CalMan 5 Release Notes and Discussion - Page 218 - AVS Forum | Home Theater Discussions And Reviews
 1854Likes
post #6511 of 6748 Old 05-18-2019, 05:41 PM - Thread Starter
WiFi-Spy's Avatar
Quoted: 1321 Post(s)
Liked: 1924
Originally Posted by jrref View Post
For the Sony’s it’s ok. If you do a 2pt first then run autocal the adjustments will be less and you get a more accurate result. D-nice found this early on and I also found it helps.
I have never seen any actual visual difference. Also the Usability isn’t good, having to manually copy of the 2 point control values to other modes and inputs.
Tyler Pruitt - Technical Evangelist - for CalMAN
10 Bit Gradient Test Patterns (HEVC) - Free Download
WiFi-Spy is online now
post #6512 of 6748 Old 05-18-2019, 06:12 PM
camacho8's Avatar
Quoted: 90 Post(s)
Liked: 37
@tyler ,you mention a few months ago when you guys would update the Sony workflow that de ICTP would be made the default recommended color error formula,so I noticed last night after doing a autocal with the updated 2019 Sony workflow the default was still de 2000 Jnd…..
Was this Sony decision to leave as is or do you still recommend de ICTp?
65 Sony A1E-Oled - Calman Home Ent/C6 HDR2000
Denon - 7200WA - Mirage Speakers
Roku Ultra/Sony UBP-X800M2/4K Firestick
camacho8 is offline
post #6513 of 6748 Old 05-18-2019, 07:09 PM - Thread Starter
WiFi-Spy's Avatar
Liked: 1924
If I was doing my own TV I would use DEITP for everything. It takes longer for the Autocal to complete but I think it is work the extra time.
Tyler
camacho8 likes this.
post #6514 of 6748 Old 05-18-2019, 08:05 PM
bluemoon737's Avatar
Quoted: 2199 Post(s)
Liked: 2700
Originally Posted by shoman94 View Post
Isn't pattern insertion for OLED? I remember having an issue with rolling but I didn't use pattern insertion to fix it. Did you try changing sync for the meter to ON or OFF? I always use ON because it works correctly all the time for me. It's been months since I last calibrated. Last firmware update I think. Maybe I'll dig it out and check into it again.
Sent from my LG-H932 using Tapatalk
CM2019 is quite a bit different than what we were using on my Z9D around the first of the year.
-Jeff-
Man cave: Sony XBR75Z9D, Marantz SR8012, and OPPO UDP-203
Living room: Sony XBR75X950G, Denon x4500, and Sony UBP-X800M2
bluemoon737 is online now
post #6515 of 6748 Old 05-19-2019, 03:51 AM
mrtickleuk's Avatar
Quoted: 4369 Post(s)
Liked: 6620
I've noticed that some workflows are now using dEICtCp 240. But I thought that dEICtCp 720 was preferred (once you understand that the numbers will always be higher than dE2000) ? So why change the workflows to use dEICtCp 240? Is it a "transition change" away from dE2000, a first step, with a move to dEICtCp 720 later?
Also, the "ratified standard" called dEITP - which one is it out of dEICtCp 240 and dEICtCp 720 please?
_______________
Denon AVR-X4200W, Arcam Alpha 8P; 5.1.4 setup: Mission 702e, M7C1i, 77DS, 731. Rel T5 Sub. Monitor Audio CT165 4 Tops | LG OLED55C8PLA TV | Samsung UBD-K8500 UHD Blu-Ray
HDMI 2.0 4K modes | Dolby & DTS core+outer audio tracks on (UHD) Blu-Rays | Hello to Jason Isaacs
mrtickleuk is online now
post #6516 of 6748 Old 05-19-2019, 07:57 AM
AnotherDude's Avatar
Quoted: 930 Post(s)
Liked: 565
DEITP is 720. Tyler explained they're in the process of a change-over with proper guidance.
Samsung 75Q9FN, OPPO UDP-205
Win 10 Pro x64 1903
HT Enthusiast Extended Custom WF v19.2.0 - 5/17/2019
HT Enthusiast Essentials Custom WF v1.1.0
AnotherDude is online now
post #6517 of 6748 Old 05-19-2019, 10:57 AM
mrtickleuk's Avatar
Liked: 6620
Originally Posted by AnotherDude View Post
DEITP is 720.
Cool, thanks.
Indeed.
_______________
post #6518 of 6748 Old 05-19-2019, 11:39 AM
Quoted: 4251 Post(s)
Liked: 5173
I tend to agree as long as the adjustments aren’t too extreme.
John
Sony 55A1E, A9F / LG 55OLEDC8
Marantz 7012, Ohm Walsh Speakers
Klein K10-A, Jeti 1501, Murideo Six-G
Calman Ultimate, ISF Level III Certified
jrref is online now
post #6519 of 6748 Old 05-19-2019, 12:04 PM
Quoted: 4383 Post(s)
Liked: 1616
The adjustments for the lowest point (+24, +24, -16) do seem rather large.
Dominic Chan is online now
post #6520 of 6748 Old 05-19-2019, 12:06 PM
skschatzman's Avatar
Quoted: 2604 Post(s)
Liked: 1563
Low point adjustments like that are very common.
shoman94 and jrref like this.
skschatzman is online now
post #6521 of 6748 Old 05-19-2019, 03:40 PM
beardontwalk123's Avatar
Quoted: 1532 Post(s)
Liked: 890
Does MobileForge not work on 5.9.2.59 anymore? Trying to calibrate with my Amazon Fire TV Stick 4k and keep getting error.
Sent from my SM-G973U using Tapatalk
beardontwalk123 is offline
post #6522 of 6748 Old 05-21-2019, 12:51 PM
p5browne's Avatar
Quoted: 3983 Post(s)
Liked: 3140
For the gamblers in the crowd!
Microsoft Windows 10 May 2019 ISO is now available:
https://www.microsoft.com/en-us/soft...d/windows10ISO
Note: AutoBoot USB installer has a bug. Use a burnt CD - For the 64 Bit you have to use a DVD +R DL disc. 32 Bit - Standard DVD will do.
(Using the USB method will result in an error message saying the new Windows 10 won't work on your computer. A fix is in progress.)
Re Versions on the ISO website, pick the correct one! Windows 10 May 2019 is 1903. Not the October 2018 version.
UN65KS9800 - Mine
UN65HU9000 + SEK-3500U / UN75JU7100 / UN55HU7250 with SEK-3500U in UJS9000 Mod Mode / UN40J5200AF / HiSense 40H5507 - Wife's
UN55NU8000 X 2 - my 2 kids families (or should I say adults?)
p5browne is offline
post #6523 of 6748 Old 05-21-2019, 01:36 PM
Quoted: 930 Post(s)
Liked: 565
Dang, you beat me!
Edit: Ahh, just an 1809 update. I was hoping it was 1903!
Win 10 Pro x64 1903
post #6524 of 6748 Old 05-21-2019, 02:34 PM
Dave_O's Avatar
Quoted: 45 Post(s)
Liked: 27
Dang, you beat me!
Actually 1903 is out, but you may need to do a manual update:
https://thewincentral.com/four-ways-...available-now/
Dave_O is online now
post #6525 of 6748 Old 05-21-2019, 03:19 PM
Quoted: 930 Post(s)
Liked: 565
You're right, it looks like it wants to do 1809's 529 before going to 1903. Cool!
Win 10 Pro x64 1903
post #6526 of 6748 Old 05-21-2019, 03:57 PM
jimmyk36's Avatar
Quoted: 107 Post(s)
Liked: 53
I'm confused - Are there new features in the Windows updates that affect Calman 5?
jimmyk36 is offline
post #6527 of 6748 Old 05-21-2019, 04:36 PM - Thread Starter
WiFi-Spy's Avatar
Liked: 1924
No. I am running on the windows insider fast ring on my machine without any issues.
Tyler
post #6528 of 6748 Old 05-21-2019, 10:27 PM
Quoted: 930 Post(s)
Liked: 565
For the Samsung Q9FN, when switching the gray level mode from SDR to HDR, the DDC RGB setting labels change accordingly but the values don't change and appear to be common to both SDR and HDR.
Win 10 Pro x64 1903
post #6529 of 6748 Old 05-22-2019, 12:17 AM
calentz's Avatar
Quoted: 180 Post(s)
Liked: 109
I had troubles with my Q9FN, but Tyler claims that he was OK???
--Carl
calentz is offline
post #6530 of 6748 Old 05-22-2019, 05:42 AM
Quoted: 930 Post(s)
Liked: 565
My bad, TV itself was not in HDR mode yet from a pattern.
Win 10 Pro x64 1903
post #6531 of 6748 Old 05-23-2019, 02:43 AM
Quoted: 86 Post(s)
Liked: 7
Hi guys do i calibrate hdr on lg c9 with the gamma 2.2 or st2084?
Toto84 is online now
post #6532 of 6748 Old 05-23-2019, 05:44 AM
Liked: 5173
2.2
John
jrref is online now
post #6533 of 6748 Old 05-23-2019, 09:18 AM - Thread Starter
WiFi-Spy's Avatar
Liked: 1924
If you are using CalMAN Home for LG, All of this is automatically set in to the correct configuration in the workflow for you.
Tyler
jrref likes this.
post #6534 of 6748 Old 05-23-2019, 12:39 PM
Quoted: 86 Post(s)
Liked: 7
Tyler
Thanks Tyler.
When you calibrate hdr to you left brightness and contrast at 100 or 50 and 85?
When you upload your peak luminance do you leave tone mapping on or off?
post #6535 of 6748 Old 05-23-2019, 01:00 PM
Liked: 5173
Thanks Tyler.
So i'm not sure why all these questions since as Tyler say's the workflows set everything up automatically but you do have a good question about the tone mapping option. LG says to leave it OFF when calibrating and you need to manually turn it off when using CalMAN with the remote in the user menu for the HDR PM you are working on. But that said I've tried calibrating both ways and I wasn't able to detect a difference. The HDR Tone Mapping option should be turned off automatically by CM when calibrating since it's very easy to forget to manually turn it off.
John
jrref is online now
post #6536 of 6748 Old 05-23-2019, 01:24 PM
Quoted: 86 Post(s)
Liked: 7
I have an i1display pro already i could get a i1display pro 2 from 2017 at a good price.
It will only come with the usb cable and the spectro, no software.
Would i need the software to use it with calman?
Is those item usually reliable?
I understand i could use the spectro to profile the i1display pro.
Would it be a big upgrade from only using the retail i1display pro on is own?
post #6537 of 6748 Old 05-23-2019, 01:30 PM
Liked: 1563
i1display pro 2?
post #6538 of 6748 Old 05-23-2019, 01:35 PM
Quoted: 86 Post(s)
Liked: 7
There is no such thing as an i1display pro 2
I think its call an i1pro2.
post #6539 of 6748 Old 05-23-2019, 01:38 PM
thoth's Avatar
Quoted: 59 Post(s)
Liked: 42
In CalMAN Home, for Manual HDR calibration, when doing the Colorspace page, selecting 50% Only patterns, can someone confirm if the corresponding DVS UHD HDR10 test patterns are the (10% Window) 50% Amplitude/50% Saturation ones?
WiFi-Spy likes this.
thoth is online now
post #6540 of 6748 Old 05-23-2019, 07:03 PM
chhanthony's Avatar
Quoted: 181 Post(s)
Liked: 108
last Calman 2019 crashed twice in Windows 7 (Chinese)
had to reinstall CalMan 2018
Anthony Chan
AV Blog: http://www.avnewbie.com
System: 5.3.4
Panasonic DMP-UB900EBK, Egreat A5, Anthem AVM60, Krell KAV2250 X 2, Theater Amplifier Standard, M&K S-150 X 5, SS150 X 4, Martin Logan Descent-i and Thiel SS 2, SS2.2 and SI 1 Integrator, Benq HT1075, JK 126" Fixed Screen N4-FL/W1
chhanthony is offline
Reply Display Calibration
