CalMan 5 Release Notes and Discussion - Page 129 - AVS Forum | Home Theater Discussions And Reviews
 1951Likes
post #3841 of 7029 Old 07-07-2017, 05:27 AM
ConnecTEDDD's Avatar
Quoted: 3249 Post(s)
Liked: 4043
Originally Posted by shoman94 View Post
Ok, so can the Linker be used in the same way?
Sent from my ZTE A2017U using Tapatalk
Yes, Linker is better choice, it has scalling capability also, for example to input 1080p24 to Linker and get 2160p24 to output etc.
shoman94 likes this.
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is online now
post #3842 of 7029 Old 07-07-2017, 06:27 AM
OMARDRIS's Avatar
Quoted: 76 Post(s)
Liked: 128
Meter-Add-On for CalMAN Home Enthusiast
Hi,
Maybe the following info is also interesting for other Enthusiast users:
Meanwhile, there is also a meter-add-on for CalMAN Home Enthusiast, which allows the use of the sensors K-10A, CR100 and Topcon BM7A.
The cost for this meter-add-on is 499$.
The meter-add-on is not advertised strongly.
Interested parties should ask directly for the sale of Spectracal.
Peter
S/W: LightSpace CMS, Calman 5, HCFR, Colorfacts
V/P: Lumagen Radiance Pro, DVDO AVlab TPG
Meters: JETI Spectraval 1501, Klein K-10A, I1Pro2, I1D3
OMARDRIS is online now
post #3843 of 7029 Old 07-07-2017, 06:52 AM
Liked: 4043
Originally Posted by WiFi-Spy View Post
The new Dolby Vision Custom calibration workflow/process for displays that support a custom Dolby Vision Configuration File is now enabled in CalMAN. Currently the only TV to support this is the 2017 LG OLED.
The process requires a pattern generator that supports Dolby Vision metadata.
CalMAN uses a new type of Dolby Vision metadata to put the color volume mapping engine into bypass mode. CalMAN then calibrates the display and generates a new Dolby Vision configuration file that is loaded into the supported TV via USB stick.
About DV calibration for LG 2017 OLED, for what peak output are you calibrating for in Cinema mode (what setting of OLED Light/Contrast required to have) the Grayscale with 2.2 Gamma target?
post #3844 of 7029 Old 07-07-2017, 09:14 AM - Thread Starter
WiFi-Spy's Avatar
Quoted: 1549 Post(s)
Liked: 2148
In DVmode the Contrast and OLED Light should be at their DV defaults which is as bright as the panel can go (@ D65)
Tyler Pruitt - Technical Evangelist - for CalMAN
10 Bit Gradient Test Patterns (HEVC) - Free Download
WiFi-Spy is offline
post #3845 of 7029 Old 07-07-2017, 12:58 PM
njfoses's Avatar
Quoted: 312 Post(s)
Liked: 181
Is there any way to use Calman internal patterns or patterns via madTPG for HDR calibration without the linker? I know i can use Masicolas patterns via USB, but they need to be used in a manual process. I have a fully HDR compatible video chain from my HTPC to TV. Just seems silly that i would need to purchase an additional piece of hardware just to calibrate HDR in an automated (reading series etc) manner.
njfoses is online now
post #3846 of 7029 Old 07-07-2017, 02:14 PM
Manni01's Avatar
Quoted: 5440 Post(s)
Liked: 5642
If you can switch your display manually to HDR, there is no need for the Linker/Integral during calibration. I use MadTPG with Calman to calibrate my JVC rs500, it works fine. I only use Masciola's USB patterns to set the levels using the bbi/boo options of Arve's curve. I do have an Integral and a Linker for other purposes, but I don't use them for calibration. My GPU isn't even HDR compatible, it doesn't make any difference as long as you select the correct gamma/gamut options in Calman (and the correct gamma/gamut options in the display). You don't even need to be in 4K, 1080p patterns work fine too.
njfoses likes this.
Manni01 is online now
post #3847 of 7029 Old 07-07-2017, 03:44 PM - Thread Starter
WiFi-Spy's Avatar
Liked: 2148
Which video card do you have? Which HDR display do you have?
WiFi-Spy is offline
post #3848 of 7029 Old 07-07-2017, 03:59 PM
njfoses's Avatar
Quoted: 312 Post(s)
Liked: 181
Nvidia 1070 and Sony 940E.
post #3849 of 7029 Old 07-07-2017, 06:19 PM
Quoted: 4474 Post(s)
Liked: 5487
So Robert at VE let me work on one of the C7s in the showroom today to try the DV calibration. You need to have firmware 3.60.09 which is only available by the sets update feature since it's not on the LG web site. Tyler, I did exactly what you suggested and just left everything at the DV Cinema default. Overall, the way I understand everything, when you run the Calman DV Custom workflow it puts the TV's Dolby Vision engine into pass-though mode via special Dolby Vision "Relative Mode" metadata as per the instructions. That allows access to the 2 and 20 pt gray scale controls. When I ran the 20 pt after the 2 pt., the lower IRE's were targeting close to 2.4 gamma up to about 35-40% then the curve settled down closer to the 2.2 target. I'm not sure if this is the way it's supposed to be since I was expecting everything to be very close to 2.2 and only have to make a couple of adjustments which was not the case. Because you are dealing with very high luminance levels, it is very tedious to get the 20 pt. flat. I did the best I could but there is a small bug in the calman interface to the Murideo where the pattern button doesn't work in DV mode and sometimes when taking continuous readings, the DV metadata would "disappear" and the LG would loose sync and the screen would go black. I reported this to the Murideo folks this afternoon. Once I got the 20 pt reasonable, and everything as close to D65 as possible with gamma 2.2 as per the workflow instructions, I ran the program in the workflow that creates the "special file" and copies it to a thumb drive. It essentially runs white and all the CMS colors, similar to when you profile your meter with a couple of additional measurements. I was then able to connect the thumb drive to the LG, run DV content, and a message asked me if I wanted to update the DV settings which I did and it loaded just fine. I then did the final step of running the last DV HDR layout in the workflow to verify the work and the grayscale was pretty flat and it tracked fairly well to the 2084 EOTF curve just like you would see when calibrating in HDR10 mode. Now all this said I needed to see how good or bad the calibration was with real content so I ran the same Netflix content on another un-calibrated C7 in the showroom and the set I calibrated, which were fairly close together, with the same firmware, both in DV Cinema mode, all the user settings the same, at default, except for the 2 and 20 pt settings on the calibrated set. The result was that I immediately saw that the skin tones on the DV calibrated set were more accurate, the overall "balance" of the picture was better and i could easily see more shadow details as well. I didn't have a lot of time to try and evaluate specular highlights, etc, but you could easily see that the DV calibration seemed to improve the PQ overall. As I stated, I was expecting the 20 pt to be pretty close the way it is when you calibrate HDR10 but on the set I worked on, it wasn't and it takes a while to do the full 20 pt at these high luminance levels. Overall, interesting process and it works but I wished it was less work and quicker to execute.
Hope this experience helps.
WiFi-Spy, vld, galonzo and 4 others like this.
John
Sony 55A1E, A9F / LG 55OLEDC8
Marantz 7012, Ohm Walsh Speakers
Klein K10-A, Jeti 1501, Murideo Six-G Gen2
Calman Ultimate, ISF Level III Certified
jrref is offline
post #3850 of 7029 Old 07-08-2017, 07:12 AM
gadgtfreek's Avatar
Quoted: 634 Post(s)
Liked: 6052
Great to hear!
So for SDR, HDr10 and DV modes you gonna be sitting there about 6 hours
XBR65A9G / XBR65A8F / 55R615
DP-UB420 / ATV4K (3) / PS Vue
AVRX6500H / RP-8000F / RP-504C / RP-502S / FV15HP
gadgtfreek is offline
post #3851 of 7029 Old 07-08-2017, 07:14 AM
shoman94's Avatar
Quoted: 5071 Post(s)
Liked: 3581
Originally Posted by gadgtfreek View Post
Great to hear!
Takes me about 6 hours to Cal all three on my Vizio P75.
Sony LCD Master Series Calibration Thread
My P75-C1 Calibration Settings (5.0.14.1).
Sony XBR-75Z9F, Vizio P75-C1, Pioneer Kuro 5020, Pioneer VSX-1131, XBox One(X), Wii, NVIDIA SHIELD.v1, FireTV 4K-HDR, HDHR Connects, QNAP 431+
shoman94 is offline
post #3852 of 7029 Old 07-08-2017, 08:09 AM
Liked: 5487
Great to hear!
I know it's crazy and you forgot about HLG. I'm going to bring my sleeping bag with me lol. There is a workflow for that too but there is a problem generating the patterns so we can't calibrate that yet.
WiFi-Spy likes this.
jrref is offline
post #3853 of 7029 Old 07-08-2017, 02:46 PM
Liked: 5487
Tyler, 2 questions:
1) When I tried to calibrate HLG using the last beta, the Murideo wasn't sending out the correct metadata even though it was set properly in Calman so the set never goes into HDR mode. Has that been fixed?
2) With the new Dolby Vision calibration, how do you revert back to the default? Also if you want to re-calibrate at a later date, if your run through the workflow again will the LG take the file update a 2nd time?
John
jrref is offline
post #3854 of 7029 Old 07-09-2017, 08:29 AM
p5browne's Avatar
Quoted: 4000 Post(s)
Liked: 3175
So soon!
http://calman.spectracal.com/downloads.html
Yes, you still have to install the licence # and Password again!
(So, is this to become the new norm for every update? Hard to read the numbers and letters in the dark - now have to carry a flashlight for every update!)
CalMAN 2017
Version: RC2
Official Release: July 6th, 2017
New Features
- Auto Calibration for Samsung 2017 QLED televisions.
- Auto Calibration for Panasonic 2017 EZxxx series OLED televisions.
- New Color Volume Workflow – allows you to quickly measure the color volume of any display.
- New Color Volume Visualizer - three-dimensional graphing engine that displays the measurements of the Color Volume Workflow. To access, follow the link in the Color Volume Workflow
- New HLG Workflow – support for the hybrid log gamma version of high dynamic range that is rapidly gaining acceptance for live video production
- New Dolby Vision Custom Workflow – adds support for displays that support the new Dolby Vision Configuration File. - CalMAN uses a new type of Dolby Vision metadata to put the color volume mapping engine into bypass mode. CalMAN then calibrates the display and generates a new Dolby Vision configuration file that is loaded into the supported TV via USB stick.
New Hardware Support
- SpectraCal VideoForge Pro 4K HDR pattern generator
- AccuPel DGA-6000 pattern generator
- Datacolor Sypder 5 colorimeter
Improved Hardware Support
- New display type characterizations for SpectraCal C6
Projector (Laser Phosphor)
Projector (Laser Phosphor) - Panasonic RZ12K
Projector (Laser Phosphor) - Panasonic RZ970
- Added 4-40 pattern support
4% window, 40% background
Added to VideoForge HDMI, Murideo SIX-G
- Enhanced capabilities added to Murideo SIX-G
Changed default output to be YCbCr
Added resolution drop down
Added FW check. V1 of the Muridio 6G will need to be the following FW versions
6G v2 - 2.40
6G v1 - 1.87
- Added support for the SpectraCal Video Forge Pro
Resolved Issues
- Resolved an issue with meter profiling.
- Resolved an issue when disconnecting from the Murideo Prisma as a Display.
- Resolved an issue which would cause CalMAN to improperly identify an x-rite OEM i1Pro2 as an i1Monitor.
- Resolved an issue with the Radiance Pro where the wrong LUT could get assigned to the pattern generator.
- Resolved an issue where CalMAN would display an inaccurate error message which attempting to connect to the Murideo 6G.
- Resolved an issue with LUT file formatting for OSEE displays.
Known Issue
Color Volume Workflow - LAB Absolute selection reports LAB Relative results
CalMAN 2016 Rev
UN65KS9800 - Mine
UN65HU9000 + SEK-3500U / UN75JU7100 / UN55HU7250 with SEK-3500U in UJS9000 Mod Mode / UN40J5200AF / HiSense 40H5507 - Wife's
UN55NU8000 X 2 - my 2 kids families (or should I say adults?)
p5browne is offline
post #3855 of 7029 Old 07-09-2017, 04:59 PM
stash64's Avatar
Quoted: 599 Post(s)
Liked: 225
AutoCal Capable Brands
Is it known what TV brands, other than Samsung and Panasonic, will be AutoCal capable in the near future ?
Sean
stash64 is offline
post #3856 of 7029 Old 07-09-2017, 08:58 PM
p5browne's Avatar
Liked: 3175
Competition breeds innovation. (And copying!)
UN65KS9800 - Mine
p5browne is offline
post #3857 of 7029 Old 07-10-2017, 12:45 PM
PlasmaPZ80U's Avatar
Quoted: 2836 Post(s)
Liked: 1025
I renewed my CalMAN Enthusiast license end of last year. It didn't come with the username and password some mention here, just the old license key format that includes the email address IIRC.
Do I need to request a username and password for the new license portal thing? And to get the latest release version installed do I need to deactivate my existing version or follow any other special steps? I haven't used the software in at least 6 months so I just want to make sure I have everything I need given the many recent changes.
PlasmaPZ80U is online now
post #3858 of 7029 Old 07-10-2017, 01:15 PM
Liked: 4043
See there: http://www.spectracal.com/Documents/...er%20Guide.pdf
post #3859 of 7029 Old 07-10-2017, 02:27 PM
Rolls-Royce's Avatar
Quoted: 1153 Post(s)
Liked: 1245
That honestly depends entirely on which brands are willing to expose their display internal controls to CalMAN, and the agreements they reach with SpectraCal/Portrait Displays. And such agreements are usually under NDI until things are set up.
...Royce...
"I never drink...wine."
Bela Lugosi, DRACULA, 1931
Rolls-Royce is offline
post #3860 of 7029 Old 07-10-2017, 02:44 PM
Liked: 1025
Yeah, I never received any of that login details just the old license key format from several years ago.
post #3861 of 7029 Old 07-10-2017, 06:50 PM - Thread Starter
WiFi-Spy's Avatar
Liked: 2148
Email support and we can provide your login information for the licensing portal.
WiFi-Spy is offline
post #3862 of 7029 Old 07-11-2017, 03:16 PM
Liked: 1025
Email sent last night
post #3863 of 7029 Old 07-11-2017, 05:56 PM
skschatzman's Avatar
Quoted: 2823 Post(s)
Liked: 1639
@WiFi-Spy
Ever since I updated my Calman I have not been able to access design mode. It is disabled and greyed out.
Calman Home Enthusiast With active All Access.
skschatzman is offline
post #3864 of 7029 Old 07-11-2017, 06:19 PM - Thread Starter
WiFi-Spy's Avatar
Liked: 2148
Originally Posted by skschatzman View Post
@WiFi-Spy
Design mode is now disabled for enthusiast by default.
However if any home user that wants it, will be given a design mode add-on license.
Email support at spectracal.com and we will get you a design mode add on license.
mrtickleuk likes this.
WiFi-Spy is offline
post #3865 of 7029 Old 07-11-2017, 07:44 PM
shoman94's Avatar
Liked: 3581
Why? You guys are just taking things away and now we have to contact you guys to add features back on..... So messy.
Furyus likes this.
shoman94 is offline
post #3866 of 7029 Old 07-11-2017, 07:49 PM - Thread Starter
WiFi-Spy's Avatar
Liked: 2148
Design mode was only in enthusiast and ultimate ($3,000), it's not included in studio or video pro ($1595)
Some people were abusing this fact and using enthusiast for professional purposes. We will give a free design mode add on to any actual home user that requests it.
I just wanted to give you some background on why the decision was made. It may be a slight inconvenience, which we are sorry for, but it was a necessary change.
sillysally likes this.
WiFi-Spy is offline
post #3867 of 7029 Old 07-11-2017, 08:22 PM
shoman94's Avatar
Liked: 3581
Thanks Tyler, I understand on the business side that it makes sense. While doing a broad shutoff is easier than vetting thru accounts, it can be more difficult on the customers and it should not. Customers first.....
Thank again for explaining.
shoman94 is offline
post #3868 of 7029 Old 07-11-2017, 08:30 PM
SJHT's Avatar
Quoted: 1120 Post(s)
Liked: 745
What is design mode used for? SJ
SJHT is offline
post #3869 of 7029 Old 07-11-2017, 08:31 PM
Liked: 1639
Allows you to customize workflows
Sent from my SM-G955U using Tapatalk
post #3870 of 7029 Old 07-12-2017, 06:39 AM
Liked: 1025
I got the new login info, thanks
Reply Display Calibration
