CalMan 5 Release Notes and Discussion - Page 217 - AVS Forum | Home Theater Discussions And Reviews
 1872Likes
post #6481 of 6789 Old 05-15-2019, 07:04 PM
Quoted: 4284 Post(s)
Liked: 5236
I believe 10pt Rolling was the only option for the legacy Sony at one point in time. Then they changed it to plain 10pt no-rolling. Now at the request of several users, both 10pt and 10pt rolling are available for these sets which is great!
shoman94 and bluemoon737 like this.
John
Sony 55A1E, A9F / LG 55OLEDC8
Marantz 7012, Ohm Walsh Speakers
Klein K10-A, Jeti 1501, Murideo Six-G Gen2
Calman Ultimate, ISF Level III Certified
jrref is online now
post #6482 of 6789 Old 05-15-2019, 10:46 PM
calentz's Avatar
Quoted: 183 Post(s)
Liked: 113
Not claiming to be very CalMAN knowledgeable, I did update my prior post, hoping someone has some insight.
Help is appreciated.
--Carl
calentz is offline
post #6483 of 6789 Old 05-16-2019, 05:53 AM
Liked: 0
Calman settings
I have Calman Enthusiast 2019, C6, LG E7 oled and a Lumagen Pro. What settings should I use/set Calman to get the best results? Number of points to reads, de formula, stimulus/sat levels and luminus/sat data points, for best results gamma & 3d lut. I'm using itu bt1886 gamma. Any guidance would be appreciated.
LGJr is offline
post #6484 of 6789 Old 05-16-2019, 03:53 PM
Quoted: 103 Post(s)
Liked: 47
Is there any word on if Calman will release a CalMAN Home for Vizio?
ajc9988 is offline
post #6485 of 6789 Old 05-17-2019, 08:24 AM
bluemoon737's Avatar
Quoted: 2204 Post(s)
Liked: 2705
Tried running my first autocal on my new 75x950G last night (Calman Enthusiast 2019 update) and ran into a bunch of problems. Kept getting inconsistent results and rolling 20 pt seemed to make it worse than non--rolling. Kept getting weird bumps at around the 50% grayscale value which it seems would also throw off CMS (this is my first CMS set though since my Z9D doesn't have the feature). I am using my laptop with Intel graphics as the pattern generator and have it's output set to full and have Calman set to video (16-235) with the TV set to limited. I also have Calman "expand to PC levels" unchecked. Pretty sure those are all correct settings. I am using all the Bravia work flow default settings and I tried sync in auto, on, and off... didn't seem to make any difference. Using a C6 2000 meter set to PFS Phosphor per @WiFi-Spy recommendations.
Gave up after a number of attempt but will try again tonight. Any thoughts?
-Jeff-
Man cave: Sony XBR75Z9D, Marantz SR8012, and OPPO UDP-203
Living room: Sony XBR75X950G, Denon x4500, and Sony UBP-X800M2
bluemoon737 is offline
post #6486 of 6789 Old 05-17-2019, 08:35 AM
thoth's Avatar
Quoted: 73 Post(s)
Liked: 45
Why do you have Intel graphics set to RGB Full, when you have everything else set to RGB Limited?
thoth is online now
post #6487 of 6789 Old 05-17-2019, 08:54 AM
Liked: 2705
Those were the recommended settings back when I did my Z9D around the first of the year. It worked fine during that calibration. The Bravia workflow has changed quite a bit since I did it last though.
-Jeff-
post #6488 of 6789 Old 05-17-2019, 08:58 AM - Thread Starter
WiFi-Spy's Avatar
Quoted: 1370 Post(s)
Liked: 2024
What size patterns are you using? Also you said the TV is set to limited range, is it forced into that or is it set to auto?
Can you post a screenshot of what your DDC controls for the grayscale look like?
Tyler Pruitt - Technical Evangelist - for CalMAN
10 Bit Gradient Test Patterns (HEVC) - Free Download
WiFi-Spy is online now
post #6489 of 6789 Old 05-17-2019, 09:01 AM
thoth's Avatar
Quoted: 73 Post(s)
Liked: 45
I'd be very interested in someone explaining why the graphics output should be set to RGB Full instead of RGB Limited, given the rest of that configuration.
thoth is online now
post #6490 of 6789 Old 05-17-2019, 09:17 AM
Liked: 2705
10% window and forced limited. After the frustration I just reset all when I wrapped up. Will look at saving them tonight if I run into problems again.
-Jeff-
post #6491 of 6789 Old 05-17-2019, 10:00 AM - Thread Starter
WiFi-Spy's Avatar
Liked: 2024
Because when using CalMAN’s built in pattern window you want the RGB value CalMAN creates to be passed to the TV without having the value compressed from 0-255 to 16-235. If CalMAN puts up code value 26,26,26 we want that exact code value to make it to the TV.
post #6492 of 6789 Old 05-17-2019, 02:43 PM
mrtickleuk's Avatar
Quoted: 4421 Post(s)
Liked: 6700
When upgrading to Calman 2019 and entering my new "all access" licence bought before the April deadline, my Design Addon licence has instantly disappeared . I had thought that once we'd asked for it, we've got it for good? I have emailed customer services, but I'm bracing myself for confusion getting it back.
_______________
Denon AVR-X4200W, Arcam Alpha 8P; 5.1.4 setup: Mission 702e, M7C1i, 77DS, 731. Rel T5 Sub. Monitor Audio CT165 4 Tops | LG OLED55C8PLA TV | Samsung UBD-K8500 UHD Blu-Ray
HDMI 2.0 4K modes | Dolby & DTS core+outer audio tracks on (UHD) Blu-Rays | Hello to Jason Isaacs
mrtickleuk is offline
post #6493 of 6789 Old 05-17-2019, 02:48 PM
mrtickleuk's Avatar
Liked: 6700
Calman Home Enthusiast taskbar icon is broken (windows 7). For every window.
EDIT: Happy to report it's ok after a reboot.
_______________
post #6494 of 6789 Old 05-17-2019, 02:55 PM
AnotherDude's Avatar
Quoted: 936 Post(s)
Liked: 576
Yeah, I had to do the properties change icon thing. However I didn't lose my Design Add-on, I had to add it again (pun not intended).
mrtickleuk likes this.
Samsung 75Q9FN, OPPO UDP-205
Win 10 Pro x64 1903
HT Enthusiast Extended Custom WF v19.3.0 - 7/5/2019
HT Enthusiast Essentials Custom WF v1.2.0 - 7/5/2019
AnotherDude is offline
post #6495 of 6789 Old 05-17-2019, 02:57 PM
mrtickleuk's Avatar
Liked: 6700
Ah. I shall try that - thanks.
_______________
post #6496 of 6789 Old 05-17-2019, 03:02 PM
mrtickleuk's Avatar
Liked: 6700
I'm happy to say it's all sorted with a very fast reply from support
I didn't realise that the uninstall of Calman2018 (part of the upgrade) did a "deactivate" of that AddOn licence. It's then there on the Portal ready to be re-added to the Calman2019 install (which is a different product effectively). Not having done this malarkey before.
So in summary for anyone else doing this. You keep your addon licence but it pops off and you need to put it back.
Always reboot after installing something, even if it doesn't think that you need to.
Sometimes the timezone difference works in my favour! It's 11pm on Friday night here, but support are still in the office
Rolls-Royce likes this.
_______________
post #6497 of 6789 Old 05-18-2019, 12:06 AM
calentz's Avatar
Quoted: 183 Post(s)
Liked: 113
Chronology of Events
When coming from CalMAN Video Pro 2018 to CalMAN Video Pro 2019 (5.10.0.50) I did not uninstall 2018. I have always downloaded for the install, as "newer version" from within the app never alerted me.
I installed R1 first, but never attempted a Cal. When (5.10.0.50) failed, I first deactivated 2019 and removed everything that I could find. (Just tonight I found on Portrait's support site an article
"CalMAN Complete Uninstall" which advised to go into the Registry) I did everything except going into the Registry prior the going back to CalMAN Video Pro 2018R3.
The reason for my backtracking has been given in earlier posts.
--Carl
calentz is offline
post #6498 of 6789 Old 05-18-2019, 12:24 AM
Liked: 2705
Well got better results tonight. The only thing I changed was the pattern insertion numbers (15, 5, 15) based on recommendations from @jrref . Here is what I got:
ID:	2568120   Click image for larger version
ID:	2568122   Click image for larger version
WiFi-Spy and jrref like this.
-Jeff-
post #6499 of 6789 Old 05-18-2019, 04:55 AM
shoman94's Avatar
Quoted: 5048 Post(s)
Liked: 3574
For "rolling" to work correctly on the Sony you need the PC set to Full Range, Calman set to Video Levels, Calman Expand levels unchecked and the TV set to Limited Range. You shouldn't need any other changes.
Ensure Calman sets your contrast to 100 when it is in the grayscale section of the workflow.
Sent from my LG-H932 using Tapatalk
Sony LCD Master Series Calibration Thread
My P75-C1 Calibration Settings (5.0.14.1).
Sony XBR-75Z9F, Vizio P75-C1, Pioneer Kuro 5020, Pioneer VSX-1131, XBox One(X), Wii, NVIDIA SHIELD.v1, FireTV 4K-HDR, HDHR Connects, QNAP 431+
shoman94 is offline
post #6500 of 6789 Old 05-18-2019, 05:19 AM
Liked: 5236
Your results are perfect!
bluemoon737 likes this.
John
jrref is online now
post #6501 of 6789 Old 05-18-2019, 07:05 AM
BlackJoker's Avatar
Quoted: 345 Post(s)
Liked: 360
His RGB values are way to high for my opinion just saying.
TV: LG OLED 65C8 Sources: Apple TV 4K, OPPO UDP-203 Video Processor: TruVue eeColor
Probe: C6-HDR, i1 Display Pro OEM Rev.B (2018), i1Pro2 OEM Rev.E Software: Lightspace HTL, Calman 2018 Enthusiast
BlackJoker is offline
post #6502 of 6789 Old 05-18-2019, 08:22 AM
Liked: 0
Quick question about HDR10 Grayscale Autocal for LG C9.
Can I choose 'LG 40 points HDR' instead of LG 20 points HDR? Will it give better results? Thanks.
Real4K is offline
post #6503 of 6789 Old 05-18-2019, 08:49 AM
Liked: 0
One more question about the DV configuration file of CalMAN 2019 R1.
I got two dots in the file name 'DolbyVision_UserDisplayConfiguration_2019..txt' like that when CalMAN generates the default config file.
Which one should I upload between 'DolbyVision_UserDisplayConfiguration_2019..txt' and 'DolbyVision_UserDisplayConfiguration.txt'?
Btw 'DolbyVision_UserDisplayConfiguration.txt' file contains parameter TLMS2RGBmat and CalMAN actually looks for *2019.txt file like attached. And no files are shown at the windows while both txt and 2019.txt files are actually there.
ID:	2568222   Click image for larger version
Real4K is offline
post #6504 of 6789 Old 05-18-2019, 10:33 AM
Liked: 2705
Those were all set. When I said the only things I changed it meant from the previous session. The previous session I had pattern insertion set per the workflow recommendations (30, 15, 25 I think?).
-Jeff-
post #6505 of 6789 Old 05-18-2019, 10:37 AM
Liked: 2705
One thing I noted is that Calman did not set video levels to limited. It left it in auto...it turned off HDR, and set contrast to 100 and such but left levels in auto so I had to put it in limited.
-Jeff-
post #6506 of 6789 Old 05-18-2019, 11:03 AM
thoth's Avatar
Quoted: 73 Post(s)
Liked: 45
In what circumstances would one use "Expand Video to PC Levels" in the Client3 source, rather than selecting PC luminance levels in the Workflow options?
thoth is online now
post #6507 of 6789 Old 05-18-2019, 12:00 PM
shoman94's Avatar
Liked: 3574
Isn't pattern insertion for OLED? I remember having an issue with rolling but I didn't use pattern insertion to fix it. Did you try changing sync for the meter to ON or OFF? I always use ON because it works correctly all the time for me. It's been months since I last calibrated. Last firmware update I think. Maybe I'll dig it out and check into it again.
shoman94 is offline
post #6508 of 6789 Old 05-18-2019, 03:00 PM
njfoses's Avatar
Quoted: 311 Post(s)
Liked: 180
Seems to be the norm for Sony autocal. Even doing a manual 2pt first results in large adjustments.
njfoses is offline
post #6509 of 6789 Old 05-18-2019, 04:12 PM
Liked: 5236
Your results are perfect![IMG class=inlineimg]/forum/images/smilies/smile.gif[/IMG]
For the Sony’s it’s ok. If you do a 2pt first then run autocal the adjustments will be less and you get a more accurate result. D-nice found this early on and I also found it helps.
John
jrref is online now
post #6510 of 6789 Old 05-18-2019, 05:39 PM - Thread Starter
WiFi-Spy's Avatar
Liked: 2024
This was a bug in version 5.10.0.49. It is now fixed in 5.10.0.50.
Reply Display Calibration
