CalMan 5 Release Notes and Discussion - Page 232 - AVS Forum | Home Theater Discussions And Reviews
 1962Likes
post #6931 of 7048 Old 08-22-2019, 12:16 PM
thoth's Avatar
Quoted: 149 Post(s)
Liked: 75
Originally Posted by WiFi-Spy View Post
That’s the firmware I was talking about. It looks like the guide needs to be updated.
thoth is online now
post #6932 of 7048 Old 08-22-2019, 12:58 PM
Quoted: 158 Post(s)
Liked: 73
With the latest public release 2.63 bt.2020 4:2:2 is not bit perfect. So at the moment it should not be used for bt.2020.
With 2.64 when it is available we will see if it is bit perfect. @WiFi-Spy
Vfp 1.11 equals 2.63 or 2.64 Firmware?
Panasonic OLED55FZW 804
i1 Display Pro OEM 2018 profiled by Jeti 1501
i1 Pro 2, DVDo AVLab TPG, HD Fury Integral
Oppo UDP203
baller02 is offline
post #6933 of 7048 Old 08-22-2019, 01:39 PM - Thread Starter
WiFi-Spy's Avatar
Quoted: 1603 Post(s)
Liked: 2192
Remember this is only for SDR 4:2:2 2020 , not HDR. HDR is currently correct. A fix is being worked on.
1.11 was released at the same time as 2.63
Tyler Pruitt - Technical Evangelist - for CalMAN
10 Bit Gradient Test Patterns (HEVC) - Free Download
WiFi-Spy is offline
post #6934 of 7048 Old 08-22-2019, 03:05 PM
Quoted: 158 Post(s)
Liked: 73
The only difference between SDR REC.2020 and HDR10 REC.2020 is the metadata. How is it possible that hdr rec.2020 is bit perfect and sdr rec.2020 not?
Oppo UDP203
baller02 is offline
post #6935 of 7048 Old 08-22-2019, 05:54 PM - Thread Starter
WiFi-Spy's Avatar
Liked: 2192
Currently my theory is that the wrong matrix is being used convert from RGB to YCbCr.
Remember 2020 and 709 have different matrices.
WiFi-Spy is offline
post #6936 of 7048 Old 08-22-2019, 11:59 PM
Quoted: 158 Post(s)
Liked: 73
In the test from mkoper with hdr10 rec.2020 4:2:2 10 bit, 4.63 was not bit perfect.
https://www.avsforum.com/forum/139-d...l#post57806718
@WiFi-Spy
What device for analyzing did you used for testing the output of vfp?
Oppo UDP203
baller02 is offline
post #6937 of 7048 Old 08-23-2019, 06:32 AM
Quoted: 4543 Post(s)
Liked: 5536
@WiFi-Spy
So correct 4.63 still had a problem. Since then Murideo made another fix which is 2.64 which was tested but i'm guessing is not on the web site yet waiting for another independent tester to report back.
John
Sony 55A1E, A9F / LG 55OLEDC8
Marantz 7012, Ohm Walsh Speakers
Klein K10-A, Jeti 1501, Murideo Six-G Gen2
Calman Ultimate, ISF Level III Certified
jrref is online now
post #6938 of 7048 Old 08-23-2019, 08:24 AM
Quoted: 158 Post(s)
Liked: 73
@WiFi-Spy
When I followed the topic correct, you tested 2160p rec.2020 444!?
Which device did you used for testing?
Oppo UDP203
baller02 is offline
post #6939 of 7048 Old 08-23-2019, 09:05 AM
Quoted: 47 Post(s)
Originally Posted by Anger.miki View Post
If you search trough @ConnecTEDDD posts, you’ll find some detailed post about that.
The short story is that since the TV receives YCbCr signal from the “normal” sources and then do various conversion to and from RGB, it is better to feed it with YCbCr patterns. If you feed it with RGB patterns you’ll have larger dE due to conversion rounding errors. Ted’s explanations will get you deep in the argument. Unfortunately, he is banned from this thread so he won’t answer to you here as he would have done normally.
WHY is Ted banned????????????????????????????
BobWalters is offline
post #6940 of 7048 Old 08-23-2019, 10:02 AM
AnotherDude's Avatar
Quoted: 1041 Post(s)
Liked: 645
In the beta I found my workflow's Gamut Saturation DEITP charts was showing way off (like in the 70s & 80s rather than ~3. Creating a new version by exporting the layouts and importing them into a new blank workflow created in the beta fixed it. Looks like not all the important stuff is in the layouts and the CalMAN software. Some important stuff seems to be within the base blank workflow. If you have a custom workflow you may want to check, though in my case it was really obvious.
Never a dull moment .
Samsung 75Q9FN, OPPO UDP-205, Radiance 2143
Win 10 Pro x64 1903
HT Enthusiast Extended Custom WF v21.0.0 - 10/26/2019
HT Enthusiast Essentials Custom WF v1.2.0 - 7/5/2019
AnotherDude is offline
post #6941 of 7048 Old 08-23-2019, 01:05 PM
Rolls-Royce's Avatar
Quoted: 1174 Post(s)
Liked: 1260
Gives you something to do in your retirement, doesn't it?
...Royce...
"I never drink...wine."
Bela Lugosi, DRACULA, 1931
Rolls-Royce is online now
post #6942 of 7048 Old 08-23-2019, 01:21 PM
Liked: 645
No rest for the unemployed
Win 10 Pro x64 1903
post #6943 of 7048 Old 08-24-2019, 04:33 PM
Quoted: 128 Post(s)
I tried the new beta version today and I can report that madTPG gets stuck on greyscale and CMS using Calman Home for Sony. It gets stuck at the end, also when optimizing madTPC before use. It doesn't flip back to black at the end.
toby5 is online now
post #6944 of 7048 Old 08-24-2019, 06:50 PM
Liked: 5536
Did you report it to the portrait support web site?
John
jrref is online now
post #6945 of 7048 Old 08-24-2019, 08:39 PM
Quoted: 128 Post(s)
I did
jrref likes this.
toby5 is online now
post #6946 of 7048 Old 08-25-2019, 04:00 PM
thoth's Avatar
Quoted: 149 Post(s)
Liked: 75
If your display only has one slot for storing HDR10 settings, do you prefer to calibrate with 1000, 2000, or 4000 nit metadata?
thoth is online now
post #6947 of 7048 Old 08-25-2019, 05:43 PM
Liked: 645
@WiFi-Spy , what are the chances of being able to save to / restore from disk the current display / processor DDC settings? I really miss ControlCal .
Win 10 Pro x64 1903
post #6948 of 7048 Old 08-27-2019, 04:09 PM
Liked: 645
When editing text boxes in CalMan, the behavior with selected text is not correct when using the mouse context menu paste function. It ignores selected text and always completely replaces all text instead of the selected text. Using the keyboard control-V to paste works properly.
This has been like this forever and can be really annoying . Submitted FWIW.
Win 10 Pro x64 1903
post #6949 of 7048 Old 09-01-2019, 03:56 PM
Liked: 645
When selecting from a dropdown box the text under the mouse pointer is unreadable. It's been like this forever, please fix. It gives me a headache . Submitted.
mrtickleuk likes this.
Win 10 Pro x64 1903
post #6950 of 7048 Old 09-01-2019, 07:13 PM
Liked: 1260
DJ, when Autocal was introduced for the KS8000, this question was asked then. The answer came back that either the Samsung architecture or its SDK doesn't allow these values to be read directly from the TV, so these have to be reset to default and the values you see in CalMAN during the calibration are those generated by the program itself. This probably hasn't changed.
...Royce...
post #6951 of 7048 Old 09-01-2019, 07:19 PM
Liked: 645
Hi Royce. what I'm thinking is to save to disk from CalMAN after the calibration, then CalMAN could read them back from disk and load them to the DDC controls, and from there send them to the TV.
Win 10 Pro x64 1903
post #6952 of 7048 Old 09-01-2019, 07:22 PM
Liked: 1260
Gotcha. I misread. I thought you were wanting to save the pre-calibration numbers direct from the set.
...Royce...
post #6953 of 7048 Old 09-01-2019, 09:39 PM
thoth's Avatar
Quoted: 149 Post(s)
Liked: 75
I have started up a Manual calibration workflow in a fresh Home process, done a DDC connect to my Q90R, and it shows the correct current values, ones generated by an Autocal in a previous process.
thoth is online now
post #6954 of 7048 Old 09-02-2019, 08:43 AM
Liked: 1260
Great! Maybe some things have changed for the better.
...Royce...
post #6955 of 7048 Old 09-02-2019, 03:01 PM
Liked: 645
A heads-up to other layout designers (in case I'm not the only one with strange ideas), if you have a layout that has datafields, charts etc. with its data source from a different tab in the same layout, if you export the layout then import it those data sources will be reset.
Win 10 Pro x64 1903
post #6956 of 7048 Old 09-04-2019, 06:16 PM
Liked: 645
This turned out to be a custom Windows theme thing. I've been dragging mine from who knows when - Windows 8? Using a standard theme gets rid of it. I made my desired changes using the new theme but I hate the white inactive title bar of the current Windows. Thankfully I found a way around via the Registry.
I have to say the PD folks have been very responsive to my several feedbacks, getting back to me for clarifications when needed.
Win 10 Pro x64 1903
post #6957 of 7048 Old 09-05-2019, 08:35 AM
** Man of Leisure **
AustinJerry's Avatar
Quoted: 11417 Post(s)
Liked: 6755
Sorry for cross-posting, but I originally posted this in the CalMAN Home for Sony thread, and that thread is not getting very much activity lately
I just purchased a new laptop. One of the selection criteria was that the laptop graphics be able to output 2160p test patterns for the CalMAN Autocal. As I was configuring the Intel graphics settings, several areas are slightly different from my previous laptop. In the first screenshot below, notice that the highest setting I can use is 30p. It seems like I could configure 60p on the previous laptop (although only HD, not UHD). Is this an issue?
In the second screenshot, I have selected 3840x2160. Is this the proper setting?
I want to see if I can duplicate the improved blacklevel measurements that @jrref and @thomasfxlt achieved using the 2160p patterns. Replies to my questions would be appreciated.
Also, I recall that @WiFi-Spy mentioned that he was working on a updated guide on how to configure laptop graphics. I still rely on the original guide titled "Dolby Vision HDMI Calibration Setup Guide", authored by Tyler back in 2016, which is still useful, but has outdated screenshots. Has there been a more recent guide published?
AustinJerry is online now
post #6958 of 7048 Old 09-05-2019, 09:18 AM
thomasfxlt's Avatar
Quoted: 3331 Post(s)
Liked: 6190
Jerry, don’t worry about the frame rate. 3840 x 2160 is correct.
AustinJerry and shoman94 like this.
SONY Z9F LCD Master Series Owners Thread
Vizio 2016 P series FAQ, general info and Help
Sony Z9F 75, Vizio P75C1 UHD/HDR/DV, Pioneer Elite SC-95, Samsung UHD Bluray K8500, AppleTV 4K, CC Ultra
thomasfxlt is offline
post #6959 of 7048 Old 09-07-2019, 03:07 PM
mrtickleuk's Avatar
Quoted: 5066 Post(s)
Liked: 7390
As Melissa had posted on the now-defunct SpectraCal forums, the loss of control over the Integral was caused by a switch to a different version (3.5.5.0) of the SiUSBXp.dll in order to work with a particular spectro. Replacing the .dll in CalMAN's folder (Program Files (x86) > Spectracal > CalMAN 5 Home Theater > Common) with 3.9.0.2 from HDFury's website will restore control functionality.
We are working on a permanent fix that doesn’t require this workaround.
For info, the version I have now (not sure when this changed), has CalMAN 5 Home Theater\Common\SiUSBXp.dll version 3.5.0.0, but also, a subdirectory "HDFury" containing SiUSBXp.dll version 3.9.0.2 and control of the HDFury it seems to work.
_______________
Denon AVR-X4200W, Arcam Alpha 8P; 5.1.4 setup: Mission 702e, M7C1i, 77DS, 731. Rel T5 Sub. Monitor Audio CT165 4 Tops | LG OLED55C8PLA TV | Samsung UBD-K8500 UHD Blu-Ray
HDMI 2.0 4K modes | Dolby & DTS core+outer audio tracks on (UHD) Blu-Rays | Hello to Jason Isaacs
mrtickleuk is offline
post #6960 of 7048 Old 09-18-2019, 10:27 AM
Liked: 1260
CalMAN 2019 R2 Release Candidate 1 is out today.
AnotherDude likes this.
...Royce...
Reply Display Calibration
