CalMan 5 Release Notes and Discussion - Page 204 - AVS Forum | Home Theater Discussions And Reviews
 1587Likes
post #6091 of 6112 Old 04-13-2019, 10:29 PM
calentz's Avatar
Quoted: 153 Post(s)
Liked: 101
My one and only TV in my bedroom. (I need a hip & nee replacement)https://www.avsforum.com/forum/attac...1&d=1555219648
--Carl
calentz is online now
post #6092 of 6112 Old 04-14-2019, 06:06 AM
Rolls-Royce's Avatar
Quoted: 948 Post(s)
Liked: 1084
@calentz may I suggest you try changing the meter's "sync" mode? Although I haven't seen the same error you have, if I notice an autocal stuck on a particular point (generally but not always around 40% gray on my set) with the readings fluctuating wildly, usually changing the sync type will stop it. If you've been running in "Auto", try "On" or "Off".
...Royce...
"I never drink...wine."
Bela Lugosi, DRACULA, 1931
Rolls-Royce is online now
post #6093 of 6112 Old 04-14-2019, 07:44 AM
BondDonBond's Avatar
Quoted: 573 Post(s)
Liked: 473
Here are some basic questions:
1) As a projector owner who owns Calman, how often is it recommended that you calibrate a projector?
2) I have Calman, C6 meter as well as the meters for the JVC projector. I also have the disc for the patterns for the Calman. I have spent a lot of money of course on all of this. But my basic question is, should I bite the bullet and spend the $1500 on the Video Forge pattern generator? Or is that really just a waste of money because I don't need to calibrate that often. I do have a Sony A1 also. It is kind of a pain having to find and change the patterns etc when you are doing Calman HDR. I have the app for SDR and that works fine.
3) When calibrating should the pattern source go through the same path it would for the other sources. Meaning, if I get a video forge should it go through the receiver instead of direct to the projector just in case something changes from the receiver?
Thanks for all your help.
Home Theater: JVC NX7, Stewart 120" 2:35 StudioTech 130, Panamorph DCR Lens, B&W 802 Nautilus, HTM1, 4-B&W 805's for surround, 4-Martin Logan 22's ceiling speakers ATMOS, 2- 18" Velodyn Subs, Marantz 8802A, MacIntosh 8207 AMP and Proceed AMP 5, Oppo 203, Panasonic 820, Apple TV, XBox One
BondDonBond is offline
post #6094 of 6112 Old 04-14-2019, 08:33 AM
Quoted: 948 Post(s)
Liked: 1084
I don't own a projector, but here's my take. You'll probably also hear from others who are more knowledgeable on the subject.
1) Bulb life and changes during that life aren't an issue for flat panels, but they are for PJs. Based on the amount of use yours sees, you may want to recalibrate every year to 6 months or even more often. It won't be a "once and done" thing.
2) Your call. Be advised that unless your set is one that relies on calibration of the underlying display before HDR mode and tone mapping are applied, you can't really calibrate HDR as thoroughly as you can SDR. Gray scale and color/tint are about it, as gamma and luminance targets are fixed and the vast majority of home displays cannot reach the gamut targets specified for HDR.
3) Yes.
BondDonBond likes this.
...Royce...
post #6095 of 6112 Old 04-15-2019, 07:32 PM
RTracey's Avatar
Quoted: 151 Post(s)
Liked: 46
To add to Rolls-Royce comments, I struggled for a couple years with the same decision about whether to buy a pattern generator. After doing some reading on the forum, I came to the conclusion there is a happy medium cost-wise, the DVDO AVLab - you can probably find one online for $700-800, which is a lot cheaper than the VideoForge. If you’re on a real budget, the Raspberry Pi might even work. Sure, the DVDO doesn’t do HDR or DV, but as R-R pointed out, you can’t calibrate most consumer sets for either anyways. As I speak, I’m doing a 17^3 LUT and I couldn’t be happier (imagine doing >4000 patches manually!). Never will I go back to manual patches....
Re the signal path, I agree with R-R - and I suspect you’ll find different opinions. Some will say you should connect directly to the display, and if you’re using different inputs on the display for multiple devices, calibrating each input individually. If you’re bothered by being uncertain, you may need to compare; but at least that’s reasonably doable with a pattern generator vs. manually.
Good luck!
Denon AVR-X7200WA | Oppo UDP-203, BDP-93
Paradigm Studio 60 Mains, CC-570 Center, (2) ADP-470 Surrounds | (4) Golden Ear Invisa HTR-7000 height | (2) SVS SB16-Ultra
Sony XBR-65A1E | Pioneer PRO-141FD | Panasonic TC-P42ST30
Apple TV 4K
RTracey is offline
post #6096 of 6112 Old 04-16-2019, 06:48 AM
p5browne's Avatar
Quoted: 3918 Post(s)
Liked: 3096
Personally, I have 3 DVDO IScan Duos on all my main systems, that I've used for years. They've outlasted 2 more expensive Lumagen Radiance Units, and don't have the quirks. 4K devices go directly to the set, so don't need a 4K VQ, Masciola's HDR Patterns (on DVD, and on my Samsung UHD Video Pak for USB) are enough on my sets, since my Samsungs, only the 2 Point and CMS HDR can be calibrated.
UN65KS9800 - Mine
UN65HU9000 + SEK-3500U / UN75JU7100 / UN55HU7250 with SEK-3500U in UJS9000 Mod Mode / UN40J5200AF / HiSense 40H5507 - Wife's
UN55NU8000 X 2 - my 2 kids families (or should I say adults?)
p5browne is offline
post #6097 of 6112 Old 04-16-2019, 10:03 AM
stama's Avatar
Quoted: 39 Post(s)
Liked: 31
@WiFi-Spy , any hints on when will the new Calman Home become available? Hoped to see it announced during NAB, but that wasn't the case.
stama is offline
post #6098 of 6112 Old 04-16-2019, 10:24 AM - Thread Starter
WiFi-Spy's Avatar
Quoted: 1157 Post(s)
Liked: 1759
It will be available for purchase when CalMAN 2019 is released.
Tyler Pruitt - Technical Evangelist - for CalMAN
10 Bit Gradient Test Patterns (HEVC) - Free Download
WiFi-Spy is online now
post #6099 of 6112 Old 04-16-2019, 10:41 AM
Dave_O's Avatar
Quoted: 20 Post(s)
Are there plans to update MobileForge to provide HDR patterns?
Dave_O is offline
post #6100 of 6112 Old 04-16-2019, 03:27 PM
p5browne's Avatar
Liked: 3096
Apparently, will be released when 2 moons are in the sky! (And no, not the illusionary ones)
UN65KS9800 - Mine
p5browne is offline
post #6101 of 6112 Old 04-16-2019, 07:32 PM
Dave_O's Avatar
Quoted: 20 Post(s)
So they are releasing a low priced ($145) product designed to allow a novice to automatically calibrate a TV, but the buyer will need to spend an additional $1,500 on a pattern generator like VideoForge PRO to fully calibrate a Samsung or Sony?
Hope they spell this out very clearly, or there will be a lot of upset folks.
Dave_O is offline
post #6102 of 6112 Old 04-16-2019, 07:58 PM
AnotherDude's Avatar
Quoted: 766 Post(s)
Liked: 485
Don't forget the meter
Samsung 75Q9FN, OPPO UDP-205
HT Enthusiast Extended Custom WF v18.2.3
HT Enthusiast Essentials Custom WF v1.1.0
AnotherDude is online now
post #6103 of 6112 Old 04-16-2019, 08:18 PM
** Man of Leisure **
AustinJerry's Avatar
Quoted: 10668 Post(s)
Liked: 6326
If you connect the laptop directly to the display using HDMI, the CalMAN software can generate the test patterns. You will still need a compatible colorimeter.
AustinJerry is online now
post #6104 of 6112 Old 04-16-2019, 10:49 PM
Dave_O's Avatar
Quoted: 20 Post(s)
I am not an expert, but Spectracal support did respond to to my question about MobileForge not doing HDR, and said that I needed a HW Pattern Generator, and gave VideoForge PRO as an example.
I did not know that the Calman PC software could generate test patterns through the PC's HDMI, and this is not specified in their data sheet
File Type: pdf CalMAN2019_Features_v5.10.0-CalMAN_2019_Home-3.pdf (132.5 KB, 14 views)
Dave_O is offline
post #6105 of 6112 Old Yesterday, 03:10 AM
Quoted: 338 Post(s)
Liked: 328
HDR patches through PC HDMI was/is only possible with a couple of HDFury devices. I’m not sure because someone wrote that HDFURY devices don’t work anymore with CalMAN, but I never checked personally.
A/V Chain: Pioneer PDP-LX5090H, Pioneer VSX-921, Panasonic DMP-BDT260EG | External LUT box: Entertainment Experience eeColor | Softwares: Light Illusion Lightspace HTP, Portrait Displays CalMAN Home Enthusiast 2018, HCFR, DisplayCAL | Probes: x-rite i1 Pro 2 - i1 Display Pro OEM B-02, basICColor DISCUS | Test Pattern Generator: DVDO AVLab TPG
Anger.miki is offline
post #6106 of 6112 Old Yesterday, 04:31 AM
Quoted: 123 Post(s)
Liked: 56
The control through Calman stopped working for hdfury integral, but you can use hdfury integral for HDR and control it through the Integral Gui.
WiFi-Spy and Anger.miki like this.
Panasonic OLED55FZW 804
i1 Display Pro OEM 2018 profiled by Jeti 1501
i1 Pro 2, DVDo AVLab TPG, HD Fury Integral
Oppo UDP203
baller02 is offline
post #6107 of 6112 Old Yesterday, 04:56 AM
Quoted: 4058 Post(s)
Liked: 4797
Actually, no 100% correct.
If you have a Sony, you can use CalmanHome/Sony, a meter like a C6 or an inexpensive one from X-Rite, and any low cost pattern generator or DVD disk and calibrate SDR. HDR and Dolby Vision picture modes will be calculated from the SDR calibration. The only restriction is you won't be able to verify the HDR and DV results but if your SDR calibration is correct, I've never seen HDR or DV having a problem. You can also use Autocal.
If you have a 2019 LG, you can use CalmanHome/LG, a meter and you can use the internal test pattern generator in the LG. It's accessed via Calman. I haven't tried it with the internal TPG but you can calibrate SDR, HDR and DV but again you can't validate your HDR and DV calibration. You can also use Autocal.
If you have a Samsung, then you need to calibrate manually and or use autocal for 2018 and older sets. PD said they will support the new Samsung's with Autocal buy I don't believe a date has been given. But here you will need an expensive TPG or use Disk patterns. No DV on this set.
Just an important note, you always want to verify your calibration and even though, from my experience, since in some cases the HDR and DV offsets are calculated, I usually don't see a problem with the verification scan, it is possible so you need to understand that.
Although some will disagree with me, for a novice or beginner calibrator, this process can work very well and give nice results and if you get more advanced or are a perfectionist, then you might want to invest in an external TPG or use one of the options that are in this thread.-> https://www.avsforum.com/forum/139-d...o_threadsearch
Otherwise hire a professional who will use reference equipment.
John
Sony 55A1E, A9F / LG 55OLEDC8
Marantz 7012, Ohm Walsh Speakers
Klein K10-A, Jeti 1501, Murideo Six-G
Calman Ultimate, ISF Level III Certified
jrref is online now
post #6108 of 6112 Old Yesterday, 05:15 AM
Quoted: 948 Post(s)
Liked: 1084
As Melissa had posted on the now-defunct SpectraCal forums, the loss of control over the Integral was caused by a switch to a different version (3.5.5.0) of the SiUSBXp.dll in order to work with a particular spectro. Replacing the .dll in CalMAN's folder (Program Files (x86) > Spectracal > CalMAN 5 Home Theater > Common) with 3.9.0.2 from HDFury's website will restore control functionality.
jrref, mrtickleuk and Anger.miki like this.
...Royce...
post #6109 of 6112 Old Yesterday, 09:25 AM - Thread Starter
WiFi-Spy's Avatar
Liked: 1759
We are working on a permanent fix that doesn’t require this workaround.
post #6110 of 6112 Old Yesterday, 10:24 AM
mrtickleuk's Avatar
Quoted: 4135 Post(s)
Liked: 6254
Thank you that is great news.
_______________
Denon AVR-X4200W, Arcam Alpha 8P; 5.1.4 setup: Mission 702e, M7C1i, 77DS, 731. Rel T5 Sub. Monitor Audio CT165 4 Tops | LG OLED55C8PLA TV | Samsung UBD-K8500 UHD Blu-Ray
HDMI 2.0 4K modes | Dolby & DTS core+outer audio tracks on (UHD) Blu-Rays | Hello to Jason Isaacs
mrtickleuk is offline
post #6111 of 6112 Old Yesterday, 03:43 PM
CPTuell's Avatar
Quoted: 175 Post(s)
Liked: 82
Will a DVDO iScan Mini generate test patterns for calibration?
CPTuell
" I'm a man, I can change, If I have to......I guess." Words to live by. From the Red Green Show...The Man's Prayer
UN65HU9000/SEK3500/US02,DirecTv HR-54 Genie w/4K MiniGenie, Denon AVR-X3300W, Roku Ultra 4K/HDR, Chromecast Ultra 4K/HDR, Sony UBP-X800
CPTuell is offline
post #6112 of 6112 Old Yesterday, 09:31 PM
p5browne's Avatar
Liked: 3096
Don't know.
The DVDO IScan Duos I have, definitely do. Also, supposedly, bit perfect.
UN65KS9800 - Mine
p5browne is offline
Reply Display Calibration
