CalMan 5 Release Notes and Discussion - Page 195 - AVS Forum | Home Theater Discussions And Reviews
 1872Likes
post #5821 of 6789 Old 03-14-2019, 07:48 AM
AnotherDude's Avatar
Quoted: 936 Post(s)
Liked: 576
Originally Posted by sjht View Post
what’s the yearly maintenance cost for the video pro $495 option? Thanks. Sj
$495
Rolls-Royce likes this.
Samsung 75Q9FN, OPPO UDP-205
Win 10 Pro x64 1903
HT Enthusiast Extended Custom WF v19.3.0 - 7/5/2019
HT Enthusiast Essentials Custom WF v1.2.0 - 7/5/2019
AnotherDude is online now
post #5822 of 6789 Old 03-14-2019, 01:16 PM
Dave_O's Avatar
Quoted: 47 Post(s)
Liked: 29
I just got a Samsung 2018 Q9FN. I have an older version of Calman Enthusiast (5.9.0), just before they supported Autocal on these TVs. I've done a manual calibration with MobileForge and the i1Display Pro meter, but could only accomplish a 2 Point Greyscale calibration manually. I've enclosed an image of the results.
I'm thinking of getting the upcoming Calman Home for Samsung, but am unclear on a few points and hoping for advice. I'm initially only going to do SDR calibration as MobileForge doesn't do HDR.
1. How automated is the Autocal process? Does it try different Gamma, Brightness, and Contrast settings, or does the user run Autocal multiple times with variations?
2. Is the addition of a specific TV type for QLED in the Meter settings important?
3. Can I expect to see any significant difference between my current results and a 20 Point Autocal with Calman set to LED Qled tv type?
Dave_O is offline
post #5823 of 6789 Old 03-14-2019, 01:48 PM
Rolls-Royce's Avatar
Quoted: 1049 Post(s)
Liked: 1176
1. Autocal uses DDC instead of the user controls, so CalMAN loads the TV with an initial group of settings the autocal needs to run. Gamma is set by the user in CalMAN's "Workflow Basic Options" sheet before beginning the process.
2. Those are only for users with the CalMAN C-6 meter.
3. Only if you have a C-6. A regular I1D3 doesn't have those options available.
Dave_O likes this.
...Royce...
"I never drink...wine."
Bela Lugosi, DRACULA, 1931
Rolls-Royce is offline
post #5824 of 6789 Old 03-14-2019, 01:50 PM
Quoted: 936 Post(s)
Liked: 576
1. It will do a calibration based on your current settings. I end up doing several AutoCals based on different current settings and choose the best combinations.
2. I believe it is.
3. You should get a better 20 point. You may try +/- 1 gamma and 0 / 1 brightness and see which one works best for your panel.
Dave_O likes this.
Win 10 Pro x64 1903
post #5825 of 6789 Old 03-14-2019, 01:53 PM
Quoted: 936 Post(s)
Liked: 576
What Royce pointed out applies. I assume you have a C6 if you see the QLED meter mode.
Dave_O likes this.
Win 10 Pro x64 1903
post #5826 of 6789 Old 03-14-2019, 02:12 PM
Dave_O's Avatar
Quoted: 47 Post(s)
Liked: 29
Thanks. I do not have a C6 meter. I did not know that I'd never see it with my i1Display Pro. I did 2 runs, Gamma 0 and 1, the 1 produced better results. For whatever reason, I could not get the 20 point to work manually, but I don't have the experience of many on this forum.
Thanks again for your insights !!
Dave_O is offline
post #5827 of 6789 Old 03-14-2019, 02:25 PM
Quoted: 936 Post(s)
Liked: 576
20 point manually ... I run away! AutoCal + tweak after for me
mrtickleuk likes this.
Win 10 Pro x64 1903
post #5828 of 6789 Old 03-14-2019, 02:28 PM
Liked: 1176
There may only be a 10-point available with normal user menu controls. The DDC (Direct Display Control) used by Autocal uses 20 points, IIRC.
...Royce...
post #5829 of 6789 Old 03-14-2019, 02:49 PM
Quoted: 936 Post(s)
Liked: 576
I get 20 points on my Samsung TV settings menu, but they show up as standard 5%. The CalMAN DDC 20 point shows odd levels but close to the 5% ones. The darkest is 7% instead of 5%, and it's almost impossible to get below a dE of 3. You either go 3+ with higher gamma or if you try one click to go lower it goes 3+ with lower gamma. I use the setting producing lower gamma to help with black crush.
I'm talking SDR here. The HDR gray levels are truly weird, the highest is something like 78%.
Win 10 Pro x64 1903
post #5830 of 6789 Old 03-14-2019, 03:12 PM
Liked: 1176
Ah. It's been a while since I did an Autocal on my KS8000. It has 2-point and 10-point in user controls, but more in DDC, IIRC.
...Royce...
post #5831 of 6789 Old 03-14-2019, 07:23 PM
p5browne's Avatar
Quoted: 3991 Post(s)
Liked: 3164
Did anyone else have this issue?
Both my calibrating laptops had this week's Microsoft Windows 10 updates done to them. (Note: updates helped fix some of the networking issues - wireless still out of it!)
Both laptops ended up failing on me with Invalid License, and I had to get Spectracal support to de-activate.
Weird thing was, restarted both laptops, and they went into Calman without issue, but I did NOT have to re-activate?
UN65KS9800 - Mine
UN65HU9000 + SEK-3500U / UN75JU7100 / UN55HU7250 with SEK-3500U in UJS9000 Mod Mode / UN40J5200AF / HiSense 40H5507 - Wife's
UN55NU8000 X 2 - my 2 kids families (or should I say adults?)
p5browne is offline
post #5832 of 6789 Old 03-15-2019, 02:21 PM
hrc4u's Avatar
thinking change to chromapure due to recent calman changes....took a look at lightspace..but..hmm seems more complicated..
whats your opinion on chromap?
cheers/H
hrc4u is offline
post #5833 of 6789 Old 03-15-2019, 02:43 PM
p5browne's Avatar
Liked: 3164
cheers/H
I left Chromapure due to different results on the different workflow pages.
Also due to every meter had a charge, So 3 different meters, 3 additional charges. Versus Calman allowing a variety of meters to be used.
Lightspace, tried, and I guess I'm just to dumb to figure it out, and appears to be a lot of work to set up.
Calman, appears to be the easiest to use.
Until Home makes an appearance and we get some user feedback, we're all still in the dark currently.
AVfile and tnaik4 like this.
UN65KS9800 - Mine
p5browne is offline
post #5834 of 6789 Old 03-15-2019, 03:29 PM
hrc4u's Avatar
crap...was that with chroma v3?
hmm...i've been on calman enthusiast for many years....now i dont know what to do...
i need software that support lumagen lut and projectors... damn calman!..
/H
hrc4u is offline
post #5835 of 6789 Old 03-16-2019, 01:11 AM
calentz's Avatar
Quoted: 183 Post(s)
Liked: 111
Hello, new to CalMAN here.
About a year & a half ago I bought a CalMAN Video Pro kit that contained a SpectraCal C6 HDR 2000 meter, a VideoForge Pro Test Pattern Generator (On latest firmware) and a FTDI USB to Serial converter. The CalMAN Pro is at 2018 R2 (5.9.1.76) & my TV is a Samsung 75” Q9FAM on Firmware 1262.0 supporting HDR10+
This will be my first attempt at a calibration, as I was unable to do this before. (I am awaiting cables that I now find I need)
Afew questions:
Will the calibration be global to the TV, or will I have to do it to each of the TV’s inputs? If that is the case, how can the TV’s OTA & streaming inputs be calibrated?
HDMI1 is fed by my Oppo UDP-203 for 4K & all disk service.
HDMI2 is fed from my Integra DHC-30.3 for programing 1080 and below.
Suggestions are appreciated
Thanks for the help
--Carl
calentz is online now
post #5836 of 6789 Old 03-16-2019, 05:18 AM
p5browne's Avatar
Liked: 3164
About a year & a half ago I bought a CalMAN Video Pro kit that contained a SpectraCal C6 HDR 2000 meter, a VideoForge Pro Test Pattern Generator (On latest firmware) and a FTDI USB to Serial converter. The CalMAN Pro is at 2018 R3 (5.9.1.76) & my TV is a Samsung 75” Q9FAM on Firmware 1262.0 supporting HDR10+
Afew questions:
Thanks for the help
If HDMI Inputs are all on board, all of them have to be calibrated. (If only using one or two, just calibrate the ones being used.) (Note: Make sure you select Current Source)
If using a Smart OCB, the same. Passive HDMI, not so much so, but you could check 2 different HDMI Inputs to see if they come up almost exactly the same. If different, back to calibrating them all, or at least the ones you're using.
UN65KS9800 - Mine
p5browne is offline
post #5837 of 6789 Old 03-16-2019, 05:47 AM
chunon's Avatar
Quoted: 3778 Post(s)
Liked: 3606
Professional calibrators don’t calibrate each hdmi input that’s overkill and totally unnecessary imo , I have never done that and never plan on doing that .That even assumes inputs don’t share white balance settings all most all sets do so not even sure how that would be practical .
LG 77C8
LG 55B7A
DirectTV/ ATV4k/Panasonic UB820/Sony Z9F Soundbar
Calman Enthusiast, Lightspace, C6 HDR 2000 I1Pro2
chunon is online now
post #5838 of 6789 Old 03-16-2019, 06:26 AM
** Man of Leisure **
AustinJerry's Avatar
Quoted: 11007 Post(s)
Liked: 6567
I certainly don’t calibrate all inputs. I calibrate one HDMI input, and then verify that the same calibration results are used across all inputs (Picture Mode, white balance settings, brightness setting, motion control, etc.). There are three places to match settings—HDMI2, which I use for my external sources being routed through my Marantz AVR (AppleTV, DirecTV DVR, and Oppo203), TV mode (for my OTA antenna), and the TV apps (Netflix and Prime).
I calibrate by hooking my laptop to the side HDMI port (HDMI1), and use the laptop to generate the patterns during calibration. With this approach, it would be difficult to calibrate HDMI2 without disconnecting the cable, and impossible to calibrate the TV OTA and internal apps. The only option is to verify that the results from HDMI1 are used across the other inputs, at least AFAIK.
AVfile likes this.
AustinJerry is online now
post #5839 of 6789 Old 03-16-2019, 06:28 AM
chunon's Avatar
Liked: 3606
Yeah that’s my point we are in agreement
LG 77C8
LG 55B7A
post #5840 of 6789 Old 03-16-2019, 06:36 AM
p5browne's Avatar
Liked: 3164
Like I mentioned. Calibrate 2, if almost exactly alike, set to All Sources. If different like I find, I calibrate both. One for my Input from the DVDO IScan Duo, and the other my UHD 4K Blu-ray player, plus HDR. Also calibrate the USB Input since that also covers the on board Apps. And this Input is definitely different than the HDMI Inputs. (But, if you're on All Sources, watch out!)
UN65KS9800 - Mine
p5browne is offline
post #5841 of 6789 Old 03-16-2019, 07:49 AM
p5browne's Avatar
Liked: 3164
To close to bother, or enough to bother?
Backlight, Brightness, Contrast, Sharpness, Tint (11 Point Grayscale not included for brevity - differences as well)
All the same: 6 45 96 0 50/50
HDMI 1 : 2 Point (Offsets Gains)
13 0 16 -13 0 -10
CMS:
Red: 33 9 4 Green: 28 47 6 Blue: 0 5 60 Yellow: 50 50 7 Cyan: 27 46 49 Magenta: 27 10 41
HDMI 2 : 2 Point
12 0 14 -13 0 -11
CMS:
Red: 32 9 3 Green: 28 48 6 Blue: 0 5 62 Yellow: 50 51 7 Cyan: 27 47 49 Magenta: 27 10 41
USB/Apps: 2 Point
10 0 10 -9 0 -8
CMS:
Red: 32 9 3 Green: 30 50 5 Blue: 0 5 58 Yellow: 53 52 7 Cyan: 28 45 48 Magenta: 20 10 37
UN65KS9800 - Mine
p5browne is offline
post #5842 of 6789 Old 03-16-2019, 07:59 AM
chunon's Avatar
Liked: 3606
13 0 16 -13 0 -10
CMS:
HDMI 2 : 2 Point
12 0 14 -13 0 -11
CMS:
USB/Apps: 2 Point
10 0 10 -9 0 -8
CMS:
How do you know that variance isn’t due to meter tolerance ? Also are you speaking about Samsung’s or all makes and models ? What you are advocating is not best practice at least for the sets I have owned .
AVfile likes this.
LG 77C8
LG 55B7A
post #5843 of 6789 Old 03-16-2019, 08:01 AM
Liked: 6567
I can do back-to-back autocalibrations on the same input, minutes apart, and get slightly different results. If I obsessed about not getting the same results all the time, I would have to give up doing calibrations.
post #5844 of 6789 Old 03-16-2019, 08:03 AM
Quoted: 4279 Post(s)
Liked: 5234
You have to remember, he has a Samsung so I wouldn't be surprised if this were the case. Calibrating most Samsung's is very difficult because they are not very stable. On the Sony and LGs I've never seen any variation across HDMI ports or USB inputs.
Think about it, you have 4 HDMI ports, at least 2 or 3 USB ports and 2 SDR PMs, 1 HDR and 1 DV. I would need to charge about $1,000 to calibrate all these PMs for every input.
John
Sony 55A1E, A9F / LG 55OLEDC8
Marantz 7012, Ohm Walsh Speakers
Klein K10-A, Jeti 1501, Murideo Six-G Gen2
Calman Ultimate, ISF Level III Certified
jrref is online now
post #5845 of 6789 Old 03-16-2019, 08:04 AM
chunon's Avatar
Liked: 3606
I certainly can’t speak for tvs I don’t own but I have never found a significant difference between hdmi inputs and neither has my calibrator. What you are probably seeing is meter variance nothing to worry about.
LG 77C8
LG 55B7A
post #5846 of 6789 Old 03-16-2019, 08:06 AM
chunon's Avatar
Liked: 3606
Yeah I see your point and yes not very practical for professional calibrations and a waste of time at least for the sets I have owned.
LG 77C8
LG 55B7A
post #5847 of 6789 Old 03-16-2019, 08:15 AM
poppagene's Avatar
Quoted: 850 Post(s)
Liked: 724
Some of us are hobbyists and willing to put in more time than a professional might. Calibrating USB inputs seperately from HDMI has benefits. Also different settings for SDR and HDR sources is useful.
UN48JS8500 UN55HU6950 w/SEK-3500U UN40HU6950 w/SEK-3500U UBD-K8500 UN37C5000
poppagene is offline
post #5848 of 6789 Old 03-16-2019, 08:17 AM
Liked: 6567
I agree. And from my perspective, any differences are significant only if you can see them.
post #5849 of 6789 Old 03-16-2019, 08:19 AM
chunon's Avatar
Liked: 3606
I never said anything about usb I am questioning whether it necessary to separately calibrate each hdmi based on my experience with both professional and diy calibration my opinion is no it is not necessary, we are all free to do what ever we want obviously . I also never said anything about using sdr settings for hdr so not sure where you are getting that .
LG 77C8
LG 55B7A
post #5850 of 6789 Old 03-16-2019, 08:23 AM
Quoted: 936 Post(s)
Liked: 576
WTH ... I get somewhat different results doing back-to-back calibrations on the same HDMI input
jrref likes this.
Win 10 Pro x64 1903
Reply Display Calibration
