CalMan 5 Release Notes and Discussion - Page 214 - AVS Forum | Home Theater Discussions And Reviews
 1872Likes
post #6391 of 6789 Old 05-11-2019, 01:07 AM
chopples123's Avatar
Liked: 6
Originally Posted by JayAy View Post
I've just downloaded the CalMAN Home Enthusiast 2019 version from the downloads page, but it downloads an installer called CalMAN2019_HomeTheater_5100 and when installed (but I've not added my licence yet - I have the maintenance until November 2019) I cannot see the Samsung 2018 QLED SDR and HDR workflows that were in the previous version of Home Enthusiast 2018. So is this the right installer that been downloaded? And how do I get the correct workflows for my 2018 QLED? I don't want to move the licence and then find I've lost what I actually need.
Hi Mate
calMAN will only show content for the registered license level.
If you navigate to Portrait Displays within documents and check the workflow folder they should show, these will then become visible in calMAN once activated
cheers
WiFi-Spy likes this.
chopples123 is offline
post #6392 of 6789 Old 05-11-2019, 07:54 AM
JayAy's Avatar
Quoted: 12 Post(s)
Liked: 9
Originally Posted by chopples123 View Post
Hi Mate
cheers
Thanks for the advice. I tracked the .cwfx workflow files down (still under the SpectraCal folder with this software) and I can see the Samsung workflows there. That gives me enough confidence to swap over.
mrtickleuk likes this.
JayAy is offline
post #6393 of 6789 Old 05-11-2019, 09:58 AM
calentz's Avatar
Quoted: 183 Post(s)
Liked: 113
Like @p5browne I had to back up to CalMAN 2018 to straighten up my Samsung Q9. I had installed the latest Video Pro update & there was a number of things wrong starting with the config of VideoForge Pro. I could not figure out why the TV did not report HDR10 even though I had configured the VF for it. I found that the Res had been set for 720. My Q9 is a 2017, but the TV config would not allow earlier than 2018. Running the autocal caused an error of unsupported operation that hung the computer that even Task Manger could not get out of. (I had to do an ungraceful power off)
--Carl
calentz is offline
post #6394 of 6789 Old 05-11-2019, 05:32 PM
Liked: 4
Originally Posted by WiFi-Spy View Post
Please contact our support team, and provide screenshots ,so we can try to figure out what is going on with your set up.
Tyler
To follow up on this problem: I talked with technical support and they suggested I do a full reset on the TV and then redo the calibration. After I did that, the next day I re-did the calibration, and this time, the reading of the 'as is panel' tracked almost perfect with the previous day calibration. I'm not sure what happened previously, but it seems that a full TV reset fixed the problem.
cupsaa is offline
post #6395 of 6789 Old 05-12-2019, 10:32 AM
Dave_O's Avatar
Quoted: 47 Post(s)
Liked: 29
In the supported hardware specs for Calman Home for Samsung, CalMAN Client3 Pattern Generator is listed as a Supported Pattern Source. I never used this program, as I thought it was only used to calibrate the PC's display that the program was running on.
How does this compare to using Mobileforge on Fire TV 4k for SDR autocal?
Are there any Windows 10 settings that need to be set, or does Client3 take over the HDMI output completely?
Dave_O is offline
post #6396 of 6789 Old 05-12-2019, 10:46 AM
mrtickleuk's Avatar
Quoted: 4421 Post(s)
Liked: 6700
Also how does it compare to opening the Pattern window in Calman itself and dragging it to the 2nd Monitor or whereever you have connected the TV to the PC?
_______________
Denon AVR-X4200W, Arcam Alpha 8P; 5.1.4 setup: Mission 702e, M7C1i, 77DS, 731. Rel T5 Sub. Monitor Audio CT165 4 Tops | LG OLED55C8PLA TV | Samsung UBD-K8500 UHD Blu-Ray
HDMI 2.0 4K modes | Dolby & DTS core+outer audio tracks on (UHD) Blu-Rays | Hello to Jason Isaacs
mrtickleuk is online now
post #6397 of 6789 Old 05-12-2019, 11:25 AM
skschatzman's Avatar
Quoted: 2656 Post(s)
Liked: 1581
Client3 exists because Calman only allows 1 installation per license. So if you want to calibrate more than 1 PC to it's connected display, the Client3 software will be installed on the PC outputting to the display being calibrated and connects to Calman over the local network.
Client3 does not take over the HDMI output. Windows or Mac would need to be properly configured for accurate output.
No matter what some here believe, the fact is not all output devices are bit-perfect accurate. Even if properly configured. This is why the Client3 software and reference test pattern generators exist.
Client3 generates an ICC profile for the PC connected to the display, allowing the best possible accuracy for that setup.
skschatzman is online now
post #6398 of 6789 Old 05-12-2019, 12:04 PM
Dave_O's Avatar
Quoted: 47 Post(s)
Liked: 29
So the steps would be:
1. Attach my meter to the PC that Calman and Client3 are on.
2. Calibrate the PC's monitor and generate the ICC profile that the PC will use.
3. Connect the PC to the TV via HDMI.
4. Run Samsung autocal with Client3 as a source and the same meter measuring my TV.
Dave_O is offline
post #6399 of 6789 Old 05-12-2019, 12:12 PM
Liked: 1581
1. No. Client3 is useless on the same PC as Calman. Client3 is installed on the PC being used with the display. Calman is installed on a separate PC. The meter is connected to the PC Calman is on.
2. Yes
3. Yes
post #6400 of 6789 Old 05-12-2019, 12:15 PM
Dave_O's Avatar
Quoted: 47 Post(s)
Liked: 29
2. Yes
3. Yes
Just be clear, I'm not interested in calibrating a PC, only my TV.
Dave_O is offline
post #6401 of 6789 Old 05-12-2019, 12:16 PM
Liked: 1581
Then Client3 is useless for your situation.
post #6402 of 6789 Old 05-12-2019, 12:19 PM
Dave_O's Avatar
Quoted: 47 Post(s)
Liked: 29
That's what I thought initially . So, I guess Calman is just throwing Client3 in as a freebee when you purchase Calman Home.
Dave_O is offline
post #6403 of 6789 Old 05-12-2019, 12:23 PM
Liked: 1581
CalMAN Home has support for PC/Client3 calibrations, but it does not include any Clinet3 licenses.
Not according to Wifi-Spy
post #6404 of 6789 Old 05-12-2019, 12:32 PM
Dave_O's Avatar
Quoted: 47 Post(s)
Liked: 29
Thanks. I'll just uninstall Client3. Sill not clear why the Calman Home for Samsung release notes state:
CalMAN Home for Samsung 2019
Version: 5.10.0
Build: 49
File Size: 89.8 MB
Official Release: May 8, 2019
Added Workflows
Home Monitor Calibration Workflow.
Meter Profile Workflow.
Manual Calibration SDR/HDR workflows for non-supported display.
Added Display Support
CalMAN Client3.
Added Pattern Support
https://www.portrait.com/downloads1/
Maybe Wifi-Spy can clarify.
Dave_O is offline
post #6405 of 6789 Old 05-12-2019, 12:33 PM
Liked: 1581
Version: 5.10.0
Build: 49
File Size: 89.8 MB
Added Workflows
CalMAN Client3.
I'm sure it just means that version of Calman Home supports it. Not Samsung itself.
post #6406 of 6789 Old 05-12-2019, 12:37 PM - Thread Starter
WiFi-Spy's Avatar
Quoted: 1372 Post(s)
Liked: 2025
Client3 is free to use as a pattern generator. If you want to use it for ICC profile calibration of a PC then you need a buy a client 3 license.
Tyler Pruitt - Technical Evangelist - for CalMAN
10 Bit Gradient Test Patterns (HEVC) - Free Download
WiFi-Spy is offline
post #6407 of 6789 Old 05-12-2019, 12:39 PM
Liked: 1581
got it.
post #6408 of 6789 Old 05-12-2019, 02:50 PM
mrtickleuk's Avatar
Liked: 6700
Thanks. I'm still not clear though, how it is different to opening the Pattern window in Calman itself?
_______________
post #6409 of 6789 Old 05-12-2019, 02:54 PM
Liked: 1581
I already told you. Client3 is controlled by Calman from a separate PC. That is the only difference.
post #6410 of 6789 Old 05-12-2019, 03:09 PM
Quoted: 134 Post(s)
Liked: 64
And with client3 you can create and use icc profiles.
Panasonic OLED55FZW 804
i1 Display Pro OEM 2018 profiled by Jeti 1501
i1 Pro 2, DVDo AVLab TPG, HD Fury Integral
Oppo UDP203
baller02 is offline
post #6411 of 6789 Old 05-12-2019, 05:20 PM
AnotherDude's Avatar
Quoted: 936 Post(s)
Liked: 576
For Samsung 2018 QLED calibration, what is the difference between HDMI Black Level Low and Normal?
Samsung 75Q9FN, OPPO UDP-205
Win 10 Pro x64 1903
HT Enthusiast Extended Custom WF v19.3.0 - 7/5/2019
HT Enthusiast Essentials Custom WF v1.2.0 - 7/5/2019
AnotherDude is online now
post #6412 of 6789 Old 05-12-2019, 05:26 PM
thoth's Avatar
Quoted: 73 Post(s)
Liked: 45
On Samsung TVs, HDMI Black Level is used for 8-bit RGB. Low is for range 16-235, Normal is for 0-255. Equivalent to terms RGB Limited vs Full.
thoth is online now
post #6413 of 6789 Old 05-12-2019, 05:36 PM
Quoted: 936 Post(s)
Liked: 576
Aah! Thanks. Wonder what would happen if it conflicts with the CalMAN Nominal Levels option ...
Win 10 Pro x64 1903
post #6414 of 6789 Old 05-13-2019, 06:54 AM
Quoted: 4493 Post(s)
Liked: 1681
The website says
At least one Client 3 license is included with all current levels of CalMAN®
https://store.portrait.com/consumer-...n-license.html
Does that apply to the new CalMAN Home?
Dominic Chan is online now
post #6415 of 6789 Old 05-13-2019, 07:09 AM
Liked: 1581
Originally Posted by Dominic Chan View Post
The website says
That is old. The rules changed with the new home versions. I'm sure that text will be revised.
post #6416 of 6789 Old 05-13-2019, 08:10 AM
Liked: 6
A new version has been posted to the download page of our website. The release notes have also been updated To reflect the changes and bug fixes.
Hi
I have just got round to giving this a go, the colour bug i reported on Samsung Home (changing to 30) appeared to be fixed in SDR but when I ran the HDR workflow it happened again, specifically when you move from the CMS to the post calibration checker
cheers
post #6417 of 6789 Old 05-13-2019, 08:32 AM
CFC
CFC's Avatar
Quoted: 62 Post(s)
Liked: 30
I apologize if this is a simple question, but I'm just not familiar with Calman.
Do the new "home" versions support Dolby Vision Golden Reference (.dvgr) files?
If not, what is the solution to calibrate DV?
CFC
Signature goes here
CFC is online now
post #6418 of 6789 Old 05-13-2019, 08:37 AM
Quoted: 4285 Post(s)
Liked: 5236
CFC
I believe the DVGR files are for the Vizio and there is no CM Home version for Vizio unless you want to calibrate manually.
For the LG and Samsung there is a DV workflow and for the Sony DV calculated from the SDR calibration.
CFC likes this.
John
Sony 55A1E, A9F / LG 55OLEDC8
Marantz 7012, Ohm Walsh Speakers
Klein K10-A, Jeti 1501, Murideo Six-G Gen2
Calman Ultimate, ISF Level III Certified
jrref is offline
post #6419 of 6789 Old 05-13-2019, 08:39 AM
CFC
CFC's Avatar
Quoted: 62 Post(s)
Liked: 30
I think this is where my confusion started - I thought the golden reference was a generic item, not Vizio specific.
That makes sense then.
I appreciate the confirmation.
CFC
Signature goes here
CFC is online now
post #6420 of 6789 Old 05-13-2019, 09:39 AM
thoth's Avatar
Quoted: 73 Post(s)
Liked: 45
Samsung TVs don't have DV.
thoth is online now
Reply Display Calibration
