saturation color pattern?
Or do I use 75% saturation 100%amp color patterns....
I plan on doing a calibration with avs709 sm apl greyscale patterns and sm color 75% apl color,but I was going to do another one as well with this GCD disc to see which results i like best,but I was just curious on which color patterns I would need on my panny since It only has a Two point adjustments.
Sony OLED XBR-65A1E| XBR65X950B|XBR55X900B|2-BR100/Subs|4K X10 Player
Denon - X7200WA|Roku Ultra 4k|PS4
Mirage Omnisat V2 5.1.4 Dolby Atmos set up with SVS PB2000 Sub
PeterLewis is offline
post #500 of 633 Old 11-01-2012, 08:18 AM
Wouter73's Avatar
Quoted: 13 Post(s)
Liked: 36
I have a question, do al versions give the same image on screen? I assume that is the case, but then why the seperate BD version? I mean, a BD burnable is expensive, and don't all BD players play AVCHD?
Wouter73 is offline
post #501 of 633 Old 11-01-2012, 09:37 AM
turbe's Avatar
Liked: 98
there have been issues reported on some BR models
Need to find a Professional Calibrator? Click Here to PM me with your Display & City
Calibrator List - Pioneer ISFccc Interface
Calibration Reports - Pioneer
ControlCAL™
Designed by Calibrators for Calibrators™
No need to fumble through the Display's Menu with its Remote Control™
turbe is offline
post #502 of 633 Old 11-18-2012, 08:35 PM
turboman123's Avatar
Quoted: 34 Post(s)
Liked: 26
I get following error warnings when I try to unzip the mp4 files.
What should I do?
Capture1.PNG 52k .PNG file
Capture2.PNG 46k .PNG file
My system: Windows 7 Home Premium 64bit
turboman123 is offline
post #503 of 633 Old 11-20-2012, 12:20 PM - Thread Starter
Try to redownload or try to use winrar from here
post #504 of 633 Old 11-20-2012, 06:39 PM
Quoted: 34 Post(s)
Liked: 26
hello visca,
winrar worked. Thanks. Any reason the standard windows7 extract all function does not work for this zip file?
post #505 of 633 Old 11-28-2012, 10:03 AM
fallengt's Avatar
Any ETA for HTPC (mp4/mkv) version frown.gif
fallengt is offline
post #506 of 633 Old 11-28-2012, 10:09 AM
zoyd's Avatar
Liked: 1349
zoyd is offline
post #507 of 633 Old 12-02-2012, 09:04 AM
fallengt's Avatar
Lol, idk why did I miss that... Thanks zoyd
fallengt is offline
post #508 of 633 Old 12-08-2012, 08:11 PM
hungro's Avatar
Quoted: 177 Post(s)
Liked: 116
Is the final GCD disk almost done?
hungro is offline
post #509 of 633 Old 12-09-2012, 02:28 AM - Thread Starter
smile.gif I knew this question would come soon.
the project have been put tempary on hold due to a very heavy workload.
meanwhile if you have any requests please let me know..
post #510 of 633 Old 12-09-2012, 06:21 AM
PeterLewis's Avatar
Quoted: 173 Post(s)
Liked: 127
Using HCFR and GCD which is the most sure fire way to set my color on my Panny GT30 since it only has color and tint control?
I got the white balance/grayscale nice and linear using the 10% pattern on a calibration i did last night,but iam still confused on which color patterns to use using HCFR.
100/100 amp/sat or 75/100 amp/sat....they give me a different reading maybe a point off one way or the other.I just want to use the pattern that many use that works well with HCFR....Thanks.
Reply Display Calibration
